Temp sensor LED lights when moving the head!
achillx
Posted · Temp sensor LED lights when moving the head!
I don't know if here is the correct place to post this thing because I don't know if it is a problem.
With NO cables attached to the printer (power and USB), if I move the print head with my hand the temp sensor's LED lights up!
Is this normal?
Electricity generator?!
    The stepper motors act as little generators when you spin them, so yes, it's normal.
    Ok although I don't get why the electricity that is produced from the motor goes through the temperature sensor's circuit.
    Beside sharing a common - I don't understand how is a closed circuit motor and temperature sensor.
    But only in one direction for each axis... ;)
    I does it on both directions, both axes!
    That's interesting. On my UM1 I only get the effect in one direction. And it made sense to me as LED are diodes. :blink:
    I try to avoid moving the print head fast (which results in higher induced current) as the electronics might not like this kind of induced power. :sad:
