- sandisw changed the title to Qubea QD-1X is not printing
GregValiant 695
OK. On Sunday it is.
They are Delta printers, and so probably Origin at Center. Quebea is gone as you probably noticed. Since you can get it/them to move and print with KissSlicer then they should work with Cura.
Hi, Sorry for the late reply , i just got home.
This is the Start Gcode i got from the developer.
; [mm] mode
G21
; absolute mode
G90
G28
M42 P7 S100
M190 S<BED>
M42 P6 S160
M42 P6 S255
G28
M109 S<TEMP>
M42 P7 S255
and this is the End Gcode
M104 S0
M140 S0
M42 P6 S0
M106 S0
G28
M42 P7 S0
M400
do you see anything wrong sir ?
GregValiant 695
Some of the Start Gcode won't work with Cura. I'm leaving in the M42 lines although at this point I don't think we know what is connected to those "pins" on your mainboard.
The G28 in your ending gcode has to go. It's never a good idea to drop the nozzle when there is a print on the bed.
Copy and paste this in as your StartUp Gcode in Cura Machine Settings:
;Start Gcode
G21 ;metric
G90 ; absolute mode
M82 ;absolute extrusion
G28 ;Home all axes
M42 P7 S100 ;set pin state of pin 7 to 100
M190 S{material_bed_temperature_layer_0} ;heat the bed and wait for it
M109 S{material_print_temperature_layer_0} ;heat the hot end and wait for it
M42 P6 S160 ;set pin state of pin 6 to 160
M42 P6 S255 ;set pin state of pin 6 to 255
M106 S0 ;start with the layer cooling fan off.
G28 ;auto-home again
M42 P7 S255 ;set pin state of pin 7 to 255
G1 F1800 Z10 ;move the nozzle up away from the build plate
;End of Start Gcode
Copy and paste this in as your Ending Gcode
; Ending Gcode
G91 ;Relative positioning
G1 E-2 F2700 ;Retract a bit
G1 E-2 Z0.2 F2400 ;Retract and raise Z
G0 X5 Y5 F3000 ;Wipe out
G0 Z10 ;Raise Z more
G90 ;Absolute positioning
G0 X0 Y{machine_depth} ;Present print
M106 S0 ;Turn-off fan
M104 S0 ;Turn-off hotend
M140 S0 ;Turn-off bed
M220 S100 ;reset feed rate to 100%
M221 S100 ;reset flow rate to 100%
M84 X Y E ;Disable all steppers but Z so the nozzle doesn't drift down
;The End
The words/phrases in curly brackets are Cura keywords. Cura will replace them with the actual values when the gcode is put together. That's why "M109 S<TEMP>" didn't work. Wrong word and no curly brackets. So your hot end and bed didn't heat up.
You can bring a simple model like a calibration cube into Cura. Use the scale tool to make it 1mm tall. Slice it and print the gcode to see how it goes.
GregValiant 695
TAAA_DAAA!
Nice. Don't bother trying to tweak that line on the hull that is at the height of the deck. Can't be done. I think doctoral thesis have been written on it.
GregValiant 695
Post your startup gcode and post the gcode file that printed.
I can't find anything on a Qubea printer. Did you mean QiDi?
