There should be no difference unless there is a bug in Cura. You have to make sure these settings are the same in both modes:
bed temp
nozzle temp
print speed
retraction speed
retraction distance
fan=100% in ultimode on UM (Marlin multiplies to the fan rates together - the rate in the gcode/cura against the fan rate for the selected filament which should probably always be 100% for PLA).
gr5 2,194
bed temp
nozzle temp
print speed
retraction speed
retraction distance
