40 minutes ago, nallath said:It's impossible to say without sharing a project file. There are just too many things that could cause this.
Thanks for the answer, but I found the problem. The problem is not only with Cura, but rather with the construction. If 2 edges are exactly on top of each other with a gap in between and you only block the support up to the lower edge, Cura still wants to support the upper edge. That's why I just shifted it a bit inwards, so that the support from edge 1 to edge 2 also seems sufficient for Cura.
nallath 1,120
