On 1/18/2022 at 10:44 AM, geert_2 said:That seems to be underextrusion, but I don't know your printer, so it is hard to say why? Filament that is stuck on the spool or entangled, or bent, so it can not easily unwind and pass through the nozzle? Or irregular diameter filament, too thick to pass through easily? Or hard parts in the filament, that temporarily block the flow through the nozzle? A partially clogged nozzle? Something along that line of thought maybe?
That could make sense, as to my filament roll sits on the top rail facing upwards and feeds down and to the right 90 degrees. The roll also has a larger diameter hole in the center compared to the pole it sits on, so it may not roll off very well.
I will move the roll and try that next. I appreciate it!
geert_2 556
