6 hours ago, tomnagel said:Did it use to work, and which changes did you made?
What material are you using? Do you have all settings in Cura set to default?
is the feeder tension indicator in the middle?
It did use to work for over a year. I don't remember making any specific change - a little while ago I replaced some tubes and did an extensive cleaning, but it did finish multiple prints successfully afterwards.
As written in my post, I use Ultimaker Tough PLA and have the settings set to default. The feeder tension indicator is right below the middle line.
tomnagel 128
