GregValiant 1,342
That resolution is in the model file. You would have to alter the settings of the STL generator/translator in the CAD software.
The model file consists of triangles and the size of the triangles determines the faceting of any circle. In a glaring show of common sense: the setting in the AutoCad STL exporter is called "facetres".
Below are two cylinders shown in MS 3D Builder. The left is at the default 0.5 facetres and the right one is at the max of 10 facetres and you can see how much denser the triangles are. The right one would make a nicer print.
Edited by GregValiant
Robust 1
It doesn't seem to be a problem of the slicing.
Although I'm unable to see it, when I'm loading the STL, it seems to be the export from Inventor.
We set up the accuracy there, now everythings seems to be fine.
Sry for the spam. Close PLS.
