It would help to know if the print does start when you run OctoPrint in safe mode (which basically turns off all plugins): https://docs.octoprint.org/en/master/features/safemode.html#how-to-start-octoprint-in-safe-mode
Yes, it seems to solve it completely (gave it multiple tries as well in case it's something racy) - so I guess it's indeed caused by a plugin.
I can do a binary search and start disabling things, but before I do, is there any specific ones that seem like likely suspects?
From your earlier list, I don't see an obvious problematic plugin. I have not tested with any of them (apart from Virtual Printer, which is a bundled plugin). I am very interested to know which plugin turns out to cause this issue.
Okay, I'll start disabling things and let you know if I have any conclusions. Thanks for the tips!
Oh man, the list above wasn't the full list - I guess it was only the ones with configuration, since I took them from the side bar...
The actual one that broke it seems to be Auto Select, which, based on the issue on GitHub, is something I assume you're familiar with - so I guess I wasted your time, sorry about that! At least I'm glad to have it solved and have everything working.
On a side note, appreciate your work (and your willingness to help!)
25 minutes ago, Galgofrit said:The actual one that broke it seems to be Auto Select, which, based on the issue on GitHub, is something I assume you're familiar with
Thanks for letting me know anyway. I never got confirmation in that issue that Auto Select was the culprit.
Edited by ahoeben
ahoeben 2,047
It is neither. It is an issue with the OctoPrint Connection plugin for Cura, which I am the creator of.
This bug has been reported before, here: https://github.com/fieldOfView/Cura-OctoPrintPlugin/issues/233
What plugins do you have installed in OctoPrint?
Galgofrit 0
Oh, great, thanks for the response!
These are the ones I'm running:
(edit: at least based on the plugin list on the web UI... if you want any log LMK)
Edited by GalgofritLink to post
