Posted · Unable to slice using 2nd extruder only
Hello.
I can't slice this simple tube using PVA on the second extruder, after selecting the BB 0.4 core.
I disabled the first extruder and enabled the second one. Used normal print settings.
Thanks in advance
    You have to select on the left side, that you want to print with the second extruder. (select the object first)
    I think that's the problem.
    You are absolutely right. I noticed that a while after posting. I'm still new to Ultimaker 3 with its 2 cores. Thanks for the help!
    Also after several years with UM printers, I still run into this issue from time to time myself 🙂
