Print bed moves finished print into the print core with force removes complete buildplate
Livery
Posted · Print bed moves finished print into the print core with force removes complete buildplate
So i was watching the print been finished
the buildplate lowers and than starts to raise again, forcing the finished print part 26 cm high into the moving printcores. Emergency buildplate lowering happend
buildplate stays low now
print core 1 does its cleanings then it went to the right side
ramping again into the finished print, it got jammed with force it went a bit back and it tried again to move the print core to the right
this time displacing the complete buildplate out of the metals holding clips with force
lifting the howl print with buildplate into the glass door that flew open….
after that i was standing next to printer to unplug the power cable before it went for a nother strike
i didn’t expect this from a ultimaker s5 pro bundle
its running the latest firmware and cura 5.0
but i have found similar issues in the forums about the same issue …
I don’t trust this machine at this moment
    Here i found these frames
    1 is the last layer
    2 it already slammed the print core while going to the left side
    you can see its way higher than the finished print was….
    3 it shuffed the howl print away to go to the right side power emergency powershut down
    To clarify:
    It did your complete print just fine.  Immediately after it finishes the print, it does some bad things.
    Right so far?
    Does it ask you if you removed the print?  Does it do this before or after asking you?  I'm guessing it never got to that step?
    Can you send the project file and also the ufp file?  For the project file, in cura, do "file "save project" and post that file.  The ufp file is the result if you slice in cura and then save that file using the same button but save to hard drive and post that here please.
    Posted (edited) · Print bed moves finished print into the print core with force removes complete buildplate
    Hi gr5
    I watched the printer finish the last line behind my pc. Buildplate went low but faster than normal with a higher pitch of sound because its a big pieces of 16 cm 380 grams or so . Normally it lowers the buildplate slower with smaller objects
    but i went down fast stopped . Went up again slow slammed with the top of the print into the printcores
    sensor detects thats not oke
    emergency kicks in buildplate lowers again
    Printhead arrives to the fromt left purges some fillament
    buildplate raises again
    printhead moves to the right
    slammed into the print with the core
    got jammed
    printcore tried again and broke the glass buildplate with the print out of the metal clips and slammed it up against the glasswindows opening them to
    at that point i was able to cut the power immediately, because this machine was on a mission i didn’t  aprove
    i downloaded log files from the machine
    it was running 5.0 cura and 7.0.2 i  thought  7.0.3 because i press firmware update last week
    log files show print successfully finished 😅
    Edited by Livery
    2 hours ago, gr5 said:
    To clarify:
    Right so far?
    UMS5_motordeel12.ufp UMS5_motordeel12.3mf
    To clarify:
    Right so far?
    Rats.  You are probably asleep and won't answer my questions until tomorrow and by the time I reply it will probably be Sunday night for you.  Anyway, please answer the above questions.  I looked at the gcodes and they are fine.  None of the movements you describe.  If the answers for the questions above are "yes, yes, before, yes" then I'd say the problem is in the firmware of the S5.
    So if the answers are "yes, yes, before, yes" then please check what firmware you have - you can do that I think from the maintenance menu.  Also I'd update to the latest version if there is a newer version available.
    Yo thx dor the reply
    i was running cura 5.0
    and firm ware 7.0.2
    updated everything to
    5.1
    7.0.3
    i read about some encoder skipping issues on facebook. because the buildplate lowered in a faster manner than normal
    just like the powwr was cut from the z axis and the buildplate wooshes with high pitch down.
     Than the z axis stops the fall and starts raising the buildplate with the high print into the printcore
    Is this before the print finishes or is the print basically done at this point?  I actually have several ideas but you still haven't answered this question.
