Yeah, it's simple enough to edit the gcode, but I'm curious why it would "resume" to 0 at all. Is my startup gcode not configured right? It's kind of a hobbled mess of copy paste stuff.
I've attached the project file and the gcode sliced from this project, let me know what you think.
GregValiant 1,288
As a quick fix you can change that M109 line (after the M0) to M109 S205 or whatever your print temperature is.
In Cura, use the "File | Save Project" command and post the 3mf file here. I use Pause at Height a lot and I've never seen that problem before.
