Hi GR5, thanks a lot for your detailed reply!
I used the stock settings in Cura for the ultimaker 2+, so g-code flavor is already (as you described) set to "Ultimaker".
Maybe the problem originated from the USB print via cura, i will cross check with an SD card next.
Probably i will switch to the Marlin flavored g-code as suggested, because i will need the remote control via USB anyway in the future...
Thanks for clearing things up 🙂
gr5 1,857
So there are 2 ways to print gcode on the UM2. The standard way is to use "gcode flavor ultimaker 2" (I'll explain in a moment) which lets the printer do the homing, purging, warmup, etc. The second way is to use "gcode flavor Marlin" which works just fine and has the start/end gcode you mentioned (and may have been deleted somehow).
To set these up, it has nothing to do with your settings profiles. It has to do with your machine profile.
Make sure you are in PREPARE mode (there are 3 modes across the top of cura - PREPARE PREVIEW MONITOR). Then just under that bar on the left choose your printer type "ultimaker 2+". Then click the um2 drop down again and choose the button "Manage Printers". Then choose the button on the right "Machine Settings". Double check at the top of the dialog that it says your machine is "ultimaker 2 +" still.
Now note that you can change the gcode flavor to Marlin or "Ultimaker 2". I recommend "Ultimaker 2" which has no start/end gcode because the UM2+ firmware takes care of it. There is a comment in the gcode header to clue in to the UM2 to do it's own homing etcetera.
Or you can choose "Marlin" but then you have to examine and possibly edit the start/end gcode commands yourself which do the heating up, the homing, the purge and so on.
gr5 1,857
Oh - I just remembered that you said you are doing USB printing. That is fine if you are printing from a rasberry pi using octoprint but that is NOT recommended (and not supported by Ultimaker) if you do it from Cura. Yes it's a feature in Cura but not meant to be used on UM2 series printers.
If you do USB printing it might be that you have to go the "gcode flavor Marlin" route. I'm not sure. I thought you could do it with either flavor but perhaps not. Perhaps the "Ulitmaker 2" flavor doesn't work through USB.
