What do you mean that it is at "any printer"? Is that some web based slicing software or something? Are you running cura yourself or some service running cura? I'm a bit confused about this aspect of your question.
This might be helpful althoughy you never clarified what you want to do:
gr5 1,870
Can you be more specific? There are
1) the edge boundaries,
2) there is the feature where you can't get 2 parts on top of each other (which can also be disabled),
3) there are the clips that hold the glass and those areas are disallowed also.
And more but those are most likely what you mean.
Did you mean #3? Did you remove the clips from your printer? Or is your print/model bigger as you get above the clips? Or do you mean one of the other things I mentioned?
Also the answer will probably require editing a file and the file location depends whether you have linux, ios, or windows. So what operating system are you running cura in?
