Help, both fans do not turn on automatically during printing.
Firedrops
Posted (edited) · Help, both fans do not turn on automatically during printing.
My set-up:
Ender 3 Pro with an SKR V1.3 mainboard, TTMC2208 drivers.
Octoprint, relatively fresh install, Version 1.7.3
Cura version 4.13.1
Expected behaviour:
  1. Heatsink fan turns on automatically when hotend temperature > ~60C or so
  2. Parts Cooling fan turn on automatically after layer 4 or so (set in Cura)
Actual behaviour:
  1. Heatsink fan does NOT turn on on its own, ever. However, sending
    m106 p0 s255
    through octoprint turns it on. Navigating to it on the LCD menu also works.
  2. Same for the Parts Cooling fan, it requires a
    m106 p1 s255
    to turn on. Navigating to it on the LCD menu also works.
  3. Probably related, but since I've set Parts Cooling fan to only turn on after Layer 4, it inserts a
    m107
    after "Start G-Code". However, this is also applying to my Heatsink fan. So if I send
    m106 p0 s255
    during the initial heating phase (before drawing the purge lines), it also gets turned off, and I need to send
    m106 p0 s255
    again.
    Hardware Info
Fans connection on my my mainboard:
r/FixMyPrint - SKR V1.3, Marlin, Both fans do not turn on automatically.
Red (P2_03) = Heatsink fan
Blue (P2_04) = Parts Cooling (duct) fan
My pins_BTT_SKR_common.h lines ~90-102:
// Heaters / Fans
#ifndef HEATER_0_PIN
#define HEATER_0_PIN P2_07
#endif
#ifndef FAN1_PIN
#define FAN1_PIN P2_04
#endif
//#else
// #ifndef HEATER_1_PIN
// #define HEATER_1_PIN P2_04
// #endif
//#endif
#ifndef FAN_PIN
#define FAN_PIN P2_03
#endif
#ifndef HEATER_BED_PIN
#define HEATER_BED_PIN P2_05
#endif
However, seeing that the correct GCode are correctly adjusting each fan's speed, the problem is probably not in the hardware/firmware/pin assignments.
The Start G-Code in Cura
M104 S{material_print_temperature} ; Start heating hot end without waiting
M140 S{material_bed_temperature} ; Start heating bed without waiting
M109 S{material_print_temperature} ; Wait for hot end to reach temp before proceeding
M190 S{material_bed_temperature} ; Wait for bed to reach temp before proceeding
; Ender 3 Custom Start G-code
G92 E0 ; Reset Extruder
G28 ; Home all axes
G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish
And an example of a generated G-Code
;FLAVOR:Marlin
;TIME:409
;Filament used: 0.34589m
;Layer height: 0.24
;MINX:104.1
;MINY:110.3
;MINZ:0.2
;MAXX:130.9
;MAXY:124.7
;MAXZ:8.84
;Generated with Cura_SteamEngine 4.13.1
M82 ;absolute extrusion mode
M104 S200 ; Start heating hot end without waiting
M140 S50 ; Start heating bed without waiting
M109 S200 ; Wait for hot end to reach temp before proceeding
M190 S50 ; Wait for bed to reach temp before proceeding
G28 ; Home all axes
G92 E0
G92 E0
G1 F1800 E-0.6
;LAYER_COUNT:34
;LAYER:0
M107
M204 S500
G0 F6000 X104.443 Y110.66 Z0.2
M204 S800
;TYPE:SKIRT
G1 F1800 E0
G1 F1200 X104.686 Y110.469 E0.01234
G1 X104.97 Y110.346 E0.02469
G1 X105.3 Y110.3 E0.03799
G1 X129.7 Y110.3 E1.01184
G1 X130.007 Y110.34 E1.0242
G1 X130.293 Y110.457 E1.03653
G1 X130.54 Y110.643 E1.04887
G1 X130.731 Y110.886 E1.06121
G1 X130.854 Y111.17 E1.07356
G1 X130.9 Y111.5 E1.08686
G1 X130.9 Y117.9 E1.3423
G1 X130.86 Y118.207 E1.35466
G1 X130.743 Y118.493 E1.36699
G1 X130.557 Y118.74 E1.37933
G1 X130.314 Y118.931 E1.39167
G1 X130.03 Y119.054 E1.40402
G1 X129.7 Y119.1 E1.41732
G1 X130.007 Y119.14 E1.42967
G1 X130.293 Y119.257 E1.44201
G1 X130.54 Y119.443 E1.45435
G1 X130.731 Y119.686 E1.46668
G1 X130.854 Y119.97 E1.47904
G1 X130.9 Y120.3 E1.49233
G1 X130.9 Y123.5 E1.62005
G1 X130.86 Y123.807 E1.63241
G1 X130.743 Y124.093 E1.64474
G1 X130.557 Y124.34 E1.65708
G1 X130.314 Y124.531 E1.66942
G1 X130.03 Y124.654 E1.68177
G1 X129.7 Y124.7 E1.69507
G1 X105.3 Y124.7 E2.66893
G1 X104.993 Y124.66 E2.68128
G1 X104.707 Y124.543 E2.69362
G1 X104.46 Y124.357 E2.70596
G1 X104.269 Y124.114 E2.71829
G1 X104.146 Y123.83 E2.73065
G1 X104.1 Y123.5 E2.74394
G1 X104.1 Y120.3 E2.87166
G1 X104.14 Y119.993 E2.88402
G1 X104.257 Y119.707 E2.89635
G1 X104.443 Y119.46 E2.90869
G1 X104.686 Y119.269 E2.92103
G1 X104.97 Y119.146 E2.93338
G1 X105.3 Y119.1 E2.94668
G1 X104.993 Y119.06 E2.95904
G1 X104.707 Y118.943 E2.97137
G1 X104.46 Y118.757 E2.98371
G1 X104.269 Y118.514 E2.99605
G1 X104.146 Y118.23 E3.0084
G1 X104.1 Y117.9 E3.0217
G1 X104.1 Y111.5 E3.27714
G1 X104.134 Y111.24 E3.2876
G0 F1080 X104.14 Y111.193
G0 X104.257 Y110.907
G0 X104.443 Y110.66
M204 S500
G0 F6000 X104.735 Y111.054
M204 S800
G1 F1200 X104.912 Y110.894 E3.29712
G1 X105.132 Y110.8 E3.30667
G1 X105.3 Y110.78 E3.31343
G1 X129.7 Y110.78 E4.28728
G1 X129.936 Y110.82 E4.29684
G1 X130.146 Y110.935 E4.30639
G1 X130.306 Y111.112 E4.31591
G1 X130.4 Y111.332 E4.32546
G1 X130.42 Y111.5 E4.33222
G1 X130.42 Y117.9 E4.58765
G1 X130.38 Y118.136 E4.59721
G1 X130.265 Y118.346 E4.60676
G1 X130.088 Y118.506 E4.61629
G1 X129.868 Y118.6 E4.62584
G1 X129.7 Y118.62 E4.63259
G1 X105.3 Y118.62 E5.60644
G1 X105.064 Y118.58 E5.616
G1 X104.854 Y118.465 E5.62555
G1 X104.694 Y118.288 E5.63508
G1 X104.6 Y118.068 E5.64463
G1 X104.58 Y117.9 E5.65138
G1 X104.58 Y111.688 E5.89931
G0 F1080 X104.58 Y111.5
G0 X104.62 Y111.264
G0 X104.735 Y111.054
M204 S500
G0 F6000 X105.099 Y111.369
M204 S800
G1 F1200 X105.204 Y111.28 E5.90481
G1 X105.3 Y111.26 E5.90872
G1 X129.7 Y111.26 E6.88258
G1 X129.831 Y111.299 E6.88803
G1 X129.92 Y111.404 E6.89353
G1 X129.94 Y111.5 E6.89744
G1 X129.94 Y117.9 E7.15288
G1 X129.901 Y118.031 E7.15833
G1 X129.796 Y118.12 E7.16383
G1 X129.7 Y118.14 E7.16774
G1 X105.3 Y118.14 E8.1416
G1 X105.169 Y118.101 E8.14705
G1 X105.08 Y117.996 E8.15255
G1 X105.06 Y117.9 E8.15646
G1 X105.06 Y112.03 E8.39074
G0 F1080 X105.06 Y111.5
G0 X105.099 Y111.369
M204 S500
G1 F1800 E7.79074
G0 F6000 X104.835 Y111.369
G0 X104.847 Y118.353
G0 X105.3 Y119.58
M204 S800
G1 F1800 E8.39074
G1 F1200 X129.7 Y119.58 E9.3646
G1 X129.936 Y119.62 E9.37415
G1 X130.146 Y119.735 E9.38371
G1 X130.306 Y119.912 E9.39323
G1 X130.4 Y120.132 E9.40278
G1 X130.42 Y120.3 E9.40953
G1 X130.42 Y123.5 E9.53725
G1 X130.38 Y123.736 E9.54681
G1 X130.265 Y123.946 E9.55636
G1 X130.088 Y124.106 E9.56589
G1 X129.868 Y124.2 E9.57544
G1 X129.7 Y124.22 E9.58219
G1 X105.3 Y124.22 E10.55604
G1 X105.064 Y124.18 E10.5656
G1 X104.854 Y124.065 E10.57515
G1 X104.694 Y123.888 E10.58468
G1 X104.6 Y123.668 E10.59423
G1 X104.58 Y123.5 E10.60098
G1 X104.58 Y120.3 E10.7287
G1 X104.62 Y120.064 E10.73825
G1 X104.726 Y119.871 E10.74704
G0 F1080 X104.735 Y119.854
G0 X104.912 Y119.694
G0 X105.132 Y119.6
G0 X105.3 Y119.58
M204 S500
G0 F6000 X105.3 Y120.06
M204 S800
G1 F1200 X129.7 Y120.06 E11.7209
G1 X129.831 Y120.099 E11.72635
G1 X129.92 Y120.204 E11.73184
G1 X129.94 Y120.3 E11.73576
G1 X129.94 Y123.5 E11.86348
G1 X129.901 Y123.631 E11.86893
G1 X129.796 Y123.72 E11.87443
G1 X129.7 Y123.74 E11.87834
G1 X105.3 Y123.74 E12.8522
G1 X105.169 Y123.701 E12.85765
G1 X105.08 Y123.596 E12.86315
G1 X105.06 Y123.5 E12.86706
G1 X105.06 Y120.595 E12.983
G0 F1080 X105.06 Y120.3
G0 X105.099 Y120.169
G0 X105.204 Y120.08
G0 X105.3 Y120.06
M204 S500
G1 F1800 E12.383
;MESH:RS_Fan-Housing-Clamp-Rev1.stl
G0 F6000 X105.3 Y119.835
G0 X104.847 Y119.847
G0 X104.847 Y123.953
G0 X129.26 Y123.965
G0 X129.26 Y123.06
M204 S800
;TYPE:WALL-OUTER
G1 F1800 E12.983
G1 F1200 X105.74 Y123.06 E13.92174
G1 X105.74 Y120.74 E14.01433
G1 X129.26 Y120.74 E14.95307
G1 X129.26 Y122.394 E15.01908
G0 F1080 X129.26 Y123.06
M204 S500
G0 F6000 X128.78 Y122.58
M204 S800
;TYPE:WALL-INNER
G1 F1200 X106.22 Y122.58 E15.9195
G1 X106.22 Y121.22 E15.97378
G1 X128.78 Y121.22 E16.8742
G1 X128.78 Y121.914 E16.9019
G0 F1080 X128.78 Y122.58
M204 S500
G0 F6000 X128.3 Y122.1
M204 S800
G1 F1200 X106.7 Y122.1 E17.764
G1 X106.7 Y121.7 E17.77997
G1 X128.3 Y121.7 E18.49989
G1 X128.3 Y122.1 E18.51585
M204 S500
G1 F1800 E17.91585
G0 F6000 X130.165 Y122.1
G0 X130.153 Y119.847
G0 X129.26 Y118.365
G0 X129.26 Y117.46
M204 S800
;TYPE:WALL-OUTER
G1 F1800 E18.51585
G1 F1200 X105.74 Y117.46 E19.45459
G1 X105.74 Y111.94 E19.6749
G1 X129.26 Y111.94 E20.61363
G1 X129.26 Y116.794 E20.80737
G0 F1080 X129.26 Y117.46
M204 S500
G1 F1800 E20.20737
G0 F6000 X126.699 Y116.152
M204 S800
G1 F1800 E20.80737
G1 F1200 X127.066 Y116.052 E20.82255
G1 X127.293 Y115.932 E20.8328
G1 X127.495 Y115.776 E20.84298
G1 X127.667 Y115.586 E20.85321
G1 X127.827 Y115.321 E20.86557
G1 X127.931 Y115.011 E20.87862
G1 X127.964 Y114.759 E20.88876
G1 X127.952 Y114.501 E20.89907
G1 X127.852 Y114.134 E20.91425
G1 X127.732 Y113.907 E20.9245
G1 X127.576 Y113.705 E20.93469
G1 X127.386 Y113.533 E20.94492
G1 X127.054 Y113.343 E20.96018
G1 X126.811 Y113.269 E20.97032
G1 X126.557 Y113.236 E20.98055
G1 X126.301 Y113.248 E20.99077
G1 X125.934 Y113.348 E21.00596
G1 X125.653 Y113.504 E21.01878
G1 X125.415 Y113.715 E21.03148
G1 X125.262 Y113.918 E21.04162
G1 X125.143 Y114.146 E21.05189
G1 X125.069 Y114.389 E21.06203
G1 X125.036 Y114.643 E21.07225
G1 X125.048 Y114.899 E21.08248
G1 X125.148 Y115.266 E21.09766
G1 X125.304 Y115.547 E21.11049
G1 X125.515 Y115.785 E21.12318
G1 X125.715 Y115.937 E21.13321
G1 X125.947 Y116.057 E21.14363
G1 X126.057 Y116.091 E21.14823
G0 F1080 X126.189 Y116.131
G0 X126.443 Y116.164
G0 X126.699 Y116.152
M204 S500
G0 F6000 X126.774 Y116.629
M204 S800
;TYPE:WALL-INNER
G1 F1200 X127.243 Y116.501 E21.16763
G1 X127.554 Y116.337 E21.18167
G1 X127.822 Y116.13 E21.19518
G1 X128.054 Y115.874 E21.20897
G1 X128.265 Y115.524 E21.22528
G1 X128.401 Y115.12 E21.2423
G1 X128.445 Y114.779 E21.25602
G1 X128.429 Y114.426 E21.27012
G1 X128.301 Y113.957 E21.28953
G1 X128.137 Y113.646 E21.30356
G1 X127.93 Y113.378 E21.31707
G1 X127.67 Y113.142 E21.33109
G1 X127.246 Y112.9 E21.35057
G1 X126.913 Y112.798 E21.36447
G1 X126.577 Y112.755 E21.37799
G1 X126.226 Y112.771 E21.39202
G1 X125.752 Y112.9 E21.41162
G1 X125.374 Y113.11 E21.42888
G1 X125.061 Y113.388 E21.44559
G1 X124.855 Y113.661 E21.45924
G1 X124.697 Y113.963 E21.47284
G1 X124.598 Y114.287 E21.48637
G1 X124.555 Y114.623 E21.49989
G1 X124.571 Y114.974 E21.51391
G1 X124.7 Y115.448 E21.53352
G1 X124.91 Y115.826 E21.55077
G1 X125.187 Y116.139 E21.56746
G1 X125.458 Y116.344 E21.58102
G1 X125.765 Y116.503 E21.59482
G1 X126.087 Y116.602 E21.60826
G1 X126.11 Y116.605 E21.60919
G0 F1080 X126.423 Y116.645
G0 X126.774 Y116.629
M204 S500
G1 F1800 E21.00919
G0 F6000 X126.479 Y115.26
G0 X114.67 Y115.233
G0 X114.699 Y116.152
M204 S800
;TYPE:WALL-OUTER
G1 F1800 E21.60919
G1 F1200 X115.066 Y116.052 E21.62437
G1 X115.347 Y115.896 E21.6372
G1 X115.585 Y115.685 E21.64989
G1 X115.737 Y115.485 E21.65992
G1 X115.857 Y115.253 E21.67034
G1 X115.931 Y115.011 E21.68044
G1 X115.964 Y114.759 E21.69059
G1 X115.952 Y114.501 E21.7009
G1 X115.852 Y114.134 E21.71608
G1 X115.732 Y113.907 E21.72633
G1 X115.576 Y113.705 E21.73651
G1 X115.386 Y113.533 E21.74674
G1 X115.121 Y113.373 E21.7591
G1 X114.811 Y113.269 E21.77215
G1 X114.557 Y113.236 E21.78237
G1 X114.301 Y113.248 E21.7926
G1 X113.934 Y113.348 E21.80778
G1 X113.653 Y113.504 E21.82061
G1 X113.415 Y113.715 E21.8333
G1 X113.262 Y113.918 E21.84345
G1 X113.143 Y114.146 E21.85371
G1 X113.069 Y114.389 E21.86385
G1 X113.036 Y114.643 E21.87408
G1 X113.048 Y114.899 E21.8843
G1 X113.148 Y115.266 E21.89949
G1 X113.304 Y115.547 E21.91231
G1 X113.515 Y115.785 E21.92501
G1 X113.715 Y115.937 E21.93503
G1 X113.947 Y116.057 E21.94546
G1 X114.057 Y116.091 E21.95005
G0 F1080 X114.189 Y116.131
G0 X114.443 Y116.164
M204 S500
G0 F6000 X114.774 Y116.629
M204 S800
;TYPE:WALL-INNER
G1 F1200 X115.248 Y116.5 E21.96966
G1 X115.626 Y116.29 E21.98692
G1 X115.939 Y116.013 E22.0036
G1 X116.144 Y115.742 E22.01716
G1 X116.303 Y115.435 E22.03096
G1 X116.402 Y115.113 E22.04441
G1 X116.445 Y114.779 E22.05785
G1 X116.429 Y114.426 E22.07195
G1 X116.301 Y113.957 E22.09136
G1 X116.137 Y113.646 E22.10539
G1 X115.93 Y113.378 E22.1189
G1 X115.674 Y113.146 E22.13269
G1 X115.324 Y112.935 E22.149
G1 X114.919 Y112.799 E22.16606
G1 X114.577 Y112.755 E22.17982
G1 X114.226 Y112.771 E22.19384
G1 X113.752 Y112.9 E22.21345
G1 X113.374 Y113.11 E22.23071
G1 X113.061 Y113.388 E22.24742
G1 X112.855 Y113.661 E22.26107
G1 X112.697 Y113.963 E22.27467
G1 X112.598 Y114.287 E22.28819
G1 X112.555 Y114.623 E22.30171
G1 X112.571 Y114.974 E22.31573
G1 X112.7 Y115.448 E22.33534
G1 X112.91 Y115.826 E22.3526
G1 X113.187 Y116.139 E22.36928
G1 X113.458 Y116.344 E22.38284
G1 X113.765 Y116.503 E22.39664
G1 X114.087 Y116.602 E22.41009
G1 X114.11 Y116.605 E22.41101
G0 F1080 X114.423 Y116.645
G0 X114.774 Y116.629
M204 S500
G1 F1800 E21.81101
G0 F6000 X114.67 Y115.233
G0 X128.78 Y118.365
G0 X128.78 Y116.98
M204 S800
G1 F1800 E22.41101
G1 F1200 X127.243 Y116.98 E22.47236
G1 X126.423 Y116.98 E22.50163
G1 X125.765 Y116.98 E22.52282
G1 X114.423 Y116.98 E22.97551
G1 X113.765 Y116.98 E22.9967
G1 X106.22 Y116.98 E23.29783
G1 X106.22 Y112.42 E23.47983
G1 X114.226 Y112.42 E23.79937
G1 X114.919 Y112.42 E23.82177
G1 X126.226 Y112.42 E24.27107
G1 X126.913 Y112.42 E24.29327
G1 X128.78 Y112.42 E24.36778
G1 X128.78 Y114.426 E24.44785
G1 X128.78 Y115.12 E24.47273
G1 X128.78 Y116.98 E24.54697
M204 S500
G0 F6000 X128.3 Y116.5
M204 S800
G1 F1200 X128.149 Y116.484 E24.55303
G1 X128.3 Y116.317 E24.55656
G1 X128.3 Y116.5 E24.55723
M204 S500
G0 F6000 X124.868 Y116.5
M204 S800
G1 F1200 X116.113 Y116.5 E24.90666
G1 X116.293 Y116.341 E24.91625
G1 X116.551 Y115.999 E24.93335
G1 X116.749 Y115.617 E24.95052
G1 X116.873 Y115.215 E24.96731
G1 X116.926 Y114.799 E24.98405
G1 X116.906 Y114.351 E25.00195
G1 X116.75 Y113.78 E25.02557
G1 X116.542 Y113.385 E25.04339
G1 X116.284 Y113.051 E25.06023
G1 X116.117 Y112.9 E25.06922
G1 X124.888 Y112.9 E25.41929
G1 X124.707 Y113.061 E25.42896
G1 X124.448 Y113.403 E25.44608
G1 X124.251 Y113.78 E25.46306
G1 X124.127 Y114.186 E25.48
G1 X124.074 Y114.603 E25.49678
G1 X124.094 Y115.049 E25.5146
G1 X124.252 Y115.63 E25.53863
G1 X124.449 Y115.985 E25.55483
G0 F1080 X124.516 Y116.105
G0 X124.859 Y116.493
G0 X124.868 Y116.5
M204 S500
G1 F1800 E24.95483
G0 F6000 X126.125 Y115.117
G0 X126.916 Y114.325
G0 X128.284 Y113.051
M204 S800
G1 F1800 E25.55483
G1 F1200 X128.118 Y112.9 E25.56379
G1 X128.3 Y112.9 E25.56445
G1 X128.284 Y113.051 E25.56503
M204 S500
G1 F1800 E24.96503
G0 F6000 X126.874 Y114.282
G0 X114.153 Y115.14
G0 X112.868 Y116.5
M204 S800
G1 F1800 E25.56503
G1 F1200 X106.7 Y116.5 E25.81121
G1 X106.7 Y112.9 E25.95489
G1 X112.888 Y112.9 E26.20187
G1 X112.707 Y113.061 E26.21154
G1 X112.448 Y113.403 E26.22866
G1 X112.251 Y113.78 E26.24564
G1 X112.127 Y114.186 E26.26258
G1 X112.074 Y114.603 E26.27936
G1 X112.094 Y115.049 E26.29717
G1 X112.252 Y115.63 E26.32121
G1 X112.449 Y115.985 E26.33741
G0 F1080 X112.516 Y116.105
G0 X112.859 Y116.493
G0 X112.868 Y116.5
M204 S500
G0 F6000 X111.937 Y116.03
M204 S800
;TYPE:SKIN
G1 F1200 X107.17 Y116.03 E26.52767
G1 X107.17 Y113.37 E26.63384
G1 X111.935 Y113.37 E26.82402
G1 X111.814 Y113.601 E26.83443
G1 X111.665 Y114.086 E26.85468
G1 X111.602 Y114.584 E26.87471
G1 X111.626 Y115.122 E26.89621
G1 X111.705 Y115.411 E26.90816
G0 F1080 X111.813 Y115.808
G0 X111.937 Y116.03
M204 S500
G0 F6000 X111.601 Y113.638
M204 S800
G1 F1200 X111.524 Y113.561 E26.91251
M204 S500
G0 F6000 X111.46 Y114.175
M204 S800
G1 F1200 X110.846 Y113.561 E26.94717
M204 S500
G0 F6000 X110.167 Y113.561
M204 S800
G1 F1200 X111.419 Y114.813 E27.01784
M204 S500
G0 F6000 X111.568 Y115.64
M204 S800
G1 F1200 X109.488 Y113.561 E27.13521
M204 S500
G0 F6000 X108.809 Y113.561
M204 S800
G1 F1200 X111.085 Y115.837 E27.26368
M204 S500
G0 F6000 X110.406 Y115.837
M204 S800
G1 F1200 X108.13 Y113.561 E27.39215
M204 S500
G0 F6000 X107.451 Y113.561
M204 S800
G1 F1200 X109.728 Y115.837 E27.52064
M204 S500
G0 F6000 X109.049 Y115.837
M204 S800
G1 F1200 X107.361 Y114.149 E27.61592
M204 S500
G0 F6000 X107.361 Y114.828
M204 S800
G1 F1200 X108.37 Y115.837 E27.67287
M204 S500
G0 F6000 X107.691 Y115.837
M204 S800
G1 F1200 X107.361 Y115.507 E27.6915
M204 S500
G1 F1800 E27.0915
G0 F6000 X104.835 Y115.507
G0 X114.981 Y114.988
G0 X117.064 Y116.03
M104 S200
M204 S800
G1 F1800 E27.6915
G1 F1200 X117.186 Y115.795 E27.70207
G1 X117.334 Y115.315 E27.72211
G1 X117.398 Y114.819 E27.74207
G1 X117.374 Y114.278 E27.76369
G1 X117.19 Y113.606 E27.7915
G1 X117.066 Y113.37 E27.80214
G1 X123.935 Y113.37 E28.07629
G1 X123.814 Y113.601 E28.0867
G1 X123.665 Y114.086 E28.10695
G1 X123.602 Y114.584 E28.12699
G1 X123.626 Y115.122 E28.14848
G1 X123.813 Y115.808 E28.17686
G1 X123.937 Y116.03 E28.18701
G1 X117.73 Y116.03 E28.43474
G0 F1080 X117.064 Y116.03
M204 S500
G0 F6000 X117.49 Y115.453
M204 S800
G1 F1200 X117.873 Y115.837 E28.45639
M204 S500
G0 F6000 X118.552 Y115.837
M204 S800
G1 F1200 X117.584 Y114.868 E28.51106
M204 S500
G0 F6000 X117.535 Y114.141
M204 S800
G1 F1200 X119.231 Y115.837 E28.60679
M204 S500
G0 F6000 X119.91 Y115.837
M204 S800
G1 F1200 X117.634 Y113.562 E28.73522
M204 S500
G0 F6000 X118.313 Y113.562
M204 S800
G1 F1200 X120.589 Y115.837 E28.86366
M204 S500
G0 F6000 X121.268 Y115.837
M204 S800
G1 F1200 X118.992 Y113.562 E28.9921
M204 S500
G0 F6000 X119.671 Y113.562
M204 S800
G1 F1200 X121.946 Y115.837 E29.12051
M204 S500
G0 F6000 X122.625 Y115.837
M204 S800
G1 F1200 X120.35 Y113.562 E29.24892
M204 S500
G0 F6000 X121.029 Y113.562
M204 S800
G1 F1200 X123.304 Y115.837 E29.37734
M204 S500
G0 F6000 X123.485 Y115.339
M204 S800
G1 F1200 X121.707 Y113.562 E29.47767
M204 S500
G0 F6000 X122.386 Y113.562
M204 S800
G1 F1200 X123.409 Y114.584 E29.53538
M204 S500
G0 F6000 X123.492 Y113.989
M204 S800
G1 F1200 X123.065 Y113.562 E29.55948
M204 S500
G1 F1800 E28.95948
;MESH:NONMESH
G0 F300 X123.065 Y113.562 Z0.48
G0 F6000 X123.065 Y111.035
G0 X130.153 Y111.047
G0 X130.153 Y118.353
G0 X128.3 Y119.835
G0 X128.3 Y122.1
;TIME_ELAPSED:50.597628
;LAYER:1
M140 S50
M106 S127.5
M204 S800
;TYPE:WALL-INNER
G1 F1800 E29.55948
G1 F2100 X106.7 Y122.1 E30.76642
G1 X106.7 Y121.7 E30.78878
G1 X128.3 Y121.7 E31.79666
G1 X128.3 Y122.1 E31.81901
M204 S500
G0 F10500 X128.78 Y122.58
M204 S800
G1 F2100 X106.22 Y122.58 E33.0796
G1 X106.22 Y121.22 E33.15559
G1 X128.78 Y121.22 E34.41618
G1 X128.78 Y122.105 E34.46563
G0 F1890 X128.78 Y122.58
M204 S500
G0 F10500 X129.26 Y123.06
M204 S800
;TYPE:WALL-OUTER
G1 F2100 X105.74 Y123.06 E35.77986
G1 X105.74 Y120.74 E35.90949
G1 X129.26 Y120.74 E37.22372
G1 X129.26 Y122.585 E37.32681
G0 F1890 X129.26 Y123.06
M204 S500
G1 F1800 E36.72681
G0 F10500 X130.165 Y123.06
G0 X126.266 Y118.365
G0 X126.266 Y116.634
M204 S800
;TYPE:WALL-INNER
G1 F1800 E37.32681
G1 F2100 X126.765 Y116.631 E37.35469
G1 X127.115 Y116.547 E37.37481
G1 X127.538 Y116.347 E37.40095
G1 X127.816 Y116.135 E37.42049
G1 X128.064 Y115.863 E37.44105
G1 X128.31 Y115.425 E37.46912
G1 X128.433 Y114.939 E37.49714
G1 X128.439 Y114.512 E37.521
G1 X128.35 Y114.091 E37.54504
G1 X128.147 Y113.662 E37.57156
G1 X127.935 Y113.384 E37.5911
G1 X127.663 Y113.136 E37.61167
G1 X127.225 Y112.89 E37.63974
G1 X126.757 Y112.771 E37.66672
G1 X126.573 Y112.755 E37.67704
G1 X126.225 Y112.772 E37.69651
G1 X125.885 Y112.853 E37.71604
G1 X125.462 Y113.053 E37.74218
G1 X125.184 Y113.265 E37.76172
G1 X124.936 Y113.537 E37.78228
G1 X124.69 Y113.975 E37.81035
G1 X124.566 Y114.466 E37.83865
G1 X124.569 Y114.965 E37.86653
G1 X124.653 Y115.315 E37.88665
G1 X124.853 Y115.738 E37.91279
G1 X125.065 Y116.016 E37.93233
G1 X125.337 Y116.264 E37.95289
G1 X125.775 Y116.51 E37.98096
G1 X125.806 Y116.518 E37.98275
G0 F1890 X126.266 Y116.634
M204 S500
G0 F10500 X126.324 Y116.154
M204 S800
;TYPE:WALL-OUTER
G1 F2100 X126.707 Y116.151 E38.00415
G1 X126.955 Y116.092 E38.0184
G1 X127.287 Y115.935 E38.03892
G1 X127.49 Y115.78 E38.05319
G1 X127.672 Y115.58 E38.0683
G1 X127.86 Y115.245 E38.08977
G1 X127.954 Y114.876 E38.11104
G1 X127.958 Y114.559 E38.12876
G1 X127.892 Y114.245 E38.14669
G1 X127.735 Y113.913 E38.16721
G1 X127.58 Y113.71 E38.18148
G1 X127.38 Y113.528 E38.19659
G1 X127.045 Y113.34 E38.21805
G1 X126.676 Y113.246 E38.23933
G1 X126.563 Y113.236 E38.24567
G1 X126.293 Y113.249 E38.26077
G1 X126.045 Y113.308 E38.27502
G1 X125.713 Y113.465 E38.29554
G1 X125.51 Y113.62 E38.30981
G1 X125.328 Y113.82 E38.32492
G1 X125.14 Y114.155 E38.34639
G1 X125.046 Y114.524 E38.36766
G1 X125.049 Y114.907 E38.38906
G1 X125.108 Y115.155 E38.40331
G1 X125.265 Y115.487 E38.42383
G1 X125.42 Y115.69 E38.4381
G1 X125.62 Y115.872 E38.45321
G1 X125.873 Y116.014 E38.46942
G0 F1890 X125.955 Y116.06
G0 X126.324 Y116.154
M204 S500
G0 F10500 X126.261 Y116.678
G1 F1800 E37.86942
G0 F10500 X126.345 Y115.238
G0 X114.528 Y115.26
G0 X114.266 Y116.634
M204 S800
;TYPE:WALL-INNER
G1 F1800 E38.46942
G1 F2100 X114.765 Y116.631 E38.49731
G1 X115.115 Y116.547 E38.51742
G1 X115.538 Y116.347 E38.54356
G1 X115.816 Y116.135 E38.5631
G1 X116.064 Y115.863 E38.58367
G1 X116.31 Y115.425 E38.61174
G1 X116.433 Y114.939 E38.63975
G1 X116.439 Y114.512 E38.66361
G1 X116.35 Y114.091 E38.68765
G1 X116.147 Y113.662 E38.71417
G1 X115.935 Y113.384 E38.73371
G1 X115.663 Y113.136 E38.75428
G1 X115.225 Y112.89 E38.78235
G1 X114.757 Y112.771 E38.80933
G1 X114.573 Y112.755 E38.81965
G1 X114.225 Y112.772 E38.83912
G1 X113.885 Y112.853 E38.85865
G1 X113.462 Y113.053 E38.88479
G1 X113.184 Y113.265 E38.90433
G1 X112.936 Y113.537 E38.9249
G1 X112.69 Y113.975 E38.95297
G1 X112.566 Y114.466 E38.98126
G1 X112.569 Y114.965 E39.00915
G1 X112.653 Y115.315 E39.02926
G1 X112.853 Y115.738 E39.0554
G1 X113.065 Y116.016 E39.07494
G1 X113.337 Y116.264 E39.09551
G1 X113.775 Y116.51 E39.12358
G1 X113.806 Y116.518 E39.12536
G0 F1890 X114.266 Y116.634
M204 S500
G0 F10500 X114.324 Y116.154
M204 S800
;TYPE:WALL-OUTER
G1 F2100 X114.707 Y116.151 E39.14677
G1 X114.955 Y116.092 E39.16101
G1 X115.287 Y115.935 E39.18153
G1 X115.49 Y115.78 E39.1958
G1 X115.672 Y115.58 E39.21091
G1 X115.86 Y115.245 E39.23238
G1 X115.954 Y114.876 E39.25365
G1 X115.958 Y114.559 E39.27137
G1 X115.892 Y114.245 E39.2893
G1 X115.735 Y113.913 E39.30982
G1 X115.58 Y113.71 E39.32409
G1 X115.38 Y113.528 E39.3392
G1 X115.045 Y113.34 E39.36067
G1 X114.676 Y113.246 E39.38194
G1 X114.563 Y113.236 E39.38828
G1 X114.293 Y113.249 E39.40339
G1 X114.045 Y113.308 E39.41763
G1 X113.713 Y113.465 E39.43815
G1 X113.51 Y113.62 E39.45242
G1 X113.328 Y113.82 E39.46753
G1 X113.14 Y114.155 E39.489
G1 X113.046 Y114.524 E39.51027
G1 X113.049 Y114.907 E39.53168
G1 X113.108 Y115.155 E39.54592
G1 X113.265 Y115.487 E39.56644
G1 X113.42 Y115.69 E39.58071
G1 X113.62 Y115.872 E39.59582
G1 X113.873 Y116.014 E39.61203
G0 F1890 X113.955 Y116.06
G0 X114.324 Y116.154
M204 S500
G0 F10500 X114.261 Y116.678
G0 X111.925 Y116.02
M204 S800
;TYPE:WALL-INNER
G1 F2100 X107.18 Y116.02 E39.87717
G1 X107.18 Y113.38 E40.02469
G1 X111.923 Y113.38 E40.28971
G1 X111.79 Y113.617 E40.3049
G1 X111.606 Y114.35 E40.34712
G1 X111.609 Y115.081 E40.38797
G1 X111.732 Y115.587 E40.41707
G0 F1890 X111.743 Y115.636
G0 X111.925 Y116.02
M204 S500
G0 F10500 X112.883 Y116.5
M204 S800
G1 F2100 X106.7 Y116.5 E40.76256
G1 X106.7 Y112.9 E40.96371
G1 X112.871 Y112.9 E41.30853
G1 X112.858 Y112.91 E41.30945
G1 X112.544 Y113.254 E41.33547
G1 X112.24 Y113.796 E41.3702
G1 X112.086 Y114.408 E41.40546
G1 X112.089 Y115.023 E41.43982
G1 X112.198 Y115.475 E41.4658
G1 X112.441 Y115.989 E41.49757
G1 X112.564 Y116.15 E41.50889
G0 F1890 X112.71 Y116.342
G0 X112.883 Y116.5
M204 S500
G1 F1800 E40.90889
G0 F10500 X114.166 Y115.15
G0 X126.88 Y114.288
G0 X128.29 Y113.058
M204 S800
G1 F1800 E41.50889
G1 F2100 X128.117 Y112.9 E41.52198
G1 X128.3 Y112.9 E41.52313
G1 X128.29 Y113.058 E41.52394
M204 S500
G1 F1800 E40.92394
G0 F10500 X126.917 Y114.326
G0 X126.003 Y114.96
G0 X123.925 Y116.02
M204 S800
G1 F1800 E41.52394
G1 F2100 X117.078 Y116.02 E41.90653
G1 X117.21 Y115.784 E41.92164
G1 X117.391 Y115.065 E41.96307
G1 X117.401 Y114.418 E41.99923
G1 X117.266 Y113.782 E42.03556
G1 X117.075 Y113.38 E42.06043
G1 X123.923 Y113.38 E42.44307
G1 X123.79 Y113.617 E42.45826
G1 X123.606 Y114.35 E42.50049
G1 X123.609 Y115.081 E42.54133
G1 X123.732 Y115.587 E42.57043
G0 F1890 X123.743 Y115.636
G0 X123.925 Y116.02
M204 S500
G0 F10500 X124.883 Y116.5
M204 S800
G1 F2100 X116.129 Y116.5 E43.05958
G1 X116.142 Y116.49 E43.06049
G1 X116.456 Y116.146 E43.08652
G1 X116.76 Y115.605 E43.12119
G1 X116.912 Y115.002 E43.15594
G1 X116.92 Y114.465 E43.18595
G1 X116.808 Y113.937 E43.21611
G1 X116.559 Y113.411 E43.24863
G1 X116.29 Y113.058 E43.27343
G1 X116.117 Y112.9 E43.28652
G1 X124.871 Y112.9 E43.77567
G1 X124.858 Y112.91 E43.77658
G1 X124.544 Y113.254 E43.80261
G1 X124.24 Y113.796 E43.83733
G1 X124.086 Y114.408 E43.87259
G1 X124.089 Y115.023 E43.90696
G1 X124.198 Y115.475 E43.93294
G1 X124.441 Y115.989 E43.96471
G1 X124.564 Y116.15 E43.97603
G0 F1890 X124.71 Y116.342
G0 X124.883 Y116.5
M204 S500
G0 F10500 X128.3 Y116.5
M204 S800
G1 F2100 X128.142 Y116.49 E43.98488
G1 X128.3 Y116.317 E43.98993
G1 X128.3 Y116.5 E43.99069
M204 S500
G0 F10500 X128.78 Y116.98
M204 S800
G1 F2100 X126.765 Y116.98 E44.10328
G1 X126.266 Y116.98 E44.12351
G1 X125.775 Y116.98 E44.14685
G1 X114.765 Y116.98 E44.76205
G1 X114.266 Y116.98 E44.78228
G1 X113.775 Y116.98 E44.80562
G1 X106.22 Y116.98 E45.22777
G1 X106.22 Y112.42 E45.48257
G1 X114.225 Y112.42 E45.92987
G1 X115.225 Y112.42 E45.97635
G1 X126.225 Y112.42 E46.58825
G1 X127.225 Y112.42 E46.63473
G1 X128.78 Y112.42 E46.72162
G1 X128.78 Y114.091 E46.81499
G1 X128.78 Y114.939 E46.85544
G1 X128.78 Y115.425 E46.87857
G1 X128.78 Y116.98 E46.96546
M204 S500
G0 F10500 X129.26 Y117.46
M204 S800
;TYPE:WALL-OUTER
G1 F2100 X105.74 Y117.46 E48.27969
G1 X105.74 Y111.94 E48.58813
G1 X129.26 Y111.94 E49.90236
G1 X129.26 Y116.985 E50.18426
G0 F1890 X129.26 Y117.46
M204 S500
G1 F1800 E49.58426
G0 F10500 X129.26 Y118.365
G0 X125.969 Y114.877
G0 X123.239 Y115.55
M204 S800
;TYPE:SKIN
G1 F1800 E50.18426
G1 F2100 X117.754 Y115.55 E50.49074
G1 X117.861 Y115.127 E50.51512
G1 X117.871 Y114.373 E50.55726
G1 X117.76 Y113.85 E50.58713
G1 X123.247 Y113.85 E50.89373
G1 X123.136 Y114.293 E50.91925
G1 X123.139 Y115.086 E50.96356
G0 F1890 X123.139 Y115.138
G0 X123.239 Y115.55
M204 S500
G0 F10500 X122.977 Y115.288
M204 S800
G1 F2100 X122.908 Y115.358 E50.96905
M204 S500
G0 F10500 X122.229 Y115.358
M204 S800
G1 F2100 X122.944 Y114.643 E51.02555
M204 S500
G0 F10500 X122.866 Y114.042
M204 S800
G1 F2100 X121.55 Y115.358 E51.12954
M204 S500
G0 F10500 X120.872 Y115.358
M204 S800
G1 F2100 X122.188 Y114.042 E51.23354
M204 S500
G0 F10500 X121.509 Y114.042
M204 S800
G1 F2100 X120.193 Y115.358 E51.33753
M204 S500
G0 F10500 X119.514 Y115.358
M204 S800
G1 F2100 X120.83 Y114.042 E51.44152
M204 S500
G0 F10500 X120.151 Y114.042
M204 S800
G1 F2100 X118.835 Y115.358 E51.54552
M204 S500
G0 F10500 X118.156 Y115.358
M204 S800
G1 F2100 X119.472 Y114.042 E51.64951
M204 S500
G0 F10500 X118.793 Y114.042
M204 S800
G1 F2100 X118.057 Y114.778 E51.70767
M204 S500
G0 F10500 X118.017 Y114.139
M204 S800
G1 F2100 X118.115 Y114.042 E51.71537
M204 S500
G1 F1800 E51.11537
G0 F10500 X115.046 Y114.572
G0 X113.965 Y114.537
G0 X111.247 Y113.85
M204 S800
G1 F1800 E51.71537
G1 F2100 X111.136 Y114.293 E51.74089
G1 X111.139 Y115.138 E51.78811
G1 X111.239 Y115.55 E51.8118
G1 X107.65 Y115.55 E52.01234
G1 X107.65 Y113.85 E52.10733
G1 X110.772 Y113.85 E52.28178
G0 F1890 X111.247 Y113.85
M204 S500
G0 F10500 X110.945 Y115.102
M204 S800
G1 F2100 X110.69 Y115.357 E52.30193
M204 S500
G0 F10500 X110.011 Y115.357
M204 S800
G1 F2100 X110.943 Y114.425 E52.37558
M204 S500
G0 F10500 X110.648 Y114.041
M204 S800
G1 F2100 X109.332 Y115.357 E52.47957
M204 S500
G0 F10500 X108.654 Y115.357
M204 S800
G1 F2100 X109.969 Y114.041 E52.58353
M204 S500
G0 F10500 X109.291 Y114.041
M204 S800
G1 F2100 X107.975 Y115.357 E52.68752
M204 S500
G0 F10500 X107.842 Y114.811
M204 S800
G1 F2100 X108.612 Y114.041 E52.74837
M204 S500
G0 F10500 X107.933 Y114.041
M204 S800
G1 F2100 X107.842 Y114.132 E52.75556
M204 S500
G1 F1800 E52.15556
;MESH:NONMESH
G0 F300 X107.842 Y114.132 Z0.84
G0 F10500 X104.835 Y114.132
G0 X130.153 Y123.953
G0 X128.3 Y123.965
G0 X128.3 Y122.1
;TIME_ELAPSED:71.396306
;LAYER:2
M106 S255
M204 S800
;TYPE:WALL-INNER
G1 F1800 E52.75556
G1 F2724.5 X106.7 Y122.1 E54.30734
G1 X106.7 Y121.7 E54.33608
G1 X128.3 Y121.7 E55.63193
G1 X128.3 Y122.1 E55.66067
M204 S500
G0 F15000 X128.78 Y122.58
M204 S800
G1 F2724.5 X106.22 Y122.58 E57.28142
G1 X106.22 Y121.22 E57.37913
G1 X128.78 Y121.22 E58.99988
G1 X128.78 Y122.212 E59.07115
G0 F2452.1 X128.78 Y122.58
M204 S500
G0 F15000 X129.26 Y123.06
M204 S800
;TYPE:WALL-OUTER
G1 F2724.5 X105.74 Y123.06 E60.76087
G1 X105.74 Y120.74 E60.92754
G1 X129.26 Y120.74 E62.61726
G1 X129.26 Y122.692 E62.7575
G0 F2452.1 X129.26 Y123.06
M204 S500
G1 F1800 E62.1575
G0 F15000 X130.165 Y123.06
G0 X128.572 Y119.838
G0 X126.29 Y115.219
G0 X125.524 Y116.387
M204 S800
;TYPE:WALL-INNER
G1 F1800 E62.7575
G1 F2724.5 X125.911 Y116.555 E62.78781
G1 X126.245 Y116.631 E62.81242
G1 X126.585 Y116.645 E62.83686
G1 X126.922 Y116.6 E62.86129
G1 X127.245 Y116.499 E62.8856
G1 X127.546 Y116.341 E62.91002
G1 X127.815 Y116.136 E62.93432
G1 X128.045 Y115.886 E62.95873
G1 X128.228 Y115.6 E62.98312
G1 X128.357 Y115.284 E63.00764
G1 X128.432 Y114.947 E63.03244
G1 X128.438 Y114.49 E63.06528
G1 X128.332 Y114.038 E63.09863
G1 X128.145 Y113.659 E63.12899
G1 X127.936 Y113.385 E63.15375
G1 X127.686 Y113.155 E63.17816
G1 X127.4 Y112.972 E63.20255
G1 X127.084 Y112.843 E63.22707
G1 X126.765 Y112.772 E63.25055
G1 X126.573 Y112.755 E63.2644
G1 X126.245 Y112.769 E63.28798
G1 X125.915 Y112.844 E63.31229
G1 X125.595 Y112.975 E63.33714
G1 X125.224 Y113.229 E63.36944
G1 X124.984 Y113.479 E63.39433
G1 X124.772 Y113.799 E63.42191
G1 X124.643 Y114.116 E63.4465
G1 X124.569 Y114.445 E63.47073
G1 X124.555 Y114.785 E63.49517
G1 X124.6 Y115.122 E63.5196
G1 X124.703 Y115.451 E63.54437
G1 X124.923 Y115.843 E63.57666
G1 X125.155 Y116.11 E63.60207
G1 X125.23 Y116.166 E63.60879
G0 F2452.1 X125.524 Y116.387
M204 S500
G0 F15000 X125.767 Y115.969
M204 S800
;TYPE:WALL-OUTER
G1 F2724.5 X126.061 Y116.097 E63.63183
G1 X126.309 Y116.153 E63.6501
G1 X126.563 Y116.164 E63.66836
G1 X126.818 Y116.13 E63.68684
G1 X127.06 Y116.054 E63.70507
G1 X127.287 Y115.935 E63.72348
G1 X127.49 Y115.78 E63.74183
G1 X127.663 Y115.592 E63.76018
G1 X127.8 Y115.378 E63.77844
G1 X127.897 Y115.14 E63.7969
G1 X127.953 Y114.891 E63.81524
G1 X127.957 Y114.543 E63.84024
G1 X127.877 Y114.201 E63.86547
G1 X127.735 Y113.913 E63.88854
G1 X127.58 Y113.71 E63.90689
G1 X127.392 Y113.537 E63.92525
G1 X127.178 Y113.4 E63.9435
G1 X126.94 Y113.303 E63.96196
G1 X126.691 Y113.247 E63.9803
G1 X126.563 Y113.236 E63.98953
G1 X126.309 Y113.247 E64.00779
G1 X126.06 Y113.303 E64.02613
G1 X125.824 Y113.4 E64.04446
G1 X125.536 Y113.597 E64.06953
G1 X125.36 Y113.78 E64.08777
G1 X125.199 Y114.024 E64.10877
G1 X125.103 Y114.26 E64.12707
G1 X125.047 Y114.509 E64.14541
G1 X125.036 Y114.763 E64.16368
G1 X125.07 Y115.018 E64.18216
G1 X125.146 Y115.26 E64.20038
G1 X125.317 Y115.565 E64.2255
G1 X125.475 Y115.746 E64.24276
G0 F2452.1 X125.484 Y115.756
G0 X125.767 Y115.969
M204 S500
G0 F15000 X125.502 Y116.425
G1 F1800 E63.64276
G0 F15000 X126.176 Y115.157
G0 X114.785 Y115.183
G0 X115.251 Y116.497
M204 S800
;TYPE:WALL-INNER
G1 F1800 E64.24276
G1 F2724.5 X115.643 Y116.277 E64.27506
G1 X115.91 Y116.045 E64.30047
G1 X116.187 Y115.676 E64.33361
G1 X116.355 Y115.289 E64.36392
G1 X116.432 Y114.947 E64.38911
G1 X116.438 Y114.49 E64.42194
G1 X116.332 Y114.038 E64.4553
G1 X116.145 Y113.659 E64.48566
G1 X115.936 Y113.385 E64.51042
G1 X115.686 Y113.155 E64.53482
G1 X115.4 Y112.972 E64.55921
G1 X115.084 Y112.843 E64.58374
G1 X114.765 Y112.772 E64.60721
G1 X114.573 Y112.755 E64.62106
G1 X114.245 Y112.769 E64.64465
G1 X113.915 Y112.844 E64.66896
G1 X113.595 Y112.975 E64.6938
G1 X113.224 Y113.229 E64.7261
G1 X112.984 Y113.479 E64.751
G1 X112.772 Y113.799 E64.77858
G1 X112.643 Y114.116 E64.80316
G1 X112.569 Y114.445 E64.82739
G1 X112.555 Y114.785 E64.85184
G1 X112.6 Y115.122 E64.87626
G1 X112.703 Y115.451 E64.90103
G1 X112.923 Y115.843 E64.93332
G1 X113.155 Y116.11 E64.95874
G1 X113.524 Y116.387 E64.99188
G1 X113.911 Y116.555 E65.02219
G1 X114.245 Y116.631 E65.0468
G1 X114.585 Y116.645 E65.07125
G1 X114.899 Y116.603 E65.09401
G0 F2452.1 X114.922 Y116.6
M204 S500
G0 F15000 X115.06 Y116.054
M204 S800
;TYPE:WALL-OUTER
G1 F2724.5 X115.365 Y115.883 E65.11913
G1 X115.556 Y115.716 E65.13736
G1 X115.769 Y115.433 E65.1628
G1 X115.897 Y115.139 E65.18584
G1 X115.953 Y114.891 E65.2041
G1 X115.957 Y114.543 E65.22911
G1 X115.877 Y114.201 E65.25434
G1 X115.735 Y113.913 E65.27741
G1 X115.58 Y113.71 E65.29576
G1 X115.392 Y113.537 E65.31411
G1 X115.178 Y113.4 E65.33237
G1 X114.94 Y113.303 E65.35083
G1 X114.691 Y113.247 E65.36917
G1 X114.563 Y113.236 E65.3784
G1 X114.309 Y113.247 E65.39666
G1 X114.06 Y113.303 E65.415
G1 X113.824 Y113.4 E65.43333
G1 X113.536 Y113.597 E65.45839
G1 X113.36 Y113.78 E65.47664
G1 X113.199 Y114.024 E65.49764
G1 X113.103 Y114.26 E65.51594
G1 X113.047 Y114.509 E65.53428
G1 X113.036 Y114.763 E65.55254
G1 X113.07 Y115.018 E65.57102
G1 X113.146 Y115.26 E65.58925
G1 X113.317 Y115.565 E65.61437
G1 X113.484 Y115.756 E65.63259
G1 X113.767 Y115.969 E65.65804
G1 X114.061 Y116.097 E65.68108
G1 X114.309 Y116.153 E65.69934
G1 X114.563 Y116.164 E65.71761
G1 X114.704 Y116.145 E65.72783
G0 F2452.1 X114.818 Y116.13
G0 X115.06 Y116.054
M204 S500
G0 F15000 X115.269 Y116.538
G0 X112.875 Y116.5
M204 S800
;TYPE:WALL-INNER
G1 F2724.5 X106.7 Y116.5 E66.17145
G1 X106.7 Y112.9 E66.43008
G1 X112.875 Y112.9 E66.87371
G1 X112.608 Y113.178 E66.9014
G1 X112.345 Y113.574 E66.93555
G1 X112.183 Y113.972 E66.96642
G1 X112.091 Y114.382 E66.99661
G1 X112.074 Y114.807 E67.02717
G1 X112.13 Y115.226 E67.05754
G1 X112.26 Y115.642 E67.08885
G1 X112.528 Y116.121 E67.12828
G1 X112.625 Y116.232 E67.13887
G0 F2452.1 X112.826 Y116.463
G0 X112.875 Y116.5
M204 S500
G1 F1800 E66.53887
G0 F15000 X114.176 Y115.157
G0 X126.874 Y114.283
G0 X128.292 Y113.06
M204 S800
G1 F1800 E67.13887
G1 F2724.5 X128.118 Y112.9 E67.15585
G1 X128.3 Y112.9 E67.15726
G1 X128.292 Y113.06 E67.15828
M204 S500
G1 F1800 E66.55828
G0 F15000 X126.917 Y114.326
G0 X126.114 Y115.106
G0 X124.875 Y116.5
M204 S800
G1 F1800 E67.15828
G1 F2724.5 X116.118 Y116.5 E67.7874
G1 X116.263 Y116.374 E67.8012
G1 X116.605 Y115.919 E67.84209
G1 X116.813 Y115.439 E67.87967
G1 X116.911 Y115.003 E67.91178
G1 X116.919 Y114.438 E67.95237
G1 X116.787 Y113.875 E67.99392
G1 X116.555 Y113.405 E68.03157
G1 X116.292 Y113.06 E68.06274
G1 X116.118 Y112.9 E68.07972
G1 X124.875 Y112.9 E68.70884
G1 X124.608 Y113.178 E68.73653
G1 X124.345 Y113.574 E68.77068
G1 X124.183 Y113.972 E68.80155
G1 X124.091 Y114.382 E68.83174
G1 X124.074 Y114.807 E68.8623
G1 X124.13 Y115.226 E68.89267
G1 X124.26 Y115.642 E68.92398
G1 X124.528 Y116.121 E68.96341
G1 X124.625 Y116.232 E68.974
G0 F2452.1 X124.826 Y116.463
G0 X124.875 Y116.5
M204 S500
G0 F15000 X128.3 Y116.5
M204 S800
G1 F2724.5 X128.14 Y116.492 E68.98551
G1 X128.3 Y116.318 E68.992
G1 X128.3 Y116.5 E68.99287
M204 S500
G0 F15000 X128.78 Y116.98
M204 S800
G1 F2724.5 X126.585 Y116.98 E69.15056
G1 X125.911 Y116.98 E69.18856
G1 X114.585 Y116.98 E70.00224
G1 X113.911 Y116.98 E70.04025
G1 X106.22 Y116.98 E70.59278
G1 X106.22 Y112.42 E70.92038
G1 X114.245 Y112.42 E71.49691
G1 X115.084 Y112.42 E71.55185
G1 X126.245 Y112.42 E72.35031
G1 X127.084 Y112.42 E72.40011
G1 X128.78 Y112.42 E72.52196
G1 X128.78 Y114.49 E72.67067
G1 X128.78 Y115.284 E72.71514
G1 X128.78 Y116.98 E72.83698
M204 S500
G0 F15000 X129.26 Y117.46
M204 S800
;TYPE:WALL-OUTER
G1 F2724.5 X105.74 Y117.46 E74.5267
G1 X105.74 Y111.94 E74.92327
G1 X129.26 Y111.94 E76.61299
G1 X129.26 Y117.092 E76.98312
G0 F2452.1 X129.26 Y117.46
M204 S500
G1 F1800 E76.38312
G0 F15000 X129.26 Y118.365
G0 X126.017 Y114.985
G0 X123.939 Y116.03
M204 S800
;TYPE:SKIN
G1 F1800 E76.98312
G1 F2724.5 X117.069 Y116.03 E77.47668
G1 X117.262 Y115.586 E77.51146
G1 X117.381 Y115.058 E77.55034
G1 X117.389 Y114.387 E77.59855
G1 X117.232 Y113.715 E77.64813
G1 X117.062 Y113.37 E77.67576
G1 X123.921 Y113.37 E78.16852
G1 X123.733 Y113.831 E78.20429
G1 X123.623 Y114.321 E78.24037
G1 X123.602 Y114.829 E78.2769
