Hi, its an Ender 5 plus-Stock firmware, not running octoprint
Print is a soap dish
Attached is the project file.
Printer info i'll update when i get back to shop
Thank you for taking a look, appreciated!
Your build plate is defined in Cura as 300 x 300. What does your build plate actually measure from edge to edge?
Oh I think get it. Are you new to 3d printing?
It looks like you configured this print with skirt, this peripheral line is the skirt, not part of the print per se. Actually this looks like a nice first layer.
GregValiant 697
I might have some suggestions. What printer? Does it have the stock firmware? Are you running Octoprint? What are the Xwidth and Ydepth as noted in Cura? What are your Home Offsets? How big is the model?
If you post a 3mf Project File it will contain some answers. Without knowing anything at all about your printer or how you set it up, it's impossible to provide guidance.
