On 3/28/2022 at 7:45 PM, gr5 said:You have lots of fixes. You could just do thicker outerwalls. That will have the infill far enough from the outer walls that you can't see the pattern. Or you can change the order - print the outer walls first by checking the cura parameter: outer before inner walls
Although doesn't it print the infill after all the walls? I forget. Anyway doing outer walls first should help a lot.
I use 2 walls I think it is default in cura and I really don’t want to add another wall and waste more time or filament with it
Anyway I have tried it before and it was still visible with three walls
I will check walls swttings and update here about it
- 1
gr5 2,225
