Thanks Daid, that did it.
Small suggestion...
Will we one day, if possible to save multiple profiles?
There could have location as:
Material-> settings-> customize-> temperature-> Choose memory
Profile 1 <-
profile 2
profile 3
Once in a profile could imagine you can edit or delete it.
I've not tried it, but I think you can already.
There's already two profiles there, PLA and ABS and it looks as though you can save a new profile.
Woofy is correct, you can already do that. Can't remember off the top of my head how to do it but I think it should be fairly obvious once you're in the menus.
Yes, under that menu you can select an entry and edit the various parameters and save it, it then appears as "Custom 1", "Custom 2", "Custom 3", etc each time you save. Unfortunately you can't seem to edit the names, delete ones you don't want, or re-edit an existing one in place, but pretty sure a factory reset removes them (need to double check, I reset the other day).
View like this ...
I think the case where several PLA profiles and multiple profiles on ABS ...
Daid 301
Material->settings->customize->temperature. Adjust it there and it will save.
