How to fit 1kg filament into S5 Material station
Posted · How to fit 1kg filament into S5 Material station
Rewind that material onto a compatible spool or buy a material which the spool of it fits into the Material Station?
Here you find the required spool dimensions: https://support.ultimaker.com/hc/en-us/articles/360012904539-Spool-dimension-compatibility-in-Material-Station
    • 3 weeks later...
    Posted (edited) · How to fit 1kg filament into S5 Material station
    It's crazy annoying. We run pretty much 90% of our material external to the material station with the door propped open with magnets because the spools don't fit. I have the spools sat on frames with bearings for low friction, helps when printing high elastic TPU as well as it reduces the friction from the station rollers on it.
    Surely making the station bays adjustable to the width of your spools would be beneficial to the users.
    Edited by Super_paulie
