We think this might be a 'not putting it in the right folder' issue rather than a 'real' security issue.
If it is indeed the same problem, one of our IT people found a workaround:
QuoteFix:
Create folder %PROGRAMDATA%\Start Menu\Programs\Ultimaker Cura
Create icons in %PROGRAMDATA%\Start Menu\Programs\Ultimaker Cura
This folder is the folder that is not logon-user based. But a system based.
The problem with the current Cura 5.0 setup is that the icons are actually saved in the %appdata%\Microsoft\Windows\Start Menu folder. So it is only visible for the account that is used for the installation. And in the case of an MDM install that is never the logged-on end-user. The install user does not even have a local profile so the icons are not stored at all.
This is indeed one of the things the IT team also reported on the Cura 5.0 installer.
EDIT: Just want to add; the error is indeed on our side, and we hope to fix it in 5.1
Edited by rburemamaking sure they know the error is not on their side
1
nallath 1,104
We had to switch out a number of systems in order go get things to work for windows 10 again, and this is one of the things that went wrong because of that.
We already identified what went wrong and are working on a solution! I expect it to be fixed in 5.1
