Question:
If feeder is all the way in the back and filament is transferred inside the tube, doest it make the filament wobble a bit making extrussion not exact ?
My printer feeder/extruder is right at the top of the nozzle. Am i missing something ? Is extruder the same as feeder ?
gr5 1,843
The feeder stepper motor for the Ultimaker machines is on the back of the machine so the head is very light weight. The default acceleration is 5000. Some people lower it to 1000 which some people find makes ringing better.
Default jerk I believe is 20mm/sec. That's basically the max instantaneous velocity change at a vertex. So yes, you could lower this proportionately (if you cut one in third, cut the other in third. Maybe).
edit: "velocity change"
