cura models have large outline and does not fit on creality cr-10 v3
Posted
· cura models have large outline and does not fit on creality cr-10 v3
With the model loaded in Cura use the File | Save Project command and post the 3mf project file here. I haven't seen that before and with just that one view as evidence I'm tending to think it's something in the model file. The model will be contained in the project file.
One thing you can do right away is to rotate that model 45° and see if it will fit diagonally.
There are also tricks you can do by making the build plate larger in the Cura Machine Settings and then manually adjusting the home offsets in the gcode file with an M206 line to compensate. Just making the build plate larger you should get it to slice and maybe something will stick out and provide a clue in the preview.
All the CR10 models are very similar so whether it's a v3, or a wifi model, or other sub-model, it's hard to go wrong using the base CR10 definition.
GregValiant 1,490
