9 hours ago, duiker2106 said:What do I have to do? And how??
You have to press the "Slice" button in the lower right.
On 2/7/2022 at 12:36 AM, GregValiant said:I am not sure what you mean.
You brought a model into Cura, sliced it, and when you hit the save button on the lower right that message came up?
Yes, exactly that!
See that pointy gray "shadow"? That needs to fit inside the build volume. The model is striped to show that Cura thinks it does not currently fit inside the buildvolume. There seems to be a "stray" point or piece of geometry in the file. Can you post a link to the model?
1 hour ago, ahoeben said:See that pointy gray "shadow"? That needs to fit inside the build volume. The model is striped to show that Cura thinks it does not currently fit inside the buildvolume. There seems to be a "stray" point or piece of geometry in the file. Can you post a link to the model?
I got the design from Thingiverse.
but I guess that I can place it correctly by replacing it on the plate.
to be continued…
IT WORKS!!
The print is being made at this moment!
Thanks for the help👍🏼
GregValiant 1,318
