On 7/15/2022 at 5:35 AM, joe30 said:
Cam Watt is a Media, Art, and Design teacher ... More details on this process can be found.
On a different link. That link just goes to a writeup of 3D printer comparisons. Any chance of the real link? I'd like to do this too and don't want to recreate the wheel.
geert_2 556
I think software that can raster photos for traditional printing might work? For example an old Photoshop or so?
If you look at printed photos in books or magazines through a magnifying glass or microscope, you will see that they do consist of solid dots in varying sizes and angles. There are no shades in-between, only dots 100% (ON) or 0% (OFF) in the colors yellow, magenta, cyan, and black. By varying the size of the dots of each ink color, all the zillion colors shades in-between are produced.
So, practically, you would need to convert a color-image into black/white in an image editor, then adjust contrast to your wishes, and then export that greyscale image as a printing-raster or printing-screen (I am not sure about the exact terminology), to convert the grey-shades into black dots of varying sizes. In some professional printing softwares, you can also select the desired shape of the dots: square, diamond, circle, and you can select the angle under which they are printed.
Next time you walk by a huge promo panel on the streets, have a closer look. Usually they have big dots, easily visible to the naked eye.
I doubt if freeware like Inkscape or GIMP can do this too, because this is a typical professional printing feature, not required for home or office use. But you might find some software, I don't know.
joe30 0
Cam Watt is a Media, Art, and Design teacher who has provided the files to 3D print a screen printing kit, including print frames, a standoff leg, and a squeegee. The kit also includes a detailed tutorial on converting your 2D files to 3D models (STL files.) Once the kit gets printed, Watt also provides instructions on how to use it to reproduce your own design repeatedly. This is a great project: the kit can be printed on any 3D printer with a 6 x 6 " bed, and the end result is durable enough to withstand what is likely to be your enthusiastic use of it! More details on this process can be found in this article
