Thank you so much. This is exactly what I was planning to do in case there was no other better solutions. The question is why the measure plug in cannot work in the "Preview" mode? I don't think it will be that tough to make it active in the "Preview" mode, no? If I may request this feature to be added, it will be helpful, I believe.
Edited by azn90-z
ahoeben 1,582
These settings are indeed not what you are looking for.
Correct. Measure tool can't do that (yet, at least).
How accurate does your measurement need to be? As a workaround with Measure tool, you can zoom in to the spot you want to measure in Preview, then switch back to Prepare and place the measure marker on that spot on the model.
