Well, you could also try using another application to actually view the g-code. I think that it's likely that the g-code that cura produces is correct, it's just that the re-loading of the g-code has some issues with it.
1
nallath 1,065
Uh, well. We generally use layerheights below 0.5 mm. Even though I don't see a reason why this wouldn't (at least theoretically) work.
My guess is that the g-code parser has an issue with too large layers. As you might imagine, it's not something that we test 😉
Kaby 0
Okay, thanks.
Oh, I see 🙂. I understand, that Cura may not be suited to use with this type of work, but I like working in it so will stick to using the software at least for now).
I will wait a couple of days for any other ideas and mark the issue as "Resolved" then.
