It's usually about 5 minutes maximum between when it at least shows a change in progress on the screen.
If you power cycle it should continue trying where it left off. That works about 70% of the time. Or power cycling every 10 minutes up to 3 times.
If that doesn't fix things and your printer is still under warranty call your reseller asap. Even if it's out of warranty they will give you the official unbricking procedure which involves getting under the printer where there are dangerous voltages so there are special instructions in a pdf they can send you.
If THAT doesn't work then it's time to go to this website: gr5.org/unbricking/
I'm excited because I've personally produced this showcase event, so if you are curious what else I'm up to nowadays, come check it out and say hi in the chat! It would mean a lot!
gr5 1,837
