Hi @tomnagel, unfortunately there is none available on the marketplace. Not sure what you mean by deprime?
Deprime is the process of unloading the material from the print core. This is critical because the tipshape determines the reliability of unloading and a future loading cycle.
I advise to only use materials which have a material profile available in the market place, and please note that compatibility with the Material Station is one of the mentioned properties.
Next to Ultimaker Nylon, there are currently 29 Nylons available which are marked compatible with the Material Station.
tomnagel 125
The deprime process needs to be tuned per material, because the tipshape must be such that it can be reliably unloaded.
Every Ultimaker material and most 3rd party materials in the Marketplace have a material profile that has the right settings for depriming.
Does your material have a material profile from the Market place? Is this material profile flagged as suited for use with the Material Station?
Your mileage with generic profiles may vary.
