I just rebuilt the head / hot end - new block, isolator, teflon thing + nozzle. With that done, attempted to get a test print out. (This machine was a salvage project). The first go was a fail - the material failed to load and instead a very nice crecent was chewed in my filament as soon as it got to the print head. So I'm thinking, "Yeah, that extruder is worn out", but then I inspect and the teeth marks in the strand up to the crecent look Goldilocks, so I try again. This time, I disconnected the gear with the release lever and push manually through the extruder till material was coming out. At that point, I reingage the gear, and it worked fine. Did the mini-cal test print. The bottom layers came out beautifully. But at the first infill stages, it got ugly like blobby and stringy. I ended up slowing down to 50% print speed and it seemed to help. But when I tried to remove from the print bed, the thing broke on those first few infill layers.
Good news - the circles and shapes pretty much came out prefect - there was no x-y shift or x/y belt/motor skipping which is what the person who gave away the machine was complaining about. I am going to post some pictures in a bit. I am thinking basically that the failure to load had something to do with the Bowden tube, but I'm not sure. It seems like maybe the filament was getting stuck on the lip of the teflon thingy after exiting the bowden, but I assure you I use all the force appropriate to cram that bowden tube all the way down in the print head.
EDIT - ADD PICTURES (1) chewed filament that failed to enter nozzle on "change filament"... got hung up and just litterally chewed a bit out of it in <1 second. (2) MINI-CAL (broken)
Edited by gdog
gr5 2,331
So you are talking about the 2 gears in the UM2+ feeder? I believe 0.5mm of play is too much. Not sure.
@fbrc8-erin - what do you think? Does he need new feeder gears? (his profile says he has a UM2+ ext).
As far as 2800 hours and 2400 meters of filamnt - it's common for those numbers to be similar - that's a lot but we've seen printers hit 10,000 meters. You might want to change the belts now. Definitely change the teflon part if you haven't done that (the teflon part in the head - the white part. Called sometimes an "isolator" I think?) That should be changed every 500-1000 hours.
