sure, here you go.
Hmm. I don't see anything weird in the logs. Could you check what happens if you disable the sidebar plugin?
If that doesn't fix it, I would need to get a copy of your local configuration folder.
I have uninstalled the sidebar plugin, but the problem remains.
I have found that I can select the profile item in the bar with a double click. However, the settings in the costum tab are still those of the 0.15mm default profile.
Since the complete configuration folder also contains data about my printers, I prefer to send it by direct message.
1
nallath 1,125
I just tried this on my setup and I can select the PETG engineering profile on both machines.
Could you share your log files?