G1 X123.67 Y115.328 E78.31308
G1 X123.786 Y115.698 E78.34093
G0 F2452.1 X123.826 Y115.828
G0 X123.939 Y116.03
M204 S500
G0 F15000 X123.499 Y113.995
M204 S800
G1 F2724.5 X123.065 Y113.562 E78.38498
M204 S500
G0 F15000 X122.386 Y113.562
M204 S800
G1 F2724.5 X123.419 Y114.594 E78.48988
M204 S500
G0 F15000 X123.477 Y115.331
M204 S800
G1 F2724.5 X121.707 Y113.562 E78.66966
M204 S500
G0 F15000 X121.029 Y113.562
M204 S800
G1 F2724.5 X123.305 Y115.838 E78.9009
M204 S500
G0 F15000 X122.626 Y115.838
M204 S800
G1 F2724.5 X120.35 Y113.562 E79.13214
M204 S500
G0 F15000 X119.671 Y113.562
M204 S800
G1 F2724.5 X121.947 Y115.838 E79.36338
M204 S500
G0 F15000 X121.268 Y115.838
M204 S800
G1 F2724.5 X118.992 Y113.562 E79.59462
M204 S500
G0 F15000 X118.313 Y113.562
M204 S800
G1 F2724.5 X120.589 Y115.838 E79.82587
M204 S500
G0 F15000 X119.911 Y115.838
M204 S800
G1 F2724.5 X117.634 Y113.562 E80.05716
M204 S500
G0 F15000 X117.524 Y114.13
M204 S800
G1 F2724.5 X119.232 Y115.838 E80.23069
M204 S500
G0 F15000 X118.553 Y115.838
M204 S800
G1 F2724.5 X117.574 Y114.858 E80.33021
M204 S500
G0 F15000 X117.487 Y115.451
M204 S800
G1 F2724.5 X117.874 Y115.838 E80.36953
M204 S500
G1 F1800 E79.76953
G0 F15000 X117.874 Y118.365
G0 X114.017 Y114.985
G0 X111.939 Y116.03
M204 S800
G1 F1800 E80.36953
G1 F2724.5 X107.17 Y116.03 E80.71214
G1 X107.17 Y113.37 E80.90324
G1 X111.921 Y113.37 E81.24456
G1 X111.733 Y113.831 E81.28033
G1 X111.623 Y114.321 E81.31641
G1 X111.602 Y114.829 E81.35293
G1 X111.67 Y115.328 E81.38911
G1 X111.786 Y115.698 E81.41697
G0 F2452.1 X111.826 Y115.828
G0 X111.939 Y116.03
M204 S500
G0 F15000 X111.604 Y113.64
M204 S800
G1 F2724.5 X111.524 Y113.561 E81.42505
M204 S500
G0 F15000 X111.459 Y114.174
M204 S800
G1 F2724.5 X110.846 Y113.561 E81.48733
M204 S500
G0 F15000 X110.167 Y113.561
M204 S800
G1 F2724.5 X111.41 Y114.804 E81.61362
M204 S500
G0 F15000 X111.567 Y115.64
M204 S800
G1 F2724.5 X109.488 Y113.561 E81.82484
M204 S500
G0 F15000 X108.809 Y113.561
M204 S800
G1 F2724.5 X111.085 Y115.836 E82.05603
M204 S500
G0 F15000 X110.406 Y115.836
M204 S800
G1 F2724.5 X108.13 Y113.561 E82.28722
M204 S500
G0 F15000 X107.451 Y113.561
M204 S800
G1 F2724.5 X109.727 Y115.836 E82.51841
M204 S500
G0 F15000 X109.048 Y115.836
M204 S800
G1 F2724.5 X107.361 Y114.149 E82.68981
M204 S500
G0 F15000 X107.361 Y114.828
M204 S800
G1 F2724.5 X108.369 Y115.836 E82.79223
M204 S500
G0 F15000 X107.69 Y115.836
M204 S800
G1 F2724.5 X107.361 Y115.507 E82.82565
M204 S500
G1 F1800 E82.22565
;MESH:NONMESH
G0 F300 X107.361 Y115.507 Z1.2
G0 F15000 X107.361 Y118.365
G0 X128.3 Y123.965
G0 X128.3 Y122.1
;TIME_ELAPSED:90.744489
;LAYER:3
M204 S800
;TYPE:WALL-INNER
G1 F1800 E82.82565
G1 F2709 X106.7 Y122.1 E84.37744
G1 X106.7 Y121.7 E84.40617
G1 X128.3 Y121.7 E85.70203
G1 X128.3 Y122.1 E85.73076
M204 S500
M204 S800
G1 F2709 X106.22 Y122.58 E87.35152
G1 X106.22 Y121.22 E87.44922
G1 X128.78 Y121.22 E89.06997
G1 X128.78 Y122.212 E89.14124
G0 F2438.1 X128.78 Y122.58
M204 S500
M204 S800
;TYPE:WALL-OUTER
G1 F2709 X105.74 Y123.06 E90.83096
G1 X105.74 Y120.74 E90.99764
G1 X129.26 Y120.74 E92.68736
G1 X129.26 Y122.692 E92.82759
G0 F2438.1 X129.26 Y123.06
M204 S500
G1 F1800 E92.22759
G0 X127.093 Y118.365
G0 X127.093 Y116.554
M204 S800
;TYPE:WALL-INNER
G1 F1800 E92.82759
G1 F2709 X127.513 Y116.363 E92.86074
G1 X127.794 Y116.155 E92.88586
G1 X128.044 Y115.888 E92.91213
G1 X128.228 Y115.6 E92.93669
G1 X128.357 Y115.284 E92.96121
G1 X128.433 Y114.944 E92.98624
G1 X128.433 Y114.455 E93.02137
G1 X128.354 Y114.107 E93.047
G1 X128.163 Y113.687 E93.08015
G1 X127.955 Y113.406 E93.10527
G1 X127.688 Y113.156 E93.13155
G1 X127.4 Y112.972 E93.1561
G1 X127.084 Y112.843 E93.18062
G1 X126.765 Y112.772 E93.2041
G1 X126.573 Y112.755 E93.21795
G1 X126.245 Y112.769 E93.24153
G1 X125.911 Y112.845 E93.26614
G1 X125.521 Y113.015 E93.2967
G1 X125.145 Y113.299 E93.33056
G1 X124.862 Y113.648 E93.36284
G1 X124.701 Y113.955 E93.38774
G1 X124.6 Y114.278 E93.41205
G1 X124.555 Y114.615 E93.43648
G1 X124.569 Y114.955 E93.46093
G1 X124.645 Y115.289 E93.48553
G1 X124.815 Y115.679 E93.5161
G1 X125.099 Y116.055 E93.54995
G1 X125.448 Y116.338 E93.58223
G1 X125.755 Y116.499 E93.60714
G1 X126.078 Y116.6 E93.63145
G1 X126.415 Y116.645 E93.65587
G1 X126.733 Y116.631 E93.67874
G0 F2438.1 X126.755 Y116.631
M204 S500
G0 F15000 X126.939 Y116.097
M204 S800
;TYPE:WALL-OUTER
G1 F2709 X127.268 Y115.947 E93.70472
G1 X127.473 Y115.795 E93.72305
G1 X127.663 Y115.592 E93.74303
G1 X127.8 Y115.378 E93.76128
G1 X127.897 Y115.14 E93.77975
G1 X127.953 Y114.891 E93.79808
G1 X127.953 Y114.509 E93.82553
G1 X127.897 Y114.261 E93.84379
G1 X127.747 Y113.932 E93.86977
G1 X127.595 Y113.727 E93.8881
G1 X127.392 Y113.537 E93.90808
G1 X127.178 Y113.4 E93.92633
G1 X126.94 Y113.303 E93.9448
G1 X126.691 Y113.247 E93.96313
G1 X126.563 Y113.236 E93.97236
G1 X126.309 Y113.247 E93.99063
G1 X126.061 Y113.303 E94.00889
G1 X125.765 Y113.432 E94.03209
G1 X125.481 Y113.647 E94.05768
G1 X125.265 Y113.913 E94.0823
G1 X125.146 Y114.14 E94.10071
G1 X125.07 Y114.382 E94.11893
G1 X125.036 Y114.637 E94.13741
G1 X125.047 Y114.891 E94.15568
G1 X125.103 Y115.139 E94.17394
G1 X125.232 Y115.435 E94.19714
G1 X125.447 Y115.719 E94.22273
G1 X125.713 Y115.935 E94.24735
G1 X125.94 Y116.054 E94.26576
G1 X126.182 Y116.13 E94.28398
G1 X126.437 Y116.164 E94.30247
G1 X126.577 Y116.157 E94.31254
G0 F2438.1 X126.691 Y116.153
G0 X126.939 Y116.097
M204 S500
G0 F15000 X127.107 Y116.597
G1 F1800 E93.71254
G0 F15000 X126.575 Y115.255
G0 X114.85 Y115.137
G0 X115.479 Y116.385
M204 S800
;TYPE:WALL-INNER
G1 F1800 E94.31254
G1 F2709 X115.855 Y116.101 E94.34639
G1 X116.138 Y115.752 E94.37867
G1 X116.299 Y115.445 E94.40357
G1 X116.4 Y115.123 E94.42782
G1 X116.445 Y114.786 E94.45224
G1 X116.431 Y114.445 E94.47676
G1 X116.354 Y114.107 E94.50167
G1 X116.163 Y113.687 E94.53481
G1 X115.955 Y113.406 E94.55993
G1 X115.688 Y113.156 E94.58621
G1 X115.4 Y112.972 E94.61076
G1 X115.084 Y112.843 E94.63528
G1 X114.765 Y112.772 E94.65876
G1 X114.573 Y112.755 E94.67261
G1 X114.245 Y112.769 E94.69619
G1 X113.911 Y112.845 E94.7208
G1 X113.521 Y113.015 E94.75137
G1 X113.145 Y113.299 E94.78522
G1 X112.862 Y113.648 E94.8175
G1 X112.701 Y113.955 E94.8424
G1 X112.6 Y114.278 E94.86672
G1 X112.555 Y114.615 E94.89114
G1 X112.569 Y114.955 E94.91559
G1 X112.645 Y115.289 E94.9402
G1 X112.815 Y115.679 E94.97076
G1 X113.099 Y116.055 E95.00461
G1 X113.448 Y116.338 E95.03689
G1 X113.755 Y116.499 E95.0618
G1 X114.078 Y116.6 E95.08611
G1 X114.415 Y116.645 E95.11054
G1 X114.755 Y116.631 E95.13498
G1 X115.089 Y116.555 E95.15959
G1 X115.142 Y116.532 E95.16374
G0 F2438.1 X115.479 Y116.385
M204 S500
G0 F15000 X115.235 Y115.968
M204 S800
;TYPE:WALL-OUTER
G1 F2709 X115.519 Y115.753 E95.18933
G1 X115.735 Y115.487 E95.21395
G1 X115.854 Y115.26 E95.23236
G1 X115.93 Y115.018 E95.25059
G1 X115.964 Y114.764 E95.269
G1 X115.953 Y114.509 E95.28733
G1 X115.897 Y114.261 E95.3056
G1 X115.747 Y113.932 E95.33158
G1 X115.595 Y113.727 E95.34991
G1 X115.392 Y113.537 E95.36988
G1 X115.178 Y113.4 E95.38814
G1 X114.94 Y113.303 E95.4066
G1 X114.691 Y113.247 E95.42494
G1 X114.563 Y113.236 E95.43417
G1 X114.309 Y113.247 E95.45243
G1 X114.061 Y113.303 E95.4707
G1 X113.765 Y113.432 E95.4939
G1 X113.481 Y113.647 E95.51949
G1 X113.265 Y113.913 E95.5441
G1 X113.146 Y114.14 E95.56252
G1 X113.07 Y114.382 E95.58074
G1 X113.036 Y114.637 E95.59922
G1 X113.047 Y114.891 E95.61749
G1 X113.103 Y115.139 E95.63575
G1 X113.232 Y115.435 E95.65895
G1 X113.447 Y115.719 E95.68454
G1 X113.713 Y115.935 E95.70916
G1 X113.94 Y116.054 E95.72757
G1 X114.182 Y116.13 E95.74579
G1 X114.437 Y116.164 E95.76427
G1 X114.691 Y116.153 E95.78254
G1 X114.895 Y116.107 E95.79756
G0 F2438.1 X114.939 Y116.097
G0 X115.235 Y115.968
M204 S500
G0 F15000 X115.501 Y116.423
G0 X111.917 Y116.02
M204 S800
;TYPE:WALL-INNER
G1 F2709 X107.18 Y116.02 E96.13788
G1 X107.18 Y113.38 E96.32754
G1 X111.919 Y113.38 E96.668
G1 X111.811 Y113.586 E96.68471
G1 X111.66 Y114.07 E96.72113
G1 X111.593 Y114.571 E96.75745
G1 X111.613 Y115.083 E96.79426
G1 X111.729 Y115.59 E96.83162
G1 X111.77 Y115.683 E96.83892
G0 F2438.1 X111.917 Y116.02
M204 S500
G0 F15000 X112.886 Y116.5
M204 S800
G1 F2709 X106.7 Y116.5 E97.28334
G1 X106.7 Y112.9 E97.54197
G1 X112.877 Y112.9 E97.98574
G1 X112.809 Y112.951 E97.99184
G1 X112.459 Y113.383 E98.03179
G1 X112.256 Y113.77 E98.06318
G1 X112.13 Y114.174 E98.09358
G1 X112.074 Y114.593 E98.12395
G1 X112.091 Y115.019 E98.15458
G1 X112.187 Y115.439 E98.18553
G1 X112.398 Y115.923 E98.22347
G1 X112.634 Y116.236 E98.25163
G0 F2438.1 X112.751 Y116.391
G0 X112.886 Y116.5
M204 S500
G1 F1800 E97.65163
G0 F15000 X114.15 Y115.138
G0 X126.893 Y114.302
G0 X128.3 Y113.071
M204 S800
G1 F1800 E98.25163
G1 F2709 X128.117 Y112.9 E98.26962
G1 X128.3 Y112.9 E98.27088
G1 X128.3 Y113.071 E98.27192
M204 S500
G1 F1800 E97.67192
G0 F15000 X126.923 Y114.333
G0 X125.999 Y114.954
G0 X123.917 Y116.02
M204 S800
G1 F1800 E98.27192
G1 F2709 X117.081 Y116.02 E98.76303
G1 X117.189 Y115.815 E98.77967
G1 X117.34 Y115.331 E98.8161
G1 X117.407 Y114.83 E98.85241
G1 X117.387 Y114.317 E98.88929
G1 X117.268 Y113.799 E98.92748
G1 X117.078 Y113.38 E98.96053
G1 X123.919 Y113.38 E99.452
G1 X123.811 Y113.586 E99.46871
G1 X123.66 Y114.07 E99.50513
G1 X123.593 Y114.571 E99.54145
G1 X123.613 Y115.083 E99.57826
G1 X123.729 Y115.59 E99.61562
G1 X123.77 Y115.683 E99.62293
G0 F2438.1 X123.917 Y116.02
M204 S500
G0 F15000 X124.886 Y116.5
M204 S800
G1 F2709 X116.123 Y116.5 E100.25248
G1 X116.191 Y116.449 E100.25858
G1 X116.541 Y116.017 E100.29853
G1 X116.744 Y115.63 E100.32992
G1 X116.87 Y115.227 E100.36026
G1 X116.926 Y114.808 E100.39063
G1 X116.909 Y114.381 E100.42133
G1 X116.811 Y113.953 E100.45287
G1 X116.579 Y113.442 E100.49319
G1 X116.315 Y113.085 E100.52509
G1 X116.117 Y112.9 E100.54455
G1 X124.877 Y112.9 E101.17389
G1 X124.809 Y112.951 E101.18
G1 X124.459 Y113.383 E101.21994
G1 X124.256 Y113.77 E101.25133
G1 X124.13 Y114.174 E101.28174
G1 X124.074 Y114.593 E101.31211
G1 X124.091 Y115.019 E101.34274
G1 X124.187 Y115.439 E101.37369
G1 X124.398 Y115.923 E101.41162
G1 X124.634 Y116.236 E101.43978
G0 F2438.1 X124.751 Y116.391
G0 X124.886 Y116.5
M204 S500
M204 S800
G1 F2709 X128.129 Y116.5 E101.45207
G1 X128.3 Y116.317 E101.45879
G1 X128.3 Y116.5 E101.45935
M204 S500
M204 S800
G1 F2709 X126.755 Y116.98 E101.60483
G1 X126.078 Y116.98 E101.64302
G1 X114.755 Y116.98 E102.45481
G1 X114.078 Y116.98 E102.49299
G1 X106.22 Y116.98 E103.05753
G1 X106.22 Y112.42 E103.38513
G1 X114.245 Y112.42 E103.96166
G1 X115.084 Y112.42 E104.0166
G1 X126.245 Y112.42 E104.81506
G1 X127.084 Y112.42 E104.86485
G1 X128.78 Y112.42 E104.9867
G1 X128.78 Y114.455 E105.1329
G1 X128.78 Y115.284 E105.17941
G1 X128.78 Y116.98 E105.30125
M204 S500
M204 S800
;TYPE:WALL-OUTER
G1 F2709 X105.74 Y117.46 E106.99097
G1 X105.74 Y111.94 E107.38754
G1 X129.26 Y111.94 E109.07726
G1 X129.26 Y117.092 E109.44739
G0 F2438.1 X129.26 Y117.46
M204 S500
G1 F1800 E108.84739
G0 X125.966 Y114.868
G0 X123.238 Y115.55
M204 S800
;TYPE:SKIN
G1 F1800 E109.44739
G1 F2709 X117.764 Y115.55 E109.84065
G1 X117.8 Y115.433 E109.84945
G1 X117.879 Y114.852 E109.89157
G1 X117.855 Y114.255 E109.9345
G1 X117.762 Y113.85 E109.96435
G1 X123.237 Y113.85 E110.35768
G1 X123.2 Y113.968 E110.36657
G1 X123.121 Y114.549 E110.40869
G1 X123.145 Y115.145 E110.45154
G1 X123.156 Y115.191 E110.45494
G0 F2438.1 X123.238 Y115.55
M204 S500
G0 F15000 X122.979 Y115.287
M204 S800
G1 F2709 X122.908 Y115.358 E110.46216
M204 S500
G0 F15000 X122.229 Y115.358
M204 S800
G1 F2709 X122.931 Y114.655 E110.53353
M204 S500
G0 F15000 X122.866 Y114.042
M204 S800
G1 F2709 X121.55 Y115.358 E110.66723
M204 S500
G0 F15000 X120.872 Y115.358
M204 S800
G1 F2709 X122.188 Y114.042 E110.80094
M204 S500
G0 F15000 X121.509 Y114.042
M204 S800
G1 F2709 X120.193 Y115.358 E110.93465
M204 S500
G0 F15000 X119.514 Y115.358
M204 S800
G1 F2709 X120.83 Y114.042 E111.06835
M204 S500
G0 F15000 X120.151 Y114.042
M204 S800
G1 F2709 X118.835 Y115.358 E111.20206
M204 S500
G0 F15000 X118.156 Y115.358
M204 S800
G1 F2709 X119.472 Y114.042 E111.33576
M204 S500
G0 F15000 X118.793 Y114.042
M204 S800
G1 F2709 X118.067 Y114.768 E111.40952
M204 S500
G0 F15000 X118.023 Y114.134
M204 S800
G1 F2709 X118.115 Y114.042 E111.41887
M204 S500
G1 F1800 E110.81887
G0 F15000 X115.047 Y114.58
G0 X113.953 Y114.58
G0 X111.237 Y113.85
M204 S800
G1 F1800 E111.41887
G1 F2709 X111.2 Y113.968 E111.42775
G1 X111.121 Y114.549 E111.46988
G1 X111.145 Y115.145 E111.51273
G1 X111.238 Y115.55 E111.54258
G1 X107.65 Y115.55 E111.80035
G1 X107.65 Y113.85 E111.92248
G1 X110.869 Y113.85 E112.15374
G0 F2438.1 X111.237 Y113.85
M204 S500
G0 F15000 X110.95 Y115.097
M204 S800
G1 F2709 X110.69 Y115.357 E112.18016
M204 S500
G0 F15000 X110.011 Y115.357
M204 S800
G1 F2709 X110.943 Y114.425 E112.27485
M204 S500
G0 F15000 X110.649 Y114.04
M204 S800
G1 F2709 X109.332 Y115.357 E112.40866
M204 S500
G0 F15000 X108.654 Y115.357
M204 S800
G1 F2709 X109.97 Y114.04 E112.54241
M204 S500
G0 F15000 X109.291 Y114.04
M204 S800
G1 F2709 X107.975 Y115.357 E112.67617
M204 S500
G0 F15000 X107.842 Y114.811
M204 S800
G1 F2709 X108.613 Y114.04 E112.7545
M204 S500
G0 F15000 X107.934 Y114.04
M204 S800
G1 F2709 X107.842 Y114.132 E112.76385
M204 S500
G1 F1800 E112.16385
;MESH:NONMESH
G0 F300 X107.842 Y114.132 Z1.4
G0 F15000 X104.835 Y114.132
G0 X106.9 Y119.835
G0 X106.9 Y122.1
;TIME_ELAPSED:109.212956
;LAYER:4
M204 S800
;TYPE:WALL-INNER
G1 F1800 E112.76385
G1 F2217.3 X106.9 Y121.7 E112.77981
G1 X128.3 Y121.7 E113.63393
G1 X128.3 Y122.1 E113.6499
G1 X106.9 Y122.1 E114.36315
M204 S500
G0 F15000 X106.42 Y122.58
M204 S800
G1 F2217.3 X106.42 Y121.22 E114.41743
G1 X128.78 Y121.22 E115.30987
G1 X128.78 Y122.58 E115.36415
G1 X107.086 Y122.58 E116.23
G0 F1995.5 X106.42 Y122.58
M204 S500
G0 F15000 X105.94 Y123.06
M204 S800
;TYPE:WALL-OUTER
G1 F2217.3 X105.94 Y120.74 E116.3226
G1 X129.26 Y120.74 E117.25335
G1 X129.26 Y123.06 E117.34595
G1 X106.606 Y123.06 E118.25012
G0 F1995.5 X105.94 Y123.06
M204 S500
G1 F1800 E117.65012
G0 F15000 X105.94 Y123.965
G0 X105.047 Y123.953
G0 X105.047 Y119.847
G0 X115.566 Y119.859
G0 X126.38 Y115.247
G0 X126.415 Y116.645
M204 S800
;TYPE:WALL-INNER
G1 F1800 E118.25012
G1 F2217.3 X126.755 Y116.631 E118.2637
G1 X127.084 Y116.557 E118.27716
G1 X127.4 Y116.428 E118.29078
G1 X127.686 Y116.245 E118.30433
G1 X127.936 Y116.015 E118.31789
G1 X128.141 Y115.747 E118.33136
G1 X128.299 Y115.446 E118.34493
G1 X128.4 Y115.122 E118.35847
G1 X128.445 Y114.785 E118.37204
G1 X128.431 Y114.445 E118.38562
G1 X128.357 Y114.116 E118.39908
G1 X128.228 Y113.8 E118.41271
G1 X128.045 Y113.514 E118.42626
G1 X127.815 Y113.264 E118.43982
G1 X127.546 Y113.059 E118.45331
G1 X127.245 Y112.901 E118.46688
G1 X126.922 Y112.8 E118.48039
G1 X126.585 Y112.755 E118.49396
G1 X126.245 Y112.769 E118.50754
G1 X125.916 Y112.843 E118.521
G1 X125.6 Y112.972 E118.53462
G1 X125.314 Y113.155 E118.54817
G1 X125.064 Y113.385 E118.56173
G1 X124.859 Y113.654 E118.57523
G1 X124.701 Y113.955 E118.5888
G1 X124.6 Y114.278 E118.60231
G1 X124.555 Y114.615 E118.61588
G1 X124.569 Y114.955 E118.62946
G1 X124.643 Y115.284 E118.64292
G1 X124.772 Y115.6 E118.65654
G1 X124.955 Y115.886 E118.67009
G1 X125.185 Y116.136 E118.68365
G1 X125.453 Y116.341 E118.69712
G1 X125.754 Y116.499 E118.71068
G1 X125.766 Y116.503 E118.71119
G0 F1995.5 X126.078 Y116.6
M204 S500
G0 F15000 X126.437 Y116.164
M204 S800
;TYPE:WALL-OUTER
G1 F2217.3 X126.691 Y116.153 E118.72134
G1 X126.94 Y116.097 E118.73152
G1 X127.178 Y116 E118.74178
G1 X127.392 Y115.863 E118.75192
G1 X127.58 Y115.69 E118.76212
G1 X127.735 Y115.488 E118.77228
G1 X127.854 Y115.261 E118.78251
G1 X127.93 Y115.018 E118.79267
G1 X127.964 Y114.763 E118.80294
G1 X127.953 Y114.509 E118.81309
G1 X127.897 Y114.26 E118.82327
G1 X127.8 Y114.022 E118.83353
G1 X127.663 Y113.808 E118.84367
G1 X127.49 Y113.62 E118.85387
G1 X127.287 Y113.465 E118.86406
G1 X127.06 Y113.346 E118.87429
G1 X126.818 Y113.27 E118.88442
G1 X126.563 Y113.236 E118.89469
G1 X126.309 Y113.247 E118.90483
G1 X126.06 Y113.303 E118.91502
G1 X125.822 Y113.4 E118.92528
G1 X125.608 Y113.537 E118.93542
G1 X125.42 Y113.71 E118.94562
G1 X125.265 Y113.913 E118.95581
G1 X125.146 Y114.14 E118.96604
G1 X125.07 Y114.382 E118.97616
G1 X125.036 Y114.637 E118.98643
G1 X125.047 Y114.891 E118.99658
G1 X125.103 Y115.14 E119.00676
G1 X125.2 Y115.378 E119.01702
G1 X125.337 Y115.592 E119.02716
G1 X125.51 Y115.78 E119.03736
G1 X125.712 Y115.935 E119.04752
G1 X125.807 Y115.985 E119.05181
G0 F1995.5 X125.939 Y116.054
G0 X126.182 Y116.13
G0 X126.437 Y116.164
M204 S500
G0 F15000 X126.414 Y116.691
G1 F1800 E118.45181
G0 F15000 X126.38 Y115.247
G0 X114.665 Y115.235
G0 X114.755 Y116.631
M204 S800
;TYPE:WALL-INNER
G1 F1800 E119.05181
G1 F2217.3 X115.084 Y116.557 E119.06527
G1 X115.4 Y116.428 E119.07889
G1 X115.686 Y116.245 E119.09244
G1 X115.936 Y116.015 E119.106
G1 X116.141 Y115.747 E119.11947
G1 X116.299 Y115.446 E119.13303
G1 X116.4 Y115.122 E119.14658
G1 X116.445 Y114.785 E119.16015
G1 X116.431 Y114.445 E119.17373
G1 X116.357 Y114.116 E119.18719
G1 X116.228 Y113.8 E119.20081
G1 X116.045 Y113.514 E119.21436
G1 X115.815 Y113.264 E119.22792
G1 X115.547 Y113.059 E119.24139
G1 X115.246 Y112.901 E119.25496
G1 X114.922 Y112.8 E119.2685
G1 X114.585 Y112.755 E119.28207
G1 X114.245 Y112.769 E119.29565
G1 X113.916 Y112.843 E119.30911
G1 X113.6 Y112.972 E119.32274
G1 X113.314 Y113.155 E119.33629
G1 X113.064 Y113.385 E119.34985
G1 X112.859 Y113.654 E119.36335
G1 X112.701 Y113.955 E119.37691
G1 X112.6 Y114.278 E119.39042
G1 X112.555 Y114.615 E119.40399
G1 X112.569 Y114.955 E119.41757
G1 X112.643 Y115.284 E119.43103
G1 X112.772 Y115.6 E119.44465
G1 X112.955 Y115.886 E119.45821
G1 X113.185 Y116.136 E119.47176
G1 X113.453 Y116.341 E119.48523
G1 X113.754 Y116.499 E119.4988
G1 X114.078 Y116.6 E119.51234
G1 X114.091 Y116.602 E119.51287
G0 F1995.5 X114.415 Y116.645
M204 S500
G0 F15000 X114.691 Y116.153
M204 S800
;TYPE:WALL-OUTER
G1 F2217.3 X114.94 Y116.097 E119.52306
G1 X115.178 Y116 E119.53331
G1 X115.392 Y115.863 E119.54345
G1 X115.58 Y115.69 E119.55365
G1 X115.735 Y115.488 E119.56381
G1 X115.854 Y115.261 E119.57404
G1 X115.93 Y115.018 E119.58421
G1 X115.964 Y114.763 E119.59447
G1 X115.953 Y114.509 E119.60462
G1 X115.897 Y114.26 E119.61481
G1 X115.8 Y114.022 E119.62506
G1 X115.663 Y113.808 E119.63521
G1 X115.49 Y113.62 E119.6454
G1 X115.288 Y113.465 E119.65557
G1 X115.061 Y113.346 E119.66579
G1 X114.818 Y113.27 E119.67596
G1 X114.563 Y113.236 E119.68622
G1 X114.309 Y113.247 E119.69637
G1 X114.06 Y113.303 E119.70656
G1 X113.822 Y113.4 E119.71682
G1 X113.608 Y113.537 E119.72696
G1 X113.42 Y113.71 E119.73715
G1 X113.265 Y113.913 E119.74735
G1 X113.146 Y114.14 E119.75758
G1 X113.07 Y114.382 E119.7677
G1 X113.036 Y114.637 E119.77797
G1 X113.047 Y114.891 E119.78812
G1 X113.103 Y115.14 E119.7983
G1 X113.2 Y115.378 E119.80856
G1 X113.337 Y115.592 E119.8187
G1 X113.51 Y115.78 E119.8289
G1 X113.712 Y115.935 E119.83906
G1 X113.939 Y116.054 E119.84929
G1 X114.04 Y116.086 E119.85352
G0 F1995.5 X114.182 Y116.13
G0 X114.437 Y116.164
G0 X114.691 Y116.153
M204 S500
G0 F15000 X114.76 Y116.676
G1 F1800 E119.25352
G0 F15000 X114.665 Y115.235
G0 X126.848 Y114.26
G0 X128.129 Y112.9
M204 S800
;TYPE:WALL-INNER
G1 F1800 E119.85352
G1 F2217.3 X128.3 Y112.9 E119.86034
G1 X128.3 Y113.082 E119.86761
G1 X128.129 Y112.9 E119.87097
M204 S500
G0 F15000 X128.118 Y116.5
M204 S800
G1 F2217.3 X128.3 Y116.33 E119.88091
G1 X128.3 Y116.5 E119.88099
G1 X128.118 Y116.5 E119.88168
M204 S500
G1 F1800 E119.28168
G0 F15000 X124.247 Y116.249
G0 X116.77 Y116.16
G1 F1800 E119.88168
G0 F15000 X116.118 Y116.5
M204 S800
G1 F2217.3 X116.292 Y116.34 E119.89111
G1 X116.547 Y116.006 E119.90788
G1 X116.744 Y115.63 E119.92482
G1 X116.87 Y115.226 E119.94171
G1 X116.926 Y114.807 E119.95859
G1 X116.909 Y114.382 E119.97556
G1 X116.817 Y113.972 E119.99233
G1 X116.656 Y113.578 E120.00932
G1 X116.427 Y113.22 E120.02628
G1 X116.14 Y112.908 E120.0432
G1 X116.13 Y112.9 E120.04371
G1 X124.882 Y112.9 E120.39303
G1 X124.708 Y113.06 E120.40246
G1 X124.453 Y113.395 E120.41926
G1 X124.256 Y113.77 E120.43617
G1 X124.13 Y114.174 E120.45306
G1 X124.074 Y114.593 E120.46993
G1 X124.091 Y115.018 E120.48691
G1 X124.183 Y115.428 E120.50368
G1 X124.344 Y115.822 E120.52067
G1 X124.573 Y116.18 E120.53763
G1 X124.86 Y116.492 E120.55455
G1 X124.87 Y116.5 E120.55506
G1 X116.784 Y116.5 E120.87779
G0 F1995.5 X116.118 Y116.5
M204 S500
G1 F1800 E120.27779
G0 F15000 X116.77 Y116.16
G0 X114.94 Y115.048
G0 X114.047 Y115.029
G0 X112.247 Y116.249
G0 X107.24 Y116.19
G1 F1800 E120.87779
G0 F15000 X106.9 Y116.5
M204 S800
G1 F2217.3 X106.9 Y112.9 E121.02147
G1 X112.882 Y112.9 E121.26023
G1 X112.708 Y113.06 E121.26966
G1 X112.453 Y113.395 E121.28647
G1 X112.256 Y113.77 E121.30337
G1 X112.13 Y114.174 E121.32026
G1 X112.074 Y114.593 E121.33713
G1 X112.091 Y115.018 E121.35411
G1 X112.183 Y115.428 E121.37088
G1 X112.344 Y115.822 E121.38787
G1 X112.573 Y116.18 E121.40483
G1 X112.86 Y116.492 E121.42175
G1 X112.87 Y116.5 E121.42226
G1 X107.566 Y116.5 E121.63396
G0 F1995.5 X106.9 Y116.5
M204 S500
G0 F15000 X106.42 Y116.98
M204 S800
G1 F2217.3 X106.42 Y112.42 E121.81596
G1 X114.245 Y112.42 E122.12827
G1 X114.922 Y112.42 E122.15245
G1 X126.245 Y112.42 E122.60243
G1 X126.922 Y112.42 E122.62432
G1 X128.78 Y112.42 E122.69848
G1 X128.78 Y114.445 E122.7793
G1 X128.78 Y115.122 E122.80348
G1 X128.78 Y116.98 E122.87764
G1 X126.755 Y116.98 E122.95846
G1 X126.078 Y116.98 E122.97968
G1 X114.755 Y116.98 E123.43067
G1 X114.078 Y116.98 E123.45188
G1 X106.42 Y116.98 E123.75753
M204 S500
G0 F15000 X105.94 Y117.46
M204 S800
;TYPE:WALL-OUTER
G1 F2217.3 X105.94 Y111.94 E123.97785
G1 X129.26 Y111.94 E124.9086
G1 X129.26 Y117.46 E125.12891
G1 X106.606 Y117.46 E126.03308
G0 F1995.5 X105.94 Y117.46
M204 S500
G0 F15000 X107.21 Y116.19
G0 X107.52 Y116.16
G0 X107.52 Y116.308
M204 S800
;TYPE:FILL
G1 F4434.5 X107.092 Y115.566 E126.06727
M204 S500
G0 F15000 X107.24 Y115.566
G0 X111.182 Y116.16
G0 X111.182 Y116.308
M204 S800
G1 F4434.5 X111.903 Y115.06 E126.1248
M204 S500
G1 F1800 E125.5248
G0 F15000 X111.759 Y115.09
G0 X111.933 Y115.504
G0 X113.985 Y114.92
G0 X114.94 Y115.048
G0 X116.702 Y116.25
G0 X119.33 Y116.16
G1 F1800 E126.1248
G0 F15000 X119.33 Y116.308
M204 S800
G1 F4434.5 X121.187 Y113.092 E126.27302
M204 S500
G0 F15000 X121.96 Y113.092
M204 S800
G1 F4434.5 X123.818 Y116.308 E126.42126
M204 S500
G0 F15000 X123.587 Y115.873
G1 F1800 E125.82126
;MESH:NONMESH
G0 F300 X123.587 Y115.873 Z1.6
G0 F15000 X116.702 Y116.25
G0 X116.702 Y118.365
G0 X107.1 Y123.965
G0 X107.1 Y122.1
;TIME_ELAPSED:126.274866
;LAYER:5
M204 S800
;TYPE:WALL-INNER
G1 F1800 E126.42126
G1 F2413.5 X107.1 Y121.7 E126.43722
G1 X128.3 Y121.7 E127.28336
G1 X128.3 Y122.1 E127.29932
G1 X107.1 Y122.1 E128.00591
M204 S500
G0 F15000 X106.62 Y122.58
M204 S800
G1 F2413.5 X106.62 Y121.22 E128.06019
G1 X128.78 Y121.22 E128.94464
G1 X128.78 Y122.58 E128.99893
G1 X107.286 Y122.58 E129.8568
G0 F2172.2 X106.62 Y122.58
M204 S500
G0 F15000 X106.14 Y123.06
M204 S800
;TYPE:WALL-OUTER
G1 F2413.5 X106.14 Y120.74 E129.94939
G1 X129.26 Y120.74 E130.87216
G1 X129.26 Y123.06 E130.96476
G1 X106.806 Y123.06 E131.86095
G0 F2172.2 X106.14 Y123.06
M204 S500
G1 F1800 E131.26095
G0 F15000 X106.14 Y123.965
G0 X105.247 Y123.953
G0 X105.247 Y119.847
G0 X115.699 Y119.859
G0 X126.42 Y115.255
G0 X126.579 Y116.646
M204 S800
;TYPE:WALL-INNER
G1 F1800 E131.86095
G1 F2413.5 X126.922 Y116.6 E131.87476
G1 X127.244 Y116.499 E131.88823
G1 X127.546 Y116.342 E131.90181
G1 X127.815 Y116.135 E131.91536
G1 X128.049 Y115.882 E131.92911
G1 X128.263 Y115.528 E131.94562
G1 X128.382 Y115.199 E131.95959
G1 X128.446 Y114.793 E131.97599
G1 X128.43 Y114.432 E131.99042
G1 X128.304 Y113.965 E132.00972
G1 X128.142 Y113.654 E132.02372
G1 X127.935 Y113.385 E132.03726
G1 X127.686 Y113.155 E132.05079
G1 X127.4 Y112.972 E132.06434
G1 X127.084 Y112.843 E132.07797
G1 X126.765 Y112.772 E132.09101
G1 X126.573 Y112.755 E132.0987
G1 X126.236 Y112.77 E132.11217
G1 X125.759 Y112.897 E132.13187
G1 X125.385 Y113.103 E132.14891
G1 X125.068 Y113.38 E132.16571
G1 X124.859 Y113.654 E132.17947
G1 X124.701 Y113.955 E132.19303
G1 X124.6 Y114.278 E132.20654
G1 X124.555 Y114.615 E132.22011
G1 X124.57 Y114.964 E132.23405
G1 X124.697 Y115.441 E132.25376
G1 X124.903 Y115.815 E132.2708
G1 X125.179 Y116.131 E132.28754
G1 X125.454 Y116.343 E132.3014
G1 X125.821 Y116.526 E132.31777
G1 X125.922 Y116.554 E132.32195
G0 F2172.2 X126.162 Y116.618
M204 S500
G0 F15000 X126.563 Y116.164
M204 S800
;TYPE:WALL-OUTER
G1 F2413.5 X126.818 Y116.13 E132.33222
G1 X127.06 Y116.054 E132.34234
G1 X127.287 Y115.936 E132.35255
G1 X127.49 Y115.78 E132.36277
G1 X127.663 Y115.592 E132.37297
G1 X127.828 Y115.32 E132.38567
G1 X127.915 Y115.079 E132.39589
G1 X127.964 Y114.766 E132.40854
G1 X127.953 Y114.506 E132.41892
G1 X127.854 Y114.14 E132.43406
G1 X127.736 Y113.913 E132.44427
G1 X127.58 Y113.71 E132.45449
G1 X127.392 Y113.537 E132.46468
G1 X127.178 Y113.4 E132.47483
G1 X126.94 Y113.303 E132.48508
G1 X126.691 Y113.247 E132.49527
G1 X126.563 Y113.236 E132.5004
G1 X126.309 Y113.247 E132.51054
G1 X125.94 Y113.346 E132.52579
G1 X125.662 Y113.499 E132.53846
G1 X125.42 Y113.71 E132.55127
G1 X125.265 Y113.913 E132.56147
G1 X125.146 Y114.14 E132.5717
G1 X125.07 Y114.382 E132.58182
G1 X125.036 Y114.637 E132.59209
G1 X125.047 Y114.891 E132.60223
G1 X125.146 Y115.26 E132.61748
G1 X125.299 Y115.538 E132.63015
G1 X125.51 Y115.78 E132.64296
G1 X125.71 Y115.934 E132.65304
G1 X125.92 Y116.039 E132.66241
G0 F2172.2 X125.992 Y116.075
G0 X126.241 Y116.142
G0 X126.563 Y116.164
M204 S500
G0 F15000 X126.579 Y116.691
G1 F1800 E132.06241
G0 F15000 X126.42 Y115.255
G0 X114.615 Y115.248
G0 X114.579 Y116.646
M204 S800
;TYPE:WALL-INNER
G1 F1800 E132.66241
G1 F2413.5 X114.922 Y116.6 E132.67622
G1 X115.249 Y116.498 E132.68989
G1 X115.615 Y116.297 E132.70656
G1 X115.931 Y116.021 E132.7233
G1 X116.143 Y115.746 E132.73716
G1 X116.326 Y115.379 E132.75353
G1 X116.416 Y115.044 E132.76737
G1 X116.447 Y114.7 E132.78116
G1 X116.402 Y114.283 E132.7979
G1 X116.299 Y113.956 E132.81158
G1 X116.142 Y113.654 E132.82517
G1 X115.935 Y113.385 E132.83872
G1 X115.682 Y113.151 E132.85247
G1 X115.328 Y112.937 E132.86898
G1 X114.998 Y112.818 E132.88298
G1 X114.59 Y112.754 E132.89946
G1 X114.236 Y112.77 E132.91361
G1 X113.759 Y112.897 E132.93331
G1 X113.385 Y113.103 E132.95035
G1 X113.068 Y113.38 E132.96715
G1 X112.859 Y113.654 E132.98091
G1 X112.701 Y113.955 E132.99448
G1 X112.6 Y114.278 E133.00798
G1 X112.555 Y114.615 E133.02155
G1 X112.57 Y114.964 E133.03549
G1 X112.697 Y115.441 E133.0552
G1 X112.903 Y115.815 E133.07224
G1 X113.179 Y116.131 E133.08898
G1 X113.454 Y116.343 E133.10284
G1 X113.821 Y116.526 E133.11921
G1 X113.922 Y116.554 E133.12339
G0 F2172.2 X114.162 Y116.618
M204 S500
G0 F15000 X114.563 Y116.164
M204 S800
;TYPE:WALL-OUTER
G1 F2413.5 X114.818 Y116.13 E133.13366
G1 X115.06 Y116.054 E133.14378
G1 X115.338 Y115.901 E133.15645
G1 X115.58 Y115.69 E133.16926
G1 X115.734 Y115.49 E133.17934
G1 X115.875 Y115.208 E133.19192
G1 X115.942 Y114.959 E133.20221
G1 X115.965 Y114.704 E133.21243
G1 X115.93 Y114.382 E133.22536
G1 X115.854 Y114.14 E133.23548
G1 X115.736 Y113.913 E133.24569
G1 X115.58 Y113.71 E133.25591
G1 X115.392 Y113.537 E133.26611
G1 X115.12 Y113.372 E133.27881
G1 X114.879 Y113.285 E133.28903
G1 X114.563 Y113.236 E133.3018
G1 X114.309 Y113.247 E133.31194
G1 X113.94 Y113.346 E133.32719
G1 X113.662 Y113.499 E133.33986
G1 X113.42 Y113.71 E133.35267
G1 X113.265 Y113.913 E133.36287
G1 X113.146 Y114.14 E133.3731
G1 X113.07 Y114.382 E133.38322
G1 X113.036 Y114.637 E133.39349
G1 X113.047 Y114.891 E133.40363
G1 X113.146 Y115.26 E133.41888
G1 X113.299 Y115.538 E133.43155
G1 X113.51 Y115.78 E133.44436
G1 X113.71 Y115.934 E133.45444
G1 X113.92 Y116.039 E133.46381
G0 F2172.2 X113.992 Y116.075
G0 X114.241 Y116.142
G0 X114.563 Y116.164
M204 S500
G0 F15000 X114.579 Y116.691
G1 F1800 E132.86381
G0 F15000 X114.615 Y115.248
G0 X126.848 Y114.26
G0 X128.117 Y112.9
M204 S800
;TYPE:WALL-INNER
G1 F1800 E133.46381
G1 F2413.5 X128.3 Y112.9 E133.47111
G1 X128.291 Y113.06 E133.47751
G1 X128.117 Y112.9 E133.48043
M204 S500
G0 F15000 X128.14 Y116.491
M204 S800
G1 F2413.5 X128.3 Y116.318 E133.48984
G1 X128.3 Y116.5 E133.49034
G1 X128.14 Y116.491 E133.49092
M204 S500
G1 F1800 E132.89092
G0 F15000 X126.838 Y115.147
G0 X125.984 Y114.917
G0 X123.53 Y115.768
G0 X117.54 Y115.68
G1 F1800 E133.49092
G0 F15000 X117.079 Y116.02
M204 S800
G1 F2413.5 X117.228 Y115.721 E133.50425
G1 X117.364 Y115.212 E133.52528
G1 X117.411 Y114.692 E133.54612
G1 X117.346 Y114.085 E133.57048
G1 X117.189 Y113.588 E133.59129
G1 X117.081 Y113.38 E133.60064
G1 X123.919 Y113.38 E133.87356
G1 X123.811 Y113.585 E133.88281
G1 X123.66 Y114.07 E133.90308
G1 X123.593 Y114.571 E133.92326
G1 X123.616 Y115.11 E133.94479
G1 X123.799 Y115.801 E133.97332
G1 X123.92 Y116.02 E133.9833
G1 X117.745 Y116.02 E134.22976
G0 F2172.2 X117.079 Y116.02
M204 S500
G0 F15000 X117.54 Y115.72
G0 X116.112 Y116.5
M204 S800
G1 F2413.5 X116.282 Y116.351 E134.23878
G1 X116.552 Y116.002 E134.2564
G1 X116.777 Y115.55 E134.27655
G1 X116.89 Y115.128 E134.29398
G1 X116.929 Y114.696 E134.3113
G1 X116.874 Y114.184 E134.33185
G1 X116.744 Y113.772 E134.34909
G1 X116.548 Y113.395 E134.36605
G1 X116.291 Y113.06 E134.3829
G1 X116.118 Y112.9 E134.39231
G1 X124.888 Y112.9 E134.74234
G1 X124.716 Y113.05 E134.75145
G1 X124.453 Y113.395 E134.76876
G1 X124.256 Y113.77 E134.78567
G1 X124.13 Y114.174 E134.80256
G1 X124.074 Y114.593 E134.81943
G1 X124.093 Y115.037 E134.83717
G1 X124.248 Y115.621 E134.86128
G1 X124.507 Y116.092 E134.88274
G1 X124.849 Y116.482 E134.90344
G1 X124.872 Y116.5 E134.9046
G1 X116.778 Y116.5 E135.22765
G0 F2172.2 X116.112 Y116.5
M204 S500
G1 F1800 E134.62765
G0 F15000 X117.54 Y115.68
G0 X115.026 Y114.893
G0 X113.973 Y114.888
G0 X111.53 Y115.768
G0 X107.92 Y115.71
G1 F1800 E135.22765
G0 F15000 X107.58 Y116.02
M204 S800
G1 F2413.5 X107.58 Y113.38 E135.33302
G1 X111.919 Y113.38 E135.5062
G1 X111.811 Y113.585 E135.51545
G1 X111.66 Y114.07 E135.53572
G1 X111.593 Y114.571 E135.5559
G1 X111.616 Y115.11 E135.57743
G1 X111.799 Y115.801 E135.60596
G1 X111.92 Y116.02 E135.61594
G1 X108.246 Y116.02 E135.76258
G0 F2172.2 X107.58 Y116.02
M204 S500
G0 F15000 X107.1 Y116.5
M204 S800
G1 F2413.5 X107.1 Y112.9 E135.90627
G1 X112.888 Y112.9 E136.13728
G1 X112.716 Y113.05 E136.14639
G1 X112.453 Y113.395 E136.1637
G1 X112.256 Y113.77 E136.18061
G1 X112.13 Y114.174 E136.1975
G1 X112.074 Y114.593 E136.21437
G1 X112.093 Y115.037 E136.23211
G1 X112.248 Y115.621 E136.25622
G1 X112.507 Y116.092 E136.27768
G1 X112.849 Y116.482 E136.29838
G1 X112.872 Y116.5 E136.29954
G1 X107.766 Y116.5 E136.50334
G0 F2172.2 X107.1 Y116.5
M204 S500
G0 F15000 X106.62 Y116.98
M204 S800
G1 F2413.5 X106.62 Y112.42 E136.68534
G1 X114.236 Y112.42 E136.98931
G1 X114.998 Y112.42 E137.01421
G1 X126.236 Y112.42 E137.46181
G1 X127.084 Y112.42 E137.49281
G1 X128.78 Y112.42 E137.5605
G1 X128.78 Y114.432 E137.64081
G1 X128.78 Y115.199 E137.66498
G1 X128.78 Y116.98 E137.73607
G1 X126.579 Y116.98 E137.82391
G1 X125.821 Y116.98 E137.84775
G1 X114.579 Y116.98 E138.29645
G1 X113.821 Y116.98 E138.32029
G1 X106.62 Y116.98 E138.60769
M204 S500
G0 F15000 X106.14 Y117.46
M204 S800
;TYPE:WALL-OUTER
G1 F2413.5 X106.14 Y111.94 E138.82801
G1 X129.26 Y111.94 E139.75078
G1 X129.26 Y117.46 E139.97109
G1 X106.806 Y117.46 E140.86728
G0 F2172.2 X106.14 Y117.46
M204 S500
G1 F1800 E140.26728
G0 F15000 X106.14 Y118.365
G0 X115.008 Y114.937
G0 X117.476 Y115.768
G0 X119.771 Y115.68
G1 F1800 E140.86728
G0 F15000 X119.771 Y115.828
M204 S800
;TYPE:FILL
G1 F4827.1 X121.073 Y113.572 E140.97124
M204 S500
G0 F15000 X121.073 Y113.72
G0 X122.075 Y113.72
G0 X122.075 Y113.572
M204 S800
G1 F4827.1 X123.378 Y115.828 E141.07522
M204 S500
G0 F15000 X122.951 Y115.413
G1 F1800 E140.47522
;MESH:NONMESH
G0 F300 X122.951 Y115.413 Z1.8
G0 F15000 X117.476 Y115.768
G0 X107.3 Y119.835
G0 X107.3 Y122.1
;TIME_ELAPSED:143.547501
;LAYER:6
M204 S800
;TYPE:WALL-INNER
;MESH:RS_Fan-Housing-Clamp-Rev1.stl
G1 F1800 E141.07522
G1 F2224.5 X107.3 Y121.7 E141.09119
G1 X128.3 Y121.7 E141.92934
G1 X128.3 Y122.1 E141.94531
G1 X107.3 Y122.1 E142.64523
M204 S500
G0 F15000 X106.82 Y122.58
M204 S800
G1 F2224.5 X106.82 Y121.22 E142.69951
G1 X128.78 Y121.22 E143.57598
G1 X128.78 Y122.58 E143.63026
G1 X107.486 Y122.58 E144.48015
G0 F2002.1 X106.82 Y122.58
M204 S500
G0 F15000 X106.34 Y123.06
M204 S800
;TYPE:WALL-OUTER
G1 F2224.5 X106.34 Y120.74 E144.57275
G1 X129.26 Y120.74 E145.48753
G1 X129.26 Y123.06 E145.58013
G1 X107.006 Y123.06 E146.46834
G0 F2002.1 X106.34 Y123.06
M204 S500
G1 F1800 E145.86834
G0 F15000 X106.34 Y123.965
G0 X105.447 Y123.953
G0 X105.447 Y119.847
G0 X115.778 Y119.858
G0 X126.38 Y115.247
M204 S800
;TYPE:WALL-INNER
G1 F1800 E146.46834
G1 F2224.5 X126.755 Y116.631 E146.48192
G1 X127.084 Y116.557 E146.49538
G1 X127.4 Y116.428 E146.509
G1 X127.686 Y116.245 E146.52255
G1 X127.936 Y116.015 E146.53611
G1 X128.141 Y115.746 E146.54961
G1 X128.299 Y115.445 E146.56318
G1 X128.4 Y115.122 E146.57668
G1 X128.445 Y114.785 E146.59025
G1 X128.431 Y114.445 E146.60383
G1 X128.357 Y114.116 E146.61729
G1 X128.228 Y113.8 E146.63092
G1 X128.045 Y113.514 E146.64447
G1 X127.815 Y113.264 E146.65803
G1 X127.546 Y113.059 E146.67153
G1 X127.245 Y112.901 E146.68509
G1 X126.922 Y112.8 E146.6986
G1 X126.585 Y112.755 E146.71217
G1 X126.245 Y112.769 E146.72575
G1 X125.916 Y112.843 E146.73921
G1 X125.6 Y112.972 E146.75283
G1 X125.314 Y113.155 E146.76639
G1 X125.064 Y113.385 E146.77994
G1 X124.859 Y113.654 E146.79344
G1 X124.701 Y113.955 E146.80701
G1 X124.6 Y114.278 E146.82052
G1 X124.555 Y114.615 E146.83409
G1 X124.569 Y114.955 E146.84767
G1 X124.643 Y115.284 E146.86113
G1 X124.772 Y115.6 E146.87475
G1 X124.955 Y115.886 E146.8883
G1 X125.185 Y116.136 E146.90186
G1 X125.454 Y116.341 E146.91536
G1 X125.755 Y116.499 E146.92893
G1 X125.766 Y116.503 E146.9294
G0 F2002.1 X126.078 Y116.6
M204 S500
M204 S800
;TYPE:WALL-OUTER
G1 F2224.5 X126.691 Y116.153 E146.93954
G1 X126.94 Y116.097 E146.94973
G1 X127.178 Y116 E146.95999
G1 X127.392 Y115.863 E146.97013
G1 X127.58 Y115.69 E146.98032
G1 X127.735 Y115.487 E146.99052
G1 X127.854 Y115.26 E147.00075
G1 X127.93 Y115.018 E147.01087
G1 X127.964 Y114.763 E147.02114
G1 X127.953 Y114.509 E147.03129
G1 X127.897 Y114.26 E147.04147
G1 X127.8 Y114.022 E147.05173
G1 X127.663 Y113.808 E147.06187
G1 X127.49 Y113.62 E147.07207
G1 X127.287 Y113.465 E147.08226
G1 X127.06 Y113.346 E147.09249
G1 X126.818 Y113.27 E147.10262
G1 X126.563 Y113.236 E147.11288
G1 X126.309 Y113.247 E147.12303
G1 X126.06 Y113.303 E147.13322
G1 X125.822 Y113.4 E147.14348
G1 X125.608 Y113.537 E147.15362
G1 X125.42 Y113.71 E147.16381
G1 X125.265 Y113.913 E147.17401
G1 X125.146 Y114.14 E147.18424
G1 X125.07 Y114.382 E147.19436
G1 X125.036 Y114.637 E147.20463
G1 X125.047 Y114.891 E147.21478
G1 X125.103 Y115.14 E147.22496
G1 X125.2 Y115.378 E147.23522
G1 X125.337 Y115.592 E147.24536
G1 X125.51 Y115.78 E147.25556
G1 X125.713 Y115.935 E147.26575
G1 X125.807 Y115.985 E147.27
G0 F2002.1 X125.94 Y116.054
G0 X126.182 Y116.13
M204 S500
G1 F1800 E146.67
M204 S800
;TYPE:WALL-INNER
G1 F1800 E147.27
G1 F2224.5 X115.084 Y116.557 E147.28346
G1 X115.4 Y116.428 E147.29708
G1 X115.686 Y116.245 E147.31064
G1 X115.936 Y116.015 E147.32419
G1 X116.141 Y115.746 E147.33769
G1 X116.299 Y115.445 E147.35126
G1 X116.4 Y115.122 E147.36477
G1 X116.445 Y114.785 E147.37834
G1 X116.431 Y114.445 E147.39192
G1 X116.357 Y114.116 E147.40538
G1 X116.228 Y113.8 E147.419
G1 X116.045 Y113.514 E147.43255
G1 X115.815 Y113.264 E147.44611
G1 X115.546 Y113.059 E147.45961
G1 X115.245 Y112.901 E147.47318
G1 X114.922 Y112.8 E147.48669
G1 X114.585 Y112.755 E147.50026
G1 X114.245 Y112.769 E147.51384
G1 X113.916 Y112.843 E147.5273
G1 X113.6 Y112.972 E147.54092
G1 X113.314 Y113.155 E147.55447
G1 X113.064 Y113.385 E147.56803
G1 X112.859 Y113.654 E147.58153
G1 X112.701 Y113.955 E147.5951
G1 X112.6 Y114.278 E147.6086
