Posted · Ultimaker S5 - Material Database
I think my material database is corrupt.
1. I cannot load materials - tried both network based and walking USB stick over to printer.
2. Is there any way to remove all of the profiles in the printer that are not being used...or ever will be used?
Thanks,
Tim
    There is no easy way. The only way I am aware of is to use the API of the printer and delete the profiles one by one.
    But a factory reset should also do the job and delete all your custom loaded profiles.
