Increasing minimal thickness of a shell model in Cura
kenny94
Posted · Increasing minimal thickness of a shell model in Cura
Hello,
I'm trying to print at very small scale a complete Trainset starting from the real 3D model at 1:1 scale.
The problem is the thickness of the surfaces in the model.
At 1:1 scale, some surfaces are few milimeter thick, like the metal sheets, the piping and so on...
But on Cura, I print at 1:30 scale, so some walls are 0.01 mm thin !
I found the option "print thin Walls" on Cura, but it only allow to print 1 line wall mimimum.
It is too thin for me, I'd like to have at least 2 or 3 line per wall for mechanical purpose.
Is there a way to achieve it in Cura directly ?
Also I'm using Autodesk Fusion 360, so If you have an idea on how to solve the issue in it, I'll take it also !
Thanks in advance !
    In cura you can set horizontal expansion to 0.4 and it will thicken everything.  This may mess up many things in a bad way.  It won't affect vertical so a thin enough horizontal wall may be between 2 layer slices.
    The best way is to fix it in CAD - one wall at a time.  So you can think about if it makes sense.
    0.4mm is the minimum wall thickness if your line width is 0.4 and you have "print thin walls" checked.  0.8mm is the minimum wall thickness if you don't have that checked.  For curved walls - after they are converted to triangles, some portions will be slightly thinner or thicker so you need a 10% or so margin.
    Thanks for your answer.
    I'll try that first, but I'm afraid I need to fix the problem in CAD. The model is very very complex and this is not an option to fix it wall by wall.
    If a tool could enable to thicken all at once, it would be great. I'm not looking for an accurate printing, but a good overall shape and recognizable mockup.
