1 hour ago, gr5 said:I think "cubic" does that? Not sure. Try every single infill type. Did you see where to change the infill pattern yet?
Another trick is to tilt your model on the build plate. but you may need more support than normal if you do that and the bottom surface may be ugly. Maybe you don't care.
Thank you, yes, Cubic is ok.
gr5 2,192