G1 X112.555 Y114.615 E147.62217
G1 X112.569 Y114.955 E147.63575
G1 X112.643 Y115.284 E147.64921
G1 X112.772 Y115.6 E147.66284
G1 X112.955 Y115.886 E147.67639
G1 X113.185 Y116.136 E147.68995
G1 X113.454 Y116.341 E147.70345
G1 X113.755 Y116.499 E147.71701
G1 X114.078 Y116.6 E147.73052
G1 X114.091 Y116.602 E147.73105
G0 F2002.1 X114.415 Y116.645
M204 S500
M204 S800
;TYPE:WALL-OUTER
G1 F2224.5 X114.94 Y116.097 E147.74123
G1 X115.178 Y116 E147.75149
G1 X115.392 Y115.863 E147.76163
G1 X115.58 Y115.69 E147.77183
G1 X115.735 Y115.487 E147.78202
G1 X115.854 Y115.26 E147.79225
G1 X115.93 Y115.018 E147.80238
G1 X115.964 Y114.763 E147.81264
G1 X115.953 Y114.509 E147.82279
G1 X115.897 Y114.26 E147.83298
G1 X115.8 Y114.022 E147.84323
G1 X115.663 Y113.808 E147.85338
G1 X115.49 Y113.62 E147.86357
G1 X115.287 Y113.465 E147.87377
G1 X115.06 Y113.346 E147.884
G1 X114.818 Y113.27 E147.89412
G1 X114.563 Y113.236 E147.90439
G1 X114.309 Y113.247 E147.91453
G1 X114.06 Y113.303 E147.92472
G1 X113.822 Y113.4 E147.93498
G1 X113.608 Y113.537 E147.94512
G1 X113.42 Y113.71 E147.95532
G1 X113.265 Y113.913 E147.96551
G1 X113.146 Y114.14 E147.97574
G1 X113.07 Y114.382 E147.98586
G1 X113.036 Y114.637 E147.99613
G1 X113.047 Y114.891 E148.00628
G1 X113.103 Y115.14 E148.01647
G1 X113.2 Y115.378 E148.02672
G1 X113.337 Y115.592 E148.03687
G1 X113.51 Y115.78 E148.04706
G1 X113.713 Y115.935 E148.05726
G1 X113.94 Y116.054 E148.06749
G1 X114.04 Y116.086 E148.07168
G0 F2002.1 X114.182 Y116.13
M204 S500
G1 F1800 E147.47168
G0 X126.848 Y114.26
G0 X128.129 Y112.9
M204 S800
;TYPE:WALL-INNER
G1 F1800 E148.07168
G1 F2224.5 X128.3 Y112.9 E148.0785
G1 X128.3 Y113.082 E148.08577
G1 X128.129 Y112.9 E148.08912
M204 S500
M204 S800
G1 F2224.5 X128.3 Y116.329 E148.09909
G1 X128.3 Y116.5 E148.09919
G1 X128.118 Y116.5 E148.09987
M204 S500
G1 F1800 E147.49987
G0 X116.77 Y116.16
G1 F1800 E148.09987
M204 S800
G1 F2224.5 X116.292 Y116.34 E148.1093
G1 X116.547 Y116.005 E148.1261
G1 X116.744 Y115.63 E148.14301
G1 X116.87 Y115.226 E148.1599
G1 X116.926 Y114.807 E148.17677
G1 X116.909 Y114.382 E148.19375
G1 X116.817 Y113.972 E148.21052
G1 X116.656 Y113.578 E148.22751
G1 X116.427 Y113.22 E148.24447
G1 X116.14 Y112.908 E148.26139
G1 X116.129 Y112.9 E148.26193
G1 X124.882 Y112.9 E148.61128
G1 X124.708 Y113.06 E148.62072
G1 X124.453 Y113.395 E148.63752
G1 X124.256 Y113.77 E148.65443
G1 X124.13 Y114.174 E148.67132
G1 X124.074 Y114.593 E148.68819
G1 X124.091 Y115.018 E148.70517
G1 X124.183 Y115.428 E148.72194
G1 X124.344 Y115.822 E148.73892
G1 X124.573 Y116.18 E148.75589
G1 X124.86 Y116.492 E148.77281
G1 X124.871 Y116.5 E148.77335
G1 X116.784 Y116.5 E149.09612
G0 F2002.1 X116.118 Y116.5
M204 S500
G1 F1800 E148.49612
G0 X114.94 Y115.048
G0 X114.06 Y115.048
G0 X107.64 Y116.19
G1 F1800 E149.09612
G0 F15000 X107.3 Y116.5
M204 S800
G1 F2224.5 X107.3 Y112.9 E149.2398
G1 X112.882 Y112.9 E149.46259
G1 X112.708 Y113.06 E149.47203
G1 X112.453 Y113.395 E149.48883
G1 X112.256 Y113.77 E149.50574
G1 X112.13 Y114.174 E149.52263
G1 X112.074 Y114.593 E149.5395
G1 X112.091 Y115.018 E149.55648
G1 X112.183 Y115.428 E149.57325
G1 X112.344 Y115.822 E149.59023
G1 X112.573 Y116.18 E149.6072
G1 X112.86 Y116.492 E149.62412
G1 X112.871 Y116.5 E149.62466
G1 X107.966 Y116.5 E149.82043
G0 F2002.1 X107.3 Y116.5
M204 S500
G0 F15000 X106.82 Y116.98
M204 S800
G1 F2224.5 X106.82 Y112.42 E150.00243
G1 X114.245 Y112.42 E150.29877
G1 X114.922 Y112.42 E150.32296
G1 X126.245 Y112.42 E150.77395
G1 X126.922 Y112.42 E150.79813
G1 X128.78 Y112.42 E150.87229
G1 X128.78 Y114.445 E150.95311
G1 X128.78 Y115.122 E150.97729
G1 X128.78 Y116.98 E151.05145
G1 X126.755 Y116.98 E151.13227
G1 X126.078 Y116.98 E151.15348
G1 X114.755 Y116.98 E151.60447
G1 X114.078 Y116.98 E151.62569
G1 X106.82 Y116.98 E151.91537
M204 S500
G0 F15000 X106.34 Y117.46
M204 S800
;TYPE:WALL-OUTER
G1 F2224.5 X106.34 Y111.94 E152.13569
G1 X129.26 Y111.94 E153.05047
G1 X129.26 Y117.46 E153.27079
G1 X107.006 Y117.46 E154.159
G0 F2002.1 X106.34 Y117.46
M204 S500
G0 F15000 X107.61 Y116.19
G0 X107.492 Y116.228
M204 S800
;TYPE:FILL
G1 F4449.1 X112.301 Y116.228 E154.35093
M204 S500
G0 F15000 X111.509 Y116.308
M204 S800
G1 F4449.1 X111.994 Y115.468 E154.38965
M204 S500
G1 F1800 E153.78965
G0 F15000 X111.85 Y115.498
G0 X114.06 Y115.048
G0 X114.94 Y115.048
G0 X116.702 Y116.25
G1 F1800 E154.38965
G0 F15000 X116.648 Y116.228
M204 S800
G1 F4449.1 X124.301 Y116.228 E154.69509
M204 S500
G0 F15000 X123.491 Y116.308
M204 S800
G1 F4449.1 X121.634 Y113.092 E154.84331
G1 X121.514 Y113.092
G1 X119.657 Y116.308 E154.99153
M204 S500
G0 F15000 X119.657 Y115.78
G1 F1800 E154.39153
;MESH:NONMESH
G0 F300 X119.657 Y115.78 Z1.92
G0 X107.42 Y123.965
G0 X107.42 Y122.1
;TIME_ELAPSED:160.482185
;LAYER:7
M204 S800
;TYPE:WALL-INNER
G1 F1800 E154.99153
G1 F2198.4 X107.42 Y121.7 E155.00111
G1 X128.3 Y121.7 E155.50113
G1 X128.3 Y122.1 E155.51071
G1 X107.42 Y122.1 E155.92826
M204 S500
G0 F15000 X106.94 Y122.58
M204 S800
G1 F2198.4 X106.94 Y121.22 E155.96083
G1 X128.78 Y121.22 E156.48384
G1 X128.78 Y122.58 E156.51641
G1 X108.05 Y122.58 E157.01284
G0 F1978.5 X106.94 Y122.58
M204 S500
G0 F15000 X106.46 Y123.06
M204 S800
;TYPE:WALL-OUTER
G1 F2198.4 X106.46 Y120.74 E157.06839
G1 X129.26 Y120.74 E157.61439
G1 X129.26 Y123.06 E157.66995
G1 X107.57 Y123.06 E158.18937
G0 F1978.5 X106.46 Y123.06
M204 S500
G1 F1800 E157.58937
G0 F15000 X106.46 Y123.965
G0 X105.567 Y123.953
G0 X105.567 Y119.847
G0 X115.039 Y119.857
G0 X127.686 Y113.804
G0 X128.78 Y112.954
M204 S800
;TYPE:WALL-INNER
G1 F1800 E158.18937
G1 F2198.4 X128.525 Y112.666 E158.19858
G1 X128.246 Y112.42 E158.20749
G1 X128.78 Y112.42 E158.21281
G1 X128.78 Y112.954 E158.21805
M204 S500
G1 F1800 E157.61805
G0 F15000 X127.757 Y113.909
G0 X127.709 Y115.563
G0 X128.78 Y116.446
M204 S800
G1 F1800 E158.21805
G1 F2198.4 X128.78 Y116.98 E158.23083
G1 X128.246 Y116.98 E158.24362
G1 X128.534 Y116.725 E158.24633
G1 X128.78 Y116.446 E158.24881
M204 S500
G1 F1800 E157.64881
G0 F15000 X127.692 Y115.588
G0 X125.599 Y113.518
G0 X124.754 Y112.42
M204 S800
G1 F1800 E158.24881
G1 F2198.4 X124.466 Y112.675 E158.25802
G1 X124.218 Y112.956 E158.267
G1 X124.014 Y113.263 E158.27582
G1 X123.844 Y113.61 E158.28508
G1 X123.725 Y113.964 E158.29402
G1 X123.653 Y114.331 E158.30298
G1 X123.629 Y114.706 E158.31198
G1 X123.654 Y115.083 E158.32102
G1 X123.728 Y115.449 E158.32997
G1 X123.85 Y115.803 E158.33893
G1 X124.016 Y116.14 E158.34793
G1 X124.225 Y116.453 E158.35694
G1 X124.475 Y116.734 E158.36595
G1 X124.754 Y116.98 E158.37486
G1 X116.246 Y116.98 E158.5786
G1 X116.534 Y116.725 E158.58781
G1 X116.782 Y116.444 E158.59679
G1 X116.986 Y116.137 E158.60561
G1 X117.156 Y115.79 E158.61487
G1 X117.275 Y115.436 E158.62381
G1 X117.347 Y115.069 E158.63277
G1 X117.371 Y114.694 E158.64177
G1 X117.346 Y114.317 E158.65081
G1 X117.272 Y113.951 E158.65976
G1 X117.15 Y113.597 E158.66872
G1 X116.984 Y113.26 E158.67772
G1 X116.775 Y112.947 E158.68673
G1 X116.525 Y112.666 E158.69574
G1 X116.246 Y112.42 E158.70465
G1 X123.644 Y112.42 E158.88181
G0 F1978.5 X124.754 Y112.42
M204 S500
G0 F15000 X122.554 Y113.632
G0 X123.679 Y112.9
M204 S800
G1 F2198.4 X123.597 Y113.024 E158.88537
G1 X123.399 Y113.427 E158.89612
G1 X123.26 Y113.841 E158.90658
G1 X123.176 Y114.269 E158.91702
G1 X123.148 Y114.707 E158.92753
G1 X123.177 Y115.147 E158.93809
G1 X123.264 Y115.575 E158.94855
G1 X123.406 Y115.988 E158.95901
G1 X123.599 Y116.38 E158.96947
G1 X123.679 Y116.5 E158.97293
G1 X117.321 Y116.5 E159.12519
G1 X117.403 Y116.376 E159.12875
G1 X117.601 Y115.973 E159.1395
G1 X117.74 Y115.559 E159.14996
G1 X117.824 Y115.131 E159.1604
G1 X117.852 Y114.693 E159.17091
G1 X117.823 Y114.253 E159.18147
G1 X117.736 Y113.825 E159.19193
G1 X117.594 Y113.412 E159.20239
G1 X117.401 Y113.02 E159.21285
G1 X117.321 Y112.9 E159.21631
G1 X122.569 Y112.9 E159.34198
G0 F1978.5 X123.679 Y112.9
M204 S500
G0 F15000 X122.908 Y113.38
M204 S800
G1 F2198.4 X122.795 Y113.718 E159.35052
G1 X122.699 Y114.207 E159.36245
G1 X122.667 Y114.707 E159.37445
G1 X122.7 Y115.211 E159.38654
G1 X122.8 Y115.701 E159.39852
G1 X122.909 Y116.02 E159.40659
G1 X118.092 Y116.02 E159.52195
G1 X118.205 Y115.682 E159.53048
G1 X118.301 Y115.193 E159.54241
G1 X118.333 Y114.693 E159.55441
G1 X118.3 Y114.189 E159.56651
G1 X118.2 Y113.699 E159.57848
G1 X118.091 Y113.38 E159.58656
G1 X121.823 Y113.38 E159.67593
G0 F1978.5 X122.908 Y113.38
M204 S500
G1 F1800 E159.07593
G0 F15000 X122.492 Y113.72
G0 X122.406 Y114.713
G0 X125.015 Y114.758
G0 X126.361 Y116.179
G0 X126.505 Y117.09
M204 S800
;TYPE:WALL-OUTER
G1 F1800 E159.67593
G1 F2198.4 X126.819 Y117.069 E159.68346
G1 X127.123 Y117.008 E159.69089
G1 X127.418 Y116.906 E159.69836
G1 X127.7 Y116.767 E159.70589
G1 X127.959 Y116.594 E159.71335
G1 X128.193 Y116.386 E159.72085
G1 X128.4 Y116.151 E159.72835
G1 X128.569 Y115.897 E159.73565
G1 X128.711 Y115.607 E159.74339
G1 X128.81 Y115.313 E159.75082
G1 X128.87 Y115.007 E159.75828
G1 X128.89 Y114.695 E159.76577
G1 X128.869 Y114.381 E159.77331
G1 X128.808 Y114.077 E159.78073
G1 X128.706 Y113.782 E159.78821
G1 X128.567 Y113.5 E159.79574
G1 X128.394 Y113.241 E159.80319
G1 X128.186 Y113.007 E159.81069
G1 X127.951 Y112.8 E159.81819
G1 X127.697 Y112.631 E159.8255
G1 X127.407 Y112.489 E159.83323
G1 X127.113 Y112.39 E159.84066
G1 X126.807 Y112.33 E159.84813
G1 X126.495 Y112.31 E159.85561
G1 X126.181 Y112.331 E159.86315
G1 X125.877 Y112.392 E159.87057
G1 X125.582 Y112.494 E159.87805
G1 X125.3 Y112.633 E159.88558
G1 X125.041 Y112.806 E159.89304
G1 X124.807 Y113.014 E159.90053
G1 X124.6 Y113.249 E159.90803
G1 X124.431 Y113.503 E159.91534
G1 X124.289 Y113.793 E159.92307
G1 X124.19 Y114.087 E159.9305
G1 X124.13 Y114.393 E159.93797
G1 X124.11 Y114.705 E159.94546
G1 X124.131 Y115.019 E159.95299
G1 X124.192 Y115.323 E159.96042
G1 X124.294 Y115.618 E159.96789
G1 X124.433 Y115.9 E159.97542
G1 X124.606 Y116.159 E159.98288
G1 X124.814 Y116.393 E159.99038
G1 X125.049 Y116.6 E159.99788
G1 X125.303 Y116.769 E160.00518
G1 X125.457 Y116.844 E160.00928
G0 F1978.5 X125.593 Y116.911
G0 X125.887 Y117.01
G0 X126.193 Y117.07
G0 X126.505 Y117.09
M204 S500
G1 F1800 E159.40928
G0 F15000 X126.322 Y116.175
G0 X113.084 Y115.148
G0 X110.557 Y115.768
G1 F1800 E160.00928
G0 F15000 X110.909 Y116.02
M204 S800
;TYPE:WALL-INNER
G1 F2198.4 X107.9 Y116.02 E160.08134
G1 X107.9 Y113.38 E160.14456
G1 X110.908 Y113.38 E160.2166
G1 X110.795 Y113.718 E160.22513
G1 X110.699 Y114.207 E160.23706
G1 X110.667 Y114.707 E160.24906
G1 X110.7 Y115.211 E160.26116
G1 X110.744 Y115.427 E160.26644
G0 F1978.5 X110.8 Y115.701
G0 X110.909 Y116.02
M204 S500
G0 F15000 X111.406 Y115.988
M204 S800
G1 F2198.4 X111.599 Y116.38 E160.2769
G1 X111.679 Y116.5 E160.28035
G1 X107.42 Y116.5 E160.38235
G1 X107.42 Y112.9 E160.46856
G1 X111.679 Y112.9 E160.57055
G1 X111.597 Y113.024 E160.57411
G1 X111.399 Y113.427 E160.58486
G1 X111.26 Y113.841 E160.59532
G1 X111.176 Y114.269 E160.60576
G1 X111.148 Y114.707 E160.61627
G1 X111.162 Y114.909 E160.62112
G0 F1978.5 X111.177 Y115.147
G0 X111.264 Y115.575
G0 X111.406 Y115.988
M204 S500
G0 F15000 X111.85 Y115.803
M204 S800
G1 F2198.4 X112.016 Y116.14 E160.63012
G1 X112.225 Y116.453 E160.63913
G1 X112.475 Y116.734 E160.64814
G1 X112.754 Y116.98 E160.65705
G1 X106.94 Y116.98 E160.79628
G1 X106.94 Y112.42 E160.90548
G1 X112.754 Y112.42 E161.0447
G1 X112.466 Y112.675 E161.05392
G1 X112.218 Y112.956 E161.06289
G1 X112.014 Y113.263 E161.07172
G1 X111.844 Y113.61 E161.08097
G1 X111.725 Y113.964 E161.08992
G1 X111.653 Y114.331 E161.09887
G1 X111.629 Y114.706 E161.10787
G1 X111.63 Y114.72 E161.10821
G0 F1978.5 X111.654 Y115.083
G0 X111.728 Y115.449
G0 X111.85 Y115.803
M204 S500
G1 F1800 E160.50821
G0 F15000 X110.458 Y115.723
G0 X114.361 Y116.179
G0 X114.505 Y117.09
M204 S800
;TYPE:WALL-OUTER
G1 F1800 E161.10821
G1 F2198.4 X114.819 Y117.069 E161.11574
G1 X115.123 Y117.008 E161.12317
G1 X115.418 Y116.906 E161.13064
G1 X115.7 Y116.767 E161.13817
G1 X115.959 Y116.594 E161.14563
G1 X116.193 Y116.386 E161.15313
G1 X116.4 Y116.151 E161.16063
G1 X116.569 Y115.897 E161.16793
G1 X116.711 Y115.607 E161.17567
G1 X116.81 Y115.313 E161.18309
G1 X116.87 Y115.007 E161.19056
G1 X116.89 Y114.695 E161.19805
G1 X116.869 Y114.381 E161.20559
G1 X116.808 Y114.077 E161.21301
G1 X116.706 Y113.782 E161.22049
G1 X116.567 Y113.5 E161.22801
G1 X116.394 Y113.241 E161.23547
G1 X116.186 Y113.007 E161.24297
G1 X115.951 Y112.8 E161.25047
G1 X115.697 Y112.631 E161.25778
G1 X115.407 Y112.489 E161.26551
G1 X115.113 Y112.39 E161.27294
G1 X114.807 Y112.33 E161.2804
G1 X114.495 Y112.31 E161.28789
G1 X114.181 Y112.331 E161.29543
G1 X113.877 Y112.392 E161.30285
G1 X113.582 Y112.494 E161.31033
G1 X113.3 Y112.633 E161.31786
G1 X113.041 Y112.806 E161.32532
G1 X112.807 Y113.014 E161.33281
G1 X112.6 Y113.249 E161.34031
G1 X112.431 Y113.503 E161.34762
G1 X112.289 Y113.793 E161.35535
G1 X112.19 Y114.087 E161.36278
G1 X112.13 Y114.393 E161.37025
G1 X112.11 Y114.705 E161.37773
G1 X112.131 Y115.019 E161.38527
G1 X112.192 Y115.323 E161.3927
G1 X112.294 Y115.618 E161.40017
G1 X112.433 Y115.9 E161.4077
G1 X112.606 Y116.159 E161.41516
G1 X112.814 Y116.393 E161.42266
G1 X113.049 Y116.6 E161.43015
G1 X113.303 Y116.769 E161.43746
G1 X113.457 Y116.844 E161.44156
G0 F1978.5 X113.593 Y116.911
G0 X113.887 Y117.01
G0 X114.193 Y117.07
G0 X114.505 Y117.09
M204 S500
G1 F1800 E160.84156
G0 F15000 X114.322 Y116.175
G0 X106.46 Y118.365
G0 X106.46 Y117.46
M204 S800
G1 F1800 E161.44156
G1 F2198.4 X106.46 Y111.94 E161.57375
G1 X129.26 Y111.94 E162.11975
G1 X129.26 Y117.46 E162.25194
G1 X107.57 Y117.46 E162.77136
G0 F1978.5 X106.46 Y117.46
M204 S500
G1 F1800 E162.17136
G0 F15000 X106.46 Y118.365
G0 X115.921 Y115.128
G0 X118.446 Y115.768
G0 X120.032 Y115.68
G1 F1800 E162.77136
G0 F15000 X120.032 Y115.828
M204 S800
;TYPE:FILL
G1 F4396.7 X121.335 Y113.572 E162.83375
M204 S500
G0 F15000 X121.813 Y113.572
M204 S800
G1 F4396.7 X122.474 Y114.716 E162.86539
M204 S500
G0 F15000 X121.947 Y114.751
G1 F1800 E162.26539
;MESH:NONMESH
G0 F300 X121.947 Y114.751 Z2.04
G0 F15000 X118.446 Y115.768
G0 X115.898 Y115.25
G0 X114.67 Y118.365
G0 X114.67 Y118.05
;TIME_ELAPSED:177.453151
;LAYER:8
M204 S800
;TYPE:WALL-INNER
G1 F1800 E162.86539
G1 F2869.9 X115.229 Y117.974 E162.87889
G1 X115.664 Y117.844 E162.88977
G1 X116.062 Y117.664 E162.90023
G1 X116.433 Y117.439 E162.91062
G1 X116.772 Y117.165 E162.92106
G1 X117.154 Y116.75 E162.93456
G1 X117.416 Y116.355 E162.94591
G1 X117.647 Y115.855 E162.9591
G1 X117.776 Y115.408 E162.97025
G1 X117.839 Y114.977 E162.98068
G1 X117.85 Y114.53 E162.99138
G1 X117.774 Y113.971 E163.00489
G1 X117.644 Y113.536 E163.01577
G1 X117.464 Y113.138 E163.02623
G1 X117.32 Y112.9 E163.03289
G1 X123.68 Y112.9 E163.18519
G1 X123.584 Y113.045 E163.18936
G1 X123.353 Y113.545 E163.20255
G1 X123.224 Y113.992 E163.21369
G1 X123.161 Y114.423 E163.22412
G1 X123.15 Y114.87 E163.23483
G1 X123.226 Y115.429 E163.24834
G1 X123.356 Y115.864 E163.25921
G1 X123.536 Y116.262 E163.26967
G1 X123.761 Y116.633 E163.28006
G1 X124.035 Y116.972 E163.2905
G1 X124.181 Y117.106 E163.29524
G1 X124.096 Y117.165 E163.29542
G1 X123.765 Y117.497 E163.30665
G1 X123.502 Y117.873 E163.31764
G1 X123.3 Y118.304 E163.32904
G1 X123.17 Y118.844 E163.34234
G1 X123.149 Y119.314 E163.35361
G1 X123.207 Y119.771 E163.36464
G1 X123.352 Y120.23 E163.37617
G1 X123.625 Y120.725 E163.3897
G1 X124.004 Y121.156 E163.40345
G1 X124.46 Y121.491 E163.417
G1 X124.904 Y121.7 E163.42875
G1 X125.444 Y121.83 E163.44205
G1 X125.914 Y121.851 E163.45332
G1 X126.371 Y121.793 E163.46435
G1 X126.83 Y121.648 E163.47587
G1 X127.325 Y121.375 E163.48941
G1 X127.756 Y120.996 E163.50316
G1 X128.094 Y120.537 E163.51681
G1 X128.3 Y120.096 E163.52846
G1 X128.3 Y122.1 E163.57645
G1 X126.371 Y122.1 E163.62265
G1 X125.444 Y122.1 E163.63789
G1 X124.904 Y122.1 E163.64691
G1 X107.54 Y122.1 E164.06273
G1 X107.541 Y112.9 E164.28304
G1 X111.68 Y112.9 E164.38216
G1 X111.584 Y113.045 E164.38632
G1 X111.353 Y113.545 E164.39951
G1 X111.224 Y113.992 E164.41066
G1 X111.161 Y114.423 E164.42109
G1 X111.15 Y114.87 E164.43179
G1 X111.226 Y115.429 E164.4453
G1 X111.356 Y115.864 E164.45618
G1 X111.536 Y116.262 E164.46664
G1 X111.761 Y116.633 E164.47703
G1 X112.035 Y116.972 E164.48747
G1 X112.45 Y117.354 E164.50097
G1 X112.845 Y117.616 E164.51232
G1 X113.345 Y117.847 E164.52551
G1 X113.573 Y117.913 E164.5312
G0 F2582.9 X113.792 Y117.976
G0 X114.223 Y118.039
G0 X114.67 Y118.05
M204 S500
G0 F15000 X114.643 Y117.569
M204 S800
G1 F2869.9 X115.127 Y117.503 E164.5429
G1 X115.496 Y117.393 E164.55212
G1 X115.838 Y117.239 E164.5611
G1 X116.156 Y117.045 E164.57002
G1 X116.443 Y116.814 E164.57884
G1 X116.775 Y116.453 E164.59059
G1 X116.996 Y116.12 E164.60016
G1 X117.196 Y115.687 E164.61158
G1 X117.306 Y115.306 E164.62108
G1 X117.36 Y114.936 E164.63003
G1 X117.369 Y114.557 E164.63911
G1 X117.303 Y114.073 E164.65081
G1 X117.193 Y113.704 E164.66003
G1 X117.039 Y113.362 E164.66901
G1 X116.845 Y113.044 E164.67793
G1 X116.614 Y112.757 E164.68675
G1 X116.253 Y112.425 E164.6985
G1 X116.245 Y112.42 E164.69872
G1 X124.77 Y112.42 E164.90287
G1 X124.56 Y112.582 E164.90923
G1 X124.225 Y112.947 E164.92109
G1 X124.004 Y113.28 E164.93066
G1 X123.804 Y113.713 E164.94208
G1 X123.694 Y114.094 E164.95158
G1 X123.64 Y114.464 E164.96053
G1 X123.631 Y114.843 E164.96961
G1 X123.697 Y115.327 E164.98131
G1 X123.807 Y115.696 E164.99053
G1 X123.961 Y116.038 E164.99951
G1 X124.155 Y116.356 E165.00843
G1 X124.386 Y116.643 E165.01726
G1 X124.747 Y116.975 E165.029
G1 X125.037 Y117.168 E165.03734
G1 X124.712 Y117.32 E165.04121
G1 X124.406 Y117.534 E165.05015
G1 X124.134 Y117.806 E165.05937
G1 X123.919 Y118.114 E165.06836
G1 X123.755 Y118.464 E165.07762
G1 X123.647 Y118.912 E165.08865
G1 X123.63 Y119.294 E165.09781
G1 X123.678 Y119.668 E165.10684
G1 X123.795 Y120.04 E165.11618
G1 X124.02 Y120.447 E165.12732
G1 X124.33 Y120.8 E165.13857
G1 X124.707 Y121.077 E165.14977
G1 X125.064 Y121.245 E165.15922
G1 X125.512 Y121.353 E165.17025
G1 X125.894 Y121.37 E165.17941
G1 X126.268 Y121.322 E165.18844
G1 X126.64 Y121.205 E165.19778
G1 X127.047 Y120.98 E165.20891
G1 X127.4 Y120.67 E165.22017
G1 X127.679 Y120.291 E165.23144
G1 X127.845 Y119.936 E165.24082
G1 X127.953 Y119.488 E165.25186
G1 X127.97 Y119.106 E165.26101
G1 X127.922 Y118.732 E165.27004
G1 X127.805 Y118.36 E165.27938
G1 X127.58 Y117.953 E165.29052
G1 X127.27 Y117.6 E165.30177
G1 X127.135 Y117.501 E165.30578
G1 X127.496 Y117.393 E165.31075
G1 X127.838 Y117.239 E165.31973
G1 X128.156 Y117.045 E165.32865
G1 X128.443 Y116.814 E165.33748
G1 X128.775 Y116.453 E165.34922
G1 X128.78 Y116.445 E165.34945
G1 X128.78 Y122.58 E165.49636
G1 X107.06 Y122.58 E166.0165
G1 X107.061 Y112.42 E166.2598
G1 X112.77 Y112.42 E166.39652
G1 X112.56 Y112.582 E166.40287
G1 X112.225 Y112.947 E166.41473
G1 X112.004 Y113.28 E166.4243
G1 X111.804 Y113.713 E166.43573
G1 X111.694 Y114.094 E166.44522
G1 X111.64 Y114.464 E166.45418
G1 X111.631 Y114.843 E166.46326
G1 X111.697 Y115.327 E166.47495
G1 X111.807 Y115.696 E166.48417
G1 X111.961 Y116.038 E166.49316
G1 X112.155 Y116.356 E166.50208
G1 X112.386 Y116.643 E166.5109
G1 X112.747 Y116.975 E166.52264
G1 X113.08 Y117.196 E166.53222
G1 X113.513 Y117.396 E166.54364
G1 X113.55 Y117.407 E166.54456
G0 F2582.9 X113.894 Y117.506
G0 X114.264 Y117.56
G0 X114.643 Y117.569
M204 S500
G0 F15000 X114.616 Y117.088
M204 S800
;TYPE:WALL-OUTER
G1 F2869.9 X115.026 Y117.032 E166.55447
G1 X115.329 Y116.942 E166.56204
G1 X115.614 Y116.814 E166.56952
G1 X115.879 Y116.652 E166.57696
G1 X116.114 Y116.463 E166.58418
G1 X116.396 Y116.156 E166.59416
G1 X116.576 Y115.885 E166.60196
G1 X116.745 Y115.519 E166.61161
G1 X116.836 Y115.204 E166.61946
G1 X116.881 Y114.896 E166.62692
G1 X116.888 Y114.584 E166.63439
G1 X116.832 Y114.174 E166.6443
G1 X116.742 Y113.871 E166.65187
G1 X116.614 Y113.586 E166.65935
G1 X116.452 Y113.321 E166.66679
G1 X116.263 Y113.086 E166.67401
G1 X115.956 Y112.804 E166.68399
G1 X115.685 Y112.624 E166.69178
G1 X115.319 Y112.455 E166.70144
G1 X115.004 Y112.364 E166.70929
G1 X114.696 Y112.319 E166.71674
G1 X114.49 Y112.31 E166.72168
G1 X114.174 Y112.331 E166.72926
G1 X113.87 Y112.395 E166.7367
G1 X113.491 Y112.533 E166.74636
G1 X113.207 Y112.69 E166.75413
G1 X112.886 Y112.937 E166.76383
G1 X112.604 Y113.244 E166.77382
G1 X112.424 Y113.515 E166.78161
G1 X112.255 Y113.881 E166.79126
G1 X112.164 Y114.196 E166.79911
G1 X112.119 Y114.504 E166.80657
G1 X112.112 Y114.816 E166.81404
G1 X112.168 Y115.226 E166.82395
G1 X112.258 Y115.529 E166.83152
G1 X112.386 Y115.814 E166.839
G1 X112.548 Y116.079 E166.84644
G1 X112.737 Y116.314 E166.85366
G1 X113.044 Y116.596 E166.86364
G1 X113.315 Y116.776 E166.87143
G1 X113.565 Y116.892 E166.87803
G0 F2582.9 X113.681 Y116.945
G0 X113.996 Y117.036
G0 X114.304 Y117.081
G0 X114.616 Y117.088
M204 S500
G0 F15000 X114.645 Y117.615
G1 F1800 E166.27803
G0 F15000 X114.683 Y116.175
G0 X127.593 Y113.694
G0 X128.78 Y112.963
M204 S800
;TYPE:WALL-INNER
G1 F1800 E166.87803
G1 F2869.9 X128.614 Y112.757 E166.88437
G1 X128.253 Y112.425 E166.89611
G1 X128.245 Y112.42 E166.89634
G1 X128.78 Y112.42 E166.89976
G1 X128.78 Y112.963 E166.90517
M204 S500
G1 F1800 E166.30517
G0 F15000 X127.706 Y113.832
G0 X126.647 Y116.179
G0 X126.616 Y117.088
M204 S800
;TYPE:WALL-OUTER
G1 F1800 E166.90517
G1 F2869.9 X127.026 Y117.032 E166.91508
G1 X127.329 Y116.942 E166.92265
G1 X127.614 Y116.814 E166.93013
G1 X127.879 Y116.652 E166.93757
G1 X128.114 Y116.463 E166.94479
G1 X128.396 Y116.156 E166.95477
G1 X128.576 Y115.885 E166.96256
G1 X128.745 Y115.519 E166.97222
G1 X128.836 Y115.204 E166.98007
G1 X128.881 Y114.896 E166.98752
G1 X128.888 Y114.584 E166.995
G1 X128.832 Y114.174 E167.00491
G1 X128.742 Y113.871 E167.01248
G1 X128.614 Y113.586 E167.01996
G1 X128.452 Y113.321 E167.0274
G1 X128.263 Y113.086 E167.03462
G1 X127.956 Y112.804 E167.0446
G1 X127.685 Y112.624 E167.05239
G1 X127.319 Y112.455 E167.06204
G1 X127.004 Y112.364 E167.0699
G1 X126.696 Y112.319 E167.07735
G1 X126.49 Y112.31 E167.08229
G1 X126.174 Y112.331 E167.08987
G1 X125.87 Y112.395 E167.09731
G1 X125.491 Y112.533 E167.10697
G1 X125.207 Y112.69 E167.11474
G1 X124.886 Y112.937 E167.12444
G1 X124.604 Y113.244 E167.13442
G1 X124.424 Y113.515 E167.14221
G1 X124.255 Y113.881 E167.15187
G1 X124.164 Y114.196 E167.15972
G1 X124.119 Y114.504 E167.16717
G1 X124.112 Y114.816 E167.17465
G1 X124.168 Y115.226 E167.18456
G1 X124.258 Y115.529 E167.19213
G1 X124.386 Y115.814 E167.19961
G1 X124.548 Y116.079 E167.20705
G1 X124.737 Y116.314 E167.21427
G1 X125.044 Y116.596 E167.22425
G1 X125.315 Y116.776 E167.23204
G1 X125.565 Y116.892 E167.23864
G0 F2582.9 X125.681 Y116.945
G0 X125.996 Y117.036
G0 X126.304 Y117.081
M204 S500
G1 F1800 E166.63864
G0 F15000 X126.096 Y118.471
G0 X125.698 Y119.978
G0 X125.58 Y120.876
M204 S800
G1 F1800 E167.23864
G1 F2869.9 X125.873 Y120.889 E167.24567
G1 X126.164 Y120.851 E167.25269
G1 X126.45 Y120.761 E167.25987
G1 X126.77 Y120.585 E167.26862
G1 X127.044 Y120.344 E167.27736
G1 X127.264 Y120.045 E167.28625
G1 X127.39 Y119.776 E167.29336
G1 X127.476 Y119.42 E167.30213
G1 X127.489 Y119.127 E167.30915
G1 X127.451 Y118.836 E167.31618
G1 X127.361 Y118.55 E167.32336
G1 X127.185 Y118.23 E167.33211
G1 X126.944 Y117.956 E167.34085
G1 X126.645 Y117.736 E167.34974
G1 X126.376 Y117.61 E167.35685
G1 X126.02 Y117.524 E167.36562
G1 X125.873 Y117.511 E167.36915
G1 X125.58 Y117.524 E167.37618
G1 X125.224 Y117.61 E167.38495
G1 X124.953 Y117.737 E167.39212
G1 X124.716 Y117.903 E167.39904
G1 X124.503 Y118.116 E167.40626
G1 X124.336 Y118.355 E167.41324
G1 X124.21 Y118.624 E167.42035
G1 X124.124 Y118.98 E167.42912
G1 X124.111 Y119.273 E167.43615
G1 X124.149 Y119.564 E167.44318
G1 X124.239 Y119.85 E167.45036
G1 X124.415 Y120.17 E167.4591
G1 X124.656 Y120.444 E167.46784
G1 X124.875 Y120.605 E167.47435
G0 F2582.9 X124.954 Y120.663
G0 X125.224 Y120.79
G0 X125.58 Y120.876
M204 S500
G0 F15000 X125.507 Y121.398
G1 F1800 E166.87435
G0 F15000 X125.599 Y119.959
G0 X106.58 Y123.965
G0 X106.58 Y123.06
M204 S800
G1 F1800 E167.47435
G1 F2869.9 X106.581 Y111.94 E167.74064
G1 X129.26 Y111.94 E168.28374
G1 X129.26 Y123.06 E168.55004
G1 X107.69 Y123.06 E169.06658
G0 F2582.9 X106.58 Y123.06
M204 S500
G1 F1800 E168.46658
G0 F15000 X106.58 Y123.965
G0 X126.445 Y118.75
G0 X127.988 Y117.698
M204 S800
;TYPE:WALL-INNER
G1 F1800 E169.06658
G1 F2869.9 X128.062 Y117.664 E169.06853
G1 X128.3 Y117.52 E169.07519
G1 X128.3 Y118.335 E169.09471
G1 X128.248 Y118.17 E169.09885
G1 X127.988 Y117.698 E169.10398
M204 S500
G1 F1800 E168.50398
G0 F15000 X127.019 Y116.091
G0 X125.189 Y115.398
G0 X123.208 Y116.249
G1 F1800 E169.10398
G0 F15000 X123.279 Y116.279
M204 S800
;TYPE:FILL
G1 F5739.7 X121.439 Y113.092 E169.19211
M204 S500
G0 F15000 X121.71 Y113.092
M204 S800
G1 F5739.7 X119.853 Y116.308 E169.28104
M204 S500
G0 F15000 X119.853 Y116.16
G0 X117.931 Y116.099
G0 X117.79 Y116.058
M204 S800
G1 F5739.7 X123.214 Y116.058 E169.41093
M204 S500
G1 F1800 E168.81093
G0 F15000 X123.072 Y116.098
G0 X117.797 Y116.248
G0 X115.825 Y115.37
G0 X113.155 Y115.331
G0 X111.208 Y116.249
G1 F1800 E169.41093
G0 F15000 X111.214 Y116.058
M204 S800
G1 F5739.7 X107.733 Y116.058 E169.49429
M204 S500
G0 F15000 X108.011 Y116.49
M204 S800
;TYPE:SKIN
G1 F2869.9 X111.124 Y116.49 E169.56884
G1 X111.375 Y116.903 E169.58041
G1 X111.691 Y117.295 E169.59247
G1 X112.159 Y117.725 E169.60769
G1 X112.615 Y118.027 E169.62079
G1 X113.18 Y118.289 E169.6357
G1 X113.692 Y118.436 E169.64846
G1 X114.184 Y118.509 E169.66037
G1 X114.696 Y118.52 E169.67263
G1 X115.329 Y118.434 E169.68793
G1 X115.829 Y118.285 E169.70042
G1 X116.281 Y118.081 E169.7123
G1 X116.703 Y117.825 E169.72412
G1 X117.095 Y117.509 E169.73618
G1 X117.525 Y117.041 E169.7514
G1 X117.827 Y116.584 E169.76451
G1 X117.871 Y116.49 E169.767
G1 X123.124 Y116.49 E169.8928
G1 X123.375 Y116.904 E169.90439
G1 X123.517 Y117.079 E169.90979
G1 X123.403 Y117.194 E169.91366
G1 X123.093 Y117.636 E169.92659
G1 X122.854 Y118.148 E169.94012
G1 X122.702 Y118.778 E169.95564
G1 X122.677 Y119.334 E169.96897
G1 X122.746 Y119.873 E169.98198
G1 X122.917 Y120.416 E169.99562
G1 X123.238 Y120.997 E170.01151
G1 X123.685 Y121.505 E170.02772
G1 X123.855 Y121.63 E170.03277
G1 X108.01 Y121.63 E170.41222
G1 X108.011 Y117.6 E170.50872
G0 F2582.9 X108.011 Y116.49
M204 S500
G1 F1800 E169.90872
G0 F15000 X108.011 Y116.16
G0 X105.675 Y116.26
G0 X105.675 Y121.437
G0 X108.54 Y121.437
M204 S800
G1 F1800 E170.50872
G1 F2869.9 X108.202 Y121.099 E170.52017
M204 S500
G0 F15000 X108.202 Y120.42
M204 S800
G1 F2869.9 X109.219 Y121.437 E170.55461
M204 S500
G0 F15000 X109.897 Y121.437
M204 S800
G1 F2869.9 X108.202 Y119.742 E170.61202
M204 S500
G0 F15000 X108.202 Y119.063
M204 S800
G1 F2869.9 X110.576 Y121.437 E170.69242
M204 S500
G0 F15000 X111.255 Y121.437
M204 S800
G1 F2869.9 X108.202 Y118.384 E170.79581
M204 S500
G0 F15000 X108.202 Y117.705
M204 S800
G1 F2869.9 X111.934 Y121.437 E170.9222
M204 S500
G0 F15000 X112.613 Y121.437
M204 S800
G1 F2869.9 X108.202 Y117.026 E171.07159
M204 S500
G0 F15000 X108.535 Y116.681
M204 S800
G1 F2869.9 X113.291 Y121.437 E171.23266
M204 S500
G0 F15000 X113.97 Y121.437
M204 S800
G1 F2869.9 X109.214 Y116.681 E171.39372
M204 S500
G0 F15000 X109.892 Y116.681
M204 S800
G1 F2869.9 X114.649 Y121.437 E171.55481
M204 S500
G0 F15000 X115.328 Y121.437
M204 S800
G1 F2869.9 X110.571 Y116.681 E171.7159
M204 S500
G1 F1800 E171.1159
G0 F15000 X110.571 Y116.16
G0 X112.973 Y118.404
M204 S800
G1 F1800 E171.7159
G1 F2869.9 X116.007 Y121.437 E171.81863
M204 S500
G0 F15000 X116.686 Y121.437
M204 S800
G1 F2869.9 X113.911 Y118.663 E171.91259
M204 S500
G0 F15000 X114.637 Y118.71
M204 S800
G1 F2869.9 X117.364 Y121.437 E172.00495
M204 S500
G0 F15000 X118.043 Y121.437
M204 S800
G1 F2869.9 X115.244 Y118.638 E172.09974
M204 S500
G0 F15000 X115.782 Y118.497
M204 S800
G1 F2869.9 X118.722 Y121.437 E172.19931
M204 S500
G0 F15000 X119.401 Y121.437
M204 S800
G1 F2869.9 X116.262 Y118.298 E172.30562
M204 S500
G0 F15000 X116.695 Y118.053
M204 S800
G1 F2869.9 X120.08 Y121.437 E172.42024
M204 S500
G0 F15000 X120.758 Y121.437
M204 S800
G1 F2869.9 X117.085 Y117.764 E172.54463
M204 S500
G0 F15000 X117.429 Y117.429
M204 S800
G1 F2869.9 X121.437 Y121.437 E172.68037
M204 S500
G0 F15000 X122.116 Y121.437
M204 S800
G1 F2869.9 X117.74 Y117.061 E172.82857
M204 S500
G0 F15000 X118.04 Y116.682
M204 S800
G1 F2869.9 X122.795 Y121.437 E172.9896
M204 S500
G0 F15000 X123 Y120.964
M204 S800
G1 F2869.9 X118.718 Y116.682 E173.13462
M204 S500
G0 F15000 X119.397 Y116.682
M204 S800
G1 F2869.9 X122.547 Y119.831 E173.24128
M204 S500
G0 F15000 X122.494 Y119.1
M204 S800
G1 F2869.9 X120.076 Y116.682 E173.32317
M204 S500
G0 F15000 X120.755 Y116.682
M204 S800
G1 F2869.9 X122.571 Y118.498 E173.38467
M204 S500
G0 F15000 X122.723 Y117.971
M204 S800
G1 F2869.9 X121.434 Y116.682 E173.42833
M204 S500
G0 F15000 X122.113 Y116.682
M204 S800
G1 F2869.9 X122.943 Y117.513 E173.45645
M204 S500
G0 F15000 X123.223 Y117.114
M204 S800
G1 F2869.9 X122.791 Y116.682 E173.47108
M204 S500
G0 F15000 X122.597 Y115.837
G1 F1800 E172.87108
;MESH:NONMESH
G0 F300 X122.597 Y115.837 Z2.24
G0 F15000 X117.797 Y116.248
G0 X114.532 Y118.533
;TIME_ELAPSED:198.053092
;LAYER:9
M204 S800
;TYPE:WALL-INNER
G1 F1800 E173.47108
G1 F2937.2 X115.031 Y118.495 E173.49106
G1 X115.525 Y118.395 E173.51118
G1 X115.993 Y118.23 E173.53098
G1 X116.422 Y118.017 E173.5501
G1 X116.858 Y117.723 E173.57109
G1 X117.233 Y117.386 E173.59121
G1 X117.561 Y117.008 E173.61118
G1 X117.838 Y116.585 E173.63136
G1 X118.053 Y116.138 E173.65116
G1 X118.204 Y115.685 E173.67022
G1 X118.303 Y115.17 E173.69115
G1 X118.333 Y114.668 E173.71122
G1 X118.295 Y114.169 E173.7312
G1 X118.195 Y113.675 E173.75131
G1 X118.091 Y113.38 E173.7638
G1 X122.908 Y113.38 E173.95605
G1 X122.796 Y113.715 E173.97015
G1 X122.697 Y114.23 E173.99108
G1 X122.667 Y114.732 E174.01115
G1 X122.705 Y115.231 E174.03113
G1 X122.805 Y115.725 E174.05124
G1 X122.97 Y116.193 E174.07105
G1 X123.183 Y116.622 E174.09017
G1 X123.477 Y117.058 E174.11116
G1 X123.5 Y117.083 E174.11251
G1 X123.393 Y117.19 E174.11855
G1 X123.072 Y117.649 E174.14091
G1 X122.811 Y118.242 E174.16677
G1 X122.69 Y118.795 E174.18936
G1 X122.668 Y119.338 E174.21105
G1 X122.739 Y119.881 E174.23291
G1 X122.911 Y120.422 E174.25556
G1 X123.23 Y121.004 E174.28205
G1 X123.679 Y121.513 E174.30914
G1 X123.825 Y121.62 E174.31637
G1 X108.22 Y121.62 E174.9392
G1 X108.221 Y113.38 E175.26807
G1 X110.908 Y113.38 E175.37532
G1 X110.796 Y113.715 E175.38941
G1 X110.697 Y114.23 E175.41035
G1 X110.667 Y114.732 E175.43042
G1 X110.705 Y115.231 E175.45039
G1 X110.805 Y115.725 E175.47051
G1 X110.97 Y116.193 E175.49031
G1 X111.183 Y116.622 E175.50943
G1 X111.477 Y117.058 E175.53042
G1 X111.814 Y117.433 E175.55054
G1 X112.192 Y117.761 E175.57052
G1 X112.615 Y118.038 E175.5907
G1 X113.062 Y118.253 E175.61049
G1 X113.515 Y118.404 E175.62955
G1 X113.869 Y118.473 E175.64395
G0 F2643.5 X114.03 Y118.503
M204 S500
G0 F15000 X114.528 Y118.052
M204 S800
G1 F2937.2 X114.965 Y118.019 E175.66144
G1 X115.397 Y117.931 E175.67903
G1 X115.806 Y117.787 E175.69634
G1 X116.18 Y117.601 E175.71301
G1 X116.562 Y117.344 E175.73139
G1 X116.89 Y117.049 E175.74899
G1 X117.177 Y116.718 E175.76648
G1 X117.419 Y116.349 E175.78409
G1 X117.607 Y115.957 E175.80144
G1 X117.739 Y115.563 E175.81803
G1 X117.826 Y115.11 E175.83644
G1 X117.852 Y114.672 E175.85395
G1 X117.819 Y114.235 E175.87144
G1 X117.731 Y113.803 E175.88904
G1 X117.587 Y113.394 E175.90634
G1 X117.401 Y113.02 E175.92302
G1 X117.32 Y112.9 E175.92879
G1 X123.68 Y112.9 E176.18264
G1 X123.581 Y113.051 E176.18984
G1 X123.393 Y113.443 E176.20719
G1 X123.261 Y113.837 E176.22378
G1 X123.174 Y114.29 E176.24219
G1 X123.148 Y114.728 E176.2597
G1 X123.181 Y115.165 E176.27719
G1 X123.269 Y115.597 E176.29479
G1 X123.413 Y116.006 E176.3121
G1 X123.599 Y116.38 E176.32877
G1 X123.856 Y116.762 E176.34714
G1 X124.151 Y117.09 E176.36475
G1 X124.175 Y117.11 E176.366
G1 X124.094 Y117.167 E176.36795
G1 X123.762 Y117.499 E176.38669
G1 X123.493 Y117.885 E176.40547
G1 X123.27 Y118.392 E176.42758
G1 X123.168 Y118.857 E176.44658
G1 X123.149 Y119.317 E176.46495
G1 X123.209 Y119.776 E176.48343
G1 X123.354 Y120.232 E176.50253
G1 X123.625 Y120.726 E176.52501
G1 X124.005 Y121.157 E176.54795
G1 X124.474 Y121.501 E176.57116
G1 X124.993 Y121.73 E176.5938
G1 X125.457 Y121.832 E176.61277
G1 X125.917 Y121.851 E176.63114
G1 X126.376 Y121.791 E176.64962
G1 X126.832 Y121.646 E176.66871
G1 X127.326 Y121.375 E176.6912
G1 X127.757 Y120.995 E176.71414
G1 X128.101 Y120.526 E176.73735
G1 X128.3 Y120.074 E176.75706
G1 X128.3 Y122.1 E176.83792
G1 X126.832 Y122.1 E176.89651
G1 X125.917 Y122.1 E176.92744
G1 X124.993 Y122.1 E176.9516
G1 X107.74 Y122.1 E177.64021
G1 X107.741 Y112.9 E178.0074
G1 X111.68 Y112.9 E178.16461
G1 X111.581 Y113.051 E178.17182
G1 X111.393 Y113.443 E178.18917
G1 X111.261 Y113.837 E178.20575
G1 X111.174 Y114.29 E178.22417
G1 X111.148 Y114.728 E178.24168
G1 X111.181 Y115.165 E178.25917
G1 X111.269 Y115.597 E178.27676
G1 X111.413 Y116.006 E178.29407
G1 X111.599 Y116.38 E178.31074
G1 X111.856 Y116.762 E178.32912
G1 X112.151 Y117.09 E178.34673
G1 X112.482 Y117.377 E178.36421
G1 X112.851 Y117.619 E178.38182
G1 X113.243 Y117.807 E178.39917
G1 X113.637 Y117.939 E178.41576
G1 X113.866 Y117.983 E178.42507
G0 F2643.5 X114.09 Y118.026
G0 X114.528 Y118.052
M204 S500
G0 F15000 X114.524 Y117.571
M204 S800
G1 F2937.2 X114.899 Y117.543 E178.44008
G1 X115.269 Y117.467 E178.45515
G1 X115.619 Y117.344 E178.46996
G1 X115.938 Y117.185 E178.48418
G1 X116.266 Y116.964 E178.49997
G1 X116.547 Y116.712 E178.51503
G1 X116.793 Y116.428 E178.53003
G1 X117 Y116.113 E178.54507
G1 X117.161 Y115.776 E178.55998
G1 X117.274 Y115.441 E178.57409
G1 X117.349 Y115.05 E178.58998
G1 X117.371 Y114.676 E178.60493
G1 X117.343 Y114.301 E178.61994
G1 X117.267 Y113.931 E178.63502
G1 X117.144 Y113.581 E178.64983
G1 X116.985 Y113.262 E178.66405
G1 X116.764 Y112.934 E178.67984
G1 X116.512 Y112.653 E178.6949
G1 X116.243 Y112.42 E178.70911
G1 X124.758 Y112.42 E179.04896
G1 X124.734 Y112.436 E179.05011
G1 X124.453 Y112.688 E179.06517
G1 X124.207 Y112.972 E179.08017
G1 X124 Y113.287 E179.09521
G1 X123.839 Y113.624 E179.11012
G1 X123.726 Y113.959 E179.12423
G1 X123.651 Y114.35 E179.14012
G1 X123.629 Y114.724 E179.15507
G1 X123.657 Y115.099 E179.17008
G1 X123.733 Y115.469 E179.18516
G1 X123.856 Y115.819 E179.19997
G1 X124.015 Y116.138 E179.21419
G1 X124.236 Y116.466 E179.22998
G1 X124.488 Y116.747 E179.24504
G1 X124.772 Y116.993 E179.26004
G1 X125.038 Y117.168 E179.27275
G1 X124.709 Y117.321 E179.27946
G1 X124.404 Y117.536 E179.29436
G1 X124.132 Y117.808 E179.30971
G1 X123.914 Y118.121 E179.32493
G1 X123.729 Y118.542 E179.34329
G1 X123.646 Y118.919 E179.35869
G1 X123.63 Y119.296 E179.37375
G1 X123.679 Y119.671 E179.38885
G1 X123.797 Y120.042 E179.40439
G1 X124.02 Y120.448 E179.42288
G1 X124.331 Y120.801 E179.44165
G1 X124.715 Y121.083 E179.46067
G1 X125.143 Y121.271 E179.47932
G1 X125.519 Y121.354 E179.49469
G1 X125.896 Y121.37 E179.50975
G1 X126.271 Y121.321 E179.52485
G1 X126.642 Y121.203 E179.54039
G1 X127.048 Y120.98 E179.55887
G1 X127.401 Y120.669 E179.57765
G1 X127.683 Y120.284 E179.5967
G1 X127.871 Y119.858 E179.61528
G1 X127.954 Y119.481 E179.63069
G1 X127.97 Y119.104 E179.64575
G1 X127.921 Y118.729 E179.66084
G1 X127.803 Y118.358 E179.67638
G1 X127.58 Y117.952 E179.69487
G1 X127.269 Y117.599 E179.71365
G1 X127.128 Y117.496 E179.72062
G1 X127.269 Y117.467 E179.72132
G1 X127.619 Y117.344 E179.73036
G1 X127.938 Y117.185 E179.74459
G1 X128.266 Y116.964 E179.76037
G1 X128.547 Y116.712 E179.77544
G1 X128.78 Y116.443 E179.78964
G1 X128.78 Y122.58 E180.03458
G1 X107.26 Y122.58 E180.89349
G1 X107.261 Y112.42 E181.299
G1 X112.758 Y112.42 E181.5184
G1 X112.734 Y112.436 E181.51955
G1 X112.453 Y112.688 E181.53461
G1 X112.207 Y112.972 E181.54961
G1 X112 Y113.287 E181.56465
G1 X111.839 Y113.624 E181.57956
G1 X111.726 Y113.959 E181.59367
G1 X111.651 Y114.35 E181.60956
G1 X111.629 Y114.724 E181.62451
G1 X111.657 Y115.099 E181.63952
G1 X111.733 Y115.469 E181.6546
