Much of Cura is implemented as a plugin, and it often helps to see what is already there and how it works.
What you want to do sounds fairly similar to the Digital Library plugin that ships with Cura. The source for that plugin is available here: https://github.com/Ultimaker/Cura/tree/master/plugins/DigitalLibrary
2
Smithy 1,146
I am sure @ahoeben can help you...
