28 minutes ago, ahoeben said:I'll admit that I don't know much about RRF, but from a cursory look Input Shaping is done mostly in the firmware. The only change that needs to be made (after calibration of the parameters) is adding an M593 gcode command to the start gcode snippet:
At now yes, they add it in frimware, but they don't use close loop control system (like klipper). So i think it's can be adding in gcode by slicer it's can open this technique to 8 bit boards and so on.
In start it was only gcode modify:
The specific parameters for the correction above was f_n=40.4 Hz, zeta=0
I got these results without making any FW changes. I instead abused the motion planner by feeding it G-code that simulated the required motion profiles. I think the results look pretty interesting and this is probably worth pursuing further.
ahoeben 1,965
https://duet3d.dozuki.com/Wiki/M593