G1 X111.856 Y115.819 E181.66941
G1 X112.015 Y116.138 E181.68363
G1 X112.236 Y116.466 E181.69942
G1 X112.488 Y116.747 E181.71448
G1 X112.772 Y116.993 E181.72948
G1 X113.087 Y117.2 E181.74452
G1 X113.424 Y117.361 E181.75943
G1 X113.759 Y117.474 E181.77354
G1 X113.864 Y117.494 E181.7778
G0 F2643.5 X114.15 Y117.549
G0 X114.524 Y117.571
M204 S500
G0 F15000 X114.52 Y117.09
M204 S800
;TYPE:WALL-OUTER
G1 F2937.2 X114.832 Y117.067 E181.79029
G1 X115.14 Y117.003 E181.80285
G1 X115.432 Y116.901 E181.81519
G1 X115.695 Y116.77 E181.82692
G1 X115.97 Y116.584 E181.84017
G1 X116.204 Y116.375 E181.85269
G1 X116.409 Y116.138 E181.8652
G1 X116.581 Y115.876 E181.87771
G1 X116.716 Y115.595 E181.89015
G1 X116.809 Y115.319 E181.90177
G1 X116.872 Y114.991 E181.9151
G1 X116.89 Y114.68 E181.92754
G1 X116.867 Y114.368 E181.94002
G1 X116.803 Y114.06 E181.95258
G1 X116.701 Y113.768 E181.96493
G1 X116.57 Y113.505 E181.97665
G1 X116.384 Y113.23 E181.9899
G1 X116.175 Y112.996 E182.00243
G1 X115.938 Y112.791 E182.01493
G1 X115.676 Y112.619 E182.02744
G1 X115.395 Y112.484 E182.03988
G1 X115.119 Y112.391 E182.05151
G1 X114.791 Y112.328 E182.06484
G1 X114.48 Y112.31 E182.07727
G1 X114.168 Y112.333 E182.08976
G1 X113.86 Y112.397 E182.10231
G1 X113.568 Y112.499 E182.11466
G1 X113.305 Y112.63 E182.12639
G1 X113.03 Y112.816 E182.13964
G1 X112.796 Y113.025 E182.15216
G1 X112.591 Y113.262 E182.16467
G1 X112.419 Y113.524 E182.17717
G1 X112.284 Y113.805 E182.18962
G1 X112.191 Y114.081 E182.20124
G1 X112.128 Y114.409 E182.21457
G1 X112.11 Y114.72 E182.22701
G1 X112.133 Y115.032 E182.23949
G1 X112.197 Y115.34 E182.25205
G1 X112.299 Y115.632 E182.26439
G1 X112.43 Y115.895 E182.27612
G1 X112.616 Y116.17 E182.28937
G1 X112.825 Y116.404 E182.30189
G1 X113.062 Y116.609 E182.3144
G1 X113.324 Y116.781 E182.32691
G1 X113.605 Y116.916 E182.33935
G1 X113.861 Y117.002 E182.35013
G0 F2643.5 X113.881 Y117.009
G0 X114.209 Y117.072
G0 X114.52 Y117.09
M204 S500
G0 F15000 X114.524 Y117.618
G1 F1800 E181.75013
G0 F15000 X114.63 Y116.18
G0 X127.632 Y113.739
G0 X128.78 Y112.958
M204 S800
;TYPE:WALL-INNER
G1 F1800 E182.35013
G1 F2937.2 X128.764 Y112.934 E182.35128
G1 X128.512 Y112.653 E182.36634
G1 X128.243 Y112.42 E182.38055
G1 X128.78 Y112.42 E182.38992
G1 X128.78 Y112.958 E182.39959
M204 S500
G1 F1800 E181.79959
G0 F15000 X127.717 Y113.849
G0 X126.38 Y116.181
G0 X126.209 Y117.072
M204 S800
;TYPE:WALL-OUTER
G1 F1800 E182.39959
G1 F2937.2 X126.52 Y117.09 E182.41202
G1 X126.832 Y117.067 E182.42451
G1 X127.14 Y117.003 E182.43707
G1 X127.432 Y116.901 E182.44941
G1 X127.695 Y116.77 E182.46114
G1 X127.97 Y116.584 E182.47439
G1 X128.204 Y116.375 E182.48691
G1 X128.409 Y116.138 E182.49942
G1 X128.581 Y115.876 E182.51193
G1 X128.716 Y115.595 E182.52437
G1 X128.809 Y115.319 E182.53599
G1 X128.872 Y114.991 E182.54932
G1 X128.89 Y114.68 E182.56176
G1 X128.867 Y114.368 E182.57424
G1 X128.803 Y114.06 E182.5868
G1 X128.701 Y113.768 E182.59914
G1 X128.57 Y113.505 E182.61087
G1 X128.384 Y113.23 E182.62412
G1 X128.175 Y112.996 E182.63664
G1 X127.938 Y112.791 E182.64915
G1 X127.676 Y112.619 E182.66166
G1 X127.395 Y112.484 E182.6741
G1 X127.119 Y112.391 E182.68573
G1 X126.791 Y112.328 E182.69906
G1 X126.48 Y112.31 E182.71149
G1 X126.168 Y112.333 E182.72398
G1 X125.86 Y112.397 E182.73653
G1 X125.568 Y112.499 E182.74888
G1 X125.305 Y112.63 E182.7606
G1 X125.03 Y112.816 E182.77386
G1 X124.796 Y113.025 E182.78638
G1 X124.591 Y113.262 E182.79888
G1 X124.419 Y113.524 E182.81139
G1 X124.284 Y113.805 E182.82384
G1 X124.191 Y114.081 E182.83546
G1 X124.128 Y114.409 E182.84879
G1 X124.11 Y114.72 E182.86122
G1 X124.133 Y115.032 E182.87371
G1 X124.197 Y115.34 E182.88627
G1 X124.299 Y115.632 E182.89861
G1 X124.43 Y115.895 E182.91034
G1 X124.616 Y116.17 E182.92359
G1 X124.825 Y116.404 E182.93611
G1 X125.062 Y116.609 E182.94862
G1 X125.324 Y116.781 E182.96113
G1 X125.568 Y116.898 E182.97193
G0 F2643.5 X125.605 Y116.916
G0 X125.881 Y117.009
M204 S500
G1 F1800 E182.37193
G0 F15000 X125.977 Y118.435
G0 X125.563 Y119.949
G0 X125.292 Y120.812
M204 S800
G1 F1800 E182.97193
G1 F2937.2 X125.582 Y120.876 E182.98378
G1 X125.875 Y120.889 E182.99549
G1 X126.166 Y120.851 E183.0072
G1 X126.452 Y120.76 E183.01918
G1 X126.77 Y120.585 E183.03366
G1 X127.045 Y120.343 E183.04829
G1 X127.265 Y120.043 E183.06313
G1 X127.412 Y119.708 E183.07773
G1 X127.476 Y119.418 E183.08959
G1 X127.489 Y119.125 E183.10129
G1 X127.451 Y118.834 E183.11301
G1 X127.36 Y118.548 E183.12499
G1 X127.185 Y118.23 E183.13947
G1 X126.943 Y117.955 E183.15409
G1 X126.643 Y117.735 E183.16894
G1 X126.308 Y117.588 E183.18354
G1 X126.018 Y117.524 E183.1954
G1 X125.871 Y117.511 E183.20129
G1 X125.578 Y117.524 E183.21299
G1 X125.223 Y117.611 E183.22758
G1 X124.951 Y117.738 E183.23956
G1 X124.714 Y117.905 E183.25113
G1 X124.502 Y118.117 E183.2631
G1 X124.335 Y118.357 E183.27477
G1 X124.188 Y118.692 E183.28937
G1 X124.124 Y118.982 E183.30122
G1 X124.111 Y119.275 E183.31293
G1 X124.149 Y119.566 E183.32464
G1 X124.24 Y119.852 E183.33662
G1 X124.415 Y120.17 E183.35111
G1 X124.657 Y120.445 E183.36573
G1 X124.715 Y120.488 E183.36861
G0 F2643.5 X124.956 Y120.665
M204 S500
G0 F15000 X125.129 Y121.314
G1 F1800 E182.76861
G0 F15000 X125.447 Y119.902
G0 X106.78 Y123.965
G0 X106.78 Y123.06
M204 S800
G1 F1800 E183.36861
G1 F2937.2 X106.781 Y111.94 E183.81243
G1 X129.26 Y111.94 E184.70962
G1 X129.26 Y123.06 E185.15344
G1 X107.446 Y123.06 E186.02408
G0 F2643.5 X106.78 Y123.06
M204 S500
G1 F1800 E185.42408
G0 F15000 X106.78 Y123.965
G0 X126.248 Y119.846
G0 X127.774 Y121.62
M204 S800
;TYPE:WALL-INNER
G1 F1800 E186.02408
G1 F2937.2 X127.82 Y121.579 E186.02654
G1 X127.82 Y121.62
G1 X127.774 Y121.62
M204 S500
G0 F15000 X127.987 Y117.697
M204 S800
G1 F2937.2 X128.3 Y117.52 E186.0409
G1 X128.3 Y118.338 E186.07354
G1 X128.246 Y118.168 E186.08066
G1 X127.987 Y117.697 E186.08932
M204 S500
G1 F1800 E185.48932
G0 F15000 X127.072 Y116.071
G0 X125.129 Y115.272
G0 X122.723 Y116.249
G0 X122.528 Y115.964
G1 F1800 E186.08932
G0 F15000 X122.668 Y115.917
M204 S800
;TYPE:FILL
G1 F5874.3 X118.329 Y115.917 E186.2625
M204 S500
G0 F15000 X118.47 Y115.964
G0 X120.016 Y116.16
G0 X120.016 Y116.308
M204 S800
G1 F5874.3 X121.596 Y113.572 E186.3886
G1 X121.552 Y113.572
G1 X122.513 Y115.236 E186.46529
M204 S500
G1 F1800 E185.86529
G0 F15000 X122.365 Y115.245
G0 X118.282 Y116.249
G0 X115.846 Y115.326
G0 X113.129 Y115.272
G0 X110.723 Y116.249
G0 X110.528 Y115.964
G1 F1800 E186.46529
G0 F15000 X110.668 Y115.917
M204 S800
G1 F5874.3 X108.413 Y115.917 E186.5553
M204 S500
G0 F15000 X108.691 Y116.49
M204 S800
;TYPE:SKIN
G1 F2937.2 X110.593 Y116.49 E186.63121
G1 X110.776 Y116.859 E186.64765
G1 X111.105 Y117.348 E186.67117
G1 X111.483 Y117.769 E186.69375
G1 X111.908 Y118.137 E186.71619
G1 X112.384 Y118.448 E186.73889
G1 X112.885 Y118.69 E186.76109
G1 X113.396 Y118.86 E186.78259
G1 X113.971 Y118.971 E186.80596
G1 X114.536 Y119.005 E186.82855
G1 X115.096 Y118.961 E186.85097
G1 X115.65 Y118.849 E186.87353
G1 X116.177 Y118.663 E186.89583
G1 X116.659 Y118.424 E186.91731
G1 X117.148 Y118.095 E186.94083
G1 X117.569 Y117.717 E186.96341
G1 X117.937 Y117.292 E186.98585
G1 X118.248 Y116.816 E187.00854
G1 X118.405 Y116.49 E187.02299
G1 X122.593 Y116.49 E187.19014
G1 X122.776 Y116.859 E187.20658
G1 X122.911 Y117.059 E187.21621
G1 X122.661 Y117.418 E187.23367
G1 X122.362 Y118.095 E187.26321
G1 X122.222 Y118.734 E187.28932
G1 X122.196 Y119.359 E187.31428
G1 X122.279 Y119.983 E187.33941
G1 X122.477 Y120.608 E187.36557
G1 X122.774 Y121.15 E187.39024
G1 X108.69 Y121.15 E187.95236
G1 X108.691 Y117.156 E188.11177
G0 F2643.5 X108.691 Y116.49
M204 S500
G0 F15000 X108.883 Y117.164
M204 S800
G1 F2937.2 X109.366 Y116.681 E188.13904
M204 S500
G0 F15000 X110.045 Y116.681
M204 S800
G1 F2937.2 X108.883 Y117.843 E188.20462
M204 S500
G0 F15000 X108.883 Y118.522
M204 S800
G1 F2937.2 X110.556 Y116.849 E188.29906
M204 S500
G0 F15000 X110.818 Y117.265
M204 S800
G1 F2937.2 X108.882 Y119.201 E188.40833
M204 S500
G0 F15000 X108.882 Y119.88
M204 S800
G1 F2937.2 X111.115 Y117.647 E188.53437
M204 S500
G0 F15000 X111.449 Y117.992
M204 S800
G1 F2937.2 X108.882 Y120.559 E188.67926
M204 S500
G0 F15000 X109.163 Y120.957
M204 S800
G1 F2937.2 X111.815 Y118.305 E188.82895
M204 S500
G0 F15000 X112.226 Y118.573
M204 S800
G1 F2937.2 X109.841 Y120.957 E188.96355
M204 S500
G0 F15000 X110.52 Y120.957
M204 S800
G1 F2937.2 X112.677 Y118.801 E189.08527
M204 S500
G0 F15000 X113.171 Y118.986
M204 S800
G1 F2937.2 X111.199 Y120.957 E189.19655
M204 S500
G0 F15000 X111.878 Y120.957
M204 S800
G1 F2937.2 X113.719 Y119.117 E189.30043
M204 S500
G0 F15000 X114.33 Y119.184
M204 S800
G1 F2937.2 X112.557 Y120.957 E189.40051
M204 S500
G0 F15000 X113.236 Y120.957
M204 S800
G1 F2937.2 X115.037 Y119.156 E189.50217
M204 S500
G0 F15000 X115.913 Y118.959
M204 S800
G1 F2937.2 X113.914 Y120.957 E189.61497
M204 S500
G0 F15000 X114.593 Y120.957
M204 S800
G1 F2937.2 X117.642 Y117.908 E189.78707
G1 X117.753 Y117.797
G1 X118.869 Y116.681 E189.85006
M204 S500
G0 F15000 X119.548 Y116.681
M204 S800
G1 F2937.2 X115.272 Y120.957 E190.09142
M204 S500
G0 F15000 X115.951 Y120.957
M204 S800
G1 F2937.2 X120.227 Y116.681 E190.33277
M204 S500
G0 F15000 X120.906 Y116.681
M204 S800
G1 F2937.2 X116.63 Y120.957 E190.57413
M204 S500
G0 F15000 X117.309 Y120.957
M204 S800
G1 F2937.2 X121.584 Y116.681 E190.81546
M204 S500
G0 F15000 X122.263 Y116.681
M204 S800
G1 F2937.2 X117.987 Y120.957 E191.05681
M204 S500
G0 F15000 X118.666 Y120.957
M204 S800
G1 F2937.2 X122.632 Y116.991 E191.28067
M204 S500
G0 F15000 X122.632 Y116.16
G0 X122.152 Y116.16
G0 X122.152 Y118.15
M204 S800
G1 F2937.2 X119.345 Y120.957 E191.43911
M204 S500
G0 F15000 X120.024 Y120.957
M204 S800
G1 F2937.2 X122.019 Y118.962 E191.55172
M204 S500
G0 F15000 X122.036 Y119.624
M204 S800
G1 F2937.2 X120.703 Y120.957 E191.62696
M204 S500
G0 F15000 X121.381 Y120.957
M204 S800
G1 F2937.2 X122.144 Y120.195 E191.67
M204 S500
G0 F15000 X122.311 Y120.707
M204 S800
G1 F2937.2 X122.06 Y120.957 E191.68413
M204 S500
G1 F1800 E191.08413
;MESH:NONMESH
G0 F300 X122.06 Y120.957 Z2.44
G0 F15000 X125.07 Y119.491
G0 X114.83 Y116.149
G0 X114.941 Y118.024
;TIME_ELAPSED:218.851902
;LAYER:10
M204 S800
;TYPE:WALL-INNER
G1 F1800 E191.68413
G1 F2819.4 X115.403 Y117.928 E191.70297
G1 X115.788 Y117.794 E191.71924
G1 X116.211 Y117.581 E191.73814
G1 X116.575 Y117.333 E191.75572
G1 X116.896 Y117.043 E191.77299
G1 X117.16 Y116.74 E191.78903
G1 X117.404 Y116.374 E191.80658
G1 X117.612 Y115.947 E191.82554
G1 X117.739 Y115.564 E191.84164
G1 X117.824 Y115.139 E191.85894
G1 X117.852 Y114.667 E191.87781
G1 X117.824 Y114.256 E191.89426
G1 X117.728 Y113.797 E191.91297
G1 X117.594 Y113.412 E191.92924
G1 X117.381 Y112.989 E191.94814
G1 X117.32 Y112.9 E191.95245
G1 X123.68 Y112.9 E192.20629
G1 X123.596 Y113.026 E192.21234
G1 X123.388 Y113.453 E192.23129
G1 X123.261 Y113.836 E192.2474
G1 X123.176 Y114.259 E192.26462
G1 X123.148 Y114.698 E192.28218
G1 X123.176 Y115.141 E192.29989
G1 X123.272 Y115.603 E192.31873
G1 X123.406 Y115.988 E192.335
G1 X123.619 Y116.411 E192.3539
G1 X123.867 Y116.775 E192.37148
G1 X124.157 Y117.096 E192.38874
G1 X124.09 Y117.17 E192.39273
G1 X123.761 Y117.503 E192.41141
G1 X123.5 Y117.879 E192.42968
G1 X123.301 Y118.304 E192.44841
G1 X123.17 Y118.851 E192.47086
G1 X123.149 Y119.319 E192.48956
G1 X123.21 Y119.78 E192.50812
G1 X123.355 Y120.233 E192.5271
G1 X123.627 Y120.729 E192.54968
G1 X124.007 Y121.159 E192.57258
G1 X124.465 Y121.496 E192.59528
G1 X124.903 Y121.701 E192.61458
G1 X125.451 Y121.83 E192.63705
G1 X125.919 Y121.851 E192.65575
G1 X126.377 Y121.79 E192.67419
G1 X126.824 Y121.65 E192.69288
G1 X127.225 Y121.439 E192.71097
G1 X127.609 Y121.144 E192.73029
G1 X127.973 Y120.727 E192.75239
G1 X128.206 Y120.319 E192.77114
G1 X128.3 Y120.059 E192.78217
G1 X128.3 Y120.727 E192.79653
G1 X128.3 Y122.1 E192.85133
G1 X126.377 Y122.1 E192.92808
G1 X125.451 Y122.1 E192.95353
G1 X124.903 Y122.1 E192.96876
G1 X107.94 Y122.1 E193.64579
G1 X107.941 Y112.9 E194.01298
G1 X111.68 Y112.9 E194.16221
G1 X111.596 Y113.026 E194.16826
G1 X111.388 Y113.453 E194.18721
G1 X111.261 Y113.836 E194.20332
G1 X111.176 Y114.259 E194.22054
G1 X111.148 Y114.698 E194.2381
G1 X111.176 Y115.141 E194.25581
G1 X111.272 Y115.603 E194.27465
G1 X111.406 Y115.988 E194.29092
G1 X111.619 Y116.411 E194.30982
G1 X111.867 Y116.775 E194.3274
G1 X112.157 Y117.096 E194.34466
G1 X112.46 Y117.36 E194.3607
G1 X112.826 Y117.604 E194.37826
G1 X113.253 Y117.812 E194.39722
G1 X113.636 Y117.939 E194.41332
G1 X114.059 Y118.024 E194.43054
G1 X114.275 Y118.038 E194.43918
G0 F2537.4 X114.498 Y118.052
M204 S500
G0 F15000 X114.877 Y117.547
M204 S800
G1 F2819.4 X115.275 Y117.464 E194.45541
G1 X115.601 Y117.351 E194.46918
G1 X115.967 Y117.167 E194.48553
G1 X116.277 Y116.955 E194.50052
G1 X116.553 Y116.706 E194.51535
G1 X116.778 Y116.448 E194.52902
G1 X116.987 Y116.135 E194.54404
G1 X117.166 Y115.766 E194.56041
G1 X117.274 Y115.441 E194.57408
G1 X117.347 Y115.077 E194.58889
G1 X117.371 Y114.669 E194.60521
G1 X117.347 Y114.322 E194.61909
G1 X117.264 Y113.925 E194.63528
G1 X117.151 Y113.599 E194.64905
G1 X116.967 Y113.233 E194.6654
G1 X116.755 Y112.923 E194.68039
G1 X116.506 Y112.647 E194.69522
G1 X116.245 Y112.42 E194.70903
G1 X124.76 Y112.42 E195.04888
G1 X124.723 Y112.445 E195.05066
G1 X124.447 Y112.694 E195.0655
G1 X124.222 Y112.952 E195.07916
G1 X124.013 Y113.265 E195.09418
G1 X123.834 Y113.634 E195.11055
G1 X123.726 Y113.959 E195.12422
G1 X123.653 Y114.322 E195.139
G1 X123.629 Y114.698 E195.15404
G1 X123.653 Y115.077 E195.16919
G1 X123.736 Y115.475 E195.18542
G1 X123.849 Y115.801 E195.19919
G1 X124.033 Y116.167 E195.21554
G1 X124.245 Y116.477 E195.23053
G1 X124.494 Y116.753 E195.24537
G1 X124.752 Y116.978 E195.25903
G1 X125.037 Y117.168 E195.2727
G1 X124.708 Y117.322 E195.27935
G1 X124.401 Y117.538 E195.29434
G1 X124.131 Y117.811 E195.30966
G1 X123.917 Y118.119 E195.32463
G1 X123.756 Y118.463 E195.33979
G1 X123.647 Y118.918 E195.35846
G1 X123.63 Y119.298 E195.37364
G1 X123.68 Y119.674 E195.38878
G1 X123.798 Y120.043 E195.40425
G1 X124.022 Y120.451 E195.42282
G1 X124.333 Y120.803 E195.44157
G1 X124.711 Y121.081 E195.4603
G1 X125.062 Y121.245 E195.47576
G1 X125.518 Y121.353 E195.49446
G1 X125.898 Y121.37 E195.50965
G1 X126.273 Y121.32 E195.52475
G1 X126.639 Y121.205 E195.54006
G1 X126.965 Y121.033 E195.55477
G1 X127.279 Y120.792 E195.57057
G1 X127.58 Y120.447 E195.58884
G1 X127.769 Y120.117 E195.60402
G1 X127.9 Y119.754 E195.61942
G1 X127.971 Y119.295 E195.63796
G1 X127.953 Y118.906 E195.6535
G1 X127.843 Y118.46 E195.67184
G1 X127.678 Y118.108 E195.68735
G1 X127.462 Y117.801 E195.70233
G1 X127.189 Y117.531 E195.71766
G1 X127.135 Y117.493 E195.72029
G1 X127.275 Y117.464 E195.72222
G1 X127.601 Y117.351 E195.73111
G1 X127.967 Y117.167 E195.74746
G1 X128.277 Y116.955 E195.76245
G1 X128.553 Y116.706 E195.77728
G1 X128.78 Y116.445 E195.79109
G1 X128.78 Y122.58 E196.03595
G1 X107.46 Y122.58 E196.88688
G1 X107.461 Y112.42 E197.29239
G1 X112.76 Y112.42 E197.50388
G1 X112.723 Y112.445 E197.50566
G1 X112.447 Y112.694 E197.5205
G1 X112.222 Y112.952 E197.53416
G1 X112.013 Y113.265 E197.54918
G1 X111.834 Y113.634 E197.56555
G1 X111.726 Y113.959 E197.57922
G1 X111.653 Y114.322 E197.594
G1 X111.629 Y114.698 E197.60904
G1 X111.653 Y115.077 E197.62419
G1 X111.736 Y115.475 E197.64042
G1 X111.849 Y115.801 E197.65419
G1 X112.033 Y116.167 E197.67054
G1 X112.245 Y116.477 E197.68553
G1 X112.494 Y116.753 E197.70037
G1 X112.752 Y116.978 E197.71403
G1 X113.065 Y117.187 E197.72905
G1 X113.434 Y117.366 E197.74542
G1 X113.759 Y117.474 E197.75909
G1 X114.122 Y117.547 E197.77387
G1 X114.211 Y117.553 E197.77743
G0 F2537.4 X114.498 Y117.571
G0 X114.877 Y117.547
M204 S500
G0 F15000 X114.812 Y117.07
M204 S800
;TYPE:WALL-OUTER
G1 F2819.4 X115.147 Y117 E197.79109
G1 X115.414 Y116.908 E197.80236
G1 X115.722 Y116.753 E197.81612
G1 X115.979 Y116.577 E197.82855
G1 X116.21 Y116.369 E197.84096
G1 X116.396 Y116.156 E197.85225
G1 X116.569 Y115.896 E197.86471
G1 X116.72 Y115.585 E197.87851
G1 X116.809 Y115.317 E197.88978
G1 X116.87 Y115.015 E197.90208
G1 X116.89 Y114.672 E197.91579
G1 X116.87 Y114.388 E197.92715
G1 X116.8 Y114.053 E197.94081
G1 X116.708 Y113.786 E197.95208
G1 X116.553 Y113.478 E197.96584
G1 X116.377 Y113.221 E197.97828
G1 X116.169 Y112.99 E197.99068
G1 X115.956 Y112.804 E198.00197
G1 X115.696 Y112.631 E198.01443
G1 X115.385 Y112.48 E198.02823
G1 X115.117 Y112.391 E198.0395
G1 X114.815 Y112.33 E198.0518
G1 X114.502 Y112.31 E198.06432
G1 X114.188 Y112.33 E198.07688
G1 X113.853 Y112.4 E198.09054
G1 X113.586 Y112.492 E198.10181
G1 X113.278 Y112.647 E198.11557
G1 X113.021 Y112.823 E198.128
G1 X112.79 Y113.031 E198.14041
G1 X112.604 Y113.244 E198.15169
G1 X112.431 Y113.504 E198.16416
G1 X112.28 Y113.815 E198.17796
G1 X112.191 Y114.083 E198.18923
G1 X112.13 Y114.385 E198.20152
G1 X112.11 Y114.698 E198.21404
G1 X112.13 Y115.012 E198.2266
G1 X112.2 Y115.347 E198.24026
G1 X112.292 Y115.614 E198.25153
G1 X112.447 Y115.922 E198.26529
G1 X112.623 Y116.179 E198.27773
G1 X112.831 Y116.41 E198.29013
G1 X113.044 Y116.596 E198.30142
G1 X113.304 Y116.769 E198.31388
G1 X113.615 Y116.92 E198.32768
G1 X113.883 Y117.009 E198.33895
G1 X114.147 Y117.063 E198.34971
G0 F2537.4 X114.185 Y117.07
G0 X114.498 Y117.09
G0 X114.812 Y117.07
M204 S500
G0 F15000 X114.882 Y117.593
G1 F1800 E197.74971
G0 F15000 X114.851 Y116.144
G0 X127.664 Y113.778
G0 X128.78 Y112.96
M204 S800
;TYPE:WALL-INNER
G1 F1800 E198.34971
G1 F2819.4 X128.755 Y112.923 E198.35149
G1 X128.506 Y112.647 E198.36633
G1 X128.245 Y112.42 E198.38013
G1 X128.78 Y112.42 E198.3897
G1 X128.78 Y112.96 E198.39988
M204 S500
G1 F1800 E197.79988
G0 F15000 X127.719 Y113.851
G0 X126.36 Y116.18
G0 X126.185 Y117.07
M204 S800
;TYPE:WALL-OUTER
G1 F1800 E198.39988
G1 F2819.4 X126.498 Y117.09 E198.4124
G1 X126.812 Y117.07 E198.42496
G1 X127.147 Y117 E198.43862
G1 X127.414 Y116.908 E198.44989
G1 X127.722 Y116.753 E198.46365
G1 X127.979 Y116.577 E198.47608
G1 X128.21 Y116.369 E198.48849
G1 X128.396 Y116.156 E198.49977
G1 X128.569 Y115.896 E198.51224
G1 X128.72 Y115.585 E198.52604
G1 X128.809 Y115.317 E198.53731
G1 X128.87 Y115.015 E198.54961
G1 X128.89 Y114.672 E198.56332
G1 X128.87 Y114.388 E198.57468
G1 X128.8 Y114.053 E198.58834
G1 X128.708 Y113.786 E198.59961
G1 X128.553 Y113.478 E198.61337
G1 X128.377 Y113.221 E198.62581
G1 X128.169 Y112.99 E198.63821
G1 X127.956 Y112.804 E198.6495
G1 X127.696 Y112.631 E198.66196
G1 X127.385 Y112.48 E198.67576
G1 X127.117 Y112.391 E198.68703
G1 X126.815 Y112.33 E198.69933
G1 X126.502 Y112.31 E198.71185
G1 X126.188 Y112.33 E198.72441
G1 X125.853 Y112.4 E198.73806
G1 X125.586 Y112.492 E198.74934
G1 X125.278 Y112.647 E198.7631
G1 X125.021 Y112.823 E198.77553
G1 X124.79 Y113.031 E198.78794
G1 X124.604 Y113.244 E198.79922
G1 X124.431 Y113.504 E198.81169
G1 X124.28 Y113.815 E198.82549
G1 X124.191 Y114.083 E198.83676
G1 X124.13 Y114.385 E198.84905
G1 X124.11 Y114.698 E198.86157
G1 X124.13 Y115.012 E198.87413
G1 X124.2 Y115.347 E198.88779
G1 X124.292 Y115.614 E198.89906
G1 X124.447 Y115.922 E198.91282
G1 X124.623 Y116.179 E198.92525
G1 X124.831 Y116.41 E198.93766
G1 X125.044 Y116.596 E198.94895
G1 X125.304 Y116.769 E198.96141
G1 X125.547 Y116.887 E198.97219
G0 F2537.4 X125.615 Y116.92
G0 X125.883 Y117.009
G0 X126.185 Y117.07
M204 S500
G1 F1800 E198.37219
G0 F15000 X125.972 Y118.434
G0 X125.691 Y119.978
G0 X125.585 Y120.876
M204 S800
G1 F1800 E198.97219
G1 F2819.4 X125.877 Y120.889 E198.98386
G1 X126.168 Y120.85 E198.99558
G1 X126.453 Y120.76 E199.00751
G1 X126.705 Y120.627 E199.01888
G1 X126.949 Y120.44 E199.03115
G1 X127.187 Y120.167 E199.0456
G1 X127.332 Y119.914 E199.05724
G1 X127.433 Y119.635 E199.06909
G1 X127.489 Y119.269 E199.08386
G1 X127.476 Y118.975 E199.09561
G1 X127.388 Y118.621 E199.11017
G1 X127.261 Y118.35 E199.12211
G1 X127.094 Y118.112 E199.13372
G1 X126.881 Y117.901 E199.14568
G1 X126.641 Y117.734 E199.15735
G1 X126.378 Y117.611 E199.16894
G1 X126.015 Y117.524 E199.18384
G1 X125.869 Y117.511 E199.18969
G1 X125.575 Y117.524 E199.20144
G1 X125.221 Y117.612 E199.21599
G1 X124.95 Y117.739 E199.22794
G1 X124.712 Y117.906 E199.23954
G1 X124.501 Y118.119 E199.25151
G1 X124.334 Y118.359 E199.26318
G1 X124.211 Y118.622 E199.27477
G1 X124.124 Y118.985 E199.28967
G1 X124.111 Y119.277 E199.30133
G1 X124.15 Y119.568 E199.31305
G1 X124.241 Y119.853 E199.32499
G1 X124.417 Y120.173 E199.33957
G1 X124.659 Y120.447 E199.35416
G1 X124.957 Y120.666 E199.36892
G0 F2537.4 X125.221 Y120.789
M204 S500
G0 F15000 X125.512 Y121.398
G1 F1800 E198.76892
G0 F15000 X125.61 Y119.963
G0 X106.98 Y123.965
G0 X106.98 Y123.06
M204 S800
G1 F1800 E199.36892
G1 F2819.4 X106.981 Y111.94 E199.81274
G1 X129.26 Y111.94 E200.70194
G1 X129.26 Y123.06 E201.14577
G1 X107.646 Y123.06 E202.00843
G0 F2537.4 X106.98 Y123.06
M204 S500
G1 F1800 E201.40843
G0 F15000 X106.98 Y123.965
G0 X126.443 Y118.747
G0 X127.977 Y117.699
M204 S800
;TYPE:WALL-INNER
G1 F1800 E202.00843
G1 F2819.4 X128.211 Y117.581 E202.01889
G1 X128.3 Y117.52 E202.0232
G1 X128.298 Y118.299 E202.05429
G1 X128.095 Y117.866
G1 X127.977 Y117.699 E202.05762
M204 S500
G1 F1800 E201.45762
G0 F15000 X127.071 Y116.07
G0 X125.191 Y115.403
G0 X123.231 Y116.249
G0 X122.969 Y116.16
G1 F1800 E202.05762
G0 F15000 X122.969 Y116.308
M204 S800
;TYPE:FILL
G1 F5638.7 X121.112 Y113.092 E202.20584
M204 S500
G0 F15000 X122.036 Y113.092
M204 S800
G1 F5638.7 X120.18 Y116.308 E202.35404
M204 S500
G0 F15000 X120.18 Y116.16
G0 X118.011 Y115.822
G0 X117.871 Y115.775
M204 S800
G1 F5638.7 X123.129 Y115.775 E202.5639
M204 S500
G1 F1800 E201.9639
G0 F15000 X122.988 Y115.821
G0 X117.779 Y116.249
G0 X115.821 Y115.38
G0 X113.164 Y115.349
G0 X111.231 Y116.249
G0 X110.988 Y115.821
G1 F1800 E202.5639
G0 F15000 X111.129 Y115.775
M204 S800
G1 F5638.7 X108.133 Y115.775 E202.68348
M204 S500
G0 F15000 X108.411 Y116.49
M204 S800
;TYPE:SKIN
G1 F2819.4 X111.133 Y116.49 E202.79212
G1 X111.213 Y116.65 E202.79926
G1 X111.497 Y117.066 E202.81936
G1 X111.828 Y117.432 E202.83906
G1 X112.174 Y117.734 E202.85739
G1 X112.591 Y118.013 E202.87741
G1 X113.075 Y118.249 E202.8989
G1 X113.515 Y118.394 E202.91739
G1 X113.998 Y118.491 E202.93706
G1 X114.498 Y118.522 E202.95705
G1 X115.004 Y118.491 E202.97728
G1 X115.528 Y118.382 E202.99865
G1 X115.972 Y118.227 E203.01742
G1 X116.45 Y117.987 E203.03876
G1 X116.866 Y117.703 E203.05887
G1 X117.232 Y117.372 E203.07856
G1 X117.534 Y117.026 E203.09689
G1 X117.813 Y116.609 E203.11692
G1 X117.871 Y116.49 E203.1222
G1 X123.133 Y116.49 E203.33222
G1 X123.213 Y116.65 E203.33936
G1 X123.497 Y117.067 E203.3595
G1 X123.398 Y117.201 E203.36614
G1 X123.091 Y117.644 E203.38766
G1 X122.855 Y118.148 E203.40987
G1 X122.702 Y118.785 E203.43602
G1 X122.677 Y119.339 E203.45815
G1 X122.75 Y119.884 E203.4801
G1 X122.921 Y120.419 E203.50251
G1 X123.24 Y121.001 E203.529
G1 X123.688 Y121.508 E203.55601
G1 X123.854 Y121.63 E203.56423
G1 X108.41 Y121.63 E204.18063
G1 X108.411 Y117.156 E204.3592
G0 F2537.4 X108.411 Y116.49
M204 S500
G1 F1800 E203.7592
G0 F15000 X108.411 Y116.16
G0 X106.075 Y116.26
G0 X106.087 Y123.953
G0 X109.218 Y123.965
G0 X109.218 Y121.437
M204 S800
G1 F1800 E204.3592
G1 F2819.4 X108.601 Y120.82 E204.39402
M204 S500
G0 F15000 X108.601 Y120.141
M204 S800
G1 F2819.4 X109.897 Y121.437 E204.46718
M204 S500
G0 F15000 X110.575 Y121.437
M204 S800
G1 F2819.4 X108.601 Y119.462 E204.57863
M204 S500
G0 F15000 X108.602 Y118.784
M204 S800
G1 F2819.4 X111.254 Y121.437 E204.72834
M204 S500
G0 F15000 X111.933 Y121.437
M204 S800
G1 F2819.4 X108.602 Y118.105 E204.91639
M204 S500
G0 F15000 X108.602 Y117.427
M204 S800
G1 F2819.4 X112.612 Y121.437 E205.14273
M204 S500
G0 F15000 X113.291 Y121.437
M204 S800
G1 F2819.4 X108.602 Y116.748 E205.4074
M204 S500
G0 F15000 X109.214 Y116.681
M204 S800
G1 F2819.4 X113.97 Y121.437 E205.67585
M204 S500
G0 F15000 X114.648 Y121.437
M204 S800
G1 F2819.4 X109.893 Y116.681 E205.94427
M204 S500
G0 F15000 X110.572 Y116.681
M204 S800
G1 F2819.4 X115.327 Y121.437 E206.21269
M204 S500
G0 F15000 X116.006 Y121.437
M204 S800
G1 F2819.4 X112.991 Y118.422 E206.38287
M204 S500
G0 F15000 X113.918 Y118.67
M204 S800
G1 F2819.4 X116.685 Y121.437 E206.53905
M204 S500
G0 F15000 X117.364 Y121.437
M204 S800
G1 F2819.4 X114.632 Y118.705 E206.69326
M204 S500
G0 F15000 X115.242 Y118.636
M204 S800
G1 F2819.4 X118.042 Y121.437 E206.85133
M204 S500
G0 F15000 X118.721 Y121.437
M204 S800
G1 F2819.4 X115.781 Y118.496 E207.0173
M204 S500
G0 F15000 X116.259 Y118.296
M204 S800
G1 F2819.4 X119.4 Y121.437 E207.19459
M204 S500
G0 F15000 X120.079 Y121.437
M204 S800
G1 F2819.4 X116.694 Y118.052 E207.38566
M204 S500
G0 F15000 X117.084 Y117.763
M204 S800
G1 F2819.4 X120.758 Y121.437 E207.59303
M204 S500
G0 F15000 X121.437 Y121.437
M204 S800
G1 F2819.4 X117.432 Y117.432 E207.81909
M204 S500
G0 F15000 X117.739 Y117.06
M204 S800
G1 F2819.4 X122.115 Y121.437 E208.06612
M204 S500
G0 F15000 X122.794 Y121.437
M204 S800
G1 F2819.4 X118.039 Y116.681 E208.33454
M204 S500
G0 F15000 X118.718 Y116.681
M204 S800
G1 F2819.4 X122.999 Y120.963 E208.57621
M204 S500
G0 F15000 X122.548 Y119.833
M204 S800
G1 F2819.4 X119.397 Y116.681 E208.75409
M204 S500
G0 F15000 X120.075 Y116.681
M204 S800
G1 F2819.4 X122.494 Y119.1 E208.89063
M204 S500
G0 F15000 X122.572 Y118.499
M204 S800
G1 F2819.4 X120.754 Y116.681 E208.99325
M204 S500
G0 F15000 X121.433 Y116.681
M204 S800
G1 F2819.4 X122.724 Y117.972 E209.06612
M204 S500
G0 F15000 X122.945 Y117.514
M204 S800
G1 F2819.4 X122.112 Y116.681 E209.11314
M204 S500
G0 F15000 X122.791 Y116.681
M204 S800
G1 F2819.4 X123.223 Y117.114 E209.13755
M204 S500
G0 F15000 X122.642 Y115.981
G1 F1800 E208.53755
;MESH:NONMESH
G0 F300 X122.642 Y115.981 Z2.64
G0 F15000 X117.779 Y116.249
G0 X115.329 Y118.443
;TIME_ELAPSED:239.353286
;LAYER:11
M204 S800
;TYPE:WALL-INNER
;MESH:RS_Fan-Housing-Clamp-Rev1.stl
G1 F1800 E209.13755
G1 F2888.6 X115.94 Y118.253 E209.16309
G1 X116.328 Y118.067 E209.18026
G1 X116.701 Y117.837 E209.19775
G1 X117.087 Y117.527 E209.21751
G1 X117.438 Y117.164 E209.23766
G1 X117.73 Y116.761 E209.25753
G1 X117.975 Y116.323 E209.27756
G1 X118.153 Y115.858 E209.29743
G1 X118.257 Y115.454 E209.31408
G1 X118.323 Y114.973 E209.33346
G1 X118.326 Y114.475 E209.35333
G1 X118.272 Y114.018 E209.3717
G1 X118.138 Y113.497 E209.39317
G1 X118.092 Y113.38 E209.39819
G1 X122.909 Y113.38 E209.59045
G1 X122.847 Y113.542 E209.59737
G1 X122.743 Y113.947 E209.61406
G1 X122.68 Y114.42 E209.6331
G1 X122.669 Y114.885 E209.65167
G1 X122.757 Y115.529 E209.67761
G1 X122.947 Y116.14 E209.70315
G1 X123.133 Y116.528 E209.72032
G1 X123.363 Y116.901 E209.73781
G1 X123.506 Y117.079 E209.74692
G1 X123.296 Y117.31 E209.75938
G1 X122.963 Y117.866 E209.78525
G1 X122.766 Y118.408 E209.80827
G1 X122.665 Y119.058 E209.83452
G1 X122.694 Y119.638 E209.8577
G1 X122.854 Y120.279 E209.88407
G1 X123.15 Y120.879 E209.91077
G1 X123.498 Y121.33 E209.93351
G1 X123.817 Y121.62 E209.95071
G1 X108.62 Y121.62 E210.55726
G1 X108.621 Y113.38 E210.88614
G1 X110.909 Y113.38 E210.97746
G1 X110.847 Y113.542 E210.98438
G1 X110.743 Y113.947 E211.00107
G1 X110.68 Y114.42 E211.02011
G1 X110.669 Y114.885 E211.03868
G1 X110.757 Y115.529 E211.06462
G1 X110.947 Y116.14 E211.09016
G1 X111.133 Y116.528 E211.10733
G1 X111.363 Y116.901 E211.12482
G1 X111.673 Y117.287 E211.14458
G1 X112.036 Y117.638 E211.16473
G1 X112.439 Y117.93 E211.1846
G1 X112.877 Y118.175 E211.20463
G1 X113.342 Y118.353 E211.2245
G1 X113.747 Y118.457 E211.24119
G1 X114.22 Y118.52 E211.26023
G1 X114.668 Y118.531 E211.27812
G0 F2599.8 X114.685 Y118.531
M204 S500
G0 F15000 X115.225 Y117.973
M204 S800
G1 F2888.6 X115.764 Y117.805 E211.30065
G1 X116.098 Y117.645 E211.31543
G1 X116.424 Y117.444 E211.33072
G1 X116.763 Y117.172 E211.34807
G1 X117.069 Y116.855 E211.36565
G1 X117.325 Y116.502 E211.38306
G1 X117.539 Y116.119 E211.40057
G1 X117.695 Y115.712 E211.41796
G1 X117.785 Y115.361 E211.43243
G1 X117.843 Y114.939 E211.44943
G1 X117.846 Y114.502 E211.46687
G1 X117.799 Y114.106 E211.48279
G1 X117.681 Y113.646 E211.50174
G1 X117.532 Y113.27 E211.51788
G1 X117.318 Y112.9 E211.53494
G1 X123.674 Y112.9 E211.78862
G1 X123.461 Y113.281 E211.80604
G1 X123.305 Y113.688 E211.82344
G1 X123.215 Y114.039 E211.8379
G1 X123.159 Y114.457 E211.85474
G1 X123.15 Y114.858 E211.87074
G1 X123.227 Y115.425 E211.89358
G1 X123.395 Y115.964 E211.91612
G1 X123.555 Y116.298 E211.9309
G1 X123.756 Y116.624 E211.94618
G1 X124.028 Y116.963 E211.96353
G1 X124.18 Y117.11 E211.97197
G1 X123.997 Y117.252 E211.97611
G1 X123.683 Y117.598 E211.99476
G1 X123.398 Y118.073 E212.01687
G1 X123.233 Y118.528 E212.03619
G1 X123.147 Y119.083 E212.0586
G1 X123.171 Y119.567 E212.07795
G1 X123.307 Y120.113 E212.1004
G1 X123.559 Y120.624 E212.12314
G1 X123.852 Y121.003 E212.14226
G1 X124.198 Y121.317 E212.16091
G1 X124.667 Y121.6 E212.18277
G1 X125.127 Y121.767 E212.20231
G1 X125.683 Y121.853 E212.22476
G1 X126.167 Y121.829 E212.2441
G1 X126.713 Y121.693 E212.26656
G1 X127.224 Y121.441 E212.2893
G1 X127.603 Y121.148 E212.30842
G1 X127.917 Y120.802 E212.32707
G1 X128.202 Y120.327 E212.34918
G1 X128.3 Y120.057 E212.36064
G1 X128.3 Y120.802 E212.37794
G1 X128.3 Y122.1 E212.42974
G1 X126.713 Y122.1 E212.49308
G1 X126.167 Y122.1 E212.50846
G1 X125.683 Y122.1 E212.5189
G1 X125.127 Y122.1 E212.53232
G1 X108.14 Y122.1 E213.2103
G1 X108.141 Y112.9 E213.5775
G1 X111.674 Y112.9 E213.71851
G1 X111.461 Y113.281 E213.73593
G1 X111.305 Y113.688 E213.75332
G1 X111.215 Y114.039 E213.76779
G1 X111.159 Y114.457 E213.78462
G1 X111.15 Y114.858 E213.80063
G1 X111.227 Y115.425 E213.82347
G1 X111.395 Y115.964 E213.846
G1 X111.555 Y116.298 E213.86078
G1 X111.756 Y116.624 E213.87607
G1 X112.028 Y116.963 E213.89341
G1 X112.345 Y117.269 E213.911
G1 X112.698 Y117.525 E213.9284
G1 X113.081 Y117.739 E213.94591
G1 X113.488 Y117.895 E213.96331
G1 X113.839 Y117.985 E213.97777
G1 X114.257 Y118.041 E213.9946
G1 X114.564 Y118.048 E214.00686
G0 F2599.8 X114.658 Y118.05
G0 X115.225 Y117.973
M204 S500
G0 F15000 X115.121 Y117.503
M204 S800
G1 F2888.6 X115.588 Y117.357 E214.02639
G1 X115.868 Y117.223 E214.03878
G1 X116.147 Y117.051 E214.05186
G1 X116.439 Y116.817 E214.06679
G1 X116.7 Y116.546 E214.08181
G1 X116.92 Y116.243 E214.09676
G1 X117.103 Y115.915 E214.11175
G1 X117.237 Y115.566 E214.12667
G1 X117.313 Y115.269 E214.1389
G1 X117.363 Y114.904 E214.15361
G1 X117.366 Y114.529 E214.16858
G1 X117.326 Y114.194 E214.18204
G1 X117.224 Y113.795 E214.19848
G1 X117.099 Y113.48 E214.212
G1 X116.855 Y113.058 E214.23146
G1 X116.617 Y112.761 E214.24665
G1 X116.346 Y112.5 E214.26167
G1 X116.236 Y112.42 E214.2671
G1 X124.764 Y112.42 E214.60747
G1 X124.561 Y112.583 E214.61786
G1 X124.3 Y112.854 E214.63287
G1 X124.08 Y113.157 E214.64782
G1 X123.897 Y113.485 E214.66281
G1 X123.763 Y113.834 E214.67773
G1 X123.687 Y114.131 E214.68997
G1 X123.638 Y114.494 E214.70459
G1 X123.631 Y114.831 E214.71804
G1 X123.697 Y115.321 E214.73777
G1 X123.843 Y115.788 E214.7573
G1 X123.977 Y116.068 E214.76969
G1 X124.149 Y116.347 E214.78277
G1 X124.383 Y116.639 E214.79771
G1 X124.654 Y116.9 E214.81272
G1 X124.957 Y117.12 E214.82767
G1 X125.04 Y117.166 E214.83146
G1 X124.632 Y117.368 E214.84351
G1 X124.324 Y117.606 E214.85904
G1 X124.07 Y117.886 E214.87413
G1 X123.833 Y118.28 E214.89248
G1 X123.7 Y118.647 E214.90806
G1 X123.629 Y119.108 E214.92668
G1 X123.648 Y119.497 E214.94222
G1 X123.76 Y119.947 E214.96073
G1 X123.968 Y120.368 E214.97947
G1 X124.206 Y120.676 E214.99501
G1 X124.486 Y120.93 E215.0101
G1 X124.875 Y121.165 E215.02824
G1 X125.247 Y121.3 E215.04403
G1 X125.708 Y121.371 E215.06265
G1 X126.097 Y121.352 E215.07819
G1 X126.547 Y121.24 E215.0967
G1 X126.968 Y121.032 E215.11544
G1 X127.276 Y120.794 E215.13098
G1 X127.53 Y120.514 E215.14607
G1 X127.767 Y120.12 E215.16442
G1 X127.9 Y119.753 E215.18
G1 X127.971 Y119.292 E215.19861
G1 X127.952 Y118.903 E215.21416
G1 X127.84 Y118.453 E215.23267
G1 X127.632 Y118.032 E215.25141
G1 X127.394 Y117.724 E215.26694
G1 X127.143 Y117.496 E215.28048
G1 X127.588 Y117.357 E215.29115
G1 X127.868 Y117.223 E215.30354
G1 X128.147 Y117.051 E215.31662
G1 X128.439 Y116.817 E215.33156
G1 X128.7 Y116.546 E215.34657
G1 X128.78 Y116.436 E215.352
G1 X128.78 Y122.58 E215.59722
G1 X107.66 Y122.58 E216.44017
G1 X107.661 Y112.42 E216.84568
G1 X112.764 Y112.42 E217.04935
G1 X112.561 Y112.583 E217.05974
G1 X112.3 Y112.854 E217.07475
G1 X112.08 Y113.157 E217.0897
G1 X111.897 Y113.485 E217.10469
G1 X111.763 Y113.834 E217.11961
G1 X111.687 Y114.131 E217.13185
G1 X111.638 Y114.494 E217.14647
G1 X111.631 Y114.831 E217.15992
G1 X111.697 Y115.321 E217.17965
G1 X111.843 Y115.788 E217.19918
G1 X111.977 Y116.068 E217.21157
G1 X112.149 Y116.347 E217.22465
G1 X112.383 Y116.639 E217.23959
G1 X112.654 Y116.9 E217.2546
G1 X112.957 Y117.12 E217.26955
G1 X113.285 Y117.303 E217.28454
G1 X113.634 Y117.437 E217.29946
G1 X113.931 Y117.513 E217.3117
G1 X114.294 Y117.562 E217.32632
G1 X114.459 Y117.566 E217.3329
G0 F2599.8 X114.631 Y117.569
G0 X115.121 Y117.503
M204 S500
G0 F15000 X115.017 Y117.033
M204 S800
;TYPE:WALL-OUTER
G1 F2888.6 X115.412 Y116.909 E217.34943
G1 X115.638 Y116.801 E217.35943
G1 X115.87 Y116.658 E217.3703
G1 X116.115 Y116.462 E217.38282
G1 X116.331 Y116.237 E217.39527
G1 X116.515 Y115.984 E217.40776
G1 X116.667 Y115.711 E217.42023
G1 X116.779 Y115.42 E217.43268
G1 X116.841 Y115.177 E217.44268
G1 X116.883 Y114.869 E217.45509
G1 X116.886 Y114.556 E217.46758
G1 X116.853 Y114.283 E217.47856
G1 X116.766 Y113.943 E217.49257
G1 X116.666 Y113.689 E217.50346
G1 X116.458 Y113.33 E217.52002
G1 X116.262 Y113.085 E217.53254
G1 X116.037 Y112.869 E217.54499
G1 X115.784 Y112.685 E217.55748
G1 X115.511 Y112.533 E217.56995
G1 X115.22 Y112.421 E217.5824
G1 X114.977 Y112.359 E217.5924
G1 X114.669 Y112.317 E217.60481
G1 X114.564 Y112.311 E217.60901
G1 X114.254 Y112.323 E217.62139
G1 X113.983 Y112.367 E217.63235
G1 X113.588 Y112.491 E217.64887
G1 X113.362 Y112.599 E217.65887
G1 X113.13 Y112.742 E217.66975
G1 X112.885 Y112.938 E217.68227
G1 X112.669 Y113.163 E217.69472
G1 X112.485 Y113.416 E217.7072
G1 X112.333 Y113.689 E217.71968
G1 X112.221 Y113.98 E217.73212
G1 X112.159 Y114.223 E217.74213
G1 X112.117 Y114.531 E217.75454
G1 X112.112 Y114.804 E217.76543
G1 X112.167 Y115.217 E217.78206
G1 X112.291 Y115.612 E217.79859
G1 X112.399 Y115.838 E217.80858
G1 X112.542 Y116.07 E217.81946
G1 X112.738 Y116.315 E217.83198
G1 X112.963 Y116.531 E217.84443
G1 X113.216 Y116.715 E217.85692
G1 X113.489 Y116.867 E217.86939
G1 X113.78 Y116.979 E217.88183
G1 X114.023 Y117.041 E217.89184
G1 X114.331 Y117.083 E217.90425
G1 X114.354 Y117.084 E217.90517
G0 F2599.8 X114.604 Y117.088
G0 X115.017 Y117.033
M204 S500
G0 F15000 X115.131 Y117.548
G1 F1800 E217.30517
G0 F15000 X114.974 Y116.108
G0 X127.664 Y113.777
G0 X128.78 Y112.964
M204 S800
;TYPE:WALL-INNER
G1 F1800 E217.90517
G1 F2888.6 X128.617 Y112.761 E217.91556
G1 X128.346 Y112.5 E217.93058
G1 X128.236 Y112.42 E217.93601
G1 X128.78 Y112.42 E217.94498
G1 X128.78 Y112.964 E217.95404
M204 S500
G1 F1800 E217.35404
G0 F15000 X127.717 Y113.847
G0 X126.649 Y116.178
G0 X126.604 Y117.088
M204 S800
;TYPE:WALL-OUTER
G1 F1800 E217.95404
G1 F2888.6 X127.017 Y117.033 E217.97067
G1 X127.412 Y116.909 E217.9872
G1 X127.638 Y116.801 E217.99719
G1 X127.87 Y116.658 E218.00807
G1 X128.115 Y116.462 E218.02059
G1 X128.331 Y116.237 E218.03304
G1 X128.515 Y115.984 E218.04553
G1 X128.667 Y115.711 E218.058
G1 X128.779 Y115.42 E218.07044
G1 X128.841 Y115.177 E218.08045
G1 X128.883 Y114.869 E218.09286
G1 X128.886 Y114.556 E218.10535
G1 X128.853 Y114.283 E218.11633
G1 X128.766 Y113.943 E218.13034
G1 X128.666 Y113.689 E218.14123
G1 X128.458 Y113.33 E218.15779
G1 X128.262 Y113.085 E218.17031
G1 X128.037 Y112.869 E218.18276
G1 X127.784 Y112.685 E218.19525
G1 X127.511 Y112.533 E218.20772
G1 X127.22 Y112.421 E218.22016
G1 X126.977 Y112.359 E218.23017
G1 X126.669 Y112.317 E218.24258
G1 X126.564 Y112.311 E218.24678
G1 X126.254 Y112.323 E218.25916
G1 X125.983 Y112.367 E218.27012
G1 X125.588 Y112.491 E218.28664
