Thanks! will check that out
Another way to do it would be in CAD: place all parts in the correct position in CAD, export to STL, and it will print as one design, all in the right place.
Yep, that worked
GregValiant 956
In the menu "Preferences / Configure Cura" and then in the Viewport Behavior section is "Ensure Models are Kept Apart". If that is ticked it will do just as it says. Like trying to push two magnets together that are facing the wrong ways.
