We just went through this with an Ender 3 Pro that had the problem. A workaround seems to have gotten the job done. It is described in THIS THREAD .
NOTE: When using the M25 command it's possible that you might have to "Pause" the print on the LCD (even though the printer is in pause mode) in order to bring up the "Resume" command.
So that sequence would be...
The file is printing and comes to the pause section. It parks the head and the M25 causes the printer to pause.
You put the magnet in.
On the LCD find the menu with the "pause" command and click on "Pause" and then move to the Resume command and click on it.
The G4 method always works but you lose control of the printer because G4 is a timed event. You don't get to choose when the printer restarts.
Edited by GregValiant
GregValiant 1,287