G1 X125.362 Y112.599 E218.29664
G1 X125.13 Y112.742 E218.30752
G1 X124.885 Y112.938 E218.32004
G1 X124.669 Y113.163 E218.33249
G1 X124.485 Y113.416 E218.34497
G1 X124.333 Y113.689 E218.35744
G1 X124.221 Y113.98 E218.36989
G1 X124.159 Y114.223 E218.3799
G1 X124.117 Y114.531 E218.3923
G1 X124.112 Y114.804 E218.4032
G1 X124.167 Y115.217 E218.41983
G1 X124.291 Y115.612 E218.43636
G1 X124.399 Y115.838 E218.44635
G1 X124.542 Y116.07 E218.45723
G1 X124.738 Y116.315 E218.46975
G1 X124.963 Y116.531 E218.4822
G1 X125.216 Y116.715 E218.49469
G1 X125.489 Y116.867 E218.50716
G1 X125.78 Y116.979 E218.5196
G1 X125.943 Y117.021 E218.52632
G0 F2599.8 X126.023 Y117.041
G0 X126.331 Y117.083
M204 S500
G1 F1800 E217.92632
G0 F15000 X126.091 Y118.47
G0 X125.772 Y119.985
G0 X125.733 Y120.889
M204 S800
G1 F1800 E218.52632
G1 F2888.6 X126.027 Y120.875 E218.53807
G1 X126.381 Y120.787 E218.55263
G1 X126.712 Y120.623 E218.56737
G1 X126.949 Y120.44 E218.57932
G1 X127.143 Y120.226 E218.59085
G1 X127.332 Y119.912 E218.60548
G1 X127.433 Y119.634 E218.61728
G1 X127.489 Y119.267 E218.6321
G1 X127.475 Y118.973 E218.64385
G1 X127.387 Y118.619 E218.65841
G1 X127.223 Y118.288 E218.67315
G1 X127.04 Y118.051 E218.6851
G1 X126.826 Y117.857 E218.69663
G1 X126.512 Y117.668 E218.71126
G1 X126.234 Y117.567 E218.72306
G1 X125.867 Y117.511 E218.73788
G1 X125.573 Y117.525 E218.74963
G1 X125.219 Y117.613 E218.76419
G1 X124.888 Y117.777 E218.77893
G1 X124.651 Y117.96 E218.79088
G1 X124.457 Y118.174 E218.80241
G1 X124.268 Y118.488 E218.81704
G1 X124.167 Y118.766 E218.82884
G1 X124.111 Y119.133 E218.84366
G1 X124.125 Y119.427 E218.85541
G1 X124.213 Y119.781 E218.86997
G1 X124.377 Y120.112 E218.88471
G1 X124.56 Y120.349 E218.89666
G1 X124.774 Y120.543 E218.90819
G1 X125.083 Y120.73 E218.9226
G1 X125.089 Y120.733 E218.92287
G0 F2599.8 X125.366 Y120.833
M204 S500
G0 F15000 X125.706 Y121.416
G1 F1800 E218.32287
G0 F15000 X125.622 Y119.965
G0 X107.18 Y123.965
G0 X107.18 Y123.06
M204 S800
G1 F1800 E218.92287
G1 F2888.6 X107.181 Y111.94 E219.3667
G1 X129.26 Y111.94 E220.24792
G1 X129.26 Y123.06 E220.69174
G1 X107.846 Y123.06 E221.54642
G0 F2599.8 X107.18 Y123.06
M204 S500
G1 F1800 E220.94642
G0 F15000 X107.18 Y123.965
G0 X126.238 Y119.853
G0 X127.777 Y121.62
M204 S800
;TYPE:WALL-INNER
G1 F1800 E221.54642
G1 F2888.6 X127.82 Y121.587 E221.54858
G1 X127.82 Y121.62
G1 X127.777 Y121.62
M204 S500
G0 F15000 X127.982 Y117.7
M204 S800
G1 F2888.6 X128.3 Y117.52 E221.56317
G1 X128.293 Y118.287 E221.59378
G1 X128.041 Y117.776 E221.5975
G1 X127.982 Y117.7
M204 S500
G1 F1800 E220.9975
G0 F15000 X127.077 Y116.069
G0 X125.153 Y115.328
G0 X122.717 Y116.249
G1 F1800 E221.5975
G0 F15000 X122.79 Y116.282
M204 S800
;TYPE:FILL
G1 F5777.3 X121.225 Y113.572 E221.7224
M204 S500
G0 F15000 X121.922 Y113.572
M204 S800
G1 F5777.3 X120.343 Y116.308 E221.84848
M204 S500
G0 F15000 X120.343 Y116.16
G0 X118.552 Y115.671
G0 X118.41 Y115.634
M204 S800
G1 F5777.3 X122.589 Y115.634 E222.01527
M204 S500
G1 F1800 E221.41527
G0 F15000 X122.448 Y115.676
G0 X118.275 Y116.249
G0 X115.849 Y115.321
G0 X113.153 Y115.328
G0 X110.717 Y116.249
G0 X110.448 Y115.676
G1 F1800 E222.01527
G0 F15000 X110.589 Y115.634
M204 S800
G1 F5777.3 X108.813 Y115.634 E222.08616
M204 S500
G0 F15000 X109.091 Y116.49
M204 S800
;TYPE:SKIN
G1 F2888.6 X110.594 Y116.49 E222.14614
G1 X110.72 Y116.753 E222.15778
G1 X110.979 Y117.173 E222.17748
G1 X111.325 Y117.604 E222.19954
G1 X111.733 Y117.999 E222.2222
G1 X112.186 Y118.327 E222.24452
G1 X112.677 Y118.602 E222.26699
G1 X113.199 Y118.802 E222.2893
G1 X113.657 Y118.919 E222.30816
G1 X114.183 Y118.99 E222.32935
G1 X114.711 Y119.001 E222.35043
G1 X115.431 Y118.903 E222.37943
G1 X116.112 Y118.692 E222.40788
G1 X116.553 Y118.48 E222.42741
G1 X116.973 Y118.221 E222.44711
G1 X117.404 Y117.875 E222.46917
G1 X117.799 Y117.467 E222.49183
G1 X118.127 Y117.014 E222.51415
G1 X118.402 Y116.523 E222.53661
G1 X118.415 Y116.49 E222.53803
G1 X122.594 Y116.49 E222.70482
G1 X122.72 Y116.753 E222.71646
G1 X122.903 Y117.05 E222.73039
G1 X122.536 Y117.663 E222.7589
G1 X122.308 Y118.291 E222.78557
G1 X122.193 Y119.033 E222.81554
G1 X122.226 Y119.707 E222.84247
G1 X122.41 Y120.442 E222.87271
G1 X122.749 Y121.13 E222.90332
G1 X122.764 Y121.15 E222.90432
G1 X109.09 Y121.15 E223.45008
G1 X109.091 Y117.156 E223.60949
G0 F2599.8 X109.091 Y116.49
M204 S500
G0 F15000 X109.283 Y116.764
M204 S800
G1 F2888.6 X109.366 Y116.681 E223.61417
M204 S500
M204 S800
G1 F2888.6 X109.283 Y117.443 E223.65718
M204 S500
G0 F15000 X109.283 Y118.122
M204 S800
G1 F2888.6 X110.554 Y116.85 E223.72895
M204 S500
G0 F15000 X110.813 Y117.27
M204 S800
G1 F2888.6 X109.283 Y118.801 E223.81534
M204 S500
G0 F15000 X109.282 Y119.48
M204 S800
G1 F2888.6 X111.114 Y117.649 E223.91872
M204 S500
M204 S800
G1 F2888.6 X109.282 Y120.159 E224.04103
M204 S500
G0 F15000 X109.282 Y120.838
M204 S800
G1 F2888.6 X111.821 Y118.298 E224.18437
M204 S500
G0 F15000 X112.229 Y118.57
M204 S800
G1 F2888.6 X109.841 Y120.957 E224.31913
M204 S500
M204 S800
G1 F2888.6 X112.673 Y118.805 E224.44063
M204 S500
G0 F15000 X113.166 Y118.99
M204 S800
G1 F2888.6 X111.199 Y120.957 E224.55166
M204 S500
M204 S800
G1 F2888.6 X113.716 Y119.119 E224.6554
M204 S500
M204 S800
G1 F2888.6 X112.557 Y120.957 E224.75548
M204 S500
M204 S800
G1 F2888.6 X115.046 Y119.146 E224.85767
M204 S500
G0 F15000 X115.922 Y118.95
M204 S800
G1 F2888.6 X113.914 Y120.957 E224.97098
M204 S500
M204 S800
G1 F2888.6 X118.868 Y116.682 E225.21228
M204 S500
G0 F15000 X119.547 Y116.682
M204 S800
G1 F2888.6 X115.272 Y120.957 E225.45358
M204 S500
M204 S800
G1 F2888.6 X120.226 Y116.682 E225.69488
M204 S500
G0 F15000 X120.905 Y116.682
M204 S800
G1 F2888.6 X116.63 Y120.957 E225.93618
M204 S500
M204 S800
G1 F2888.6 X121.584 Y116.682 E226.17748
M204 S500
G0 F15000 X122.263 Y116.682
M204 S800
G1 F2888.6 X117.987 Y120.957 E226.41881
M204 S500
M204 S800
G1 F2888.6 X122.637 Y116.987 E226.64292
M204 S500
G0 F15000 X122.637 Y116.16
G0 X122.153 Y116.16
G0 X122.153 Y118.149
M204 S800
G1 F2888.6 X119.345 Y120.957 E226.80141
M204 S500
M204 S800
G1 F2888.6 X122.005 Y118.976 E226.91323
M204 S500
G0 F15000 X122.028 Y119.631
M204 S800
G1 F2888.6 X120.703 Y120.957 E226.98805
M204 S500
M204 S800
G1 F2888.6 X122.148 Y120.191 E227.03131
M204 S500
G0 F15000 X122.32 Y120.697
M204 S800
G1 F2888.6 X122.06 Y120.957 E227.04599
M204 S500
G1 F1800 E226.44599
;MESH:NONMESH
G0 F300 X122.06 Y120.957 Z2.84
G0 F15000 X125.069 Y119.489
G0 X114.569 Y116.184
G0 X114.276 Y118.045
;TIME_ELAPSED:260.052112
;LAYER:12
M204 S800
;TYPE:WALL-INNER
G1 F1800 E227.04599
G1 F1789.4 X114.709 Y118.045 E227.06327
G1 X115.086 Y117.999 E227.07843
G1 X115.504 Y117.899 E227.09558
G1 X115.848 Y117.768 E227.11027
G1 X116.229 Y117.57 E227.12741
G1 X116.539 Y117.36 E227.14235
G1 X116.818 Y117.12 E227.15704
G1 X117.108 Y116.807 E227.17407
G1 X117.324 Y116.503 E227.18896
G1 X117.509 Y116.179 E227.20385
G1 X117.692 Y115.719 E227.22361
G1 X117.786 Y115.354 E227.23865
G1 X117.845 Y114.924 E227.25597
G1 X117.845 Y114.491 E227.27326
G1 X117.799 Y114.114 E227.28841
G1 X117.699 Y113.696 E227.30557
G1 X117.568 Y113.352 E227.32026
G1 X117.37 Y112.971 E227.3374
G1 X117.322 Y112.9 E227.34082
G1 X123.674 Y112.9 E227.59434
G1 X123.491 Y113.221 E227.60909
G1 X123.308 Y113.681 E227.62885
G1 X123.214 Y114.046 E227.64389
G1 X123.155 Y114.476 E227.66121
G1 X123.155 Y114.909 E227.6785
G1 X123.201 Y115.286 E227.69365
G1 X123.301 Y115.704 E227.71081
G1 X123.432 Y116.048 E227.7255
G1 X123.63 Y116.429 E227.74264
G1 X123.84 Y116.739 E227.75758
G1 X124.08 Y117.018 E227.77227
G1 X124.179 Y117.109 E227.77764
G1 X124.086 Y117.172 E227.77886
G1 X123.695 Y117.581 E227.80145
G1 X123.4 Y118.065 E227.82407
G1 X123.228 Y118.537 E227.84412
G1 X123.147 Y119.087 E227.86631
G1 X123.171 Y119.558 E227.88513
G1 X123.272 Y120.008 E227.90354
G1 X123.45 Y120.438 E227.92211
G1 X123.772 Y120.914 E227.94505
G1 X124.181 Y121.305 E227.96763
G1 X124.665 Y121.6 E227.99025
G1 X125.137 Y121.772 E228.01031
G1 X125.687 Y121.853 E228.03249
G1 X126.158 Y121.829 E228.05132
G1 X126.604 Y121.73 E228.06955
G1 X126.982 Y121.576 E228.08584
G1 X127.346 Y121.358 E228.10278
G1 X127.766 Y120.986 E228.12517
G1 X128.102 Y120.527 E228.14787
G1 X128.3 Y120.074 E228.1676
G1 X128.3 Y122.1 E228.24847
G1 X126.604 Y122.1 E228.31616
G1 X125.687 Y122.1 E228.34374
G1 X125.137 Y122.1 E228.3569
G1 X108.34 Y122.1 E229.0273
G1 X108.341 Y112.9 E229.39449
G1 X111.674 Y112.9 E229.52752
G1 X111.491 Y113.221 E229.54227
G1 X111.308 Y113.681 E229.56203
G1 X111.214 Y114.046 E229.57707
G1 X111.155 Y114.476 E229.59439
G1 X111.155 Y114.909 E229.61167
G1 X111.201 Y115.286 E229.62683
G1 X111.301 Y115.704 E229.64399
G1 X111.432 Y116.048 E229.65868
G1 X111.63 Y116.429 E229.67582
G1 X111.84 Y116.739 E229.69076
G1 X112.08 Y117.018 E229.70545
G1 X112.393 Y117.308 E229.72248
G1 X112.697 Y117.524 E229.73736
G1 X113.021 Y117.709 E229.75225
G1 X113.481 Y117.892 E229.77201
G1 X113.621 Y117.928 E229.77778
G0 F1610.4 X113.846 Y117.986
M204 S500
G0 F15000 X114.309 Y117.565
M204 S800
G1 F1789.4 X114.68 Y117.565 E229.79259
G1 X115.001 Y117.526 E229.8055
G1 X115.362 Y117.439 E229.82032
G1 X115.652 Y117.329 E229.8327
G1 X115.983 Y117.157 E229.84759
G1 X116.247 Y116.978 E229.86032
G1 X116.484 Y116.774 E229.8728
G1 X116.735 Y116.503 E229.88754
G1 X116.919 Y116.245 E229.90019
G1 X117.075 Y115.97 E229.91281
G1 X117.235 Y115.57 E229.93
G1 X117.314 Y115.261 E229.94273
G1 X117.365 Y114.891 E229.95764
G1 X117.365 Y114.52 E229.97244
G1 X117.326 Y114.199 E229.98535
G1 X117.239 Y113.838 E230.00017
G1 X117.129 Y113.548 E230.01255
G1 X116.957 Y113.217 E230.02744
G1 X116.778 Y112.953 E230.04017
G1 X116.574 Y112.716 E230.05265
G1 X116.303 Y112.465 E230.06739
G1 X116.24 Y112.42 E230.07048
G1 X124.265 Y112.42 E230.39078
G1 X124.755 Y112.42 E230.41033
G1 X124.516 Y112.626 E230.41291
G1 X124.265 Y112.897 E230.42313
G1 X124.081 Y113.155 E230.43578
G1 X123.925 Y113.43 E230.4484
G1 X123.765 Y113.83 E230.46559
G1 X123.686 Y114.139 E230.47832
G1 X123.635 Y114.509 E230.49323
G1 X123.635 Y114.88 E230.50804
G1 X123.674 Y115.201 E230.52094
G1 X123.761 Y115.562 E230.53576
G1 X123.871 Y115.852 E230.54814
G1 X124.043 Y116.183 E230.56303
G1 X124.222 Y116.447 E230.57576
G1 X124.426 Y116.684 E230.58824
G1 X124.697 Y116.935 E230.60299
G1 X124.955 Y117.119 E230.61563
G1 X125.045 Y117.17 E230.61976
G1 X124.791 Y117.275 E230.62505
G1 X124.397 Y117.541 E230.64402
G1 X124.078 Y117.875 E230.66246
G1 X123.835 Y118.274 E230.6811
G1 X123.696 Y118.655 E230.69729
G1 X123.629 Y119.11 E230.71565
G1 X123.648 Y119.493 E230.73095
G1 X123.731 Y119.862 E230.74605
G1 X123.875 Y120.209 E230.76104
G1 X124.141 Y120.603 E230.78002
G1 X124.475 Y120.922 E230.79845
G1 X124.874 Y121.165 E230.81709
G1 X125.255 Y121.304 E230.83328
G1 X125.71 Y121.371 E230.85164
G1 X126.093 Y121.352 E230.86694
G1 X126.46 Y121.27 E230.88195
G1 X126.767 Y121.145 E230.89518
G1 X127.061 Y120.969 E230.90886
G1 X127.409 Y120.661 E230.92741
G1 X127.683 Y120.286 E230.94594
G1 X127.87 Y119.859 E230.96455
G1 X127.955 Y119.471 E230.9804
G1 X127.97 Y119.096 E230.99538
G1 X127.92 Y118.728 E231.0102
G1 X127.805 Y118.363 E231.02548
G1 X127.575 Y117.946 E231.04448
G1 X127.261 Y117.591 E231.0634
G1 X127.13 Y117.495 E231.06988
G1 X127.362 Y117.439 E231.07349
G1 X127.652 Y117.329 E231.08166
G1 X127.983 Y117.157 E231.09655
G1 X128.247 Y116.978 E231.10928
G1 X128.484 Y116.774 E231.12176
G1 X128.735 Y116.503 E231.13651
G1 X128.78 Y116.44 E231.1396
G1 X128.78 Y122.58 E231.38466
G1 X107.86 Y122.58 E232.21962
G1 X107.861 Y112.42 E232.62513
G1 X112.265 Y112.42 E232.8009
G1 X112.755 Y112.42 E232.82046
G1 X112.516 Y112.626 E232.82304
G1 X112.265 Y112.897 E232.83505
G1 X112.081 Y113.155 E232.8477
G1 X111.925 Y113.43 E232.86031
G1 X111.765 Y113.83 E232.87751
G1 X111.686 Y114.139 E232.89024
G1 X111.635 Y114.509 E232.90515
G1 X111.635 Y114.88 E232.91995
G1 X111.674 Y115.201 E232.93286
G1 X111.761 Y115.562 E232.94768
G1 X111.871 Y115.852 E232.96006
G1 X112.043 Y116.183 E232.97495
G1 X112.222 Y116.447 E232.98768
G1 X112.426 Y116.684 E233.00016
G1 X112.697 Y116.935 E233.0149
G1 X112.955 Y117.119 E233.02755
G1 X113.23 Y117.275 E233.04017
G1 X113.63 Y117.435 E233.05736
G1 X113.875 Y117.498 E233.06746
G0 F1610.4 X113.939 Y117.514
G0 X114.309 Y117.565
M204 S500
G0 F15000 X114.342 Y117.085
M204 S800
;TYPE:WALL-OUTER
G1 F1789.4 X114.651 Y117.085 E233.07979
G1 X114.915 Y117.053 E233.09041
G1 X115.22 Y116.979 E233.10293
G1 X115.456 Y116.89 E233.113
G1 X115.737 Y116.744 E233.12564
G1 X115.955 Y116.596 E233.13615
G1 X116.15 Y116.428 E233.14643
G1 X116.362 Y116.199 E233.15888
G1 X116.514 Y115.986 E233.16933
G1 X116.642 Y115.761 E233.17966
G1 X116.778 Y115.421 E233.19427
G1 X116.842 Y115.169 E233.20465
G1 X116.885 Y114.858 E233.21718
G1 X116.885 Y114.549 E233.22951
G1 X116.853 Y114.285 E233.24013
G1 X116.779 Y113.98 E233.25265
G1 X116.69 Y113.744 E233.26272
G1 X116.544 Y113.463 E233.27536
G1 X116.396 Y113.245 E233.28588
G1 X116.228 Y113.05 E233.29615
G1 X115.999 Y112.838 E233.3086
G1 X115.786 Y112.686 E233.31905
G1 X115.561 Y112.558 E233.32938
G1 X115.221 Y112.422 E233.344
G1 X114.969 Y112.358 E233.35437
G1 X114.658 Y112.315 E233.3669
G1 X114.5 Y112.31 E233.37321
G1 X114.242 Y112.323 E233.38352
G1 X113.935 Y112.378 E233.39597
G1 X113.639 Y112.472 E233.40837
G1 X113.353 Y112.603 E233.42092
G1 X113.045 Y112.804 E233.4356
G1 X112.85 Y112.972 E233.44587
G1 X112.638 Y113.201 E233.45833
G1 X112.486 Y113.414 E233.46877
G1 X112.358 Y113.639 E233.47911
G1 X112.222 Y113.979 E233.49372
G1 X112.158 Y114.231 E233.5041
G1 X112.115 Y114.542 E233.51663
G1 X112.115 Y114.851 E233.52896
G1 X112.147 Y115.115 E233.53958
G1 X112.221 Y115.42 E233.5521
G1 X112.31 Y115.656 E233.56217
G1 X112.456 Y115.937 E233.57481
G1 X112.604 Y116.155 E233.58532
G1 X112.772 Y116.35 E233.5956
G1 X113.001 Y116.562 E233.60805
G1 X113.214 Y116.714 E233.6185
G1 X113.439 Y116.842 E233.62883
G1 X113.693 Y116.944 E233.63975
G0 F1610.4 X113.779 Y116.978
G0 X114.031 Y117.042
G0 X114.342 Y117.085
M204 S500
G0 F15000 X114.306 Y117.611
G1 F1800 E233.03975
G0 F15000 X114.201 Y118.377
G0 X115.138 Y118.275
G0 X115.881 Y118.048
G0 X122.959 Y113.998
G0 X125.067 Y114.307
G0 X127.675 Y113.791
G0 X128.78 Y112.956
M204 S800
;TYPE:WALL-INNER
G1 F1800 E233.63975
G1 F1789.4 X128.574 Y112.716 E233.65238
G1 X128.303 Y112.465 E233.66712
G1 X128.24 Y112.42 E233.67021
G1 X128.78 Y112.42 E233.67927
G1 X128.78 Y112.956 E233.6881
M204 S500
G1 F1800 E233.0881
G0 F15000 X127.746 Y113.892
G0 X126.499 Y116.184
G0 X126.342 Y117.085
M204 S800
;TYPE:WALL-OUTER
G1 F1800 E233.6881
G1 F1789.4 X126.651 Y117.085 E233.70044
G1 X126.915 Y117.053 E233.71105
G1 X127.22 Y116.979 E233.72358
G1 X127.456 Y116.89 E233.73364
G1 X127.737 Y116.744 E233.74628
G1 X127.955 Y116.596 E233.7568
G1 X128.15 Y116.428 E233.76707
G1 X128.362 Y116.199 E233.77953
G1 X128.514 Y115.986 E233.78997
G1 X128.642 Y115.761 E233.8003
G1 X128.778 Y115.421 E233.81492
G1 X128.842 Y115.169 E233.82529
G1 X128.885 Y114.858 E233.83782
G1 X128.885 Y114.549 E233.85016
G1 X128.853 Y114.285 E233.86077
G1 X128.779 Y113.98 E233.8733
G1 X128.69 Y113.744 E233.88336
G1 X128.544 Y113.463 E233.896
G1 X128.396 Y113.245 E233.90652
G1 X128.228 Y113.05 E233.91679
G1 X127.999 Y112.838 E233.92925
G1 X127.786 Y112.686 E233.93969
G1 X127.561 Y112.558 E233.95002
G1 X127.221 Y112.422 E233.96464
G1 X126.969 Y112.358 E233.97502
G1 X126.658 Y112.315 E233.98755
G1 X126.5 Y112.31 E233.99386
G1 X126.242 Y112.323 E234.00417
G1 X125.935 Y112.378 E234.01662
G1 X125.639 Y112.472 E234.02901
G1 X125.353 Y112.603 E234.04157
G1 X125.045 Y112.804 E234.05624
G1 X124.85 Y112.972 E234.06652
G1 X124.638 Y113.201 E234.07897
G1 X124.486 Y113.414 E234.08942
G1 X124.358 Y113.639 E234.09975
G1 X124.222 Y113.979 E234.11436
G1 X124.158 Y114.231 E234.12474
G1 X124.115 Y114.542 E234.13727
G1 X124.115 Y114.851 E234.14961
G1 X124.147 Y115.115 E234.16022
G1 X124.221 Y115.42 E234.17275
G1 X124.31 Y115.656 E234.18281
G1 X124.456 Y115.937 E234.19545
G1 X124.604 Y116.155 E234.20597
G1 X124.772 Y116.35 E234.21624
G1 X125.001 Y116.562 E234.2287
G1 X125.214 Y116.714 E234.23914
G1 X125.439 Y116.842 E234.24947
G1 X125.693 Y116.944 E234.2604
G0 F1610.4 X125.779 Y116.978
G0 X126.031 Y117.042
M204 S500
G1 F1800 E233.6604
G0 F15000 X125.938 Y118.427
G0 X125.202 Y119.71
G0 X123.572 Y121.08
G0 X123.99 Y121.591
G1 F1800 E234.2604
G0 F15000 X125.373 Y120.836
M204 S800
G1 F1789.4 X125.734 Y120.889 E234.27496
G1 X126.028 Y120.875 E234.28671
G1 X126.316 Y120.81 E234.29849
G1 X126.552 Y120.714 E234.30866
G1 X126.776 Y120.58 E234.31908
G1 X127.052 Y120.336 E234.33378
G1 X127.264 Y120.045 E234.34815
G1 X127.411 Y119.71 E234.36275
G1 X127.477 Y119.409 E234.37505
G1 X127.489 Y119.119 E234.38663
G1 X127.45 Y118.833 E234.39815
G1 X127.362 Y118.553 E234.40987
G1 X127.18 Y118.224 E234.42488
G1 X126.936 Y117.948 E234.43958
G1 X126.645 Y117.736 E234.45395
G1 X126.31 Y117.589 E234.46855
G1 X126.009 Y117.523 E234.48085
G1 X125.866 Y117.511 E234.48658
G1 X125.572 Y117.525 E234.49832
G1 X125.284 Y117.59 E234.51011
G1 X125.02 Y117.7 E234.52152
G1 X124.708 Y117.91 E234.53653
G1 X124.461 Y118.169 E234.55082
G1 X124.27 Y118.483 E234.56549
G1 X124.164 Y118.773 E234.57781
G1 X124.111 Y119.134 E234.59237
G1 X124.125 Y119.428 E234.60412
G1 X124.19 Y119.716 E234.6159
G1 X124.3 Y119.98 E234.62732
G1 X124.51 Y120.292 E234.64233
G1 X124.769 Y120.539 E234.65661
G1 X124.777 Y120.544 E234.65699
G0 F1610.4 X125.083 Y120.73
G0 X125.373 Y120.836
M204 S500
G0 F15000 X125.244 Y121.347
G1 F1800 E234.05699
G0 F15000 X124.003 Y121.579
G0 X108.65 Y121.79
G1 F1800 E234.65699
G0 F15000 X107.38 Y123.06
M204 S800
G1 F1789.4 X107.381 Y111.94 E235.10081
G1 X129.26 Y111.94 E235.97405
G1 X129.26 Y123.06 E236.41787
G1 X108.046 Y123.06 E237.26457
G0 F1610.4 X107.38 Y123.06
M204 S500
G1 F1800 E236.66457
G0 F15000 X108.68 Y121.79
G0 X123.164 Y117.955
G0 X125.118 Y118.811
G0 X126.444 Y118.749
G0 X127.986 Y117.696
M204 S800
;TYPE:WALL-INNER
G1 F1800 E237.26457
G1 F1789.4 X128.229 Y117.57 E237.2755
G1 X128.3 Y117.522 E237.27892
G1 X128.3 Y118.338 E237.31149
G1 X128.248 Y118.173 E237.31839
G1 X127.986 Y117.696 E237.32716
M204 S500
G1 F1800 E236.72716
G0 F15000 X126.393 Y118.684
G0 X125.286 Y118.605
G0 X123.809 Y117.095
G0 X123.298 Y117.582
G1 F1800 E237.32716
G0 F15000 X123.423 Y117.66
M204 S800
;TYPE:FILL
G1 F3578.7 X120.785 Y113.092 E237.5377
M204 S500
G0 F15000 X120.785 Y113.24
G0 X122.363 Y113.24
G0 X122.363 Y113.092
M204 S800
G1 F3578.7 X117.273 Y121.908 E237.944
M204 S500
G0 F15000 X117.727 Y121.908
M204 S800
G1 F3578.7 X115.524 Y118.092 E238.11987
M204 S500
G0 F15000 X115.558 Y118.236
G0 X116.709 Y117.583
G0 X117.324 Y116.987
G0 X117.679 Y116.429
G0 X118.092 Y115.529
G0 X117.948 Y115.493
M204 S800
G1 F3578.7 X123.052 Y115.493 E238.32358
M204 S500
G0 F15000 X122.908 Y115.527
G0 X115.583 Y118.168
G0 X114.728 Y118.324
G0 X113.794 Y118.261
G0 X112.903 Y117.963
G0 X111.787 Y117.199
G0 X111.899 Y117.103
M204 S800
G1 F3578.7 X109.125 Y121.908 E238.54502
M204 S500
G0 F15000 X109.579 Y121.908
M204 S800
G1 F3578.7 X108.532 Y120.094 E238.62861
M204 S500
G0 F15000 X108.68 Y120.095
G0 X108.68 Y115.494
G0 X108.533 Y115.493
M204 S800
G1 F3578.7 X111.052 Y115.493 E238.72915
M204 S500
G0 F15000 X110.538 Y115.616
;MESH:NONMESH
G0 F300 X110.538 Y115.616 Z3.04
G0 F15000 X111.878 Y117.211
G0 X112.545 Y117.759
G0 X113.307 Y118.119
G0 X115.002 Y118.501
;TIME_ELAPSED:275.753159
;LAYER:13
M204 S800
;TYPE:WALL-INNER
G1 F2096.4 X115.486 Y118.404 E238.74886
G1 X115.895 Y118.269 E238.76605
G1 X116.277 Y118.095 E238.7828
G1 X116.692 Y117.843 E238.80218
G1 X117.031 Y117.576 E238.8194
G1 X117.327 Y117.288 E238.83588
G1 X117.596 Y116.958 E238.85288
G1 X117.824 Y116.609 E238.86951
G1 X118.041 Y116.164 E238.88927
G1 X118.204 Y115.693 E238.90917
G1 X118.301 Y115.199 E238.92926
G1 X118.333 Y114.7 E238.94922
G1 X118.301 Y114.198 E238.96929
G1 X118.204 Y113.714 E238.989
G1 X118.094 Y113.38 E239.00303
G1 X122.909 Y113.38 E239.19521
G1 X122.796 Y113.707 E239.20902
G1 X122.699 Y114.201 E239.22911
G1 X122.667 Y114.7 E239.24907
G1 X122.699 Y115.202 E239.26914
G1 X122.796 Y115.686 E239.28884
G1 X122.931 Y116.095 E239.30603
G1 X123.105 Y116.477 E239.32279
G1 X123.357 Y116.892 E239.34217
G1 X123.507 Y117.083 E239.35186
G1 X123.236 Y117.391 E239.36823
G1 X122.953 Y117.888 E239.39106
G1 X122.766 Y118.405 E239.413
G1 X122.665 Y119.061 E239.43949
G1 X122.694 Y119.644 E239.46279
G1 X122.856 Y120.293 E239.48949
G1 X123.157 Y120.889 E239.51614
G1 X123.513 Y121.345 E239.53923
G1 X123.827 Y121.62 E239.55589
G1 X109.02 Y121.62 E240.14687
G1 X109.021 Y113.38 E240.47574
G1 X110.909 Y113.38 E240.5511
G1 X110.796 Y113.707 E240.56491
G1 X110.699 Y114.201 E240.585
G1 X110.667 Y114.7 E240.60496
G1 X110.699 Y115.202 E240.62503
G1 X110.796 Y115.686 E240.64473
G1 X110.931 Y116.095 E240.66192
G1 X111.105 Y116.477 E240.67868
G1 X111.357 Y116.892 E240.69806
G1 X111.624 Y117.231 E240.71528
G1 X111.912 Y117.527 E240.73176
G1 X112.242 Y117.796 E240.74875
G1 X112.591 Y118.024 E240.76539
G1 X113.036 Y118.241 E240.78515
G1 X113.507 Y118.404 E240.80505
G1 X114.001 Y118.501 E240.82514
G1 X114.338 Y118.523 E240.83862
G0 F1886.8 X114.5 Y118.533
M204 S500
G0 F15000 X114.939 Y118.024
M204 S800
G1 F2096.4 X115.363 Y117.939 E240.85588
G1 X115.72 Y117.821 E240.87088
G1 X116.052 Y117.67 E240.88544
G1 X116.418 Y117.448 E240.90253
G1 X116.714 Y117.215 E240.91756
G1 X116.972 Y116.963 E240.93196
G1 X117.208 Y116.674 E240.94685
G1 X117.406 Y116.371 E240.96129
G1 X117.597 Y115.98 E240.97866
G1 X117.739 Y115.568 E240.99606
G1 X117.824 Y115.137 E241.01359
G1 X117.852 Y114.7 E241.03107
G1 X117.824 Y114.261 E241.04862
G1 X117.739 Y113.837 E241.06588
G1 X117.621 Y113.48 E241.08089
G1 X117.47 Y113.148 E241.09545
G1 X117.32 Y112.9 E241.10701
G1 X123.678 Y112.9 E241.36078
G1 X123.594 Y113.029 E241.36692
G1 X123.403 Y113.42 E241.38429
G1 X123.261 Y113.832 E241.40168
G1 X123.176 Y114.263 E241.41921
G1 X123.148 Y114.7 E241.43669
G1 X123.176 Y115.139 E241.45425
G1 X123.261 Y115.563 E241.47151
G1 X123.379 Y115.92 E241.48652
G1 X123.53 Y116.252 E241.50107
G1 X123.752 Y116.618 E241.51816
G1 X123.985 Y116.914 E241.53319
G1 X124.179 Y117.113 E241.54428
G1 X123.987 Y117.263 E241.54819
G1 X123.629 Y117.671 E241.56986
G1 X123.39 Y118.09 E241.58911
G1 X123.233 Y118.524 E241.60753
G1 X123.147 Y119.086 E241.63022
G1 X123.171 Y119.573 E241.64968
G1 X123.309 Y120.125 E241.67239
G1 X123.564 Y120.631 E241.69501
G1 X123.863 Y121.014 E241.7144
G1 X124.267 Y121.367 E241.73581
G1 X124.645 Y121.589 E241.75331
G1 X125.13 Y121.768 E241.77394
G1 X125.686 Y121.853 E241.79639
G1 X126.171 Y121.829 E241.81577
G1 X126.718 Y121.693 E241.83827
G1 X127.143 Y121.488 E241.8571
G1 X127.516 Y121.225 E241.87532
G1 X127.845 Y120.892 E241.894
G1 X128.098 Y120.525 E241.91179
G1 X128.3 Y120.097 E241.93068
G1 X128.3 Y120.892 E241.94847
G1 X128.3 Y122.1 E241.99669
G1 X126.718 Y122.1 E242.05983
G1 X126.171 Y122.1 E242.07523
G1 X125.686 Y122.1 E242.0857
G1 X125.13 Y122.1 E242.09909
G1 X108.54 Y122.1 E242.76123
G1 X108.541 Y112.9 E243.12842
G1 X111.678 Y112.9 E243.25363
G1 X111.594 Y113.029 E243.25977
G1 X111.403 Y113.42 E243.27714
G1 X111.261 Y113.832 E243.29453
G1 X111.176 Y114.263 E243.31207
G1 X111.148 Y114.7 E243.32954
G1 X111.176 Y115.139 E243.3471
G1 X111.261 Y115.563 E243.36436
G1 X111.379 Y115.92 E243.37937
G1 X111.53 Y116.252 E243.39392
G1 X111.752 Y116.618 E243.41101
G1 X111.985 Y116.914 E243.42604
G1 X112.237 Y117.172 E243.44044
G1 X112.526 Y117.408 E243.45533
G1 X112.829 Y117.606 E243.46978
G1 X113.22 Y117.797 E243.48714
G1 X113.632 Y117.939 E243.50454
G1 X114.063 Y118.024 E243.52207
G1 X114.273 Y118.038 E243.53047
G0 F1886.8 X114.5 Y118.052
G0 X114.939 Y118.024
M204 S500
G0 F15000 X114.876 Y117.547
M204 S800
G1 F2096.4 X115.24 Y117.474 E243.54529
G1 X115.545 Y117.373 E243.55811
G1 X115.828 Y117.245 E243.57051
G1 X116.144 Y117.053 E243.58527
G1 X116.397 Y116.854 E243.59811
G1 X116.617 Y116.639 E243.61039
G1 X116.82 Y116.39 E243.62321
G1 X116.988 Y116.133 E243.63547
G1 X117.153 Y115.796 E243.65044
G1 X117.274 Y115.443 E243.66534
G1 X117.347 Y115.075 E243.68031
G1 X117.371 Y114.7 E243.69531
G1 X117.347 Y114.324 E243.71035
G1 X117.274 Y113.96 E243.72516
G1 X117.173 Y113.655 E243.73799
G1 X117.045 Y113.372 E243.75038
G1 X116.853 Y113.056 E243.76514
G1 X116.654 Y112.803 E243.77799
G1 X116.439 Y112.583 E243.79027
G1 X116.239 Y112.42 E243.80056
G1 X124.763 Y112.42 E244.14078
G1 X124.603 Y112.546 E244.1489
G1 X124.383 Y112.761 E244.16118
G1 X124.18 Y113.01 E244.174
G1 X124.012 Y113.267 E244.18626
G1 X123.847 Y113.604 E244.20123
G1 X123.726 Y113.957 E244.21613
G1 X123.653 Y114.325 E244.2311
G1 X123.629 Y114.7 E244.2461
G1 X123.653 Y115.076 E244.26114
G1 X123.726 Y115.44 E244.27595
G1 X123.827 Y115.745 E244.28878
G1 X123.955 Y116.028 E244.30117
G1 X124.147 Y116.344 E244.31593
G1 X124.346 Y116.597 E244.32878
G1 X124.561 Y116.817 E244.34106
G1 X124.81 Y117.02 E244.35388
G1 X125.034 Y117.166 E244.36455
G1 X124.627 Y117.371 E244.3753
G1 X124.318 Y117.613 E244.39097
G1 X124.022 Y117.951 E244.4089
G1 X123.827 Y118.292 E244.42458
G1 X123.7 Y118.643 E244.43948
G1 X123.629 Y119.111 E244.45837
G1 X123.648 Y119.502 E244.47399
G1 X123.762 Y119.957 E244.49271
G1 X123.971 Y120.373 E244.5113
G1 X124.213 Y120.682 E244.52696
G1 X124.549 Y120.976 E244.54478
G1 X124.851 Y121.154 E244.55877
G1 X125.25 Y121.301 E244.57574
G1 X125.711 Y121.371 E244.59435
G1 X126.101 Y121.352 E244.60994
G1 X126.554 Y121.239 E244.62857
G1 X126.899 Y121.073 E244.64385
G1 X127.205 Y120.857 E244.6588
G1 X127.474 Y120.585 E244.67407
G1 X127.681 Y120.285 E244.68862
G1 X127.845 Y119.937 E244.70397
G1 X127.955 Y119.475 E244.72293
G1 X127.97 Y119.094 E244.73815
G1 X127.918 Y118.715 E244.75341
G1 X127.771 Y118.287 E244.77148
G1 X127.568 Y117.938 E244.78759
G1 X127.262 Y117.592 E244.80603
G1 X127.13 Y117.496 E244.81254
G1 X127.24 Y117.474 E244.81259
G1 X127.545 Y117.373 E244.81882
G1 X127.828 Y117.245 E244.83121
G1 X128.144 Y117.053 E244.84597
G1 X128.397 Y116.854 E244.85882
G1 X128.617 Y116.639 E244.8711
G1 X128.78 Y116.439 E244.8814
G1 X128.78 Y122.58 E245.1265
G1 X108.06 Y122.58 E245.95348
G1 X108.061 Y112.42 E246.35898
G1 X112.763 Y112.42 E246.54665
G1 X112.603 Y112.546 E246.55478
G1 X112.383 Y112.761 E246.56706
G1 X112.18 Y113.01 E246.57988
G1 X112.012 Y113.267 E246.59213
G1 X111.847 Y113.604 E246.60711
G1 X111.726 Y113.957 E246.622
G1 X111.653 Y114.325 E246.63698
G1 X111.629 Y114.7 E246.65197
G1 X111.653 Y115.076 E246.66701
G1 X111.726 Y115.44 E246.68183
G1 X111.827 Y115.745 E246.69465
G1 X111.955 Y116.028 E246.70705
G1 X112.147 Y116.344 E246.72181
G1 X112.346 Y116.597 E246.73465
G1 X112.561 Y116.817 E246.74693
G1 X112.81 Y117.02 E246.75975
G1 X113.067 Y117.188 E246.77201
G1 X113.404 Y117.353 E246.78698
G1 X113.757 Y117.474 E246.80188
G1 X114.125 Y117.547 E246.81685
G1 X114.21 Y117.553 E246.82025
G0 F1886.8 X114.5 Y117.571
G0 X114.876 Y117.547
M204 S500
G0 F15000 X114.813 Y117.07
M204 S800
;TYPE:WALL-OUTER
G1 F2096.4 X115.117 Y117.009 E246.83263
G1 X115.371 Y116.925 E246.84331
G1 X115.604 Y116.82 E246.85351
G1 X115.87 Y116.658 E246.86594
G1 X116.08 Y116.493 E246.8766
G1 X116.262 Y116.315 E246.88676
G1 X116.432 Y116.106 E246.89751
G1 X116.57 Y115.895 E246.90757
G1 X116.709 Y115.612 E246.92016
G1 X116.809 Y115.318 E246.93255
G1 X116.87 Y115.012 E246.945
G1 X116.89 Y114.7 E246.95748
G1 X116.87 Y114.387 E246.97
G1 X116.809 Y114.083 E246.98237
G1 X116.725 Y113.829 E246.99305
G1 X116.62 Y113.596 E247.00325
G1 X116.458 Y113.33 E247.01568
G1 X116.293 Y113.12 E247.02634
G1 X116.115 Y112.938 E247.0365
G1 X115.906 Y112.768 E247.04726
G1 X115.695 Y112.63 E247.05732
G1 X115.412 Y112.491 E247.0699
G1 X115.118 Y112.391 E247.0823
G1 X114.812 Y112.33 E247.09475
G1 X114.5 Y112.31 E247.10723
G1 X114.187 Y112.33 E247.11975
G1 X113.883 Y112.391 E247.13212
G1 X113.629 Y112.475 E247.1428
G1 X113.396 Y112.58 E247.153
G1 X113.13 Y112.742 E247.16543
G1 X112.92 Y112.907 E247.17609
G1 X112.738 Y113.085 E247.18625
G1 X112.568 Y113.294 E247.197
G1 X112.43 Y113.505 E247.20707
G1 X112.291 Y113.788 E247.21965
G1 X112.191 Y114.082 E247.23204
G1 X112.13 Y114.388 E247.2445
G1 X112.11 Y114.7 E247.25698
G1 X112.13 Y115.013 E247.26949
G1 X112.191 Y115.317 E247.28187
G1 X112.275 Y115.571 E247.29255
G1 X112.38 Y115.804 E247.30275
G1 X112.542 Y116.07 E247.31518
G1 X112.707 Y116.28 E247.32584
G1 X112.885 Y116.462 E247.336
G1 X113.094 Y116.632 E247.34675
G1 X113.305 Y116.77 E247.35681
G1 X113.588 Y116.909 E247.3694
G1 X113.882 Y117.009 E247.38179
G1 X114.148 Y117.062 E247.39262
G0 F1886.8 X114.188 Y117.07
G0 X114.5 Y117.09
G0 X114.813 Y117.07
M204 S500
G0 F15000 X114.881 Y117.593
G1 F1800 E246.79262
G0 F15000 X114.958 Y118.843
G0 X116.002 Y118.528
G0 X116.24 Y118.401
G0 X122.408 Y114.7
G0 X125.016 Y114.7
G0 X127.684 Y113.802
G0 X128.78 Y112.963
M204 S800
;TYPE:WALL-INNER
G1 F1800 E247.39262
G1 F2096.4 X128.654 Y112.803 E247.40074
G1 X128.439 Y112.583 E247.41302
G1 X128.239 Y112.42 E247.42332
G1 X128.78 Y112.42 E247.43394
G1 X128.78 Y112.963 E247.44324
M204 S500
G1 F1800 E246.84324
G0 F15000 X127.709 Y113.836
G0 X126.406 Y116.182
G0 X126.188 Y117.07
M204 S800
;TYPE:WALL-OUTER
G1 F1800 E247.44324
G1 F2096.4 X126.5 Y117.09 E247.45572
G1 X126.813 Y117.07 E247.46824
G1 X127.117 Y117.009 E247.48061
G1 X127.371 Y116.925 E247.49129
G1 X127.604 Y116.82 E247.50149
G1 X127.87 Y116.658 E247.51392
G1 X128.08 Y116.493 E247.52458
G1 X128.262 Y116.315 E247.53474
G1 X128.432 Y116.106 E247.54549
G1 X128.57 Y115.895 E247.55556
G1 X128.709 Y115.612 E247.56814
G1 X128.809 Y115.318 E247.58054
G1 X128.87 Y115.012 E247.59299
G1 X128.89 Y114.7 E247.60547
G1 X128.87 Y114.387 E247.61799
G1 X128.809 Y114.083 E247.63036
G1 X128.725 Y113.829 E247.64104
G1 X128.62 Y113.596 E247.65124
G1 X128.458 Y113.33 E247.66367
G1 X128.293 Y113.12 E247.67433
G1 X128.115 Y112.938 E247.68449
G1 X127.906 Y112.768 E247.69524
G1 X127.695 Y112.63 E247.7053
G1 X127.412 Y112.491 E247.71789
G1 X127.118 Y112.391 E247.73028
G1 X126.812 Y112.33 E247.74274
G1 X126.5 Y112.31 E247.75521
G1 X126.187 Y112.33 E247.76773
G1 X125.883 Y112.391 E247.78011
G1 X125.629 Y112.475 E247.79078
G1 X125.396 Y112.58 E247.80098
G1 X125.13 Y112.742 E247.81342
G1 X124.92 Y112.907 E247.82407
G1 X124.738 Y113.085 E247.83424
G1 X124.568 Y113.294 E247.84499
G1 X124.43 Y113.505 E247.85505
G1 X124.291 Y113.788 E247.86763
G1 X124.191 Y114.082 E247.88003
G1 X124.13 Y114.388 E247.89248
G1 X124.11 Y114.7 E247.90496
G1 X124.13 Y115.013 E247.91748
G1 X124.191 Y115.317 E247.92985
G1 X124.275 Y115.571 E247.94053
G1 X124.38 Y115.804 E247.95073
G1 X124.542 Y116.07 E247.96316
G1 X124.707 Y116.28 E247.97382
G1 X124.885 Y116.462 E247.98398
G1 X125.094 Y116.632 E247.99473
G1 X125.305 Y116.77 E248.0048
G1 X125.549 Y116.89 E248.01565
G0 F1886.8 X125.588 Y116.909
G0 X125.882 Y117.009
G0 X126.188 Y117.07
M204 S500
G1 F1800 E247.41565
G0 F15000 X125.974 Y118.434
G0 X125.771 Y119.985
G0 X125.736 Y120.889
M204 S800
G1 F1800 E248.01565
G1 F2096.4 X126.031 Y120.875 E248.02744
G1 X126.39 Y120.785 E248.04221
G1 X126.655 Y120.658 E248.05394
G1 X126.893 Y120.49 E248.06557
G1 X127.103 Y120.277 E248.0775
G1 X127.264 Y120.045 E248.08877
G1 X127.389 Y119.778 E248.10054
G1 X127.477 Y119.409 E248.11568
G1 X127.489 Y119.117 E248.12735
G1 X127.449 Y118.827 E248.13903
G1 X127.332 Y118.487 E248.15338
G1 X127.177 Y118.22 E248.1657
G1 X126.937 Y117.949 E248.18015
G1 X126.645 Y117.736 E248.19458
G1 X126.378 Y117.611 E248.20634
G1 X126.009 Y117.523 E248.22148
G1 X125.864 Y117.511 E248.22729
G1 X125.569 Y117.525 E248.23908
G1 X125.211 Y117.615 E248.25381
G1 X124.885 Y117.779 E248.26838
G1 X124.649 Y117.963 E248.28032
G1 X124.415 Y118.231 E248.29452
G1 X124.264 Y118.494 E248.30662
G1 X124.168 Y118.761 E248.31795
G1 X124.111 Y119.136 E248.33309
G1 X124.125 Y119.431 E248.34487
G1 X124.215 Y119.789 E248.35961
G1 X124.379 Y120.115 E248.37417
G1 X124.563 Y120.351 E248.38612
G1 X124.831 Y120.585 E248.40032
G1 X125.058 Y120.719 E248.41084
G1 X125.092 Y120.732 E248.41229
G0 F1886.8 X125.37 Y120.834
M204 S500
G0 F15000 X125.71 Y121.416
G1 F1800 E247.81229
G0 F15000 X125.633 Y119.967
G0 X107.58 Y123.965
G0 X107.58 Y123.06
M204 S800
G1 F1800 E248.41229
G1 F2096.4 X107.581 Y111.94 E248.85611
G1 X129.26 Y111.94 E249.72137
G1 X129.26 Y123.06 E250.16519
G1 X108.246 Y123.06 E251.00391
G0 F1886.8 X107.58 Y123.06
M204 S500
G1 F1800 E250.40391
G0 F15000 X107.58 Y123.965
G0 X126.248 Y119.845
G0 X127.789 Y121.62
M204 S800
;TYPE:WALL-INNER
G1 F1800 E251.00391
G1 F2096.4 X127.82 Y121.598 E251.00542
G1 X127.82 Y121.62
G1 X127.789 Y121.62
M204 S500
G0 F15000 X127.985 Y117.7
M204 S800
G1 F2096.4 X128.052 Y117.67 E251.00835
G1 X128.3 Y117.52 E251.01992
G1 X128.3 Y118.349 E251.05301
G1 X128.21 Y118.086 E251.0641
G1 X127.985 Y117.7 E251.0725
M204 S500
G1 F1800 E250.4725
G0 F15000 X126.392 Y118.683
G0 X125.201 Y118.691
G0 X123.17 Y117.08
G0 X122.933 Y117.239
G1 F1800 E251.0725
G0 F15000 X123.06 Y117.313
M204 S800
;TYPE:FILL
G1 F4192.9 X120.9 Y113.572 E251.24492
M204 S500
G0 F15000 X120.9 Y113.72
G0 X122.249 Y113.72
G0 X122.249 Y113.572
M204 S800
G1 F4192.9 X117.714 Y121.428 E251.60696
M204 S500
G0 F15000 X117.287 Y121.428
M204 S800
G1 F4192.9 X115.63 Y118.558 E251.73923
M204 S500
G0 F15000 X115.676 Y118.699
G0 X114.5 Y118.812
G0 X113.437 Y118.675
G0 X112.639 Y118.344
G0 X111.647 Y117.74
G0 X111.753 Y117.638
M204 S800
G1 F4192.9 X109.564 Y121.428 E251.91391
M204 S500
G0 F15000 X109.564 Y121.28
G0 X109.36 Y115.352
G0 X109.213 Y115.351
M204 S800
G1 F4192.9 X110.533 Y115.351 E251.9666
M204 S500
G0 F15000 X110.388 Y115.379
G0 X110.856 Y116.606
G0 X111.419 Y117.422
G0 X112.079 Y118.024
G0 X112.93 Y118.499
G0 X113.959 Y118.779
G0 X115.044 Y118.777
G0 X116.844 Y118.078
G0 X117.53 Y117.48
G0 X118.066 Y116.749
G0 X118.181 Y116.47
G0 X118.613 Y115.38
G0 X118.468 Y115.351
M204 S800
G1 F4192.9 X122.533 Y115.351 E252.12884
M204 S500
G0 F15000 X122.014 Y115.452
;MESH:NONMESH
G0 F300 X122.014 Y115.452 Z3.24
G0 F15000 X116.002 Y118.528
G0 X114.927 Y118.845
G0 X114.877 Y118.033
;TIME_ELAPSED:292.103392
;LAYER:14
M204 S800
;TYPE:WALL-INNER
G1 F2952.3 X115.327 Y117.948 E252.14712
G1 X115.869 Y117.762 E252.16999
G1 X116.374 Y117.48 E252.19307
G1 X116.764 Y117.174 E252.21286
G1 X117.07 Y116.851 E252.23062
G1 X117.325 Y116.503 E252.24784
G1 X117.54 Y116.115 E252.26554
G1 X117.694 Y115.712 E252.28276
G1 X117.792 Y115.331 E252.29846
G1 X117.846 Y114.895 E252.316
G1 X117.839 Y114.415 E252.33516
G1 X117.774 Y113.979 E252.35275
G1 X117.651 Y113.555 E252.37037
G1 X117.494 Y113.192 E252.38616
G1 X117.321 Y112.9 E252.3997
G1 X123.673 Y112.9 E252.65322
G1 X123.46 Y113.285 E252.67079
G1 X123.306 Y113.688 E252.688
G1 X123.209 Y114.069 E252.7037
G1 X123.152 Y114.511 E252.72148
G1 X123.167 Y115.077 E252.74408
G1 X123.252 Y115.527 E252.76236
G1 X123.438 Y116.069 E252.78523
G1 X123.72 Y116.574 E252.80832
G1 X124.026 Y116.964 E252.8281
G1 X124.179 Y117.109 E252.83651
G1 X124.088 Y117.17 E252.83687
G1 X123.754 Y117.509 E252.85587
G1 X123.495 Y117.883 E252.87402
G1 X123.272 Y118.392 E252.8962
G1 X123.168 Y118.855 E252.91514
G1 X123.149 Y119.318 E252.93364
G1 X123.212 Y119.792 E252.95272
G1 X123.355 Y120.233 E252.97123
G1 X123.563 Y120.628 E252.98904
G1 X123.865 Y121.018 E253.00873
G1 X124.28 Y121.378 E253.03066
G1 X124.65 Y121.591 E253.0477
G1 X125.121 Y121.767 E253.06777
G1 X125.692 Y121.853 E253.09081
G1 X126.164 Y121.828 E253.10968
G1 X126.613 Y121.726 E253.12805
G1 X127.04 Y121.549 E253.1465
G1 X127.51 Y121.23 E253.16917
G1 X127.846 Y120.891 E253.18822
G1 X128.105 Y120.517 E253.20638
G1 X128.3 Y120.072 E253.22577
G1 X128.3 Y120.891 E253.24417
G1 X128.3 Y122.1 E253.29242
G1 X126.613 Y122.1 E253.35975
G1 X125.692 Y122.1 E253.38759
G1 X125.121 Y122.1 E253.40136
G1 X108.74 Y122.1 E254.05516
G1 X108.741 Y112.9 E254.42235
G1 X111.673 Y112.9 E254.53938
G1 X111.46 Y113.285 E254.55694
G1 X111.306 Y113.688 E254.57416
G1 X111.209 Y114.069 E254.58985
G1 X111.152 Y114.511 E254.60764
G1 X111.167 Y115.077 E254.63023
G1 X111.252 Y115.527 E254.64851
