This seems to be quite obvious under-extrusion. together with the messages from the flow sensor, there seems to be too much resistance in the material feed.
the possible problem zones are in the print head, bowden tube and feeder.
For the printhead, a printcore cleaning is recommended to make sure no residue is stuck.
For the bowden tube, check its attachment and replace if necessary. Ultimaker recommends replacing it after I think 1500 printing hours.
For the feeder, open it up and clean it with compressed air and a brush. the feed gear should be free of material residue.
the feeder housing can also be removed and the drive gear on the motor lubricated. this should also be done every 1500 printing hours according to the maintenance schedule.
These are all the points that come to mind.
Good Morning,, well, looks like I fixed the problem. SO what i ended up doing was adjust the feed pressure of the filament feeder on the back, i notice that the adjustment screw head was on the outside of the box and not on the inside. Well I have more things to print let see if am right or just got lucky.
NelsB54 0
ok I have just checked on my print and it seems to be working, everything is the way it should be. I will show the final print tomorrow this thing won't be done until 7:20 to night. Tired and going home
