Thanks for the reply.
I will test another filament but up to the sudden change in quality, the filament I'm currently using was a 'known good' material. The temperature is set to that on the spool, i.e. 210°C and the cooling fan appears to be working.
I'll try another print soon and pay particular attention to your suggestions, though - the printer is on my desk so I try to print when I don't expect to be sat next to it for long due to the noise.
geert_2 556
Have you tried a "known good" material, to see if it is the material or the printer?
Hard to say from the photos, but it looks a bit like it is burned? Maybe printed too hot, or wrong material setting?
Does your printer have a head/nozzle cooling fan? If yes, verify if that works well.
I don't know your printer, so this is just guessing...