G1 X111.438 Y116.069 E254.67138
G1 X111.72 Y116.574 E254.69447
G1 X112.026 Y116.964 E254.71425
G1 X112.349 Y117.27 E254.73201
G1 X112.697 Y117.525 E254.74923
G1 X113.085 Y117.74 E254.76693
G1 X113.488 Y117.894 E254.78415
G1 X113.869 Y117.991 E254.79985
G1 X114.212 Y118.036 E254.81365
G0 F2657.1 X114.311 Y118.048
M204 S500
G0 F15000 X114.826 Y117.554
M204 S800
G1 F2952.3 X115.204 Y117.483 E254.829
G1 X115.672 Y117.322 E254.84876
G1 X116.107 Y117.079 E254.86864
G1 X116.44 Y116.818 E254.88553
G1 X116.701 Y116.543 E254.90066
G1 X116.92 Y116.244 E254.91545
G1 X117.104 Y115.912 E254.9306
G1 X117.236 Y115.567 E254.94535
G1 X117.319 Y115.241 E254.95877
G1 X117.366 Y114.868 E254.97378
G1 X117.36 Y114.454 E254.9903
G1 X117.304 Y114.082 E255.00532
G1 X117.198 Y113.718 E255.02045
G1 X117.065 Y113.41 E255.03384
G1 X116.875 Y113.089 E255.04873
G1 X116.618 Y112.76 E255.06539
G1 X116.343 Y112.499 E255.08052
G1 X116.235 Y112.42 E255.08586
G1 X124.767 Y112.42 E255.42639
G1 X124.56 Y112.582 E255.43689
G1 X124.299 Y112.857 E255.45202
G1 X124.08 Y113.156 E255.46681
G1 X123.896 Y113.488 E255.48196
G1 X123.764 Y113.833 E255.4967
G1 X123.681 Y114.159 E255.51013
G1 X123.633 Y114.535 E255.52526
G1 X123.646 Y115.026 E255.54486
G1 X123.717 Y115.404 E255.56021
G1 X123.878 Y115.872 E255.57997
G1 X124.121 Y116.307 E255.59985
G1 X124.382 Y116.64 E255.61674
G1 X124.657 Y116.901 E255.63187
G1 X124.956 Y117.12 E255.64666
G1 X125.046 Y117.17 E255.65077
G1 X124.778 Y117.283 E255.65663
G1 X124.397 Y117.541 E255.67499
G1 X124.125 Y117.817 E255.69046
G1 X123.916 Y118.118 E255.70509
G1 X123.73 Y118.542 E255.72357
G1 X123.646 Y118.918 E255.73894
G1 X123.63 Y119.296 E255.75404
G1 X123.682 Y119.685 E255.76971
G1 X123.799 Y120.046 E255.78485
G1 X123.968 Y120.367 E255.79933
G1 X124.215 Y120.686 E255.81543
G1 X124.56 Y120.985 E255.83366
G1 X124.855 Y121.155 E255.84725
G1 X125.242 Y121.3 E255.86374
G1 X125.715 Y121.371 E255.88283
G1 X126.098 Y121.351 E255.89814
G1 X126.467 Y121.267 E255.91324
G1 X126.811 Y121.124 E255.92811
G1 X127.202 Y120.859 E255.94696
G1 X127.475 Y120.583 E255.96246
G1 X127.684 Y120.282 E255.97708
G1 X127.87 Y119.858 E255.99556
G1 X127.954 Y119.482 E256.01094
G1 X127.97 Y119.104 E256.02604
G1 X127.918 Y118.715 E256.0417
G1 X127.801 Y118.354 E256.05685
G1 X127.632 Y118.033 E256.07133
G1 X127.385 Y117.714 E256.08743
G1 X127.134 Y117.496 E256.1007
G1 X127.204 Y117.483
G1 X127.672 Y117.322 E256.12045
G1 X128.107 Y117.079 E256.14034
G1 X128.44 Y116.818 E256.15723
G1 X128.701 Y116.543 E256.17236
G1 X128.78 Y116.435 E256.1777
G1 X128.78 Y122.58 E256.42296
G1 X108.26 Y122.58 E257.24196
G1 X108.261 Y112.42 E257.64746
G1 X112.767 Y112.42 E257.82731
G1 X112.56 Y112.582 E257.8378
G1 X112.299 Y112.857 E257.85293
G1 X112.08 Y113.156 E257.86772
G1 X111.896 Y113.488 E257.88287
G1 X111.764 Y113.833 E257.89762
G1 X111.681 Y114.159 E257.91104
G1 X111.633 Y114.535 E257.92617
G1 X111.646 Y115.026 E257.94578
G1 X111.717 Y115.404 E257.96113
G1 X111.878 Y115.872 E257.98088
G1 X112.121 Y116.307 E258.00077
G1 X112.382 Y116.64 E258.01765
G1 X112.657 Y116.901 E258.03279
G1 X112.956 Y117.12 E258.04758
G1 X113.288 Y117.304 E258.06273
G1 X113.633 Y117.436 E258.07747
G1 X113.959 Y117.519 E258.0909
G1 X114.162 Y117.545 E258.09907
G0 F2657.1 X114.335 Y117.567
G0 X114.826 Y117.554
M204 S500
G0 F15000 X114.775 Y117.075
M204 S800
;TYPE:WALL-OUTER
G1 F2952.3 X115.081 Y117.018 E258.11149
G1 X115.475 Y116.882 E258.12813
G1 X115.84 Y116.678 E258.14481
G1 X116.116 Y116.462 E258.1588
G1 X116.332 Y116.235 E258.17131
G1 X116.515 Y115.985 E258.18367
G1 X116.668 Y115.709 E258.19627
G1 X116.778 Y115.421 E258.20857
G1 X116.847 Y115.151 E258.2197
G1 X116.886 Y114.841 E258.23217
G1 X116.881 Y114.494 E258.24602
G1 X116.834 Y114.186 E258.25845
G1 X116.745 Y113.881 E258.27113
G1 X116.636 Y113.628 E258.28213
G1 X116.478 Y113.36 E258.29455
G1 X116.262 Y113.084 E258.30853
G1 X116.035 Y112.868 E258.32104
G1 X115.785 Y112.685 E258.33341
G1 X115.509 Y112.532 E258.346
G1 X115.221 Y112.422 E258.35831
G1 X114.951 Y112.353 E258.36943
G1 X114.641 Y112.314 E258.3819
G1 X114.501 Y112.31 E258.38749
G1 X114.225 Y112.325 E258.39852
G1 X113.919 Y112.382 E258.41094
G1 X113.525 Y112.518 E258.42758
G1 X113.16 Y112.722 E258.44427
G1 X112.884 Y112.938 E258.45826
G1 X112.668 Y113.165 E258.47076
G1 X112.485 Y113.415 E258.48313
G1 X112.332 Y113.691 E258.49572
G1 X112.222 Y113.979 E258.50803
G1 X112.153 Y114.249 E258.51915
G1 X112.114 Y114.559 E258.53162
G1 X112.125 Y114.975 E258.54823
G1 X112.182 Y115.281 E258.56065
G1 X112.318 Y115.675 E258.57729
G1 X112.522 Y116.04 E258.59398
G1 X112.738 Y116.316 E258.60797
G1 X112.965 Y116.532 E258.62047
G1 X113.215 Y116.715 E258.63284
G1 X113.491 Y116.868 E258.64543
G1 X113.779 Y116.978 E258.65774
G1 X114.049 Y117.047 E258.66886
G1 X114.111 Y117.055 E258.67136
G0 F2657.1 X114.359 Y117.086
G0 X114.775 Y117.075
M204 S500
G0 F15000 X114.83 Y117.6
G1 F1800 E258.07136
G0 F15000 X114.855 Y116.142
G0 X127.646 Y113.754
G0 X128.78 Y112.967
M204 S800
;TYPE:WALL-INNER
G1 F1800 E258.67136
G1 F2952.3 X128.618 Y112.76 E258.68185
G1 X128.343 Y112.499 E258.69698
G1 X128.235 Y112.42 E258.70232
G1 X128.78 Y112.42 E258.71123
G1 X128.78 Y112.967 E258.72028
M204 S500
G1 F1800 E258.12028
G0 F15000 X127.718 Y113.851
G0 X126.507 Y116.185
G0 X126.359 Y117.086
M204 S800
;TYPE:WALL-OUTER
G1 F1800 E258.72028
G1 F2952.3 X126.775 Y117.075 E258.73688
G1 X127.081 Y117.018 E258.74931
G1 X127.475 Y116.882 E258.76594
G1 X127.84 Y116.678 E258.78263
G1 X128.116 Y116.462 E258.79662
G1 X128.332 Y116.235 E258.80913
G1 X128.515 Y115.985 E258.82149
G1 X128.668 Y115.709 E258.83409
G1 X128.778 Y115.421 E258.84639
G1 X128.847 Y115.151 E258.85751
G1 X128.886 Y114.841 E258.86999
G1 X128.881 Y114.494 E258.88384
G1 X128.834 Y114.186 E258.89627
G1 X128.745 Y113.881 E258.90895
G1 X128.636 Y113.628 E258.91995
G1 X128.478 Y113.36 E258.93236
G1 X128.262 Y113.084 E258.94635
G1 X128.035 Y112.868 E258.95886
G1 X127.785 Y112.685 E258.97122
G1 X127.509 Y112.532 E258.98382
G1 X127.221 Y112.422 E258.99612
G1 X126.951 Y112.353 E259.00725
G1 X126.641 Y112.314 E259.01972
G1 X126.501 Y112.31 E259.02531
G1 X126.225 Y112.325 E259.03634
G1 X125.919 Y112.382 E259.04876
G1 X125.525 Y112.518 E259.0654
G1 X125.16 Y112.722 E259.08209
G1 X124.884 Y112.938 E259.09607
G1 X124.668 Y113.165 E259.10858
G1 X124.485 Y113.415 E259.12095
G1 X124.332 Y113.691 E259.13354
G1 X124.222 Y113.979 E259.14585
G1 X124.153 Y114.249 E259.15697
G1 X124.114 Y114.559 E259.16944
G1 X124.125 Y114.975 E259.18605
G1 X124.182 Y115.281 E259.19847
G1 X124.318 Y115.675 E259.21511
G1 X124.522 Y116.04 E259.2318
G1 X124.738 Y116.316 E259.24578
G1 X124.965 Y116.532 E259.25829
G1 X125.215 Y116.715 E259.27066
G1 X125.491 Y116.868 E259.28325
G1 X125.708 Y116.951 E259.29252
G0 F2657.1 X125.779 Y116.978
G0 X126.049 Y117.047
M204 S500
G1 F1800 E258.69252
G0 F15000 X126.009 Y118.444
G0 X125.597 Y119.959
G0 X125.363 Y120.833
M204 S800
G1 F1800 E259.29252
G1 F2952.3 X125.738 Y120.889 E259.30766
G1 X126.032 Y120.874 E259.31941
G1 X126.32 Y120.808 E259.3312
G1 X126.582 Y120.699 E259.34253
G1 X126.894 Y120.488 E259.35756
G1 X127.104 Y120.275 E259.3695
G1 X127.263 Y120.046 E259.38062
G1 X127.412 Y119.708 E259.39537
G1 X127.476 Y119.419 E259.40718
G1 X127.489 Y119.126 E259.41889
G1 X127.448 Y118.822 E259.43113
G1 X127.357 Y118.541 E259.44292
G1 X127.227 Y118.294 E259.45406
G1 X127.035 Y118.046 E259.46658
G1 X126.76 Y117.808 E259.48109
G1 X126.436 Y117.634 E259.49577
G1 X126.166 Y117.55 E259.50706
G1 X125.862 Y117.511 E259.51929
G1 X125.568 Y117.526 E259.53104
G1 X125.28 Y117.592 E259.54283
G1 X125.008 Y117.707 E259.55462
G1 X124.706 Y117.912 E259.56919
G1 X124.496 Y118.125 E259.58112
G1 X124.337 Y118.354 E259.59225
G1 X124.188 Y118.692 E259.60699
G1 X124.124 Y118.981 E259.61881
G1 X124.111 Y119.274 E259.63051
G1 X124.152 Y119.578 E259.64276
G1 X124.243 Y119.859 E259.65455
G1 X124.373 Y120.106 E259.66569
G1 X124.565 Y120.354 E259.6782
G1 X124.773 Y120.534 E259.68918
G0 F2657.1 X124.84 Y120.592
G0 X125.061 Y120.72
M204 S500
G0 F15000 X125.231 Y121.344
G1 F1800 E259.08918
G0 F15000 X125.533 Y119.939
G0 X107.78 Y123.965
G0 X107.78 Y123.06
M204 S800
G1 F1800 E259.68918
G1 F2952.3 X107.781 Y111.94 E260.13301
G1 X129.26 Y111.94 E260.99028
G1 X129.26 Y123.06 E261.4341
G1 X108.446 Y123.06 E262.26483
G0 F2657.1 X107.78 Y123.06
M204 S500
G1 F1800 E261.66483
G0 F15000 X107.78 Y123.965
G0 X126.445 Y118.751
G0 X127.981 Y117.7
M204 S800
;TYPE:WALL-INNER
G1 F1800 E262.26483
G1 F2952.3 X128.3 Y117.521 E262.27943
G1 X128.3 Y118.337 E262.312
G1 X128.245 Y118.167 E262.31913
G1 X128.037 Y117.772 E262.32371
G1 X127.981 Y117.7
M204 S500
G0 F15000 X127.83 Y121.575
M204 S800
;TYPE:SKIN
G1 F2952.3 X127.83 Y121.63 E262.32591
G1 X127.757 Y121.63 E262.32882
G1 X127.821 Y121.582 E262.33202
G0 F2657.1 X127.83 Y121.575
M204 S500
G0 F15000 X123.854 Y121.63
M204 S800
G1 F2952.3 X109.21 Y121.63 E262.91649
G1 X109.211 Y113.37 E263.24616
G1 X110.924 Y113.37 E263.31453
G1 X110.857 Y113.545 E263.32201
G1 X110.747 Y113.981 E263.33996
G1 X110.682 Y114.487 E263.36032
G1 X110.699 Y115.127 E263.38587
G1 X110.796 Y115.648 E263.40702
G1 X111.007 Y116.261 E263.4329
G1 X111.328 Y116.835 E263.45915
G1 X111.677 Y117.281 E263.48175
G1 X112.047 Y117.632 E263.50211
G1 X112.443 Y117.922 E263.5217
G1 X112.886 Y118.167 E263.5419
G1 X113.345 Y118.343 E263.56152
G1 X113.781 Y118.453 E263.57947
G1 X114.287 Y118.518 E263.59983
G1 X114.927 Y118.501 E263.62538
G1 X115.448 Y118.404 E263.64653
G1 X116.061 Y118.193 E263.67241
G1 X116.635 Y117.872 E263.69866
G1 X117.081 Y117.523 E263.72126
G1 X117.432 Y117.153 E263.74162
G1 X117.722 Y116.757 E263.76121
G1 X117.967 Y116.314 E263.78141
G1 X118.143 Y115.855 E263.80103
G1 X118.254 Y115.419 E263.81899
G1 X118.316 Y114.921 E263.83902
G1 X118.309 Y114.376 E263.86077
G1 X118.234 Y113.879 E263.88083
G1 X118.094 Y113.396 E263.9009
G1 X118.083 Y113.37 E263.90203
G1 X122.924 Y113.37 E264.09525
G1 X122.857 Y113.545 E264.10273
G1 X122.747 Y113.981 E264.12067
G1 X122.682 Y114.487 E264.14103
G1 X122.699 Y115.127 E264.16659
G1 X122.796 Y115.648 E264.18774
G1 X123.007 Y116.261 E264.21361
G1 X123.328 Y116.835 E264.23986
G1 X123.518 Y117.078 E264.25217
G1 X123.39 Y117.208 E264.25945
G1 X123.082 Y117.652 E264.28102
G1 X122.823 Y118.245 E264.30685
G1 X122.7 Y118.794 E264.3293
G1 X122.677 Y119.34 E264.35112
G1 X122.752 Y119.896 E264.37351
G1 X122.92 Y120.417 E264.39536
G1 X123.166 Y120.883 E264.41639
G1 X123.383 Y121.163 E264.43053
G0 F2657.1 X123.522 Y121.343
G0 X123.854 Y121.63
M204 S500
G1 F1800 E263.83053
G0 F15000 X125.273 Y119.782
G0 X125.038 Y114.439
G0 X122.601 Y113.776
M204 S800
G1 F1800 E264.43053
G1 F2952.3 X122.386 Y113.562 E264.44263
M204 S500
G0 F15000 X121.707 Y113.562
M204 S800
G1 F2952.3 X122.504 Y114.358 E264.48759
M204 S500
G0 F15000 X122.504 Y115.037
M204 S800
G1 F2952.3 X121.029 Y113.562 E264.57085
M204 S500
G0 F15000 X120.35 Y113.562
M204 S800
G1 F2952.3 X122.675 Y115.887 E264.70208
M204 S500
G0 F15000 X123.222 Y117.113
M204 S800
G1 F2952.3 X119.671 Y113.562 E264.90251
M204 S500
G0 F15000 X118.992 Y113.562
M204 S800
G1 F2952.3 X122.943 Y117.512 E265.1255
M204 S500
G0 F15000 X122.728 Y117.977
M204 S800
G1 F2952.3 X118.351 Y113.599 E265.37258
M204 S500
G0 F15000 X118.501 Y114.428
M204 S800
G1 F2952.3 X122.569 Y118.496 E265.6022
M204 S500
G0 F15000 X122.494 Y119.1
M204 S800
G1 F2952.3 X118.486 Y115.092 E265.82843
M204 S500
G0 F15000 X118.385 Y115.67
M204 S800
G1 F2952.3 X122.549 Y119.834 E266.06346
M204 S500
G0 F15000 X122.978 Y120.942
M204 S800
G1 F2952.3 X118.221 Y116.184 E266.33199
M204 S500
G0 F15000 X118.002 Y116.645
M204 S800
G1 F2952.3 X122.794 Y121.437 E266.60248
M204 S500
G0 F15000 X122.115 Y121.437
M204 S800
G1 F2952.3 X117.738 Y117.059 E266.84956
M204 S500
G0 F15000 X117.431 Y117.431
M204 S800
G1 F2952.3 X121.437 Y121.437 E267.07568
M204 S500
G0 F15000 X120.758 Y121.437
M204 S800
G1 F2952.3 X117.084 Y117.762 E267.28308
M204 S500
G0 F15000 X116.698 Y118.055
M204 S800
G1 F2952.3 X120.079 Y121.437 E267.47395
M204 S500
G0 F15000 X119.4 Y121.437
M204 S800
G1 F2952.3 X116.263 Y118.299 E267.65104
M204 S500
G0 F15000 X115.778 Y118.493
M204 S800
G1 F2952.3 X118.721 Y121.437 E267.81719
M204 S500
G0 F15000 X118.042 Y121.437
M204 S800
G1 F2952.3 X115.242 Y118.636 E267.97526
M204 S500
G0 F15000 X114.627 Y118.7
M204 S800
G1 F2952.3 X117.364 Y121.437 E268.12975
M204 S500
G0 F15000 X116.685 Y121.437
M204 S800
G1 F2952.3 X113.91 Y118.662 E268.28638
M204 S500
G0 F15000 X112.975 Y118.405
M204 S800
G1 F2952.3 X116.006 Y121.437 E268.45749
M204 S500
G0 F15000 X115.327 Y121.437
M204 S800
G1 F2952.3 X109.402 Y115.512 E268.79192
M204 S500
G0 F15000 X109.402 Y114.833
M204 S800
G1 F2952.3 X110.791 Y116.222 E268.87032
M204 S500
G0 F15000 X110.534 Y115.285
M204 S800
G1 F2952.3 X109.402 Y114.154 E268.93419
M204 S500
G0 F15000 X109.488 Y113.561
M204 S800
G1 F2952.3 X110.492 Y114.565 E268.99086
M204 S500
G0 F15000 X110.557 Y113.951
M204 S800
G1 F2952.3 X110.167 Y113.561 E269.01287
M204 S500
G0 F15000 X109.402 Y116.191
M204 S800
G1 F2952.3 X114.648 Y121.437 E269.30898
M204 S500
G0 F15000 X113.97 Y121.437
M204 S800
G1 F2952.3 X109.402 Y116.869 E269.56682
M204 S500
G0 F15000 X109.402 Y117.548
M204 S800
G1 F2952.3 X113.291 Y121.437 E269.78633
M204 S500
G0 F15000 X112.612 Y121.437
M204 S800
G1 F2952.3 X109.402 Y118.226 E269.96754
M204 S500
G0 F15000 X109.402 Y118.905
M204 S800
G1 F2952.3 X111.933 Y121.437 E270.11043
M204 S500
G0 F15000 X111.254 Y121.437
M204 S800
G1 F2952.3 X109.402 Y119.584 E270.215
M204 S500
G0 F15000 X109.402 Y120.263
M204 S800
G1 F2952.3 X110.575 Y121.437 E270.28123
M204 S500
G0 F15000 X109.897 Y121.437
M204 S800
G1 F2952.3 X109.402 Y120.942 E270.30917
M204 S500
G1 F1800 E269.70917
;MESH:NONMESH
G0 F300 X109.402 Y120.942 Z3.44
G0 F15000 X106.875 Y120.942
G0 X114.4 Y116.182
G0 X114.628 Y118.532
;TIME_ELAPSED:312.402478
;LAYER:15
M204 S800
;TYPE:WALL-INNER
G1 F1800 E270.30917
G1 F2909.9 X115.274 Y118.455 E270.33514
G1 X115.807 Y118.304 E270.35725
G1 X116.27 Y118.101 E270.37743
G1 X116.695 Y117.843 E270.39727
G1 X117.073 Y117.542 E270.41656
G1 X117.507 Y117.08 E270.44186
G1 X117.819 Y116.619 E270.46407
G1 X118.042 Y116.167 E270.48419
G1 X118.201 Y115.694 E270.50411
G1 X118.304 Y115.192 E270.52456
G1 X118.332 Y114.572 E270.54933
G1 X118.255 Y113.926 E270.5753
G1 X118.104 Y113.393 E270.59741
G1 X118.098 Y113.38 E270.59798
G1 X122.909 Y113.38 E270.79
G1 X122.799 Y113.706 E270.80373
G1 X122.696 Y114.208 E270.82418
G1 X122.668 Y114.828 E270.84895
G1 X122.745 Y115.474 E270.87492
G1 X122.896 Y116.007 E270.89703
G1 X123.099 Y116.47 E270.91721
G1 X123.357 Y116.895 E270.93705
G1 X123.503 Y117.078 E270.94639
G1 X123.395 Y117.186 E270.95249
G1 X123.075 Y117.645 E270.97482
G1 X122.814 Y118.242 E271.00083
G1 X122.69 Y118.792 E271.02333
G1 X122.668 Y119.337 E271.0451
G1 X122.739 Y119.894 E271.06751
G1 X122.952 Y120.513 E271.09364
G1 X123.233 Y121.004 E271.11622
G1 X123.599 Y121.431 E271.13866
G1 X123.824 Y121.62 E271.15039
G1 X109.42 Y121.62 E271.72529
G1 X109.421 Y113.38 E272.05416
G1 X110.909 Y113.38 E272.11355
G1 X110.799 Y113.706 E272.12728
G1 X110.696 Y114.208 E272.14774
G1 X110.668 Y114.828 E272.17251
G1 X110.745 Y115.474 E272.19847
G1 X110.896 Y116.007 E272.22058
G1 X111.099 Y116.47 E272.24076
G1 X111.357 Y116.895 E272.2606
G1 X111.658 Y117.273 E272.27989
G1 X112.12 Y117.707 E272.30519
G1 X112.581 Y118.019 E272.32741
G1 X113.033 Y118.242 E272.34752
G1 X113.506 Y118.401 E272.36744
G1 X113.963 Y118.495 E272.38606
G0 F2618.9 X114.008 Y118.504
M204 S500
G0 F15000 X114.61 Y118.051
M204 S800
G1 F2909.9 X115.179 Y117.983 E272.40893
G1 X115.644 Y117.851 E272.42823
G1 X116.048 Y117.674 E272.44583
G1 X116.42 Y117.448 E272.4632
G1 X116.747 Y117.188 E272.47988
G1 X117.131 Y116.779 E272.50227
G1 X117.403 Y116.377 E272.52164
G1 X117.597 Y115.983 E272.53917
G1 X117.737 Y115.569 E272.55661
G1 X117.826 Y115.133 E272.57437
G1 X117.851 Y114.59 E272.59607
G1 X117.783 Y114.021 E272.61894
G1 X117.651 Y113.556 E272.63823
G1 X117.474 Y113.152 E272.65583
G1 X117.321 Y112.9 E272.6676
G1 X123.68 Y112.9 E272.9214
G1 X123.597 Y113.023 E272.92733
G1 X123.403 Y113.417 E272.94485
G1 X123.263 Y113.831 E272.9623
G1 X123.174 Y114.267 E272.98006
G1 X123.149 Y114.81 E273.00175
G1 X123.217 Y115.379 E273.02462
G1 X123.349 Y115.844 E273.04392
G1 X123.526 Y116.248 E273.06152
G1 X123.752 Y116.62 E273.07889
G1 X124.012 Y116.947 E273.09557
G1 X124.182 Y117.106 E273.10486
G1 X124.08 Y117.178 E273.10555
G1 X123.765 Y117.495 E273.12338
G1 X123.496 Y117.881 E273.14216
G1 X123.272 Y118.392 E273.16443
G1 X123.168 Y118.855 E273.18337
G1 X123.149 Y119.316 E273.20179
G1 X123.209 Y119.784 E273.22062
G1 X123.391 Y120.314 E273.24298
G1 X123.627 Y120.726 E273.26193
G1 X123.938 Y121.089 E273.28101
G1 X124.274 Y121.371 E273.29852
G1 X124.647 Y121.591 E273.3158
G1 X125.121 Y121.767 E273.33598
G1 X125.676 Y121.853 E273.3584
G1 X126.176 Y121.828 E273.37838
G1 X126.728 Y121.69 E273.40109
G1 X127.231 Y121.438 E273.42355
G1 X127.681 Y121.072 E273.4467
G1 X127.981 Y120.714 E273.46534
G1 X128.25 Y120.224 E273.48765
G1 X128.3 Y120.065 E273.4943
G1 X128.3 Y120.714 E273.50585
G1 X128.3 Y122.1 E273.56117
G1 X126.728 Y122.1 E273.62391
G1 X126.176 Y122.1 E273.63955
G1 X125.676 Y122.1 E273.65036
G1 X125.121 Y122.1 E273.66375
G1 X108.94 Y122.1 E274.30956
G1 X108.941 Y112.9 E274.67676
G1 X111.68 Y112.9 E274.78608
G1 X111.597 Y113.023 E274.792
G1 X111.403 Y113.417 E274.80953
G1 X111.263 Y113.831 E274.82697
G1 X111.174 Y114.267 E274.84473
G1 X111.149 Y114.81 E274.86643
G1 X111.217 Y115.379 E274.8893
G1 X111.349 Y115.844 E274.90859
G1 X111.526 Y116.248 E274.92619
G1 X111.752 Y116.62 E274.94357
G1 X112.012 Y116.947 E274.96024
G1 X112.421 Y117.331 E274.98263
G1 X112.823 Y117.603 E275.002
G1 X113.217 Y117.797 E275.01953
G1 X113.631 Y117.937 E275.03697
G1 X113.947 Y118.002 E275.04985
G0 F2618.9 X114.067 Y118.026
G0 X114.61 Y118.051
M204 S500
G0 F15000 X114.593 Y117.57
M204 S800
G1 F2909.9 X115.084 Y117.511 E275.06959
G1 X115.481 Y117.398 E275.08606
G1 X115.826 Y117.247 E275.10109
G1 X116.145 Y117.053 E275.116
G1 X116.421 Y116.834 E275.13006
G1 X116.755 Y116.478 E275.14954
G1 X116.987 Y116.136 E275.16604
G1 X117.152 Y115.799 E275.18101
G1 X117.273 Y115.443 E275.19602
G1 X117.348 Y115.074 E275.21105
G1 X117.37 Y114.607 E275.22971
G1 X117.311 Y114.116 E275.24944
G1 X117.198 Y113.719 E275.26592
G1 X117.047 Y113.374 E275.28095
G1 X116.853 Y113.055 E275.29585
G1 X116.634 Y112.779 E275.30991
G1 X116.278 Y112.445 E275.3294
G1 X116.241 Y112.42 E275.33118
G1 X124.763 Y112.42 E275.67131
G1 X124.579 Y112.566 E275.68069
G1 X124.245 Y112.922 E275.70017
G1 X124.013 Y113.264 E275.71666
G1 X123.848 Y113.601 E275.73164
G1 X123.727 Y113.957 E275.74665
G1 X123.652 Y114.326 E275.76168
G1 X123.63 Y114.793 E275.78033
G1 X123.689 Y115.284 E275.80007
G1 X123.802 Y115.681 E275.81655
G1 X123.953 Y116.026 E275.83158
G1 X124.147 Y116.345 E275.84648
G1 X124.366 Y116.621 E275.86054
G1 X124.722 Y116.955 E275.88003
G1 X125.034 Y117.167 E275.89508
G1 X124.712 Y117.32 E275.90144
G1 X124.391 Y117.546 E275.91711
G1 X124.135 Y117.804 E275.93162
G1 X123.917 Y118.117 E275.94684
G1 X123.73 Y118.542 E275.96537
G1 X123.646 Y118.918 E275.98075
G1 X123.63 Y119.295 E275.99581
G1 X123.679 Y119.674 E276.01106
G1 X123.83 Y120.115 E276.02967
G1 X124.021 Y120.448 E276.04499
G1 X124.277 Y120.747 E276.0607
G1 X124.552 Y120.978 E276.07503
G1 X124.854 Y121.156 E276.08902
G1 X125.242 Y121.3 E276.10554
G1 X125.701 Y121.371 E276.12408
G1 X126.105 Y121.351 E276.14022
G1 X126.56 Y121.237 E276.15895
G1 X126.969 Y121.032 E276.17721
G1 X127.343 Y120.728 E276.19644
G1 X127.583 Y120.442 E276.21134
G1 X127.806 Y120.035 E276.22987
G1 X127.921 Y119.669 E276.24518
G1 X127.971 Y119.277 E276.26095
G1 X127.951 Y118.895 E276.27622
G1 X127.838 Y118.445 E276.29474
G1 X127.68 Y118.112 E276.30945
G1 X127.454 Y117.791 E276.32512
G1 X127.196 Y117.535 E276.33962
G1 X127.139 Y117.495 E276.3424
G1 X127.481 Y117.398 E276.34997
G1 X127.826 Y117.247 E276.365
G1 X128.145 Y117.053 E276.3799
G1 X128.421 Y116.834 E276.39396
G1 X128.755 Y116.478 E276.41345
G1 X128.78 Y116.441 E276.41523
G1 X128.78 Y122.58 E276.66025
G1 X108.46 Y122.58 E277.47126
G1 X108.461 Y112.42 E277.87677
G1 X112.763 Y112.42 E278.04847
G1 X112.579 Y112.566 E278.05785
G1 X112.245 Y112.922 E278.07733
G1 X112.013 Y113.264 E278.09383
G1 X111.848 Y113.601 E278.1088
G1 X111.727 Y113.957 E278.12381
G1 X111.652 Y114.326 E278.13884
G1 X111.63 Y114.793 E278.1575
G1 X111.689 Y115.284 E278.17724
G1 X111.802 Y115.681 E278.19371
G1 X111.953 Y116.026 E278.20874
G1 X112.147 Y116.345 E278.22364
G1 X112.366 Y116.621 E278.2377
G1 X112.722 Y116.955 E278.25719
G1 X113.064 Y117.187 E278.27368
G1 X113.401 Y117.352 E278.28866
G1 X113.757 Y117.473 E278.30366
G1 X113.931 Y117.509 E278.31076
G0 F2618.9 X114.126 Y117.548
G0 X114.593 Y117.57
M204 S500
G0 F15000 X114.576 Y117.089
M204 S800
;TYPE:WALL-OUTER
G1 F2909.9 X114.989 Y117.039 E278.32736
G1 X115.318 Y116.945 E278.34102
G1 X115.604 Y116.82 E278.35347
G1 X115.87 Y116.658 E278.36591
G1 X116.095 Y116.48 E278.37736
G1 X116.379 Y116.177 E278.39393
G1 X116.571 Y115.894 E278.40758
G1 X116.708 Y115.615 E278.41999
G1 X116.809 Y115.318 E278.43251
G1 X116.87 Y115.015 E278.44484
G1 X116.889 Y114.624 E278.46047
G1 X116.839 Y114.211 E278.47707
G1 X116.745 Y113.882 E278.49073
G1 X116.62 Y113.596 E278.50318
G1 X116.458 Y113.33 E278.51562
G1 X116.28 Y113.105 E278.52707
G1 X115.977 Y112.821 E278.54364
G1 X115.694 Y112.629 E278.55729
G1 X115.415 Y112.492 E278.5697
G1 X115.118 Y112.391 E278.58222
G1 X114.815 Y112.33 E278.59455
G1 X114.424 Y112.311 E278.61018
G1 X114.011 Y112.361 E278.62678
G1 X113.682 Y112.455 E278.64044
G1 X113.396 Y112.58 E278.65289
G1 X113.13 Y112.742 E278.66533
G1 X112.905 Y112.92 E278.67678
G1 X112.621 Y113.223 E278.69335
G1 X112.429 Y113.506 E278.707
G1 X112.292 Y113.785 E278.71941
G1 X112.191 Y114.082 E278.73193
G1 X112.13 Y114.385 E278.74426
G1 X112.111 Y114.776 E278.75989
G1 X112.161 Y115.189 E278.77649
G1 X112.255 Y115.518 E278.79015
G1 X112.38 Y115.804 E278.8026
G1 X112.542 Y116.07 E278.81504
G1 X112.72 Y116.295 E278.82649
G1 X113.023 Y116.579 E278.84306
G1 X113.306 Y116.771 E278.85671
G1 X113.585 Y116.908 E278.86912
G1 X113.882 Y117.009 E278.88164
G1 X113.916 Y117.016 E278.88302
G0 F2618.9 X114.185 Y117.07
G0 X114.576 Y117.089
M204 S500
G0 F15000 X114.594 Y117.616
G1 F1800 E278.28302
G0 F15000 X114.676 Y116.176
G0 X127.603 Y113.704
G0 X128.78 Y112.963
M204 S800
;TYPE:WALL-INNER
G1 F1800 E278.88302
G1 F2909.9 X128.634 Y112.779 E278.8924
G1 X128.278 Y112.445 E278.91188
G1 X128.241 Y112.42 E278.91366
G1 X128.78 Y112.42 E278.91952
G1 X128.78 Y112.963 E278.92866
M204 S500
G1 F1800 E278.32866
G0 X126.645 Y116.179
G0 X126.576 Y117.089
M204 S800
;TYPE:WALL-OUTER
G1 F1800 E278.92866
G1 F2909.9 X126.989 Y117.039 E278.94526
G1 X127.318 Y116.945 E278.95892
G1 X127.604 Y116.82 E278.97138
G1 X127.87 Y116.658 E278.98381
G1 X128.095 Y116.48 E278.99526
G1 X128.379 Y116.177 E279.01183
G1 X128.571 Y115.894 E279.02548
G1 X128.708 Y115.615 E279.03789
G1 X128.809 Y115.318 E279.05041
G1 X128.87 Y115.015 E279.06274
G1 X128.889 Y114.624 E279.07837
G1 X128.839 Y114.211 E279.09497
G1 X128.745 Y113.882 E279.10863
G1 X128.62 Y113.596 E279.12109
G1 X128.458 Y113.33 E279.13352
G1 X128.28 Y113.105 E279.14497
G1 X127.977 Y112.821 E279.16154
G1 X127.694 Y112.629 E279.17519
G1 X127.415 Y112.492 E279.1876
G1 X127.118 Y112.391 E279.20012
G1 X126.815 Y112.33 E279.21245
G1 X126.424 Y112.311 E279.22808
G1 X126.011 Y112.361 E279.24468
G1 X125.682 Y112.455 E279.25834
G1 X125.396 Y112.58 E279.2708
G1 X125.13 Y112.742 E279.28323
G1 X124.905 Y112.92 E279.29468
G1 X124.621 Y113.223 E279.31125
G1 X124.429 Y113.506 E279.3249
G1 X124.292 Y113.785 E279.33731
G1 X124.191 Y114.082 E279.34983
G1 X124.13 Y114.385 E279.36216
G1 X124.111 Y114.776 E279.37779
G1 X124.161 Y115.189 E279.39439
G1 X124.255 Y115.518 E279.40805
G1 X124.38 Y115.804 E279.42051
G1 X124.542 Y116.07 E279.43294
G1 X124.72 Y116.295 E279.44439
G1 X125.023 Y116.579 E279.46096
G1 X125.306 Y116.771 E279.47461
G1 X125.585 Y116.908 E279.48702
G1 X125.882 Y117.009 E279.49954
G1 X125.916 Y117.016 E279.50092
G0 F2618.9 X126.185 Y117.07
M204 S500
G1 F1800 E278.90092
G0 F15000 X126.107 Y118.478
G0 X125.77 Y119.985
G0 X125.726 Y120.889
M204 S800
G1 F1800 E279.50092
G1 F2909.9 X126.034 Y120.874 E279.51323
G1 X126.392 Y120.784 E279.52796
G1 X126.707 Y120.626 E279.54203
G1 X127.005 Y120.384 E279.55735
G1 X127.185 Y120.17 E279.56851
G1 X127.362 Y119.846 E279.58325
G1 X127.45 Y119.566 E279.59496
G1 X127.489 Y119.259 E279.60731
G1 X127.474 Y118.966 E279.61902
G1 X127.384 Y118.608 E279.63375
G1 X127.264 Y118.355 E279.64493
G1 X127.086 Y118.102 E279.65728
G1 X126.887 Y117.905 E279.66845
G1 X126.647 Y117.737 E279.68015
G1 X126.308 Y117.588 E279.69493
G1 X126.019 Y117.524 E279.70674
G1 X125.859 Y117.511 E279.71315
G1 X125.566 Y117.526 E279.72486
G1 X125.208 Y117.616 E279.73959
G1 X124.955 Y117.736 E279.75077
G1 X124.702 Y117.914 E279.76311
G1 X124.505 Y118.113 E279.77429
G1 X124.337 Y118.353 E279.78598
G1 X124.188 Y118.692 E279.80076
G1 X124.124 Y118.981 E279.81257
G1 X124.111 Y119.274 E279.82428
G1 X124.149 Y119.564 E279.83595
G1 X124.269 Y119.916 E279.8508
G1 X124.415 Y120.17 E279.86249
G1 X124.616 Y120.405 E279.87483
G1 X124.83 Y120.585 E279.88599
G1 X125.061 Y120.721 E279.89669
G1 X125.083 Y120.729 E279.89763
G0 F2618.9 X125.363 Y120.833
M204 S500
G0 F15000 X125.699 Y121.416
G1 F1800 E279.29763
G0 F15000 X125.654 Y119.971
G0 X107.98 Y123.965
G0 X107.98 Y123.06
M204 S800
G1 F1800 E279.89763
G1 F2909.9 X107.981 Y111.94 E280.34145
G1 X129.26 Y111.94 E281.19074
G1 X129.26 Y123.06 E281.63456
G1 X108.646 Y123.06 E282.45731
G0 F2618.9 X107.98 Y123.06
M204 S500
G1 F1800 E281.85731
G0 F15000 X107.98 Y123.965
G0 X126.227 Y119.86
G0 X127.768 Y121.62
M204 S800
;TYPE:WALL-INNER
G1 F1800 E282.45731
G1 F2909.9 X127.82 Y121.577 E282.46001
G1 X127.82 Y121.62
G1 X127.768 Y121.62
M204 S500
G0 F15000 X127.98 Y117.704
M204 S800
G1 F2909.9 X128.048 Y117.674 E282.46297
G1 X128.3 Y117.521 E282.47474
G1 X128.292 Y118.282 E282.50511
G1 X128.096 Y117.869
G1 X127.98 Y117.704 E282.50791
M204 S500
G1 F1800 E281.90791
G0 F15000 X126.393 Y118.686
G0 X125.195 Y118.698
G0 X122.909 Y117.062
M204 S800
;TYPE:SKIN
G1 F1800 E282.50791
G1 F2909.9 X122.663 Y117.414 E282.52505
G1 X122.365 Y118.095 E282.55472
G1 X122.222 Y118.731 E282.58074
G1 X122.196 Y119.357 E282.60574
G1 X122.279 Y120.001 E282.63166
G1 X122.522 Y120.708 E282.6615
G1 X122.775 Y121.15 E282.68182
G1 X109.89 Y121.15 E283.19609
G1 X109.891 Y113.85 E283.48745
G1 X110.29 Y113.85 E283.50338
G1 X110.228 Y114.149 E283.51556
G1 X110.196 Y114.846 E283.54341
G1 X110.283 Y115.566 E283.57236
G1 X110.453 Y116.166 E283.59725
G1 X110.681 Y116.687 E283.61995
G1 X110.971 Y117.165 E283.64226
G1 X111.311 Y117.592 E283.66404
G1 X111.826 Y118.075 E283.69223
G1 X112.344 Y118.426 E283.7172
G1 X112.853 Y118.677 E283.73985
G1 X113.383 Y118.855 E283.76216
G1 X113.949 Y118.972 E283.78523
G1 X114.646 Y119.004 E283.81308
G1 X115.366 Y118.917 E283.84203
G1 X115.966 Y118.747 E283.86692
G1 X116.487 Y118.519 E283.88961
G1 X116.965 Y118.229 E283.91193
G1 X117.392 Y117.889 E283.93371
G1 X117.875 Y117.374 E283.96189
G1 X118.226 Y116.856 E283.98687
G1 X118.477 Y116.347 E284.00952
G1 X118.655 Y115.817 E284.03183
G1 X118.772 Y115.251 E284.0549
G1 X118.804 Y114.554 E284.08275
G1 X118.719 Y113.85 E284.11105
G1 X122.29 Y113.85 E284.25358
G1 X122.228 Y114.149 E284.26577
G1 X122.196 Y114.846 E284.29361
G1 X122.283 Y115.566 E284.32256
G1 X122.453 Y116.166 E284.34745
G1 X122.59 Y116.478 E284.36105
G0 F2618.9 X122.681 Y116.687
M204 S500
G0 F15000 X122.315 Y120.703
M204 S800
G1 F2909.9 X122.06 Y120.958 E284.37544
M204 S500
G0 F15000 X121.381 Y120.958
M204 S800
G1 F2909.9 X122.142 Y120.197 E284.4184
M204 S500
G0 F15000 X122.036 Y119.624
M204 S800
G1 F2909.9 X120.702 Y120.958 E284.49369
M204 S500
G0 F15000 X120.023 Y120.958
M204 S800
G1 F2909.9 X122.019 Y118.962 E284.60636
M204 S500
G0 F15000 X122.154 Y118.148
M204 S800
G1 F2909.9 X119.344 Y120.958 E284.76497
M204 S500
G0 F15000 X118.665 Y120.958
M204 S800
G1 F2909.9 X122.637 Y116.987 E284.98913
M204 S500
G0 F15000 X122.405 Y116.539
M204 S800
G1 F2909.9 X117.987 Y120.958 E285.23853
M204 S500
G0 F15000 X117.308 Y120.958
M204 S800
G1 F2909.9 X122.219 Y116.047 E285.51573
M204 S500
G0 F15000 X122.081 Y115.506
M204 S800
G1 F2909.9 X116.629 Y120.958 E285.82347
M204 S500
G0 F15000 X115.951 Y120.957
M204 S800
G1 F2909.9 X122.007 Y114.901 E286.16529
M204 S500
G0 F15000 X122.032 Y114.197
M204 S800
G1 F2909.9 X115.272 Y120.957 E286.54686
M204 S500
G0 F15000 X114.593 Y120.957
M204 S800
G1 F2909.9 X117.519 Y118.032 E286.71198
G1 X117.546 Y118.004
G1 X121.509 Y114.042 E286.93564
M204 S500
G0 F15000 X120.83 Y114.042
M204 S800
G1 F2909.9 X118.757 Y116.114 E287.05263
M204 S500
G0 F15000 X118.965 Y115.228
M204 S800
G1 F2909.9 X120.151 Y114.042 E287.11957
M204 S500
G0 F15000 X119.472 Y114.042
M204 S800
G1 F2909.9 X118.993 Y114.521 E287.14661
M204 S500
G0 F15000 X115.911 Y118.96
M204 S800
G1 F2909.9 X113.914 Y120.957 E287.25932
M204 S500
G0 F15000 X113.236 Y120.957
M204 S800
G1 F2909.9 X115.045 Y119.148 E287.36143
M204 S500
G0 F15000 X114.334 Y119.18
M204 S800
G1 F2909.9 X112.557 Y120.957 E287.46173
M204 S500
G0 F15000 X111.878 Y120.957
M204 S800
G1 F2909.9 X113.716 Y119.119 E287.56548
M204 S500
G0 F15000 X113.171 Y118.985
M204 S800
G1 F2909.9 X111.199 Y120.957 E287.67679
M204 S500
G0 F15000 X110.52 Y120.957
M204 S800
G1 F2909.9 X112.676 Y118.802 E287.79845
M204 S500
G0 F15000 X112.224 Y118.574
M204 S800
G1 F2909.9 X110.082 Y120.717 E287.91938
M204 S500
G0 F15000 X110.082 Y120.038
M204 S800
G1 F2909.9 X111.819 Y118.301 E288.01743
M204 S500
G0 F15000 X111.454 Y117.987
M204 S800
G1 F2909.9 X110.082 Y119.359 E288.09487
M204 S500
G0 F15000 X110.082 Y118.68
M204 S800
G1 F2909.9 X111.112 Y117.65 E288.15301
M204 S500
G0 F15000 X110.812 Y117.272
M204 S800
G1 F2909.9 X110.083 Y118.001 E288.19416
M204 S500
G0 F15000 X110.083 Y117.322
M204 S800
G1 F2909.9 X110.555 Y116.85 E288.2208
M204 S500
G0 F15000 X110.339 Y116.386
M204 S800
G1 F2909.9 X110.083 Y116.643 E288.23528
M204 S500
G0 F15000 X110.083 Y115.964
M204 S800
G1 F2909.9 X110.171 Y115.876 E288.24024
M204 S500
G1 F1800 E287.64024
;MESH:NONMESH
G0 F300 X110.171 Y115.876 Z3.64
G0 F15000 X113.08 Y115.133
G0 X114.434 Y116.184
G0 X114.624 Y118.051
;TIME_ELAPSED:332.016120
;LAYER:16
M204 S800
;TYPE:WALL-INNER
;MESH:RS_Fan-Housing-Clamp-Rev1.stl
G1 F1800 E288.24024
G1 F2885.3 X115.081 Y118.001 E288.25859
G1 X115.508 Y117.897 E288.27613
G1 X115.918 Y117.739 E288.29367
G1 X116.302 Y117.525 E288.31121
G1 X116.652 Y117.269 E288.32852
G1 X116.972 Y116.966 E288.34611
G1 X117.246 Y116.62 E288.36373
G1 X117.473 Y116.249 E288.38109
G1 X117.65 Y115.847 E288.39862
G1 X117.774 Y115.424 E288.41621
G1 X117.839 Y114.993 E288.43361
G1 X117.851 Y114.576 E288.45026
G1 X117.801 Y114.119 E288.46861
G1 X117.697 Y113.692 E288.48615
G1 X117.539 Y113.282 E288.50368
G1 X117.326 Y112.9 E288.52114
G1 X123.681 Y112.9 E288.77478
G1 X123.527 Y113.151 E288.78653
G1 X123.35 Y113.553 E288.80407
G1 X123.226 Y113.976 E288.82166
G1 X123.161 Y114.407 E288.83906
G1 X123.149 Y114.824 E288.85571
G1 X123.199 Y115.281 E288.87405
G1 X123.303 Y115.708 E288.8916
G1 X123.461 Y116.118 E288.90913
G1 X123.675 Y116.502 E288.92668
G1 X123.931 Y116.852 E288.94398
G1 X124.175 Y117.11 E288.95816
G1 X124.094 Y117.164
G1 X123.694 Y117.582 E288.98125
G1 X123.395 Y118.076 E289.0043
G1 X123.21 Y118.617 E289.02712
G1 X123.147 Y119.107 E289.04683
G1 X123.172 Y119.572 E289.06542
G1 X123.277 Y120.02 E289.08379
G1 X123.45 Y120.435 E289.10173
G1 X123.764 Y120.906 E289.12432
G1 X124.182 Y121.306 E289.14741
G1 X124.676 Y121.605 E289.17046
G1 X125.217 Y121.79 E289.19328
G1 X125.707 Y121.853 E289.213
G1 X126.172 Y121.828 E289.23159
G1 X126.62 Y121.723 E289.24995
G1 X127.035 Y121.55 E289.2679
G1 X127.506 Y121.236 E289.29049
G1 X127.906 Y120.818 E289.31358
G1 X128.205 Y120.324 E289.33663
G1 X128.3 Y120.046 E289.34835
G1 X128.3 Y120.818 E289.36646
G1 X128.3 Y122.1 E289.41763
G1 X126.62 Y122.1 E289.48468
G1 X125.707 Y122.1 E289.51234
G1 X125.217 Y122.1 E289.52369
G1 X124.709 Y122.1 E289.54084
G1 X109.14 Y122.1 E290.16223
G1 X109.141 Y112.9 E290.52943
G1 X111.681 Y112.9 E290.6308
G1 X111.527 Y113.151 E290.64256
G1 X111.35 Y113.553 E290.66009
G1 X111.226 Y113.976 E290.67768
G1 X111.161 Y114.407 E290.69508
G1 X111.149 Y114.824 E290.71173
G1 X111.199 Y115.281 E290.73008
G1 X111.303 Y115.708 E290.74762
G1 X111.461 Y116.118 E290.76515
G1 X111.675 Y116.502 E290.7827
G1 X111.931 Y116.852 E290.80001
G1 X112.234 Y117.172 E290.8176
G1 X112.58 Y117.446 E290.83521
G1 X112.951 Y117.673 E290.85257
G1 X113.353 Y117.85 E290.8701
G1 X113.776 Y117.974 E290.88769
G1 X113.961 Y118.002 E290.89516
G0 F2596.8 X114.207 Y118.039
M204 S500
G0 F15000 X114.605 Y117.57
M204 S800
G1 F2885.3 X114.998 Y117.527 E290.91094
G1 X115.364 Y117.438 E290.92597
G1 X115.714 Y117.303 E290.94095
G1 X116.043 Y117.12 E290.95597
G1 X116.344 Y116.9 E290.97085
G1 X116.617 Y116.641 E290.98587
G1 X116.852 Y116.345 E291.00096
G1 X117.047 Y116.026 E291.01588
G1 X117.198 Y115.682 E291.03087
G1 X117.304 Y115.32 E291.04593
G1 X117.36 Y114.95 E291.06086
G1 X117.37 Y114.595 E291.07504
G1 X117.327 Y114.202 E291.09082
G1 X117.238 Y113.836 E291.10585
G1 X117.103 Y113.486 E291.12082
G1 X116.92 Y113.157 E291.13585
G1 X116.7 Y112.856 E291.15073
G1 X116.441 Y112.583 E291.16575
G1 X116.236 Y112.42 E291.1762
G1 X124.765 Y112.42 E291.51661
G1 X124.656 Y112.5 E291.52201
G1 X124.383 Y112.759 E291.53703
G1 X124.148 Y113.055 E291.55211
G1 X123.953 Y113.374 E291.56704
G1 X123.802 Y113.718 E291.58203
G1 X123.696 Y114.08 E291.59708
G1 X123.64 Y114.45 E291.61202
G1 X123.63 Y114.805 E291.6262
G1 X123.673 Y115.198 E291.64197
G1 X123.762 Y115.564 E291.65701
G1 X123.897 Y115.914 E291.67198
G1 X124.08 Y116.243 E291.68701
G1 X124.3 Y116.544 E291.70189
G1 X124.559 Y116.817 E291.71691
G1 X124.855 Y117.052 E291.73199
G1 X125.046 Y117.169 E291.74093
G1 X124.793 Y117.275 E291.74515
G1 X124.404 Y117.534 E291.7638
G1 X124.077 Y117.876 E291.78268
G1 X123.832 Y118.28 E291.80154
G1 X123.68 Y118.726 E291.82035
G1 X123.629 Y119.125 E291.8364
G1 X123.649 Y119.504 E291.85155
G1 X123.735 Y119.872 E291.86663
G1 X123.875 Y120.207 E291.88113
G1 X124.134 Y120.596 E291.89978
G1 X124.476 Y120.923 E291.91866
G1 X124.88 Y121.168 E291.93752
G1 X125.326 Y121.32 E291.95633
G1 X125.725 Y121.371 E291.97238
G1 X126.104 Y121.351 E291.98753
G1 X126.472 Y121.265 E292.00261
G1 X126.807 Y121.125 E292.0171
G1 X127.196 Y120.866 E292.03576
G1 X127.523 Y120.524 E292.05464
G1 X127.768 Y120.12 E292.0735
G1 X127.92 Y119.674 E292.09231
G1 X127.971 Y119.275 E292.10836
G1 X127.951 Y118.896 E292.12351
G1 X127.865 Y118.528 E292.13859
G1 X127.725 Y118.193 E292.15308
G1 X127.466 Y117.804 E292.17173
G1 X127.14 Y117.492 E292.18975
G1 X127.364 Y117.438 E292.19161
G1 X127.714 Y117.303 E292.20658
G1 X128.043 Y117.12 E292.22161
G1 X128.344 Y116.9 E292.23649
G1 X128.617 Y116.641 E292.2515
G1 X128.78 Y116.436 E292.26196
G1 X128.78 Y122.58 E292.50718
G1 X108.66 Y122.58 E293.31021
G1 X108.661 Y112.42 E293.71572
G1 X112.765 Y112.42 E293.87952
G1 X112.656 Y112.5 E293.88491
G1 X112.383 Y112.759 E293.89993
G1 X112.148 Y113.055 E293.91502
G1 X111.953 Y113.374 E293.92994
G1 X111.802 Y113.718 E293.94494
G1 X111.696 Y114.08 E293.95999
G1 X111.64 Y114.45 E293.97493
G1 X111.63 Y114.805 E293.9891
G1 X111.673 Y115.198 E294.00488
G1 X111.762 Y115.564 E294.01991
G1 X111.897 Y115.914 E294.03489
G1 X112.08 Y116.243 E294.04991
G1 X112.3 Y116.544 E294.06479
G1 X112.559 Y116.817 E294.07981
G1 X112.855 Y117.052 E294.0949
G1 X113.174 Y117.247 E294.10982
G1 X113.518 Y117.398 E294.12481
G1 X113.88 Y117.504 E294.13987
G1 X113.943 Y117.514 E294.14241
G0 F2596.8 X114.25 Y117.56
G0 X114.605 Y117.57
M204 S500
G0 F15000 X114.585 Y117.089
M204 S800
;TYPE:WALL-OUTER
G1 F2885.3 X114.915 Y117.053 E294.15566
