Thanks I just went and tried changing that Reset it to the normal PLA setting. Then tried custom settings that I had setup. Same thing. I noticed that the build plate isn't heating even if I go into tune and try to adjust the temp there. If I adjust the nozzle temp it seems to work. Baffling, I have never done it because I wasn't sure what it would reset exactly, but I am thinking of selecting the reset to factory defaults to see if that will do something.
I unplugged it completely for about 5 minutes and restarted it just to make sure there wasn't some glitch or bug, but still the same.
I guess I shouldn't be too surprised. I have used this old printer for more hours than I expected it would make it.
tinkergnome 917
First guess - while looking at the symptoms:
Check the material setting on the printer. Sounds like there's no material selected - or the stored settings are broken?
