GregValiant 697
With the model loaded in Cura and the settings the way you want, use the "File | Save Project" command and save it as a 3mf project file. Then post the file here.
One thing you can check is the size of the model in Cura. The Scale tool on the left toolbar will give the size in X Y Z (and percentages). Maybe there is an artifact from the redesign that is sitting way out in space and it's affecting the size of the model.
Edited by GregValiant
jsw 13
My first question would be along the line of how close to the Z build limit is your model?
I've had to futz around with various settings when my models were close or at the X and/or Y limits, but never the Z.