G1 X115.22 Y116.979 E294.16819
G1 X115.51 Y116.867 E294.1806
G1 X115.784 Y116.715 E294.1931
G1 X116.036 Y116.531 E294.20556
G1 X116.262 Y116.316 E294.21801
G1 X116.458 Y116.07 E294.23056
G1 X116.62 Y115.804 E294.24299
G1 X116.746 Y115.517 E294.2555
G1 X116.834 Y115.216 E294.26802
G1 X116.881 Y114.907 E294.28049
G1 X116.889 Y114.615 E294.29215
G1 X116.853 Y114.285 E294.3054
G1 X116.779 Y113.98 E294.31793
G1 X116.667 Y113.69 E294.33033
G1 X116.515 Y113.416 E294.34284
G1 X116.331 Y113.164 E294.35529
G1 X116.116 Y112.938 E294.36774
G1 X115.87 Y112.742 E294.3803
G1 X115.604 Y112.58 E294.39273
G1 X115.317 Y112.454 E294.40524
G1 X115.016 Y112.366 E294.41775
G1 X114.707 Y112.319 E294.43023
G1 X114.415 Y112.311 E294.44189
G1 X114.085 Y112.347 E294.45514
G1 X113.78 Y112.421 E294.46766
G1 X113.49 Y112.533 E294.48007
G1 X113.216 Y112.685 E294.49258
G1 X112.964 Y112.869 E294.50503
G1 X112.738 Y113.084 E294.51748
G1 X112.542 Y113.33 E294.53003
G1 X112.38 Y113.596 E294.54246
G1 X112.254 Y113.883 E294.55497
G1 X112.166 Y114.184 E294.56749
G1 X112.119 Y114.493 E294.57997
G1 X112.111 Y114.785 E294.59162
G1 X112.147 Y115.115 E294.60487
G1 X112.221 Y115.42 E294.6174
G1 X112.333 Y115.71 E294.62981
G1 X112.485 Y115.984 E294.64231
G1 X112.669 Y116.236 E294.65477
G1 X112.884 Y116.462 E294.66722
G1 X113.13 Y116.658 E294.67977
G1 X113.396 Y116.82 E294.6922
G1 X113.683 Y116.946 E294.70471
G1 X113.925 Y117.017 E294.71478
G0 F2596.8 X113.984 Y117.034
G0 X114.293 Y117.081
G0 X114.585 Y117.089
M204 S500
G0 F15000 X114.606 Y117.616
G1 F1800 E294.11478
G0 F15000 X114.68 Y116.175
G0 X128.78 Y112.965
M204 S800
;TYPE:WALL-INNER
G1 F1800 E294.71478
G1 F2885.3 X128.7 Y112.856 E294.72017
G1 X128.441 Y112.583 E294.73519
G1 X128.236 Y112.42 E294.74565
G1 X128.78 Y112.42 E294.75473
G1 X128.78 Y112.965 E294.76445
M204 S500
G1 F1800 E294.16445
G0 F15000 X127.708 Y113.836
G0 X126.644 Y116.179
G0 X126.585 Y117.089
M204 S800
;TYPE:WALL-OUTER
G1 F1800 E294.76445
G1 F2885.3 X126.915 Y117.053 E294.77769
G1 X127.22 Y116.979 E294.79022
G1 X127.51 Y116.867 E294.80263
G1 X127.784 Y116.715 E294.81513
G1 X128.036 Y116.531 E294.82759
G1 X128.262 Y116.316 E294.84004
G1 X128.458 Y116.07 E294.85259
G1 X128.62 Y115.804 E294.86502
G1 X128.746 Y115.517 E294.87753
G1 X128.834 Y115.216 E294.89005
G1 X128.881 Y114.907 E294.90252
G1 X128.889 Y114.615 E294.91418
G1 X128.853 Y114.285 E294.92743
G1 X128.779 Y113.98 E294.93996
G1 X128.667 Y113.69 E294.95237
G1 X128.515 Y113.416 E294.96487
G1 X128.331 Y113.164 E294.97733
G1 X128.116 Y112.938 E294.98977
G1 X127.87 Y112.742 E295.00233
G1 X127.604 Y112.58 E295.01476
G1 X127.317 Y112.454 E295.02727
G1 X127.016 Y112.366 E295.03979
G1 X126.707 Y112.319 E295.05226
G1 X126.415 Y112.311 E295.06392
G1 X126.085 Y112.347 E295.07717
G1 X125.78 Y112.421 E295.08969
G1 X125.49 Y112.533 E295.1021
G1 X125.216 Y112.685 E295.11461
G1 X124.964 Y112.869 E295.12706
G1 X124.738 Y113.084 E295.13951
G1 X124.542 Y113.33 E295.15207
G1 X124.38 Y113.596 E295.1645
G1 X124.254 Y113.883 E295.17701
G1 X124.166 Y114.184 E295.18952
G1 X124.119 Y114.493 E295.202
G1 X124.111 Y114.785 E295.21366
G1 X124.147 Y115.115 E295.22691
G1 X124.221 Y115.42 E295.23943
G1 X124.333 Y115.71 E295.25184
G1 X124.485 Y115.984 E295.26435
G1 X124.669 Y116.236 E295.2768
G1 X124.884 Y116.462 E295.28925
G1 X125.13 Y116.658 E295.3018
G1 X125.396 Y116.82 E295.31423
G1 X125.683 Y116.946 E295.32674
G1 X125.925 Y117.017 E295.33681
G0 F2596.8 X125.984 Y117.034
G0 X126.293 Y117.081
M204 S500
G1 F1800 E294.73681
G0 F15000 X126.105 Y118.477
G0 X125.622 Y119.964
G0 X125.434 Y120.85
M204 S800
G1 F1800 E295.33681
G1 F2885.3 X125.743 Y120.889 E295.34924
G1 X126.037 Y120.874 E295.36099
G1 X126.324 Y120.807 E295.37275
G1 X126.579 Y120.7 E295.38379
G1 X126.886 Y120.496 E295.3985
G1 X127.14 Y120.23 E295.41318
G1 X127.331 Y119.916 E295.42785
G1 X127.45 Y119.566 E295.4426
G1 X127.489 Y119.257 E295.45503
G1 X127.474 Y118.963 E295.46678
G1 X127.407 Y118.676 E295.47855
G1 X127.3 Y118.421 E295.48958
G1 X127.096 Y118.114 E295.5043
G1 X126.83 Y117.86 E295.51898
G1 X126.516 Y117.669 E295.53364
G1 X126.166 Y117.55 E295.5484
G1 X125.857 Y117.511 E295.56083
G1 X125.563 Y117.526 E295.57258
G1 X125.276 Y117.593 E295.58434
G1 X125.021 Y117.7 E295.59538
G1 X124.714 Y117.904 E295.61009
G1 X124.46 Y118.17 E295.62477
G1 X124.269 Y118.484 E295.63944
G1 X124.15 Y118.834 E295.65419
G1 X124.111 Y119.143 E295.66662
G1 X124.126 Y119.437 E295.67837
G1 X124.193 Y119.724 E295.69014
G1 X124.3 Y119.979 E295.70117
G1 X124.504 Y120.286 E295.71588
G1 X124.77 Y120.54 E295.73056
G1 X124.83 Y120.577 E295.73338
G0 F2596.8 X125.084 Y120.731
G0 X125.434 Y120.85
M204 S500
G0 F15000 X125.316 Y121.364
G1 F1800 E295.13338
G0 F15000 X125.493 Y119.922
G0 X108.18 Y123.965
G0 X108.18 Y123.06
M204 S800
G1 F1800 E295.73338
G1 F2885.3 X108.181 Y111.94 E296.1772
G1 X129.26 Y111.94 E297.01851
G1 X129.26 Y123.06 E297.46233
G1 X108.846 Y123.06 E298.2771
G0 F2596.8 X108.18 Y123.06
M204 S500
G1 F1800 E297.6771
G0 F15000 X108.18 Y123.965
G0 X126.441 Y118.744
G0 X127.977 Y117.706
M204 S800
;TYPE:WALL-INNER
G1 F1800 E298.2771
G1 F2885.3 X128.3 Y117.526 E298.29186
G1 X128.3 Y118.325 E298.32375
G1 X128.15 Y117.965
G1 X127.977 Y117.706 E298.32772
M204 S500
G0 F15000 X127.83 Y121.577
M204 S800
;TYPE:SKIN
G1 F2885.3 X127.83 Y121.63 E298.32983
G1 X127.762 Y121.63 E298.33255
G1 X127.822 Y121.583 E298.33559
G0 F2596.8 X127.83 Y121.577
M204 S500
G0 F15000 X123.84 Y121.63
M204 S800
G1 F2885.3 X109.61 Y121.63 E298.90354
G1 X109.611 Y113.37 E299.23321
G1 X110.918 Y113.37 E299.28538
G1 X110.908 Y113.392 E299.28634
G1 X110.766 Y113.874 E299.3064
G1 X110.692 Y114.366 E299.32626
G1 X110.679 Y114.843 E299.3453
G1 X110.735 Y115.363 E299.36617
G1 X110.853 Y115.849 E299.38614
G1 X111.034 Y116.318 E299.4062
G1 X111.279 Y116.756 E299.42623
G1 X111.569 Y117.154 E299.44589
G1 X111.916 Y117.519 E299.46599
G1 X112.31 Y117.832 E299.48607
G1 X112.733 Y118.09 E299.50584
G1 X113.192 Y118.292 E299.52586
G1 X113.674 Y118.434 E299.54592
G1 X114.166 Y118.508 E299.56577
G1 X114.643 Y118.521 E299.58482
G1 X115.163 Y118.465 E299.60569
G1 X115.649 Y118.347 E299.62565
G1 X116.118 Y118.166 E299.64572
G1 X116.556 Y117.921 E299.66575
G1 X116.954 Y117.631 E299.6854
G1 X117.319 Y117.284 E299.7055
G1 X117.632 Y116.89 E299.72559
G1 X117.89 Y116.467 E299.74536
G1 X118.092 Y116.008 E299.76538
G1 X118.234 Y115.526 E299.78543
G1 X118.308 Y115.034 E299.80529
G1 X118.321 Y114.557 E299.82434
G1 X118.265 Y114.037 E299.84521
G1 X118.147 Y113.551 E299.86517
G1 X118.077 Y113.37 E299.87292
G1 X122.918 Y113.37 E300.06613
G1 X122.908 Y113.392 E300.0671
G1 X122.766 Y113.874 E300.08715
G1 X122.692 Y114.366 E300.10701
G1 X122.679 Y114.843 E300.12605
G1 X122.735 Y115.363 E300.14693
G1 X122.853 Y115.849 E300.16689
G1 X123.034 Y116.318 E300.18695
G1 X123.279 Y116.756 E300.20698
G1 X123.519 Y117.085 E300.22324
G1 X123.318 Y117.294 E300.23481
G1 X122.966 Y117.876 E300.26196
G1 X122.75 Y118.51 E300.28869
G1 X122.675 Y119.089 E300.31199
G1 X122.704 Y119.639 E300.33397
G1 X122.828 Y120.165 E300.35554
G1 X123.033 Y120.658 E300.37685
G1 X123.369 Y121.161 E300.401
G0 F2596.8 X123.402 Y121.21
G0 X123.84 Y121.63
M204 S500
G1 F1800 E299.801
G0 F15000 X125.271 Y119.781
G0 X125.039 Y114.435
G0 X122.596 Y113.771
M204 S800
G1 F1800 E300.401
G1 F2885.3 X122.386 Y113.562 E300.41282
M204 S500
M204 S800
G1 F2885.3 X122.499 Y114.353 E300.4575
M204 S500
G0 F15000 X122.506 Y115.039
M204 S800
G1 F2885.3 X121.029 Y113.562 E300.54087
M204 S500
M204 S800
G1 F2885.3 X122.659 Y115.871 E300.6712
M204 S500
G0 F15000 X123.223 Y117.114
M204 S800
G1 F2885.3 X119.671 Y113.562 E300.87169
M204 S500
M204 S800
G1 F2885.3 X122.953 Y117.523 E301.09526
M204 S500
G0 F15000 X122.727 Y117.975
M204 S800
G1 F2885.3 X118.358 Y113.606 E301.34187
M204 S500
G0 F15000 X118.497 Y114.424
M204 S800
G1 F2885.3 X122.559 Y118.486 E301.57114
M204 S500
G0 F15000 X122.482 Y119.088
M204 S800
G1 F2885.3 X118.492 Y115.097 E301.79639
M204 S500
G0 F15000 X118.389 Y115.674
M204 S800
G1 F2885.3 X122.552 Y119.837 E302.03136
M204 S500
G0 F15000 X123.018 Y120.981
M204 S800
G1 F2885.3 X118.222 Y116.186 E302.30204
M204 S500
G0 F15000 X118.003 Y116.645
M204 S800
G1 F2885.3 X122.795 Y121.437 E302.57252
M204 S500
G0 F15000 X122.116 Y121.437
M204 S800
G1 F2885.3 X117.739 Y117.06 E302.81958
M204 S500
G0 F15000 X117.437 Y117.437
M204 S800
G1 F2885.3 X121.437 Y121.437 E303.04536
M204 S500
M204 S800
G1 F2885.3 X117.089 Y117.767 E303.25248
M204 S500
G0 F15000 X116.697 Y118.055
M204 S800
G1 F2885.3 X120.08 Y121.437 E303.4434
M204 S500
G0 F15000 X119.401 Y121.437
M204 S800
G1 F2885.3 X116.266 Y118.303 E303.62033
M204 S500
G0 F15000 X115.785 Y118.5
M204 S800
G1 F2885.3 X118.722 Y121.437 E303.7861
M204 S500
G0 F15000 X118.043 Y121.437
M204 S800
G1 F2885.3 X115.247 Y118.641 E303.94392
M204 S500
G0 F15000 X114.638 Y118.711
M204 S800
G1 F2885.3 X117.364 Y121.437 E304.09779
M204 S500
G0 F15000 X116.686 Y121.437
M204 S800
G1 F2885.3 X113.912 Y118.664 E304.25434
M204 S500
G0 F15000 X112.976 Y118.407
M204 S800
G1 F2885.3 X116.006 Y121.437 E304.42536
M204 S500
M204 S800
G1 F2885.3 X109.802 Y115.911 E304.73725
M204 S500
G0 F15000 X109.802 Y115.232
M204 S800
G1 F2885.3 X110.79 Y116.22 E304.79301
M204 S500
G0 F15000 X110.533 Y115.285
M204 S800
G1 F2885.3 X109.802 Y114.554 E304.83428
M204 S500
G0 F15000 X109.802 Y113.875
M204 S800
G1 F2885.3 X110.494 Y114.567 E304.87333
M204 S500
G0 F15000 X110.559 Y113.953
M204 S800
G1 F2885.3 X110.167 Y113.561 E304.89546
M204 S500
G0 F15000 X109.802 Y116.59
M204 S800
G1 F2885.3 X114.648 Y121.437 E305.16902
M204 S500
M204 S800
G1 F2885.3 X109.802 Y117.269 E305.40428
M204 S500
G0 F15000 X109.802 Y117.948
M204 S800
G1 F2885.3 X113.291 Y121.437 E305.60121
M204 S500
M204 S800
G1 F2885.3 X109.802 Y118.627 E305.75982
M204 S500
G0 F15000 X109.802 Y119.305
M204 S800
G1 F2885.3 X111.933 Y121.437 E305.88013
M204 S500
M204 S800
G1 F2885.3 X109.802 Y119.984 E305.96212
M204 S500
G0 F15000 X109.802 Y120.663
M204 S800
G1 F2885.3 X110.575 Y121.437 E306.00578
M204 S500
M204 S800
G1 F2885.3 X109.802 Y121.342 E306.01114
M204 S500
G1 F1800 E305.41114
;MESH:NONMESH
G0 F300 X109.802 Y121.342 Z3.84
G0 F15000 X109.802 Y123.965
G0 X114.644 Y116.179
G0 X115.003 Y118.501
;TIME_ELAPSED:352.185671
;LAYER:17
M204 S800
;TYPE:WALL-INNER
G1 F1800 E306.01114
G1 F2863.3 X115.494 Y118.401 E306.03114
G1 X115.964 Y118.243 E306.05093
G1 X116.404 Y118.027 E306.07049
G1 X116.834 Y117.743 E306.09106
G1 X117.21 Y117.41 E306.11111
G1 X117.542 Y117.034 E306.13113
G1 X117.822 Y116.613 E306.15131
G1 X118.042 Y116.165 E306.17123
G1 X118.201 Y115.695 E306.19103
G1 X118.301 Y115.206 E306.21095
G1 X118.333 Y114.71 E306.23079
G1 X118.301 Y114.198 E306.25126
G1 X118.201 Y113.706 E306.2713
G1 X118.091 Y113.38 E306.28503
G1 X122.909 Y113.38 E306.47733
G1 X122.799 Y113.705 E306.49102
G1 X122.699 Y114.196 E306.51102
G1 X122.667 Y114.7 E306.53118
G1 X122.699 Y115.203 E306.5513
G1 X122.799 Y115.694 E306.57129
G1 X122.957 Y116.164 E306.59109
G1 X123.173 Y116.604 E306.61065
G1 X123.457 Y117.034 E306.63122
G1 X123.504 Y117.087 E306.63404
G1 X123.29 Y117.316 E306.64655
G1 X122.95 Y117.89 E306.67318
G1 X122.759 Y118.429 E306.696
G1 X122.665 Y119.054 E306.72123
G1 X122.695 Y119.652 E306.74513
G1 X122.85 Y120.262 E306.77025
G1 X123.084 Y120.769 E306.79253
G1 X123.425 Y121.25 E306.81607
G1 X123.82 Y121.62 E306.83767
G1 X109.82 Y121.62 E307.39644
G1 X109.821 Y113.38 E307.72531
G1 X110.909 Y113.381 E307.76874
G1 X110.799 Y113.705 E307.78239
G1 X110.699 Y114.196 E307.80239
G1 X110.667 Y114.7 E307.82255
G1 X110.699 Y115.203 E307.84267
G1 X110.799 Y115.694 E307.86267
G1 X110.957 Y116.164 E307.88246
G1 X111.173 Y116.604 E307.90202
G1 X111.457 Y117.034 E307.92259
G1 X111.79 Y117.41 E307.94263
G1 X112.166 Y117.742 E307.96265
G1 X112.587 Y118.022 E307.98283
G1 X113.035 Y118.242 E308.00275
G1 X113.505 Y118.401 E308.02256
G1 X113.996 Y118.501 E308.04256
G1 X114.339 Y118.523 E308.05627
G0 F2576.9 X114.5 Y118.533
M204 S500
G0 F15000 X114.94 Y118.024
M204 S800
G1 F2863.3 X115.369 Y117.937 E308.07374
G1 X115.781 Y117.798 E308.0911
G1 X116.165 Y117.61 E308.10816
G1 X116.541 Y117.361 E308.12616
G1 X116.87 Y117.07 E308.14369
G1 X117.16 Y116.741 E308.1612
G1 X117.405 Y116.373 E308.17884
G1 X117.597 Y115.981 E308.19626
G1 X117.737 Y115.569 E308.21363
G1 X117.824 Y115.142 E308.23102
G1 X117.852 Y114.709 E308.24834
G1 X117.824 Y114.261 E308.26626
G1 X117.737 Y113.831 E308.28377
G1 X117.598 Y113.419 E308.30112
G1 X117.41 Y113.035 E308.31819
G1 X117.321 Y112.9 E308.32464
G1 X123.68 Y112.9 E308.57844
G1 X123.595 Y113.027 E308.58454
G1 X123.403 Y113.419 E308.60196
G1 X123.263 Y113.831 E308.61933
G1 X123.176 Y114.259 E308.63676
G1 X123.148 Y114.7 E308.6544
G1 X123.176 Y115.14 E308.672
G1 X123.263 Y115.569 E308.68947
G1 X123.402 Y115.981 E308.70682
G1 X123.59 Y116.365 E308.72388
G1 X123.839 Y116.741 E308.74188
G1 X124.13 Y117.07 E308.75941
G1 X124.177 Y117.111 E308.7619
G1 X124.067 Y117.189 E308.76451
G1 X123.676 Y117.606 E308.78732
G1 X123.387 Y118.094 E308.80996
G1 X123.227 Y118.546 E308.82909
G1 X123.147 Y119.078 E308.85057
G1 X123.172 Y119.58 E308.87063
G1 X123.304 Y120.101 E308.89208
G1 X123.501 Y120.527 E308.91081
G1 X123.789 Y120.933 E308.93068
G1 X124.204 Y121.322 E308.95338
G1 X124.678 Y121.607 E308.97546
G1 X125.217 Y121.79 E308.99817
G1 X125.708 Y121.853 E309.01793
G1 X126.182 Y121.828 E309.03688
G1 X126.705 Y121.696 E309.0584
G1 X127.148 Y121.486 E309.07797
G1 X127.517 Y121.224 E309.09603
G1 X127.924 Y120.796 E309.11961
G1 X128.213 Y120.306 E309.14231
G1 X128.3 Y120.06 E309.15273
G1 X128.3 Y120.796 E309.16912
G1 X128.3 Y122.1 E309.22117
G1 X126.705 Y122.1 E309.28483
G1 X125.708 Y122.1 E309.31566
G1 X125.217 Y122.1 E309.32704
G1 X124.706 Y122.1 E309.34428
G1 X109.34 Y122.1 E309.95757
G1 X109.341 Y112.9 E310.32476
G1 X111.679 Y112.901 E310.41808
G1 X111.595 Y113.027 E310.42412
G1 X111.403 Y113.419 E310.44154
G1 X111.263 Y113.831 E310.45891
G1 X111.176 Y114.259 E310.47634
G1 X111.148 Y114.7 E310.49398
G1 X111.176 Y115.14 E310.51158
G1 X111.263 Y115.569 E310.52905
G1 X111.402 Y115.981 E310.5464
G1 X111.59 Y116.365 E310.56347
G1 X111.839 Y116.741 E310.58147
G1 X112.13 Y117.07 E310.599
G1 X112.459 Y117.36 E310.6165
G1 X112.827 Y117.605 E310.63414
G1 X113.219 Y117.797 E310.65157
G1 X113.631 Y117.937 E310.66893
G1 X114.059 Y118.024 E310.68637
G1 X114.274 Y118.038 E310.69496
G0 F2576.9 X114.5 Y118.052
G0 X114.94 Y118.024
M204 S500
G0 F15000 X114.877 Y117.547
M204 S800
G1 F2863.3 X115.244 Y117.473 E310.70991
G1 X115.598 Y117.353 E310.72483
G1 X115.926 Y117.193 E310.73939
G1 X116.248 Y116.979 E310.75482
G1 X116.53 Y116.73 E310.76984
G1 X116.779 Y116.448 E310.78485
G1 X116.988 Y116.134 E310.79991
G1 X117.152 Y115.798 E310.81483
G1 X117.273 Y115.443 E310.8298
G1 X117.347 Y115.078 E310.84466
G1 X117.371 Y114.708 E310.85946
G1 X117.347 Y114.324 E310.87482
G1 X117.273 Y113.956 E310.8898
G1 X117.153 Y113.602 E310.90472
G1 X116.993 Y113.274 E310.91928
G1 X116.779 Y112.952 E310.93472
G1 X116.53 Y112.67 E310.94973
G1 X116.246 Y112.42 E310.96483
G1 X124.754 Y112.42 E311.3044
G1 X124.47 Y112.67 E311.3195
G1 X124.221 Y112.952 E311.33452
G1 X124.012 Y113.266 E311.34957
G1 X123.848 Y113.602 E311.3645
G1 X123.727 Y113.957 E311.37947
G1 X123.653 Y114.322 E311.39433
G1 X123.629 Y114.7 E311.40945
G1 X123.653 Y115.077 E311.42453
G1 X123.727 Y115.444 E311.43947
G1 X123.847 Y115.798 E311.45439
G1 X124.007 Y116.126 E311.46895
G1 X124.221 Y116.448 E311.48438
G1 X124.47 Y116.73 E311.4994
G1 X124.752 Y116.979 E311.51441
G1 X125.037 Y117.169 E311.52808
G1 X124.715 Y117.318 E311.53441
G1 X124.384 Y117.553 E311.55061
G1 X124.062 Y117.896 E311.56939
G1 X123.824 Y118.298 E311.58804
G1 X123.695 Y118.663 E311.60349
G1 X123.629 Y119.102 E311.62121
G1 X123.649 Y119.509 E311.63747
G1 X123.758 Y119.94 E311.65521
G1 X123.918 Y120.285 E311.67039
G1 X124.153 Y120.616 E311.68659
G1 X124.495 Y120.937 E311.70532
G1 X124.881 Y121.169 E311.72329
G1 X125.326 Y121.32 E311.74205
G1 X125.726 Y121.371 E311.75814
G1 X126.11 Y121.351 E311.77349
G1 X126.542 Y121.242 E311.79127
G1 X126.905 Y121.07 E311.8073
G1 X127.201 Y120.86 E311.82179
G1 X127.538 Y120.505 E311.84132
G1 X127.776 Y120.102 E311.86
G1 X127.905 Y119.737 E311.87545
G1 X127.971 Y119.298 E311.89317
G1 X127.951 Y118.891 E311.90944
G1 X127.842 Y118.46 E311.92718
G1 X127.682 Y118.115 E311.94236
G1 X127.447 Y117.784 E311.95856
G1 X127.138 Y117.494 E311.97547
G1 X127.244 Y117.473
G1 X127.598 Y117.353 E311.98477
G1 X127.926 Y117.193 E311.99933
G1 X128.248 Y116.979 E312.01476
G1 X128.53 Y116.73 E312.02978
G1 X128.78 Y116.446 E312.04488
G1 X128.78 Y122.58 E312.2897
G1 X108.86 Y122.58 E313.08475
G1 X108.861 Y112.42 E313.49026
G1 X112.752 Y112.421 E313.64556
G1 X112.47 Y112.67 E313.66057
G1 X112.221 Y112.952 E313.67559
G1 X112.012 Y113.266 E313.69064
G1 X111.848 Y113.602 E313.70556
G1 X111.727 Y113.957 E313.72053
G1 X111.653 Y114.322 E313.7354
G1 X111.629 Y114.7 E313.75051
G1 X111.653 Y115.077 E313.76559
G1 X111.727 Y115.444 E313.78053
G1 X111.847 Y115.798 E313.79545
G1 X112.007 Y116.126 E313.81002
G1 X112.221 Y116.448 E313.82545
G1 X112.47 Y116.73 E313.84047
G1 X112.752 Y116.979 E313.85548
G1 X113.066 Y117.188 E313.87053
G1 X113.402 Y117.352 E313.88546
G1 X113.757 Y117.473 E313.90043
G1 X114.122 Y117.547 E313.91529
G1 X114.211 Y117.553 E313.91885
G0 F2576.9 X114.5 Y117.571
G0 X114.877 Y117.547
M204 S500
G0 F15000 X114.814 Y117.07
M204 S800
;TYPE:WALL-OUTER
G1 F2863.3 X115.119 Y117.009 E313.93127
G1 X115.414 Y116.908 E313.94371
G1 X115.687 Y116.775 E313.95583
G1 X115.955 Y116.597 E313.96867
G1 X116.19 Y116.39 E313.98117
G1 X116.397 Y116.155 E313.99367
G1 X116.571 Y115.894 E314.00619
G1 X116.708 Y115.614 E314.01863
G1 X116.809 Y115.318 E314.03111
G1 X116.87 Y115.015 E314.04345
G1 X116.89 Y114.707 E314.05577
G1 X116.87 Y114.386 E314.06861
G1 X116.809 Y114.081 E314.08102
G1 X116.708 Y113.786 E314.09346
G1 X116.575 Y113.513 E314.10559
G1 X116.397 Y113.245 E314.11843
G1 X116.19 Y113.01 E314.13093
G1 X115.955 Y112.803 E314.14342
G1 X115.694 Y112.629 E314.15594
G1 X115.414 Y112.492 E314.16839
G1 X115.118 Y112.391 E314.18087
G1 X114.815 Y112.33 E314.1932
G1 X114.5 Y112.31 E314.2058
G1 X114.186 Y112.33 E314.21836
G1 X113.881 Y112.391 E314.23077
G1 X113.586 Y112.492 E314.24322
G1 X113.313 Y112.625 E314.25534
G1 X113.045 Y112.803 E314.26818
G1 X112.81 Y113.01 E314.28068
G1 X112.603 Y113.245 E314.29318
G1 X112.429 Y113.506 E314.3057
G1 X112.292 Y113.786 E314.31814
G1 X112.191 Y114.082 E314.33062
G1 X112.13 Y114.385 E314.34296
G1 X112.11 Y114.7 E314.35556
G1 X112.13 Y115.014 E314.36811
G1 X112.191 Y115.319 E314.38053
G1 X112.292 Y115.614 E314.39297
G1 X112.425 Y115.887 E314.40509
G1 X112.603 Y116.155 E314.41793
G1 X112.81 Y116.39 E314.43043
G1 X113.045 Y116.597 E314.44293
G1 X113.306 Y116.771 E314.45545
G1 X113.586 Y116.908 E314.46789
G1 X113.882 Y117.009 E314.48038
G1 X114.149 Y117.063 E314.49125
G0 F2576.9 X114.185 Y117.07
G0 X114.5 Y117.09
G0 X114.814 Y117.07
M204 S500
G0 F15000 X114.882 Y117.593
G1 F1800 E313.89125
G0 F15000 X114.827 Y116.149
G0 X128.779 Y112.952
M204 S800
;TYPE:WALL-INNER
G1 F1800 E314.49125
G1 F2863.3 X128.53 Y112.67 E314.50626
G1 X128.246 Y112.42 E314.52137
G1 X128.78 Y112.42 E314.53007
G1 X128.779 Y112.952 E314.53877
M204 S500
G1 F1800 E313.93877
G0 X126.356 Y116.179
G0 X126.185 Y117.07
M204 S800
;TYPE:WALL-OUTER
G1 F1800 E314.53877
G1 F2863.3 X126.5 Y117.09 E314.55136
G1 X126.814 Y117.07 E314.56392
G1 X127.119 Y117.009 E314.57634
G1 X127.414 Y116.908 E314.58878
G1 X127.687 Y116.775 E314.6009
G1 X127.955 Y116.597 E314.61374
G1 X128.19 Y116.39 E314.62624
G1 X128.397 Y116.155 E314.63874
G1 X128.571 Y115.894 E314.65126
G1 X128.708 Y115.614 E314.6637
G1 X128.809 Y115.318 E314.67618
G1 X128.87 Y115.015 E314.68852
G1 X128.89 Y114.707 E314.70084
G1 X128.87 Y114.386 E314.71368
G1 X128.809 Y114.081 E314.72609
G1 X128.708 Y113.786 E314.73853
G1 X128.575 Y113.513 E314.75066
G1 X128.397 Y113.245 E314.7635
G1 X128.19 Y113.01 E314.776
G1 X127.955 Y112.803 E314.78849
G1 X127.694 Y112.629 E314.80101
G1 X127.414 Y112.492 E314.81346
G1 X127.118 Y112.391 E314.82594
G1 X126.815 Y112.33 E314.83827
G1 X126.5 Y112.31 E314.85087
G1 X126.186 Y112.33 E314.86343
G1 X125.881 Y112.391 E314.87584
G1 X125.586 Y112.492 E314.88829
G1 X125.313 Y112.625 E314.90041
G1 X125.045 Y112.803 E314.91325
G1 X124.81 Y113.01 E314.92575
G1 X124.603 Y113.245 E314.93825
G1 X124.429 Y113.506 E314.95077
G1 X124.292 Y113.786 E314.96321
G1 X124.191 Y114.082 E314.97569
G1 X124.13 Y114.385 E314.98803
G1 X124.11 Y114.7 E315.00063
G1 X124.13 Y115.014 E315.01318
G1 X124.191 Y115.319 E315.0256
G1 X124.292 Y115.614 E315.03804
G1 X124.425 Y115.887 E315.05016
G1 X124.603 Y116.155 E315.063
G1 X124.81 Y116.39 E315.0755
G1 X125.045 Y116.597 E315.088
G1 X125.306 Y116.771 E315.10052
G1 X125.546 Y116.889 E315.1112
G0 F2576.9 X125.586 Y116.908
G0 X125.882 Y117.009
G0 X126.185 Y117.07
M204 S500
G1 F1800 E314.5112
G0 F15000 X125.938 Y118.427
G0 X125.434 Y120.85
M204 S800
G1 F1800 E315.1112
G1 F2863.3 X125.744 Y120.889 E315.12367
G1 X126.038 Y120.874 E315.13542
G1 X126.379 Y120.788 E315.14945
G1 X126.662 Y120.654 E315.16195
G1 X126.885 Y120.496 E315.17286
G1 X127.152 Y120.214 E315.18836
G1 X127.339 Y119.898 E315.20301
G1 X127.437 Y119.62 E315.21478
G1 X127.489 Y119.274 E315.22874
G1 X127.474 Y118.962 E315.24121
G1 X127.388 Y118.621 E315.25525
G1 X127.265 Y118.357 E315.26687
G1 X127.083 Y118.101 E315.27941
G1 X126.814 Y117.848 E315.29415
G1 X126.498 Y117.661 E315.3088
G1 X126.22 Y117.563 E315.32057
G1 X125.874 Y117.511 E315.33453
G1 X125.562 Y117.526 E315.347
G1 X125.221 Y117.612 E315.36103
G1 X124.957 Y117.735 E315.37266
G1 X124.701 Y117.917 E315.38519
G1 X124.448 Y118.186 E315.39993
G1 X124.261 Y118.502 E315.41459
G1 X124.163 Y118.78 E315.42635
G1 X124.111 Y119.126 E315.44032
G1 X124.126 Y119.438 E315.45278
G1 X124.212 Y119.779 E315.46682
G1 X124.335 Y120.043 E315.47844
G1 X124.517 Y120.299 E315.49098
G1 X124.786 Y120.552 E315.50572
G1 X124.829 Y120.578 E315.50773
G0 F2576.9 X125.084 Y120.731
G0 X125.434 Y120.85
M204 S500
G1 F1800 E314.90773
G0 F15000 X125.501 Y119.926
G0 X108.38 Y123.965
G0 X108.38 Y123.06
M204 S800
G1 F1800 E315.50773
G1 F2863.3 X108.381 Y111.94 E315.95155
G1 X129.26 Y111.94 E316.78488
G1 X129.26 Y123.06 E317.2287
G1 X109.046 Y123.06 E318.03548
G0 F2576.9 X108.38 Y123.06
M204 S500
G1 F1800 E317.43548
G0 F15000 X108.38 Y123.965
G0 X126.251 Y119.843
G0 X127.788 Y121.62
M204 S800
;TYPE:WALL-INNER
G1 F1800 E318.03548
G1 F2863.3 X127.82 Y121.597 E318.03706
G1 X127.82 Y121.62
G1 X127.788 Y121.62
M204 S500
G0 F15000 X127.978 Y117.702
M204 S800
G1 F2863.3 X128.3 Y117.521 E318.0518
G1 X128.296 Y118.299 E318.08285
G1 X128.099 Y117.873
G1 X127.978 Y117.702 E318.0842
M204 S500
G1 F1800 E317.4842
G0 F15000 X126.4 Y118.693
G0 X125.176 Y118.724
G0 X122.903 Y117.048
M204 S800
;TYPE:SKIN
G1 F1800 E318.0842
G1 F2863.3 X122.523 Y117.69 E318.11398
G1 X122.301 Y118.315 E318.14045
G1 X122.193 Y119.031 E318.16935
G1 X122.228 Y119.722 E318.19696
G1 X122.405 Y120.42 E318.2257
G1 X122.675 Y121.006 E318.25146
G1 X122.777 Y121.15 E318.2585
G1 X110.29 Y121.15 E318.75688
G1 X110.291 Y115.554 E318.98023
G1 X110.344 Y115.816 E318.9909
G1 X110.522 Y116.344 E319.01314
G1 X110.764 Y116.838 E319.03509
G1 X111.083 Y117.32 E319.05816
G1 X111.457 Y117.743 E319.0807
G1 X111.878 Y118.116 E319.10315
G1 X112.352 Y118.431 E319.12586
G1 X112.855 Y118.677 E319.14821
G1 X113.382 Y118.856 E319.17042
G1 X113.934 Y118.968 E319.1929
G1 X114.5 Y119.003 E319.21554
G1 X115.065 Y118.968 E319.23813
G1 X115.616 Y118.856 E319.26057
G1 X116.144 Y118.678 E319.28281
G1 X116.638 Y118.436 E319.30477
G1 X117.12 Y118.117 E319.32784
G1 X117.543 Y117.743 E319.35037
G1 X117.916 Y117.322 E319.37282
G1 X118.231 Y116.848 E319.39554
G1 X118.477 Y116.345 E319.41788
G1 X118.655 Y115.818 E319.44009
G1 X118.768 Y115.269 E319.46246
G1 X118.803 Y114.71 E319.48481
G1 X118.768 Y114.136 E319.50776
G1 X118.71 Y113.85 E319.51941
G1 X122.29 Y113.85 E319.6623
G1 X122.232 Y114.134 E319.67387
G1 X122.197 Y114.7 E319.6965
G1 X122.232 Y115.265 E319.71909
G1 X122.344 Y115.816 E319.74153
G1 X122.522 Y116.344 E319.76377
G1 X122.582 Y116.466 E319.7692
G0 F2576.9 X122.764 Y116.838
M204 S500
G0 F15000 X122.32 Y120.698
M204 S800
G1 F2863.3 X122.06 Y120.958 E319.78387
M204 S500
M204 S800
G1 F2863.3 X122.148 Y120.191 E319.82717
M204 S500
G0 F15000 X122.029 Y119.631
M204 S800
G1 F2863.3 X120.702 Y120.958 E319.90207
M204 S500
M204 S800
G1 F2863.3 X122.004 Y118.977 E320.01389
M204 S500
G0 F15000 X122.155 Y118.147
M204 S800
G1 F2863.3 X119.344 Y120.958 E320.17255
M204 S500
M204 S800
G1 F2863.3 X122.633 Y116.99 E320.39652
M204 S500
G0 F15000 X122.403 Y116.541
M204 S800
G1 F2863.3 X117.987 Y120.958 E320.64581
M204 S500
M204 S800
G1 F2863.3 X122.218 Y116.048 E320.92295
M204 S500
G0 F15000 X122.083 Y115.504
M204 S800
G1 F2863.3 X116.629 Y120.958 E321.2308
M204 S500
M204 S800
G1 F2863.3 X122.015 Y114.893 E321.57307
M204 S500
G0 F15000 X122.034 Y114.195
M204 S800
G1 F2863.3 X115.272 Y120.957 E321.95475
M204 S500
M204 S800
G1 F2863.3 X117.632 Y117.919 E322.12626
G1 X117.725 Y117.825
G1 X121.509 Y114.042 E322.33981
M204 S500
M204 S800
G1 F2863.3 X118.757 Y116.115 E322.45682
M204 S500
G0 F15000 X118.961 Y115.232
M204 S800
G1 F2863.3 X120.151 Y114.042 E322.52399
M204 S500
M204 S800
G1 F2863.3 X118.984 Y114.53 E322.55154
M204 S500
G0 F15000 X115.915 Y118.957
M204 S800
G1 F2863.3 X113.914 Y120.957 E322.66445
M204 S500
M204 S800
G1 F2863.3 X115.032 Y119.161 E322.76583
M204 S500
G0 F15000 X114.331 Y119.183
M204 S800
G1 F2863.3 X112.557 Y120.957 E322.86596
M204 S500
M204 S800
G1 F2863.3 X113.717 Y119.118 E322.96976
M204 S500
G0 F15000 X113.171 Y118.986
M204 S800
G1 F2863.3 X111.199 Y120.957 E323.08104
M204 S500
M204 S800
G1 F2863.3 X112.676 Y118.802 E323.20271
M204 S500
G0 F15000 X112.224 Y118.575
M204 S800
G1 F2863.3 X110.482 Y120.317 E323.30103
M204 S500
G0 F15000 X110.482 Y119.638
M204 S800
G1 F2863.3 X111.816 Y118.304 E323.37633
M204 S500
G0 F15000 X111.449 Y117.992
M204 S800
G1 F2863.3 X110.482 Y118.959 E323.43091
M204 S500
G0 F15000 X110.482 Y118.28
M204 S800
G1 F2863.3 X111.116 Y117.647 E323.46667
M204 S500
G0 F15000 X110.817 Y117.266
M204 S800
G1 F2863.3 X110.482 Y117.601 E323.48558
M204 S500
G0 F15000 X110.482 Y116.922
M204 S800
G1 F2863.3 X110.552 Y116.852 E323.48953
M204 S500
G0 F15000 X110.37 Y115.337
M204 S800
;TYPE:SKIN
G1 F2863.3 X110.507 Y115.201 E323.49338
M204 S500
G0 F15000 X110.486 Y114.882
M204 S800
G1 F2863.3 X110.013 Y115.355 E323.50673
M204 S500
G0 F15000 X110.013 Y115.016
M204 S800
G1 F2863.3 X110.484 Y114.544 E323.52004
M204 S500
G0 F15000 X110.507 Y114.182
M204 S800
G1 F2863.3 X110.013 Y114.677 E323.53399
M204 S500
G0 F15000 X110.013 Y114.337
M204 S800
G1 F2863.3 X110.591 Y113.759 E323.55031
M204 S500
G0 F15000 X110.439 Y113.571
M204 S800
G1 F2863.3 X110.013 Y113.998 E323.56234
M204 S500
G0 F15000 X110.013 Y113.658
M204 S800
G1 F2863.3 X110.1 Y113.571 E323.5648
M204 S500
G1 F1800 E322.9648
;MESH:NONMESH
G0 F300 X110.1 Y113.571 Z4.04
G0 F15000 X110.1 Y111.035
G0 X113.935 Y113.25
G0 X115.949 Y114.373
G0 X125.481 Y119.917
;TIME_ELAPSED:372.234044
;LAYER:18
M204 S800
;TYPE:WALL-OUTER
G1 F1800 E323.5648
G1 F600 X125.746 Y120.889 E323.58025
G1 X126.02 Y120.876 E323.59119
G1 X126.398 Y120.782 E323.60674
G1 X126.646 Y120.663 E323.61772
G1 X126.886 Y120.495 E323.62941
G1 X127.139 Y120.231 E323.64401
G1 X127.332 Y119.915 E323.65878
G1 X127.433 Y119.637 E323.67059
G1 X127.489 Y119.254 E323.68604
G1 X127.476 Y118.98 E323.69699
G1 X127.382 Y118.602 E323.71253
G1 X127.226 Y118.293 E323.72635
G1 X127.03 Y118.042 E323.73906
G1 X126.831 Y117.861 E323.7498
G1 X126.515 Y117.668 E323.76457
G1 X126.237 Y117.567 E323.77638
G1 X125.854 Y117.511 E323.79183
G1 X125.58 Y117.524 E323.80278
G1 X125.202 Y117.618 E323.81832
G1 X124.893 Y117.774 E323.83214
G1 X124.642 Y117.97 E323.84485
G1 X124.461 Y118.169 E323.85559
G1 X124.268 Y118.485 E323.87036
G1 X124.167 Y118.763 E323.88217
G1 X124.111 Y119.146 E323.89762
G1 X124.124 Y119.42 E323.90857
G1 X124.218 Y119.798 E323.92411
G1 X124.374 Y120.107 E323.93793
G1 X124.57 Y120.358 E323.95064
G1 X124.769 Y120.539 E323.96137
G0 F540 X125.085 Y120.732
M204 S500
G0 F15000 X125.539 Y121.194
M204 S800
G1 F600 X125.277 Y121.14 E323.97205
G1 X125.025 Y121.055 E323.98267
G1 X124.79 Y120.938 E323.99314
G1 X124.578 Y120.797 E324.00331
G1 X124.375 Y120.618 E324.01411
G1 X124.202 Y120.42 E324.0246
G1 X124.061 Y120.209 E324.03473
G1 X123.943 Y119.97 E324.04537
G1 X123.858 Y119.716 E324.05606
G1 X123.808 Y119.47 E324.06608
G1 X123.791 Y119.113 E324.08034
G1 X123.821 Y118.847 E324.09103
G1 X123.885 Y118.589 E324.10164
G1 X123.977 Y118.354 E324.11171
G1 X124.107 Y118.116 E324.12253
G1 X124.263 Y117.904 E324.13304
G1 X124.446 Y117.714 E324.14357
G1 X124.643 Y117.556 E324.15365
G1 X124.876 Y117.415 E324.16452
G1 X125.108 Y117.313 E324.17463
G1 X125.372 Y117.236 E324.18561
G1 X125.628 Y117.198 E324.19594
G1 X125.887 Y117.191 E324.20628
G1 X126.153 Y117.221 E324.21696
G1 X126.411 Y117.285 E324.22757
G1 X126.646 Y117.377 E324.23764
G1 X126.884 Y117.507 E324.24847
G1 X127.096 Y117.663 E324.25897
G1 X127.286 Y117.846 E324.2695
G1 X127.444 Y118.043 E324.27958
G1 X127.58 Y118.266 E324.29
G1 X127.687 Y118.508 E324.30057
G1 X127.764 Y118.772 E324.31154
G1 X127.802 Y119.028 E324.32187
G1 X127.809 Y119.281 E324.33197
G1 X127.779 Y119.553 E324.34289
G1 X127.716 Y119.809 E324.35342
G1 X127.623 Y120.046 E324.36358
G1 X127.585 Y120.124 E324.36704
G1 X127.444 Y120.357 E324.37791
G1 X127.286 Y120.554 E324.38799
G1 X127.096 Y120.737 E324.39852
G1 X126.884 Y120.893 E324.40902
G1 X126.646 Y121.023 E324.41985
G1 X126.411 Y121.115 E324.42992
G1 X126.202 Y121.167 E324.43852
G0 F540 X126.154 Y121.179
G0 X125.895 Y121.208
G0 X125.539 Y121.194
M204 S500
;MESH:NONMESH
G0 F300 X125.539 Y121.194 Z4.32
G0 F15000 X125.362 Y120.833
;TIME_ELAPSED:374.814427
;LAYER:19
M204 S800
;TYPE:WALL-OUTER
G1 F600 X125.727 Y120.889 E324.45915
G1 X126.02 Y120.876 E324.47554
G1 X126.306 Y120.813 E324.4919
G1 X126.603 Y120.687 E324.50993
G1 X126.903 Y120.48 E324.5303
G1 X127.14 Y120.23 E324.54954
G1 X127.332 Y119.915 E324.57016
G1 X127.433 Y119.638 E324.58663
G1 X127.489 Y119.273 E324.60727
G1 X127.476 Y118.98 E324.62365
G1 X127.413 Y118.694 E324.64002
G1 X127.287 Y118.397 E324.65805
G1 X127.08 Y118.097 E324.67841
G1 X126.83 Y117.86 E324.69766
G1 X126.515 Y117.668 E324.71827
G1 X126.238 Y117.567 E324.73475
G1 X125.873 Y117.511 E324.75538
G1 X125.58 Y117.524 E324.77177
G1 X125.294 Y117.587 E324.78813
G1 X124.997 Y117.713 E324.80616
G1 X124.697 Y117.92 E324.82653
G1 X124.46 Y118.17 E324.84578
G1 X124.268 Y118.485 E324.86639
G1 X124.167 Y118.762 E324.88286
G1 X124.111 Y119.127 E324.9035
G1 X124.124 Y119.42 E324.91989
G1 X124.187 Y119.706 E324.93625
G1 X124.313 Y120.003 E324.95428
G1 X124.52 Y120.303 E324.97464
G1 X124.77 Y120.54 E324.99389
G1 X124.931 Y120.639 E325.00445
G0 F540 X125.065 Y120.722
G0 X125.362 Y120.833
M204 S500
G0 F15000 X125.539 Y121.193
M204 S800
G1 F600 X125.207 Y121.121 E325.02344
G1 X124.954 Y121.023 E325.0386
G1 X124.716 Y120.893 E325.05375
G1 X124.504 Y120.737 E325.06846
G1 X124.314 Y120.554 E325.0832
G1 X124.156 Y120.357 E325.09731
G1 X124.015 Y120.124 E325.11252
G1 X123.91 Y119.884 E325.12716
G1 X123.835 Y119.625 E325.14223
G1 X123.798 Y119.372 E325.15652
G1 X123.791 Y119.119 E325.17066
G1 X123.819 Y118.856 E325.18544
G1 X123.877 Y118.612 E325.19945
G1 X123.977 Y118.354 E325.21491
G1 X124.107 Y118.116 E325.23007
G1 X124.263 Y117.904 E325.24477
G1 X124.446 Y117.714 E325.25951
G1 X124.643 Y117.556 E325.27362
G1 X124.876 Y117.415 E325.28884
G1 X125.108 Y117.313 E325.303
G1 X125.375 Y117.235 E325.31855
G1 X125.628 Y117.198 E325.33283
G1 X125.881 Y117.191 E325.34698
G1 X126.151 Y117.22 E325.36215
G1 X126.572 Y117.344 E325.38667
G1 X126.81 Y117.462 E325.40152
G1 X127.02 Y117.602 E325.41562
G1 X127.218 Y117.775 E325.43031
G1 X127.392 Y117.972 E325.445
G1 X127.538 Y118.19 E325.45966
G1 X127.655 Y118.425 E325.47433
G1 X127.765 Y118.775 E325.49483
G1 X127.802 Y119.028 E325.50911
G1 X127.809 Y119.281 E325.52326
G1 X127.781 Y119.544 E325.53804
G1 X127.723 Y119.788 E325.55205
G1 X127.623 Y120.046 E325.56751
G1 X127.585 Y120.124 E325.57236
G1 X127.444 Y120.357 E325.58758
G1 X127.286 Y120.554 E325.60169
G1 X127.096 Y120.737 E325.61643
G1 X126.884 Y120.893 E325.63113
G1 X126.646 Y121.023 E325.64629
G1 X126.408 Y121.116 E325.66057
G1 X126.154 Y121.179 E325.67519
G1 X126.013 Y121.195 E325.68312
G0 F540 X125.895 Y121.208
G0 X125.539 Y121.193
M204 S500
;MESH:NONMESH
G0 F300 X125.539 Y121.193 Z4.68
G0 F15000 X125.727 Y120.889
;TIME_ELAPSED:377.349207
;LAYER:20
M204 S800
;TYPE:WALL-OUTER
G1 F600 X126.02 Y120.876 E325.70419
G1 X126.265 Y120.825 E325.72217
G1 X126.513 Y120.732 E325.7412
G1 X126.792 Y120.568 E325.76445
G1 X127.046 Y120.343 E325.78882
G1 X127.264 Y120.045 E325.81535
G1 X127.373 Y119.82 E325.83331
G1 X127.451 Y119.565 E325.85247
G1 X127.489 Y119.273 E325.87362
G1 X127.476 Y118.98 E325.89469
G1 X127.425 Y118.735 E325.91267
G1 X127.332 Y118.487 E325.9317
G1 X127.168 Y118.208 E325.95495
G1 X126.943 Y117.954 E325.97933
G1 X126.645 Y117.736 E326.00585
G1 X126.42 Y117.627 E326.02381
G1 X126.165 Y117.549 E326.04297
G1 X125.873 Y117.511 E326.06413
G1 X125.58 Y117.524 E326.0852
G1 X125.335 Y117.575 E326.10318
G1 X125.087 Y117.668 E326.1222
G1 X124.808 Y117.832 E326.14545
G1 X124.554 Y118.057 E326.16983
G1 X124.336 Y118.355 E326.19636
G1 X124.227 Y118.58 E326.21432
G1 X124.149 Y118.835 E326.23348
G1 X124.111 Y119.127 E326.25463
G1 X124.124 Y119.42 E326.2757
G1 X124.175 Y119.665 E326.29368
G1 X124.268 Y119.913 E326.31271
G1 X124.432 Y120.192 E326.33596
G1 X124.657 Y120.446 E326.36034
G1 X124.955 Y120.664 E326.38686
G1 X125.18 Y120.773 E326.40482
G1 X125.365 Y120.83 E326.41873
G0 F540 X125.435 Y120.851
G0 X125.727 Y120.889
M204 S500
G0 F15000 X125.37 Y121.164
M204 S800
G1 F600 X125.108 Y121.087 E326.43835
G1 X124.874 Y120.984 E326.45672
G1 X124.643 Y120.844 E326.47612
G1 X124.446 Y120.686 E326.49427
G1 X124.259 Y120.491 E326.51368
G1 X124.107 Y120.283 E326.53218
G1 X123.977 Y120.046 E326.5516
G1 X123.882 Y119.801 E326.57048
G1 X123.819 Y119.544 E326.58949
G1 X123.792 Y119.295 E326.60749
G1 X123.798 Y119.028 E326.62667
G1 X123.835 Y118.774 E326.64511
G1 X123.91 Y118.516 E326.66441
G1 X124.015 Y118.276 E326.68323
G1 X124.156 Y118.043 E326.7028
G1 X124.314 Y117.846 E326.72094
G1 X124.504 Y117.663 E326.73989
G1 X124.716 Y117.507 E326.7588
G1 X124.954 Y117.377 E326.77829
G1 X125.198 Y117.282 E326.7971
G1 X125.446 Y117.221 E326.81545
G1 X125.705 Y117.192 E326.83417
G1 X125.972 Y117.198 E326.85336
G1 X126.23 Y117.236 E326.87209
G1 X126.492 Y117.313 E326.89171
G1 X126.724 Y117.415 E326.90992
G1 X126.957 Y117.556 E326.92948
G1 X127.154 Y117.714 E326.94762
G1 X127.337 Y117.904 E326.96658
G1 X127.493 Y118.116 E326.98549
G1 X127.623 Y118.354 E327.00497
G1 X127.718 Y118.598 E327.02378
G1 X127.779 Y118.846 E327.04213
G1 X127.808 Y119.103 E327.06071
G1 X127.802 Y119.372 E327.08004
G1 X127.765 Y119.626 E327.09848
G1 X127.69 Y119.884 E327.11778
G1 X127.585 Y120.124 E327.1366
G1 X127.444 Y120.357 E327.15617
G1 X127.286 Y120.554 E327.17431
G1 X127.096 Y120.737 E327.19326
G1 X126.884 Y120.893 E327.21217
G1 X126.646 Y121.023 E327.23165
G1 X126.402 Y121.118 E327.25046
G1 X126.154 Y121.179 E327.26881
G1 X125.895 Y121.208 E327.28754
G1 X125.736 Y121.204 E327.29896
G0 F540 X125.628 Y121.202
G0 X125.37 Y121.164
M204 S500
;MESH:NONMESH
G0 F300 X125.37 Y121.164 Z5.04
;TIME_ELAPSED:379.891459
;LAYER:21
M204 S800
;TYPE:WALL-OUTER
G1 F600 X126.02 Y120.876 E327.32003
G1 X126.268 Y120.824 E327.33824
G1 X126.581 Y120.699 E327.36245
G1 X126.884 Y120.497 E327.38861
G1 X127.115 Y120.262 E327.41229
G1 X127.264 Y120.045 E327.4312
G1 X127.374 Y119.817 E327.44938
G1 X127.451 Y119.565 E327.46831
G1 X127.489 Y119.273 E327.48947
G1 X127.476 Y118.98 E327.51054
G1 X127.424 Y118.732 E327.52874
G1 X127.299 Y118.419 E327.55296
