That stickup out of the side of the shelf does not exist here, in OpenSCAD, or a cura preview. The solid part of that brace only penetrates the skin of that shelf by about .2mm, So where is the stickout of a fraction of a mm I see in the top edge of your 1st shot, coming from?
Call me puzzled.
Thanks
Gene1934
ahoeben 1,586
Maybe it is because it is friday afternoon, and I have had a beer, but I am having a very hard time understanding what your problem is. Perhaps you could share one or more screenshots of the problem (as opposed to what "it" should be).
GregValiant 696
I sliced it and there are a couple of places where you assembled and combined the model and I think you missed it.
Here you can see that the ribs continue up through the top surface leaving 3 islands.
In this screenshot you can see a large island across the bottom of the model.
As for the rest of it I'm right there with @ahoeben. I don't get it.
More screenshots or a project file might make it clearer. When I sliced the STL it looks exactly as I would expect.
This image is the first skin layer over the infill. The wall of the ribs will rest on the skins and the infill is continuous from the bottom up into the ribs. That's the way it typically slices.
