Internal structure problem (Cura created tiny hole in slice)
leoshusar
Posted (edited) · Internal structure problem (Cura created tiny hole in slice)
Hi! How can I convince Cura to generate this part without that little hole?
I was curious how Prusa Slic3r handles it and it puts there bigger surface area.
Is there any setting or something that will fix this?
Thank you!
Edited by leoshusar
    Posted · Internal structure problem (Cura created tiny hole in slice)
    Try to increase the wall count to 3 or 4, maybe that helps.
    I am not sure if there is something else which could solve it too, but I would try it with more walls.
    Thank you, this works.
    But I still wonder if there is better solution than increasing the wall count... I would expect Cura do it's best to not create any holes without any settings.
    • leoshusar changed the title to Internal structure problem (Cura created tiny hole in slice)
    Thank you! This works too and is closer to what I would expect 🙂
    Before (0.8 mm):
    After (0.6 mm):
    Edited by leoshusar
    The solution from Greg is definitely the better one when you don't need 3 or more wall on the object. It also safes printing time to keep the 2 walls.