G1 X127.097 Y118.116 E327.57912
G1 X126.862 Y117.885 E327.60279
G1 X126.645 Y117.736 E327.6217
G1 X126.417 Y117.626 E327.63989
G1 X126.165 Y117.549 E327.65882
G1 X125.873 Y117.511 E327.67997
G1 X125.58 Y117.524 E327.70105
G1 X125.332 Y117.576 E327.71925
G1 X125.019 Y117.701 E327.74346
G1 X124.716 Y117.903 E327.76962
G1 X124.485 Y118.138 E327.7933
G1 X124.336 Y118.355 E327.81221
G1 X124.226 Y118.583 E327.8304
G1 X124.149 Y118.835 E327.84933
G1 X124.111 Y119.127 E327.87048
G1 X124.124 Y119.42 E327.89155
G1 X124.176 Y119.668 E327.90976
G1 X124.301 Y119.981 E327.93397
G1 X124.503 Y120.284 E327.96013
G1 X124.738 Y120.515 E327.9838
G1 X124.954 Y120.664 E328.00266
G1 X125.183 Y120.774 E328.02091
G1 X125.365 Y120.83 E328.03459
M204 S500
G0 F15000 X125.628 Y121.203
M204 S800
G1 F600 X125.37 Y121.164 E328.05333
G1 X125.117 Y121.09 E328.07227
G1 X124.874 Y120.984 E328.09132
G1 X124.643 Y120.844 E328.11072
G1 X124.446 Y120.686 E328.12887
G1 X124.259 Y120.491 E328.14828
G1 X124.107 Y120.283 E328.16678
G1 X123.977 Y120.046 E328.1862
G1 X123.882 Y119.802 E328.20501
G1 X123.819 Y119.544 E328.22409
G1 X123.792 Y119.288 E328.24259
G1 X123.797 Y119.028 E328.26127
G1 X123.835 Y118.774 E328.27972
G1 X123.91 Y118.516 E328.29902
G1 X124.015 Y118.276 E328.31784
G1 X124.156 Y118.043 E328.33741
G1 X124.314 Y117.846 E328.35555
G1 X124.504 Y117.663 E328.3745
G1 X124.716 Y117.507 E328.39341
G1 X124.954 Y117.377 E328.4129
G1 X125.198 Y117.282 E328.43171
G1 X125.446 Y117.221 E328.45005
G1 X125.712 Y117.192 E328.46928
G1 X125.972 Y117.197 E328.48796
G1 X126.23 Y117.236 E328.50671
G1 X126.484 Y117.31 E328.52571
G1 X126.724 Y117.415 E328.54453
G1 X126.957 Y117.556 E328.5641
G1 X127.154 Y117.714 E328.58224
G1 X127.337 Y117.904 E328.60119
G1 X127.493 Y118.116 E328.6201
G1 X127.623 Y118.354 E328.63958
G1 X127.718 Y118.598 E328.6584
G1 X127.779 Y118.846 E328.67674
G1 X127.808 Y119.112 E328.69597
G1 X127.803 Y119.372 E328.71465
G1 X127.765 Y119.626 E328.7331
G1 X127.69 Y119.884 E328.7524
G1 X127.585 Y120.124 E328.77122
G1 X127.444 Y120.357 E328.79079
G1 X127.286 Y120.554 E328.80893
G1 X127.096 Y120.737 E328.82788
G1 X126.884 Y120.893 E328.84679
G1 X126.646 Y121.023 E328.86627
G1 X126.402 Y121.118 E328.88509
G1 X126.154 Y121.179 E328.90343
G1 X125.995 Y121.197 E328.91493
G0 F540 X125.888 Y121.208
G0 X125.628 Y121.203
M204 S500
;MESH:NONMESH
G0 F300 X125.628 Y121.203 Z5.4
;TIME_ELAPSED:382.417400
;LAYER:22
M204 S800
;TYPE:WALL-OUTER
G1 F600 X126.02 Y120.876 E328.936
G1 X126.271 Y120.824 E328.95441
G1 X126.582 Y120.699 E328.97849
G1 X126.886 Y120.496 E329.00476
G1 X127.14 Y120.23 E329.03118
G1 X127.332 Y119.915 E329.05768
G1 X127.433 Y119.638 E329.07886
G1 X127.489 Y119.273 E329.10539
G1 X127.476 Y118.98 E329.12646
G1 X127.424 Y118.729 E329.14488
G1 X127.299 Y118.418 E329.16896
G1 X127.096 Y118.114 E329.19522
G1 X126.83 Y117.86 E329.22164
G1 X126.515 Y117.668 E329.24815
G1 X126.238 Y117.567 E329.26933
G1 X125.873 Y117.511 E329.29586
G1 X125.58 Y117.524 E329.31693
G1 X125.329 Y117.576 E329.33534
G1 X125.018 Y117.701 E329.35942
G1 X124.714 Y117.904 E329.38568
G1 X124.46 Y118.17 E329.41211
G1 X124.268 Y118.485 E329.43861
G1 X124.167 Y118.762 E329.45979
G1 X124.111 Y119.127 E329.48632
G1 X124.124 Y119.42 E329.50739
G1 X124.176 Y119.671 E329.52581
G1 X124.301 Y119.982 E329.54989
G1 X124.504 Y120.286 E329.57615
G1 X124.77 Y120.54 E329.60257
G1 X125.085 Y120.732 E329.62907
G1 X125.362 Y120.833 E329.65026
G1 X125.363 Y120.834 E329.65036
G0 F540 X125.727 Y120.889
M204 S500
G0 F15000 X125.391 Y121.168
M204 S800
G1 F600 X125.048 Y121.064 E329.67611
G1 X124.79 Y120.938 E329.69673
G1 X124.456 Y120.695 E329.72641
G1 X124.223 Y120.447 E329.75085
G1 X124.061 Y120.209 E329.77154
G1 X123.945 Y119.975 E329.7903
G1 X123.857 Y119.713 E329.81016
G1 X123.806 Y119.455 E329.82905
G1 X123.791 Y119.145 E329.85135
G1 X123.832 Y118.791 E329.87695
G1 X123.936 Y118.448 E329.9027
G1 X124.062 Y118.19 E329.92333
G1 X124.305 Y117.856 E329.953
G1 X124.55 Y117.626 E329.97714
G1 X124.79 Y117.462 E329.99803
G1 X125.025 Y117.345 E330.01689
G1 X125.277 Y117.26 E330.03599
G1 X125.535 Y117.207 E330.05491
G1 X125.856 Y117.191 E330.078
G1 X126.209 Y117.232 E330.10353
G1 X126.552 Y117.336 E330.12928
G1 X126.81 Y117.462 E330.14991
G1 X127.144 Y117.705 E330.17959
G1 X127.374 Y117.95 E330.20373
G1 X127.538 Y118.19 E330.22461
G1 X127.654 Y118.422 E330.24325
G1 X127.74 Y118.677 E330.26258
G1 X127.792 Y118.93 E330.28113
G1 X127.809 Y119.255 E330.30452
G1 X127.768 Y119.609 E330.33012
G1 X127.664 Y119.951 E330.3558
G1 X127.539 Y120.209 E330.37639
G1 X127.4 Y120.417 E330.39437
G1 X127.225 Y120.618 E330.41351
G1 X126.951 Y120.848 E330.43921
G1 X126.726 Y120.984 E330.4581
G1 X126.437 Y121.106 E330.48064
G1 X126.065 Y121.193 E330.50808
G1 X125.757 Y121.209 E330.53024
G0 F540 X125.744 Y121.209
G0 X125.391 Y121.168
M204 S500
;MESH:NONMESH
G0 F300 X125.391 Y121.168 Z5.76
G0 F15000 X125.58 Y120.876
;TIME_ELAPSED:384.951002
;LAYER:23
M204 S800
;TYPE:WALL-OUTER
G1 F600 X125.873 Y120.889 E330.55131
G1 X126.132 Y120.857 E330.57006
G1 X126.448 Y120.761 E330.59379
G1 X126.678 Y120.645 E330.61229
G1 X126.886 Y120.495 E330.63072
G1 X127.14 Y120.23 E330.65709
G1 X127.282 Y120.012 E330.67578
G1 X127.412 Y119.707 E330.6996
G1 X127.476 Y119.42 E330.72072
G1 X127.489 Y119.127 E330.74179
G1 X127.457 Y118.868 E330.76054
G1 X127.361 Y118.551 E330.78434
G1 X127.244 Y118.322 E330.80281
G1 X127.095 Y118.114 E330.82119
G1 X126.83 Y117.86 E330.84756
G1 X126.612 Y117.718 E330.86626
G1 X126.307 Y117.588 E330.89007
G1 X126.02 Y117.524 E330.9112
G1 X125.873 Y117.511 E330.9218
G1 X125.581 Y117.524 E330.9428
G1 X125.255 Y117.6 E330.96685
G1 X125.02 Y117.7 E330.9852
G1 X124.714 Y117.905 E331.01166
G1 X124.46 Y118.17 E331.03803
G1 X124.318 Y118.388 E331.05672
G1 X124.188 Y118.693 E331.08054
G1 X124.124 Y118.98 E331.10166
G1 X124.111 Y119.273 E331.12273
G1 X124.143 Y119.532 E331.14148
G1 X124.239 Y119.849 E331.16528
G1 X124.356 Y120.078 E331.18375
G1 X124.505 Y120.286 E331.20213
G1 X124.77 Y120.54 E331.22851
G1 X124.988 Y120.682 E331.2472
G1 X125.225 Y120.783 E331.2657
G0 F540 X125.293 Y120.812
G0 X125.58 Y120.876
M204 S500
G0 F15000 X125.57 Y121.198
M204 S800
G1 F600 X125.233 Y121.128 E331.29043
G1 X124.907 Y121.001 E331.31557
G1 X124.681 Y120.87 E331.33433
G1 X124.462 Y120.7 E331.35425
G1 X124.224 Y120.447 E331.37921
G1 X124.073 Y120.228 E331.39832
G1 X123.94 Y119.963 E331.41962
G1 X123.837 Y119.631 E331.44459
G1 X123.792 Y119.287 E331.46951
G1 X123.802 Y118.97 E331.4923
G1 X123.872 Y118.633 E331.51703
G1 X123.999 Y118.308 E331.5421
G1 X124.13 Y118.081 E331.56092
G1 X124.3 Y117.862 E331.58084
G1 X124.544 Y117.631 E331.60498
G1 X124.772 Y117.473 E331.62491
G1 X125.037 Y117.34 E331.64621
G1 X125.369 Y117.237 E331.67118
G1 X125.713 Y117.192 E331.69611
G1 X125.858 Y117.19 E331.70653
G1 X126.148 Y117.22 E331.72747
G1 X126.452 Y117.299 E331.75004
G1 X126.692 Y117.399 E331.76872
G1 X126.919 Y117.53 E331.78754
G1 X127.138 Y117.7 E331.80746
G1 X127.369 Y117.944 E331.8316
G1 X127.527 Y118.172 E331.85153
G1 X127.66 Y118.437 E331.87283
G1 X127.762 Y118.763 E331.89737
G1 X127.808 Y119.113 E331.92273
G1 X127.798 Y119.43 E331.94552
G1 X127.728 Y119.767 E331.97024
G1 X127.601 Y120.092 E331.99531
G1 X127.47 Y120.319 E332.01414
G1 X127.302 Y120.535 E332.0338
G1 X127.056 Y120.769 E332.05819
G1 X126.831 Y120.925 E332.07786
G1 X126.563 Y121.06 E332.09942
G1 X126.231 Y121.163 E332.12439
G1 X125.937 Y121.202 E332.1457
G0 F540 X125.887 Y121.208
G0 X125.57 Y121.198
M204 S500
;MESH:NONMESH
G0 F300 X125.57 Y121.198 Z6.12
;TIME_ELAPSED:387.477083
;LAYER:24
M204 S800
;TYPE:WALL-OUTER
G1 F600 X126.02 Y120.876 E332.16677
G1 X126.28 Y120.821 E332.18586
G1 X126.528 Y120.726 E332.20494
G1 X126.83 Y120.54 E332.23042
G1 X127.024 Y120.366 E332.24914
G1 X127.185 Y120.17 E332.26737
G1 X127.332 Y119.915 E332.28851
G1 X127.433 Y119.638 E332.30969
G1 X127.489 Y119.273 E332.33622
G1 X127.476 Y118.98 E332.35729
G1 X127.421 Y118.72 E332.37639
G1 X127.331 Y118.485 E332.39446
G1 X127.159 Y118.196 E332.41863
G1 X126.942 Y117.954 E332.44198
G1 X126.734 Y117.792 E332.46092
G1 X126.515 Y117.668 E332.479
G1 X126.238 Y117.567 E332.50018
G1 X125.873 Y117.511 E332.52671
G1 X125.58 Y117.524 E332.54778
G1 X125.32 Y117.579 E332.56687
G1 X125.085 Y117.669 E332.58495
G1 X124.796 Y117.841 E332.60911
G1 X124.554 Y118.058 E332.63246
G1 X124.392 Y118.266 E332.6514
G1 X124.268 Y118.485 E332.66948
G1 X124.167 Y118.762 E332.69067
G1 X124.111 Y119.127 E332.7172
G1 X124.124 Y119.42 E332.73827
G1 X124.179 Y119.68 E332.75736
G1 X124.269 Y119.915 E332.77544
G1 X124.441 Y120.204 E332.7996
G1 X124.658 Y120.446 E332.82295
G1 X124.866 Y120.608 E332.84189
G1 X125.085 Y120.732 E332.85997
G1 X125.362 Y120.833 E332.88115
G1 X125.363 Y120.834 E332.88125
M204 S500
G0 F15000 X125.889 Y121.208
M204 S800
G1 F600 X125.619 Y121.201 E332.90066
G1 X125.361 Y121.162 E332.9194
G1 X125.063 Y121.07 E332.94181
G1 X124.788 Y120.937 E332.96375
G1 X124.542 Y120.767 E332.98524
G1 X124.312 Y120.552 E333.00786
G1 X124.103 Y120.277 E333.03267
G1 X123.942 Y119.967 E333.05777
G1 X123.835 Y119.626 E333.08344
G1 X123.792 Y119.289 E333.10785
G1 X123.799 Y119.019 E333.12725
G1 X123.839 Y118.758 E333.14622
G1 X123.93 Y118.463 E333.1684
G1 X124.063 Y118.188 E333.19035
G1 X124.231 Y117.944 E333.21163
G1 X124.448 Y117.712 E333.23445
G1 X124.726 Y117.501 E333.25953
G1 X125.033 Y117.342 E333.28436
G1 X125.371 Y117.236 E333.30981
G1 X125.711 Y117.192 E333.33444
G1 X125.84 Y117.19 E333.34371
G1 X126.101 Y117.212 E333.36253
G1 X126.359 Y117.27 E333.38153
G1 X126.609 Y117.36 E333.40061
G1 X126.884 Y117.507 E333.42302
G1 X127.123 Y117.687 E333.44451
G1 X127.335 Y117.902 E333.4662
G1 X127.497 Y118.123 E333.48589
G1 X127.658 Y118.433 E333.51098
G1 X127.765 Y118.774 E333.53666
G1 X127.808 Y119.105 E333.56064
G1 X127.801 Y119.381 E333.58047
G1 X127.762 Y119.638 E333.59915
G1 X127.67 Y119.937 E333.62162
G1 X127.539 Y120.208 E333.64325
G1 X127.369 Y120.456 E333.66485
G1 X127.155 Y120.685 E333.68737
G1 X126.877 Y120.897 E333.71248
G1 X126.567 Y121.058 E333.73758
G1 X126.253 Y121.157 E333.76123
G0 F540 X126.229 Y121.164
G0 X125.889 Y121.208
M204 S500
;MESH:NONMESH
G0 F300 X125.889 Y121.208 Z6.48
G0 F15000 X126.019 Y120.876
;TIME_ELAPSED:390.006521
;LAYER:25
M204 S800
;TYPE:WALL-OUTER
G1 F600 X126.377 Y120.789 E333.7877
G1 X126.684 Y120.64 E333.81222
G1 X126.977 Y120.413 E333.83884
G1 X127.168 Y120.193 E333.85977
G1 X127.332 Y119.914 E333.88302
G1 X127.433 Y119.637 E333.90421
G1 X127.481 Y119.375 E333.92334
G1 X127.476 Y118.981 E333.95165
G1 X127.389 Y118.623 E333.97812
G1 X127.278 Y118.379 E333.99738
G1 X127.095 Y118.114 E334.02051
G1 X126.908 Y117.923 E334.03972
G1 X126.707 Y117.774 E334.05769
G1 X126.378 Y117.611 E334.08407
G1 X126.094 Y117.535 E334.10519
G1 X125.873 Y117.511 E334.12116
G1 X125.581 Y117.524 E334.14216
G1 X125.223 Y117.611 E334.16863
G1 X124.979 Y117.722 E334.18789
G1 X124.714 Y117.905 E334.21102
G1 X124.523 Y118.092 E334.23023
G1 X124.374 Y118.293 E334.2482
G1 X124.211 Y118.622 E334.27458
G1 X124.135 Y118.906 E334.2957
G1 X124.111 Y119.273 E334.32212
G1 X124.144 Y119.539 E334.34138
G1 X124.257 Y119.891 E334.36794
G1 X124.417 Y120.172 E334.39117
G1 X124.587 Y120.377 E334.4103
G1 X124.807 Y120.568 E334.43123
G1 X125.086 Y120.732 E334.45448
G1 X125.363 Y120.833 E334.47566
G1 X125.625 Y120.881 E334.4948
G1 X125.651 Y120.88 E334.49667
G0 F540 X126.019 Y120.876
M204 S500
G0 F15000 X125.675 Y121.206
M204 S800
G1 F600 X125.322 Y121.153 E334.52231
G1 X125.074 Y121.075 E334.54099
G1 X124.842 Y120.967 E334.55937
G1 X124.621 Y120.828 E334.57813
G1 X124.354 Y120.596 E334.60354
G1 X124.179 Y120.387 E334.62313
G1 X124.038 Y120.166 E334.64196
G1 X123.881 Y119.798 E334.6707
G1 X123.821 Y119.554 E334.68875
G1 X123.792 Y119.295 E334.70748
G1 X123.808 Y118.93 E334.73373
G1 X123.885 Y118.587 E334.75898
G1 X123.993 Y118.319 E334.77974
G1 X124.129 Y118.083 E334.79931
G1 X124.312 Y117.848 E334.8207
G1 X124.506 Y117.662 E334.84001
G1 X124.749 Y117.487 E334.86153
G1 X124.993 Y117.36 E334.88129
G1 X125.375 Y117.235 E334.91016
G1 X125.631 Y117.198 E334.92875
G1 X125.925 Y117.194 E334.94987
G1 X126.278 Y117.247 E334.97551
G1 X126.526 Y117.325 E334.99419
G1 X126.758 Y117.433 E335.01258
G1 X126.979 Y117.572 E335.03133
G1 X127.244 Y117.802 E335.05654
G1 X127.421 Y118.013 E335.07633
G1 X127.56 Y118.23 E335.09484
G1 X127.718 Y118.598 E335.12361
G1 X127.778 Y118.841 E335.14159
G1 X127.808 Y119.105 E335.16068
G1 X127.792 Y119.47 E335.18693
G1 X127.716 Y119.809 E335.21189
G1 X127.607 Y120.081 E335.23294
G1 X127.471 Y120.317 E335.25251
G1 X127.288 Y120.552 E335.27391
G1 X127.094 Y120.738 E335.29322
G1 X126.851 Y120.913 E335.31473
G1 X126.607 Y121.04 E335.33449
G1 X126.225 Y121.165 E335.36337
G1 X126.042 Y121.192 E335.37666
G0 F540 X125.969 Y121.202
G0 X125.675 Y121.206
M204 S500
;MESH:NONMESH
G0 F300 X125.675 Y121.206 Z6.84
G0 F15000 X125.085 Y120.731
;TIME_ELAPSED:392.567129
;LAYER:26
M204 S800
;TYPE:WALL-OUTER
G1 F600 X125.434 Y120.85 E335.40315
G1 X125.727 Y120.889 E335.42438
G1 X126.02 Y120.876 E335.44545
G1 X126.285 Y120.819 E335.46493
G1 X126.579 Y120.7 E335.48771
G1 X126.886 Y120.495 E335.51423
G1 X127.126 Y120.248 E335.53897
G1 X127.331 Y119.915 E335.56707
G1 X127.45 Y119.566 E335.59356
G1 X127.489 Y119.273 E335.61479
G1 X127.476 Y118.98 E335.63586
G1 X127.419 Y118.715 E335.65534
G1 X127.3 Y118.421 E335.67812
G1 X127.095 Y118.114 E335.70464
G1 X126.848 Y117.874 E335.72939
G1 X126.515 Y117.669 E335.75748
G1 X126.166 Y117.55 E335.78397
G1 X125.873 Y117.511 E335.8052
G1 X125.58 Y117.524 E335.82628
G1 X125.315 Y117.581 E335.84575
G1 X125.021 Y117.7 E335.86853
G1 X124.714 Y117.905 E335.89506
G1 X124.474 Y118.152 E335.9198
G1 X124.269 Y118.485 E335.94789
G1 X124.15 Y118.834 E335.97438
G1 X124.111 Y119.127 E335.99562
G1 X124.124 Y119.42 E336.01669
G1 X124.181 Y119.685 E336.03616
G1 X124.3 Y119.979 E336.05895
G1 X124.505 Y120.286 E336.08547
G1 X124.752 Y120.526 E336.11021
G1 X124.772 Y120.539 E336.11192
G0 F540 X125.085 Y120.731
M204 S500
G0 F15000 X125.769 Y121.21
M204 S800
G1 F600 X125.451 Y121.18 E336.13487
G1 X125.195 Y121.117 E336.15381
G1 X124.876 Y120.985 E336.17861
G1 X124.578 Y120.796 E336.20396
G1 X124.373 Y120.615 E336.22361
G1 X124.154 Y120.354 E336.24809
G1 X124.013 Y120.12 E336.26771
G1 X123.91 Y119.884 E336.28621
G1 X123.832 Y119.605 E336.30703
G1 X123.792 Y119.287 E336.33005
G1 X123.808 Y118.929 E336.3558
G1 X123.881 Y118.601 E336.37994
G1 X124.015 Y118.276 E336.40519
G1 X124.201 Y117.982 E336.43019
G1 X124.385 Y117.773 E336.45019
G1 X124.646 Y117.554 E336.47467
G1 X124.876 Y117.415 E336.49398
G1 X125.116 Y117.31 E336.5128
G1 X125.395 Y117.232 E336.53361
G1 X125.713 Y117.192 E336.55663
G1 X126.068 Y117.208 E336.58216
G1 X126.405 Y117.283 E336.60697
G1 X126.724 Y117.415 E336.63177
G1 X127.022 Y117.604 E336.65712
G1 X127.227 Y117.785 E336.67677
G1 X127.446 Y118.046 E336.70124
G1 X127.587 Y118.28 E336.72087
G1 X127.69 Y118.516 E336.73937
G1 X127.767 Y118.79 E336.75982
G1 X127.808 Y119.106 E336.78271
G1 X127.792 Y119.468 E336.80874
G1 X127.717 Y119.805 E336.83354
G1 X127.585 Y120.124 E336.85835
G1 X127.399 Y120.418 E336.88334
G1 X127.215 Y120.627 E336.90334
G1 X126.954 Y120.846 E336.92782
G1 X126.724 Y120.985 E336.94713
G1 X126.486 Y121.089 E336.96579
G1 X126.324 Y121.14 E336.97799
G1 X126.135 Y121.178 E336.99184
G0 F540 X126.056 Y121.193
G0 X125.769 Y121.21
M204 S500
;MESH:NONMESH
G0 F300 X125.769 Y121.21 Z7.2
;TIME_ELAPSED:395.119935
;LAYER:27
M204 S800
;TYPE:WALL-OUTER
G1 F600 X126.02 Y120.876 E337.01291
G1 X126.288 Y120.818 E337.03261
G1 X126.582 Y120.698 E337.05542
G1 X126.886 Y120.495 E337.08168
G1 X127.128 Y120.246 E337.10663
G1 X127.332 Y119.915 E337.13456
G1 X127.433 Y119.637 E337.15581
G1 X127.489 Y119.273 E337.18227
G1 X127.476 Y118.98 E337.20334
G1 X127.418 Y118.712 E337.22304
G1 X127.274 Y118.373 E337.2495
G1 X127.094 Y118.112 E337.27228
G1 X126.846 Y117.872 E337.29707
G1 X126.515 Y117.668 E337.325
G1 X126.237 Y117.567 E337.34625
G1 X125.873 Y117.511 E337.37271
G1 X125.58 Y117.524 E337.39378
G1 X125.312 Y117.582 E337.41348
G1 X124.973 Y117.726 E337.43994
G1 X124.712 Y117.906 E337.46272
G1 X124.472 Y118.154 E337.48751
G1 X124.268 Y118.485 E337.51545
G1 X124.167 Y118.763 E337.5367
G1 X124.111 Y119.127 E337.56315
G1 X124.124 Y119.42 E337.58422
G1 X124.182 Y119.688 E337.60392
G1 X124.326 Y120.027 E337.63038
G1 X124.506 Y120.288 E337.65316
G1 X124.754 Y120.528 E337.67796
G1 X125.085 Y120.732 E337.70589
G1 X125.363 Y120.833 E337.72714
M204 S500
G0 F15000 X125.774 Y121.21
M204 S800
G1 F600 X125.419 Y121.174 E337.75277
G1 X125.168 Y121.108 E337.77142
G1 X124.926 Y121.01 E337.79018
G1 X124.694 Y120.878 E337.80935
G1 X124.484 Y120.719 E337.82828
G1 X124.304 Y120.541 E337.84646
G1 X124.142 Y120.336 E337.86523
G1 X123.977 Y120.045 E337.88927
G1 X123.882 Y119.802 E337.90801
G1 X123.816 Y119.519 E337.92889
G1 X123.79 Y119.178 E337.95346
G1 X123.826 Y118.819 E337.97938
G1 X123.893 Y118.565 E337.99825
G1 X123.992 Y118.321 E338.01717
G1 X124.122 Y118.094 E338.03596
G1 X124.281 Y117.884 E338.05488
G1 X124.459 Y117.704 E338.07307
G1 X124.664 Y117.542 E338.09184
G1 X124.951 Y117.379 E338.11555
G1 X125.198 Y117.282 E338.13462
G1 X125.476 Y117.217 E338.15513
G1 X125.826 Y117.19 E338.18035
G1 X126.181 Y117.226 E338.20598
G1 X126.432 Y117.292 E338.22463
G1 X126.674 Y117.39 E338.24338
G1 X126.906 Y117.522 E338.26256
G1 X127.116 Y117.681 E338.28148
G1 X127.296 Y117.859 E338.29967
G1 X127.458 Y118.064 E338.31844
G1 X127.621 Y118.351 E338.34215
G1 X127.715 Y118.59 E338.3606
G1 X127.783 Y118.876 E338.38172
G1 X127.81 Y119.222 E338.40666
G1 X127.774 Y119.581 E338.43258
G1 X127.708 Y119.832 E338.45122
G1 X127.61 Y120.074 E338.46998
G1 X127.478 Y120.306 E338.48916
G1 X127.32 Y120.514 E338.50792
G1 X127.141 Y120.696 E338.52626
G1 X126.936 Y120.858 E338.54503
G1 X126.649 Y121.021 E338.56874
G1 X126.402 Y121.118 E338.58781
G1 X126.14 Y121.18 E338.60715
G0 F540 X126.124 Y121.183
G0 X125.774 Y121.21
M204 S500
;MESH:NONMESH
G0 F300 X125.774 Y121.21 Z7.56
;TIME_ELAPSED:397.648822
;LAYER:28
M204 S800
;TYPE:WALL-OUTER
G1 F600 X125.873 Y120.889 E338.62822
G1 X126.166 Y120.851 E338.64945
G1 X126.5 Y120.739 E338.67475
G1 X126.771 Y120.584 E338.69718
G1 X127.046 Y120.342 E338.7235
G1 X127.263 Y120.047 E338.74981
G1 X127.408 Y119.723 E338.77531
G1 X127.474 Y119.435 E338.79654
G1 X127.489 Y119.127 E338.81869
G1 X127.451 Y118.834 E338.83992
G1 X127.339 Y118.5 E338.86523
G1 X127.184 Y118.229 E338.88765
G1 X126.942 Y117.954 E338.91397
G1 X126.647 Y117.737 E338.94028
G1 X126.323 Y117.592 E338.96578
G1 X126.035 Y117.526 E338.98701
G1 X125.874 Y117.511 E338.99863
G1 X125.58 Y117.524 E339.01977
G1 X125.309 Y117.583 E339.03969
G1 X125.017 Y117.702 E339.06235
G1 X124.716 Y117.903 E339.08835
G1 X124.462 Y118.168 E339.11472
G1 X124.3 Y118.421 E339.1363
G1 X124.192 Y118.677 E339.15626
G1 X124.126 Y118.965 E339.17749
G1 X124.111 Y119.273 E339.19964
G1 X124.149 Y119.566 E339.22087
G1 X124.261 Y119.9 E339.24618
G1 X124.416 Y120.171 E339.26861
G1 X124.658 Y120.446 E339.29492
G1 X124.953 Y120.663 E339.32123
G1 X125.222 Y120.789 E339.34257
G0 F540 X125.58 Y120.876
M204 S500
M204 S800
G1 F600 X125.536 Y121.193 E339.36796
G1 X125.256 Y121.135 E339.3885
G1 X124.874 Y120.984 E339.41801
G1 X124.627 Y120.832 E339.43885
G1 X124.426 Y120.666 E339.45757
G1 X124.245 Y120.473 E339.47658
G1 X124.098 Y120.269 E339.49465
G1 X123.944 Y119.971 E339.51875
G1 X123.837 Y119.633 E339.54422
G1 X123.792 Y119.289 E339.56914
G1 X123.807 Y118.936 E339.59452
G1 X123.862 Y118.666 E339.61432
G1 X123.946 Y118.422 E339.63286
G1 X124.072 Y118.174 E339.65284
G1 X124.214 Y117.966 E339.67094
G1 X124.387 Y117.77 E339.68972
G1 X124.595 Y117.592 E339.70939
G1 X124.816 Y117.448 E339.72834
G1 X125.198 Y117.282 E339.75826
G1 X125.464 Y117.219 E339.7779
G1 X125.818 Y117.19 E339.80341
G1 X126.168 Y117.224 E339.82868
G1 X126.428 Y117.29 E339.84795
G1 X126.726 Y117.416 E339.87119
G1 X126.973 Y117.568 E339.89203
G1 X127.174 Y117.734 E339.91076
G1 X127.355 Y117.927 E339.92977
G1 X127.502 Y118.131 E339.94783
G1 X127.653 Y118.422 E339.97138
G1 X127.763 Y118.767 E339.9974
G1 X127.808 Y119.106 E340.02197
G1 X127.793 Y119.464 E340.04771
G1 X127.738 Y119.734 E340.0675
G1 X127.654 Y119.978 E340.08604
G1 X127.528 Y120.226 E340.10603
G1 X127.432 Y120.373 E340.11864
G1 X127.271 Y120.569 E340.13686
G1 X127.073 Y120.755 E340.15638
G1 X126.869 Y120.902 E340.17444
G1 X126.571 Y121.056 E340.19854
G1 X126.254 Y121.157 E340.22244
G0 F540 X126.233 Y121.163
M204 S500
;MESH:NONMESH
G0 F300 X125.889 Y121.208 Z7.92
G0 F15000 X125.279 Y120.808
;TIME_ELAPSED:400.206665
;LAYER:29
M204 S800
;TYPE:WALL-OUTER
;MESH:RS_Fan-Housing-Clamp-Rev1.stl
G1 F600 X125.582 Y120.876 E340.24475
G1 X125.873 Y120.889 E340.26568
G1 X126.164 Y120.851 E340.28676
G1 X126.447 Y120.762 E340.30808
G1 X126.77 Y120.585 E340.33454
G1 X127.046 Y120.342 E340.36096
G1 X127.263 Y120.047 E340.38727
G1 X127.408 Y119.721 E340.4129
G1 X127.476 Y119.418 E340.43521
G1 X127.489 Y119.127 E340.45613
G1 X127.451 Y118.836 E340.47722
G1 X127.361 Y118.55 E340.49876
G1 X127.185 Y118.23 E340.525
G1 X126.942 Y117.954 E340.55141
G1 X126.647 Y117.737 E340.57772
G1 X126.321 Y117.592 E340.60336
G1 X126.018 Y117.524 E340.62567
G1 X125.873 Y117.511 E340.63612
G1 X125.58 Y117.524 E340.65719
G1 X125.224 Y117.61 E340.68351
G1 X124.953 Y117.737 E340.70501
G1 X124.716 Y117.903 E340.72579
G1 X124.468 Y118.16 E340.75145
G1 X124.3 Y118.421 E340.77375
G1 X124.192 Y118.679 E340.79385
G1 X124.124 Y118.982 E340.81616
G1 X124.111 Y119.273 E340.83708
G1 X124.149 Y119.564 E340.85817
G1 X124.239 Y119.85 E340.87971
G1 X124.415 Y120.17 E340.90594
G1 X124.658 Y120.446 E340.93236
G1 X124.944 Y120.656 E340.95785
G0 F540 X124.953 Y120.663
G0 X125.279 Y120.808
M204 S500
G0 F15000 X125.887 Y121.208
M204 S800
G1 F600 X125.525 Y121.192 E340.98388
G1 X125.264 Y121.137 E341.00305
G1 X124.862 Y120.978 E341.0341
G1 X124.641 Y120.842 E341.05275
G1 X124.436 Y120.677 E341.07165
G1 X124.25 Y120.479 E341.09117
G1 X124.095 Y120.264 E341.11021
G1 X123.944 Y119.971 E341.13389
G1 X123.835 Y119.625 E341.15995
G1 X123.792 Y119.287 E341.18443
G1 X123.807 Y118.931 E341.21003
G1 X123.863 Y118.664 E341.22963
G1 X124.02 Y118.266 E341.26037
G1 X124.158 Y118.041 E341.27933
G1 X124.321 Y117.838 E341.29803
G1 X124.521 Y117.65 E341.31775
G1 X124.736 Y117.495 E341.33679
G1 X125.029 Y117.344 E341.36047
G1 X125.37 Y117.236 E341.38617
G1 X125.713 Y117.192 E341.41101
G1 X125.813 Y117.19 E341.4182
G1 X126.075 Y117.208 E341.43707
G1 X126.336 Y117.263 E341.45623
G1 X126.738 Y117.422 E341.48729
G1 X126.959 Y117.558 E341.50593
G1 X127.162 Y117.721 E341.52463
G1 X127.35 Y117.921 E341.54435
G1 X127.505 Y118.136 E341.56339
G1 X127.656 Y118.429 E341.58708
G1 X127.765 Y118.775 E341.61314
G1 X127.808 Y119.106 E341.63712
G1 X127.793 Y119.469 E341.66322
G1 X127.737 Y119.736 E341.68282
G1 X127.58 Y120.134 E341.71355
G1 X127.442 Y120.359 E341.73252
G1 X127.279 Y120.562 E341.75122
G1 X127.079 Y120.75 E341.77094
G1 X126.865 Y120.905 E341.78992
G1 X126.571 Y121.056 E341.81367
G1 X126.251 Y121.158 E341.8378
G0 F540 X126.23 Y121.164
G0 X125.887 Y121.208
M204 S500
;MESH:NONMESH
G0 F300 X125.887 Y121.208 Z8.28
G0 F15000 X125.582 Y120.876
;TIME_ELAPSED:402.763497
;LAYER:30
M204 S800
;TYPE:WALL-OUTER
G1 F600 X125.873 Y120.889 E341.85872
G1 X126.164 Y120.851 E341.87981
G1 X126.449 Y120.761 E341.90128
G1 X126.705 Y120.627 E341.92204
G1 X126.944 Y120.444 E341.94366
G1 X127.138 Y120.232 E341.96431
G1 X127.3 Y119.979 E341.98589
G1 X127.411 Y119.711 E342.00673
G1 X127.476 Y119.418 E342.02829
G1 X127.489 Y119.127 E342.04922
G1 X127.451 Y118.836 E342.0703
G1 X127.361 Y118.55 E342.09184
G1 X127.231 Y118.301 E342.11202
G1 X127.044 Y118.056 E342.13416
G1 X126.832 Y117.862 E342.15481
G1 X126.579 Y117.7 E342.17639
G1 X126.311 Y117.589 E342.19723
G1 X126.018 Y117.524 E342.21879
G1 X125.873 Y117.511 E342.22925
G1 X125.58 Y117.524 E342.25032
G1 X125.224 Y117.61 E342.27663
G1 X124.901 Y117.769 E342.3025
G1 X124.656 Y117.956 E342.32464
G1 X124.462 Y118.168 E342.34529
G1 X124.3 Y118.421 E342.36687
G1 X124.189 Y118.689 E342.38771
G1 X124.124 Y118.982 E342.40927
G1 X124.111 Y119.273 E342.4302
G1 X124.149 Y119.564 E342.45128
G1 X124.239 Y119.85 E342.47282
G1 X124.369 Y120.099 E342.493
G1 X124.556 Y120.344 E342.51514
G1 X124.768 Y120.538 E342.53579
G1 X125.021 Y120.7 E342.55737
G1 X125.227 Y120.785 E342.57338
G0 F540 X125.289 Y120.811
G0 X125.582 Y120.876
M204 S500
G0 F15000 X125.701 Y121.208
M204 S800
G1 F600 X125.442 Y121.178 E342.59211
G1 X125.186 Y121.115 E342.61105
G1 X124.952 Y121.022 E342.62914
G1 X124.711 Y120.89 E342.64888
G1 X124.503 Y120.735 E342.66752
G1 X124.318 Y120.558 E342.68591
G1 X124.153 Y120.352 E342.70487
G1 X124.014 Y120.121 E342.72424
G1 X123.885 Y119.812 E342.7483
G1 X123.82 Y119.541 E342.76832
G1 X123.792 Y119.287 E342.78668
G1 X123.798 Y119.022 E342.80572
G1 X123.837 Y118.766 E342.82432
G1 X123.942 Y118.431 E342.84955
G1 X124.065 Y118.185 E342.8693
G1 X124.265 Y117.903 E342.89414
G1 X124.44 Y117.72 E342.91233
G1 X124.648 Y117.553 E342.9315
G1 X124.879 Y117.414 E342.95086
G1 X125.188 Y117.285 E342.97492
G1 X125.459 Y117.22 E342.99494
G1 X125.713 Y117.192 E343.0133
G1 X125.978 Y117.198 E343.03234
G1 X126.234 Y117.237 E343.05095
G1 X126.573 Y117.344 E343.07649
G1 X126.815 Y117.465 E343.09592
G1 X127.097 Y117.665 E343.12076
G1 X127.28 Y117.84 E343.13895
G1 X127.447 Y118.048 E343.15812
G1 X127.586 Y118.279 E343.17748
G1 X127.714 Y118.585 E343.20131
G1 X127.779 Y118.852 E343.22106
G1 X127.808 Y119.113 E343.23992
G1 X127.802 Y119.378 E343.25896
G1 X127.793 Y119.468 E343.26546
G1 X127.741 Y119.722 E343.28409
G1 X127.658 Y119.969 E343.30281
G1 X127.536 Y120.214 E343.32247
G1 X127.397 Y120.422 E343.34044
G1 X127.221 Y120.622 E343.35958
G1 X127.02 Y120.797 E343.37873
G1 X126.807 Y120.94 E343.39716
G1 X126.565 Y121.059 E343.41654
G1 X126.227 Y121.164 E343.44196
G1 X126.068 Y121.188 E343.45351
G0 F540 X125.966 Y121.202
G0 X125.701 Y121.208
M204 S500
;MESH:NONMESH
G0 F300 X125.701 Y121.208 Z8.64
;TIME_ELAPSED:405.292551
;LAYER:31
M204 S800
;TYPE:WALL-OUTER
G1 F600 X125.873 Y120.889 E343.47459
G1 X126.163 Y120.852 E343.49559
G1 X126.511 Y120.734 E343.52199
G1 X126.77 Y120.585 E343.54345
G1 X127.044 Y120.344 E343.56967
G1 X127.264 Y120.045 E343.59634
G1 X127.389 Y119.778 E343.61752
G1 X127.476 Y119.42 E343.64399
G1 X127.489 Y119.127 E343.66506
G1 X127.452 Y118.837 E343.68606
G1 X127.334 Y118.489 E343.71246
G1 X127.185 Y118.23 E343.73393
G1 X126.944 Y117.956 E343.76014
G1 X126.645 Y117.736 E343.78681
G1 X126.378 Y117.611 E343.80799
G1 X126.02 Y117.524 E343.83446
G1 X125.873 Y117.511 E343.84506
G1 X125.58 Y117.524 E343.86613
G1 X125.295 Y117.587 E343.8871
G1 X124.955 Y117.736 E343.91377
G1 X124.716 Y117.903 E343.93471
G1 X124.503 Y118.116 E343.95636
G1 X124.336 Y118.355 E343.9773
G1 X124.211 Y118.622 E343.99848
G1 X124.124 Y118.98 E344.02495
G1 X124.111 Y119.273 E344.04602
G1 X124.148 Y119.563 E344.06702
G1 X124.266 Y119.911 E344.09342
G1 X124.415 Y120.17 E344.11489
G1 X124.656 Y120.444 E344.1411
G1 X124.955 Y120.664 E344.16777
G1 X125.222 Y120.789 E344.18895
M204 S500
G0 F15000 X125.888 Y121.168
M204 S800
G1 F600 X125.629 Y121.162 E344.20756
G1 X125.379 Y121.125 E344.22572
G1 X125.107 Y121.043 E344.24613
G1 X124.871 Y120.937 E344.26472
G1 X124.579 Y120.745 E344.28982
G1 X124.337 Y120.517 E344.31371
G1 X124.138 Y120.259 E344.33712
G1 X124.01 Y120.02 E344.3566
G1 X123.917 Y119.775 E344.37542
G1 X123.845 Y119.438 E344.40018
G1 X123.832 Y119.105 E344.42412
G1 X123.875 Y118.779 E344.44774
G1 X123.957 Y118.507 E344.46815
G1 X124.063 Y118.271 E344.48674
G1 X124.255 Y117.979 E344.51185
G1 X124.483 Y117.737 E344.53573
G1 X124.741 Y117.538 E344.55914
G1 X124.98 Y117.41 E344.57862
G1 X125.225 Y117.317 E344.59745
G1 X125.562 Y117.245 E344.6222
G1 X125.892 Y117.232 E344.64593
G1 X126.147 Y117.26 E344.66436
G1 X126.407 Y117.327 E344.68365
G1 X126.725 Y117.461 E344.70844
G1 X127.021 Y117.655 E344.73386
G1 X127.263 Y117.883 E344.75775
G1 X127.465 Y118.146 E344.78158
G1 X127.59 Y118.38 E344.80064
G1 X127.683 Y118.625 E344.81946
G1 X127.755 Y118.962 E344.84422
G1 X127.768 Y119.292 E344.86795
G1 X127.725 Y119.621 E344.89178
G1 X127.643 Y119.893 E344.91219
G1 X127.492 Y120.206 E344.93716
G1 X127.345 Y120.421 E344.95587
G1 X127.117 Y120.663 E344.97976
G1 X126.859 Y120.862 E345.00316
G1 X126.62 Y120.99 E345.02264
G1 X126.454 Y121.058 E345.03553
G1 X126.252 Y121.115 E345.05061
G0 F540 X126.203 Y121.128
G0 X125.888 Y121.168
M204 S500
;MESH:NONMESH
G0 F300 X125.888 Y121.168 Z8.84
;TIME_ELAPSED:407.766200
;LAYER:32
M204 S800
;TYPE:WALL-OUTER
G1 F600 X126.02 Y120.876 E345.06231
G1 X126.374 Y120.791 E345.07684
G1 X126.704 Y120.628 E345.09153
G1 X126.944 Y120.444 E345.1036
G1 X127.185 Y120.17 E345.11817
G1 X127.33 Y119.917 E345.12981
G1 X127.432 Y119.64 E345.14159
G1 X127.489 Y119.273 E345.15641
G1 X127.476 Y118.98 E345.16812
G1 X127.391 Y118.626 E345.18265
G1 X127.228 Y118.296 E345.19734
G1 X127.044 Y118.056 E345.20941
G1 X126.77 Y117.815 E345.22397
G1 X126.517 Y117.67 E345.23561
G1 X126.24 Y117.568 E345.24739
G1 X125.873 Y117.511 E345.26222
G1 X125.58 Y117.524 E345.27392
G1 X125.226 Y117.609 E345.28845
G1 X124.896 Y117.772 E345.30314
G1 X124.656 Y117.956 E345.31521
G1 X124.415 Y118.23 E345.32978
G1 X124.27 Y118.483 E345.34142
G1 X124.168 Y118.76 E345.3532
G1 X124.111 Y119.127 E345.36802
G1 X124.124 Y119.42 E345.37973
G1 X124.209 Y119.774 E345.39426
G1 X124.372 Y120.104 E345.40895
G1 X124.556 Y120.344 E345.42102
G1 X124.83 Y120.585 E345.43558
G1 X125.083 Y120.73 E345.44722
G0 F540 X125.36 Y120.832
M204 S500
G0 F15000 X125.506 Y120.946
M204 S800
G1 F600 X125.237 Y120.876 E345.45831
G1 X124.91 Y120.73 E345.47261
G1 X124.61 Y120.51 E345.48745
G1 X124.424 Y120.311 E345.49833
G1 X124.269 Y120.088 E345.50917
G1 X124.137 Y119.805 E345.52163
G1 X124.067 Y119.551 E345.53214
G1 X124.032 Y119.283 E345.54293
G1 X124.046 Y118.959 E345.55588
G1 X124.107 Y118.682 E345.5672
G1 X124.27 Y118.31 E345.58341
G1 X124.488 Y118.012 E345.59814
G1 X124.689 Y117.824 E345.60913
G1 X124.91 Y117.67 E345.61988
G1 X125.191 Y117.539 E345.63225
G1 X125.449 Y117.467 E345.64294
G1 X125.717 Y117.432 E345.65373
G1 X126.04 Y117.446 E345.66663
G1 X126.323 Y117.509 E345.67821
G1 X126.688 Y117.669 E345.69411
G1 X126.988 Y117.888 E345.70894
G1 X127.176 Y118.089 E345.71992
G1 X127.33 Y118.31 E345.73067
G1 X127.461 Y118.591 E345.74305
G1 X127.533 Y118.849 E345.75374
G1 X127.568 Y119.117 E345.76452
G1 X127.554 Y119.44 E345.77743
G1 X127.493 Y119.718 E345.78879
G1 X127.331 Y120.088 E345.80491
G1 X127.112 Y120.388 E345.81973
G1 X126.911 Y120.576 E345.83072
G1 X126.69 Y120.73 E345.84147
G1 X126.409 Y120.861 E345.85384
G1 X126.151 Y120.933 E345.86453
G1 X125.883 Y120.968 E345.87532
G1 X125.8 Y120.97 E345.87863
G1 X125.506 Y120.946 E345.89041
;TIME_ELAPSED:409.996997
G1 F1800 E345.29041
M140 S0
M204 S500
M107
G91 ;Relative positioning
G1 E-2 F2700 ;Retract a bit
G1 E-2 Z0.2 F2400 ;Retract and raise Z
G1 X5 Y5 F3000 ;Wipe out
G1 Z10 ;Raise Z more
G90 ;Absolute positioning
G1 X0 Y235 ;Present print
M106 S0 ;Turn-off fan
M104 S0 ;Turn-off hotend
M140 S0 ;Turn-off bed
M84 X Y E ;Disable all steppers but Z
M82 ;absolute extrusion mode
M104 S0
;End of Gcode
;SETTING_3 {"global_quality": "[general]\\nversion = 4\\nname = Ender 3 Direct D
;SETTING_3 rive\\ndefinition = creality_ender3pro\\n\\n[metadata]\\nquality_type
;SETTING_3  = standard\\nsetting_version = 19\\ntype = quality_changes\\n\\n[val
;SETTING_3 ues]\\nacceleration_enabled = True\\nadaptive_layer_height_enabled =
;SETTING_3 True\\nadaptive_layer_height_threshold = 0.24\\nadaptive_layer_height
;SETTING_3 _variation = 0.12\\nadaptive_layer_height_variation_step = 0.08\\nadh
;SETTING_3 esion_type = brim\\njerk_enabled = False\\nlayer_height = 0.24\\nmate
;SETTING_3 rial_bed_temperature = 50\\nmaterial_bed_temperature_layer_0 = 60\\nr
;SETTING_3 etraction_combing = infill\\nsupport_enable = True\\nsupport_structur
;SETTING_3 e = tree\\nsupport_type = buildplate\\n\\n", "extruder_quality": ["[g
;SETTING_3 eneral]\\nversion = 4\\nname = Ender 3 Direct Drive\\ndefinition = cr
;SETTING_3 eality_ender3pro\\n\\n[metadata]\\nquality_type = standard\\nsetting_
;SETTING_3 version = 19\\ntype = quality_changes\\nintent_category = default\\np
;SETTING_3 osition = 0\\n\\n[values]\\nacceleration_print = 800.0\\nalternate_ex
;SETTING_3 tra_perimeter = True\\nbrim_gap = 0.2\\nbrim_line_count = 3\\ncoastin
;SETTING_3 g_enable = True\\ncool_fan_speed = 100.0\\nfill_outline_gaps = True\\
;SETTING_3 nfilter_out_tiny_gaps = True\\ninfill_overlap = 10.0\\ninfill_pattern
;SETTING_3  = cubicsubdiv\\ninfill_sparse_density = 25\\nline_width = 0.48\\nmat
;SETTING_3 erial_print_temperature = 200\\nmaterial_print_temperature_layer_0 =
;SETTING_3 210\\nretraction_amount = 0.6\\nretraction_extrusion_window = 1.2\\nr
;SETTING_3 etraction_retract_speed = =retraction_speed\\nretraction_speed = 30\\
;SETTING_3 nspeed_print = 100\\nsupport_angle = 70\\nsupport_interface_material_
;SETTING_3 flow = 70\\nsupport_material_flow = 75\\nwall_line_count = 3\\n\\n"]}
Does anyone know what's happening?
Edited by Firedrops
    Posted · Help, both fans do not turn on automatically during printing.
    I'll take a stab at this but you need to check with the board manufacturer.
    You said:
    Red (P2_03) = Heatsink fan
    Blue (P2_04) = Parts Cooling (duct) fan
    But the SKR schematic says
    FAN 2.3   This one sounds like the Part Cooling blower
    HE1 2.4   This appears to be the power pins for Hot End 1 (unless you have multiple hot ends this should be unused.)
    HE0 2.7   This one sounds like the power for Hot End 0 which is what you should have on a single extruder machine.
    Your pin table appears to bear that out:
    #ifndef HEATER_0_PIN
    #define HEATER_0_PIN P2_07  This looks like power for Heater0
    #endif
    #ifndef FAN1_PIN
    #define FAN1_PIN P2_04   This looks like a second fan but I don't see a connect point on the SKR.
    #endif
    //#else
    // #ifndef HEATER_1_PIN
    // #define HEATER_1_PIN P2_04  Undefined power for a second extruder (heater1)
    // #endif
    //#endif
    #ifndef FAN_PIN
    #define FAN_PIN P2_03  this one looks like the layer cooling fan F0?
    #endif
    You've likely got something wired wrong.  The M106 should only effect the layer cooling fan.
    There is no gcode command for control of the hot end fan.  In some firmware, the hot end fan can be regulated by the temperature setting (it sounds like you have that enabled at 60°) so the fan doesn't run all the time.
    In Cura Manage Printers / Machine Settings / Extruder 1 the "Cooling Fan Number" should be set to "0".   There is often some confusion about this but your hot end on a single extruder machine is called Extruder #1 but its number is Extruder0 and it is related to T0 in gcode and it's fan should be number "0".
    You can just post the gcode file.  There is no reason to do all of that copy and paste work and things are way easier to search for in a text editor than on a webpage.
    Thanks, didn't realize the P0 and P1 were not supposed to be referring to heatsink fan and 1st part cooling fan, respectively.
    Investigated further, and solved it by changing
    pins_BTT_SKR_common.h
    // Heaters / Fans
    #endif
    #ifndef FAN_PIN
    #define FAN_PIN P2_04
    #endif
    //#else
    // #endif
    //#endif
    #ifndef E0_AUTO_FAN_PIN
    #define E0_AUTO_FAN_PIN P2_03
    #endif
    #ifndef HEATER_BED_PIN
    #define HEATER_BED_PIN P2_05
    #endif
    and Configuration_adv.h line 610
    I'll quote you here "....the problem is probably not in the hardware/firmware/pin assignments."
    Things like this are why it's always good to put another set of eyeballs on a problem.  You then get to lean back and hit yourself in the forehead with the palm of your hand and say "How the #$%^ did I miss that!!!"
        • 28 replies
