Worked like a charm, thanks so much!
I had been following the same gist I followed for the old version at https://gist.github.com/BenRoe/f166e8b65fe62edda4427fd419059695
but tried skipping all the manual build steps since I could just apt-get curaengine. Then I used the wget lines from the gist, which it turns out were very outdated but still download something.
ahoeben 1,589
What resources repo exactly?
The CuraEngine you are using seems to be version 4.8. You would need to use a version of fdmprinter.def.json and fdmextruder.def.json that matches this version.
https://github.com/Ultimaker/Cura/blob/4.8/resources/definitions/fdmprinter.def.json
https://github.com/Ultimaker/Cura/blob/4.8/resources/definitions/fdmextruder.def.json
