Posted · Ultimaker Cura 5.1
1 hour ago, Casper1313 said:
Hi, seems that update checker is broken.
Version 5.1.0 does not see new one. If so, please check if it on exists on 5.1.1
That is correct! The 5.1.1 release is what we call a "silent" one. It fixes a single thing for S5 printers. We had to make some changes to cope with chipaggedon.
So we did want a new version so that people who would get those machines would be able to properly print with them, but we also didn't feel that everyone that currently uses Cura needs to get an update.
TLDR: Well spotted, but the behavior is correct 🙂
  • Thanks 1
@Opaaleks the code below is the 5.1 definition Ending Gcode
G91 ; Set Positioning to Relative
M83 ; Set Extruder to Relative
G92 E0 ; Reset Extruder
G1 E-4 F3000 ; Retract 4mm of filament
G1 Z0.2 ; Raise nozzle .2mm
G90 ; Set positioning to absolute
G1 X{machine_width} Y{machine_depth} ; Park print head
G91 ; Set Positioning to RelativeG1 Z10 ; Raise nozzle 10mm
M106 S0 ; Turn off part fan
M104 S0 ; Set nozzle temp to zero
M140 S0 ; set bed temp to zero
M84 X Y Z E ; Disable X Y Z and E steppers
In Manage Printers and Machine Settings "Ending Gcode" if you change that BOLD line to G1 X0 Y0 then the head will park at the left front corner.
If you remove the Z from that last line and make it M84 X Y E then your Z can't drift down into the print.  That is a problem if the Z system is a tad loose.
    Posted (edited) · Ultimaker Cura 5.1
    On 7/20/2022 at 5:00 AM, dsp said:
    No inventor connect? You can say smoother finish (update notes), but converting to STL makes rounds not round, not Cura when using native Inventor files, a cylinder is round and not angled.
    See attached photos same configuration of Cura. the one on the left in the image is uploaded to Cura as IPT the right one as STL.
    Don't look at the top finish, it was a quick print to try something on.
    I am going to tell you that the problem of the non-rounded edges is the product of a bad export of the file in inventor, you must enter options in the export window and adjust the quality millimeters etc etc, it is not a cure problem
    [translated using google by gr5]
    Edited by gr5
    translation
    On 14.09.2022 at 15:29, GregValiant said:
    @Опаалекс приведенный ниже код является определением 5.1 Ending Gcode
    G91 ; Установить относительное позиционирование
    М83 ; Установите экструдер на относительный
    G92 E0 ; Сбросить экструдер
    G1 E-4 F3000 ; Оттяните 4 мм нити
    G1 Z0.2 ; Поднимите сопло на 0,2 мм
    G90 ; Установите абсолютное позиционирование
    G1 X{ширина_машины} Y{глубина_машины} ; Парковая печатающая головка
    G91 ; Установить позиционирование на RelativeG1 Z10 ; Поднимите сопло на 10 мм.
    М106 С0 ; Выключите часть вентилятора
    М104 С0 ; Установите температуру сопла на ноль
    М140 С0 ; установить температуру кровати на ноль
    M84 XYZE ; Отключить степперы XYZ и E
    В разделе «Управление принтерами и настройками машины» «Конечный код Gcode», если вы измените эту ЖИРНУЮ строку на G1 X0 Y0, тогда головка припаркуется в левом переднем углу.
    Если вы удалите Z из этой последней строки и сделаете ее M84 XYE, тогда ваша Z не сможет сместиться в отпечаток. Это проблема, если система Z немного расшатана.
    Thank you, I will try - learn
