GregValiant 1,304
Also try lowering the "Skin Removal Width". It's in the Top/Bottom section.
1
Thank you! This works too and is closer to what I would expect 🙂
Before (0.8 mm):
After (0.6 mm):
The solution from Greg is definitely the better one when you don't need 3 or more wall on the object. It also safes printing time to keep the 2 walls.
Smithy 1,144
Try to increase the wall count to 3 or 4, maybe that helps.
I am not sure if there is something else which could solve it too, but I would try it with more walls.
leoshusar 0
Thank you, this works.
But I still wonder if there is better solution than increasing the wall count... I would expect Cura do it's best to not create any holes without any settings.
