GregValiant 1,489
"...but it is thoroughly checked. No errors."
You should have a talk with your checker.
From https://formware.co/OnlineStlRepair:
--> 0 Naked edges (?)
--> 0 Planar holes (?)
--> 0 Non-planar holes (?)
--> 586098 Non-manifold edges (?)
--> 390147 Inverted faces (?)
--> 0 Degenerate faces (?)
--> 780879 Duplicate faces (?)
--> 0 Disjoint shells (?)
-> Repairing: 100.00%
----- Repair completed in 39429ms ------
-> Vertex count changed from 195368 to 196569 (+1201)
-> Triangle count changed from 781464 to 393134 (-388330)
After opening the file I checked the model with @ahoeben's Mesh Tools and the "not watertight" warning came up. I exported the model as an STL file and uploaded it. MS 3D Builder also noted defects in the model and was able to repair it (but the formware site gives a report).
I've attached a repaired file.
2
ahoeben 2,047
It is hard to know what we are looking at without seeing the model and your print settings, but I blame your model. It may not be "manifold", which confuses Cura.
https://github.com/Ghostkeeper/SettingsGuide/blob/master/resources/articles/troubleshooting/missing_parts.md#non-manifold-meshes
If you want a better diagnosis, please save a project and post a link to it here.
File -> Save project...
Edited by ahoebenLink to post
nilsglind 0
I would be super happy if it was the model, but it is thoroughly checked. No errors. It happends to a few other models as well. Like there is a limit to the height of the model. But ill post the project file, and I am super thankful for any help 🙂
CFFFP_Hips.3mf
