One layer is printed inverted (print air instead of part)
nelstaar
Posted · One layer is printed inverted (print air instead of part)
I have Cura computing layer 106 inverted, It print in the air inside my piece and avoid printing the piece.
See attached GIF.
In low quality I don't have the pb.
Did any one already have this behavior ?
I did check in X-ray mode but all is good.
Cura 4.13.3 Linux 64bits
Ender 3
    Tried your project file on cura 4.13 windows version and it sliced perfectly so not sure whats happening on your end.
    • Thanks 1
    Good to know. Thx
    On a lark I opened the model in MS 3D Builder and it reported an error.
    This report is from https://formware.co/OnlineStlRepair.  There were some triangles added but that's it.
    --> 0 Naked edges (?)
    --> 0 Planar holes (?)
    --> 0 Non-planar holes (?)
    --> 0 Non-manifold edges (?)
    --> 0 Inverted faces (?)
    --> 0 Degenerate faces (?)
    --> 0 Duplicate faces (?)
    --> 0 Disjoint shells (?)
    -> Repairing: 100.00%
    ----- Repair completed in 279ms ------
    -> Vertex count changed from 112 to 300 (+188)
    -> Triangle count changed from 220 to 596 (+376)
    3D builder before repair
    And after repair.  You can see where the triangles were added to the flats between the ribs.
    • Thanks 1
    I guess OnlineStlRepair is make a safer 3D model.
    Posted (edited) · One layer is printed inverted (print air instead of part)
    Fixed STL fixed the issue.
    Thank you every one. 👍
    (original STL exported from Freecad)
    Edited by nelstaar
