I spent a little time looking for a previous post on how to adjust the tension of the short belts on an Ultimaker 2. I couldn't find anything.
The short belt located on the back-right side of my UM2 is loose. I decided to check it after noticing that my circular holes in my prints are a little oval and not so round.
Can anyone point me in the right direction or explain to me the best way to go about tightening up this short belt? Or is there another option to adjusting settings in Cura or through the control panel?
That might have happened because the screws of the stepper motor got loose. On the back side of the UM2 you see the four screws going to the stepper motor. Open them slight, push the stepper motor down and tighten the screws again.
I had an issue with the pulley of the left stepper motor and realized that the screws were not tightened too strong.
This issue was described in this post:
http://umforum.ultimaker.com/index.php?/topic/4171-ultimaker2-axis-squeeknoise-solved/
jonnybischof 60
There's the possibility to (ab)use an idler pulley bearing: You could mount one in a way that it scretches the timing belt, though there's probably very little space. I don't know the UM2 in detail, you can probably see better whether that would work or not.
Idler pulley bearings come in various sizes, maybe you can just put a small one in the middle between the pulleys, and then slide it out of center so that the timing belt will form a triangle.
Then you could go all engineery and mount the idler pulley with a spring, controlling the belt tension nicely![:)](//content.invisioncic.com/ultimake/emoticons/5a33abdf6d109_1f60acopy.png)
