5 hours ago, ahoeben said:What printer do you use? If your printer does not support printing over USB, it does not support OctoPrint. Though most printers do still support that, the Ultimaker 3 and newer for example do not. It could be that you inadvertently told Cura that you have an Ultimaker S5 printer, since it is the default option when you add the printer to Cura.
If this does not turn out to be the issue, I need to see your Cura.log. It can be found in the folder that opens when you go to Help -> Show configuration folder. Please upload the Cura.log file somewhere and post a link to it here.
Ok so I managed to get it set up on Cura, was a pain, wasnt installing correctly. So now I have it installed however when I attempt to link it is stating that Octoprint is available. Any ideas?
ahoeben 2,047
