Layer preview not working properly?
Thegladster
Go to solution Solved by GregValiant,
Posted · Layer preview not working properly?
Hello,
I am having a problem with my layer view. Say, for instance, I'm trying to print this 20x20mm cube: image.thumb.png.bcd85f5c751f64dcc3276ce7172ad3f1.png
After slicing, I select preview (either in the bottom right or top of screen) and I get this wonky result-image.thumb.png.f6d8b7f75221f22661abde5653a85bf0.png
as if the item isn't sliced at all (however I know it is, as the time and layer count is accurate). Furthermore, the vertical slider on the right does nothing, and pressing the play button does show the model, albeit dark gray (even though color scheme is selected as 'Line Type').
When I save the .gcode and reopen it, the file does not show, and merely produces the empty buildplate. I first had this problem on my older version of Cura, so I downloaded the newset version and am still faced with this problem. This error simply happened out of nowhere--does it have to do with my GPU? I might just be stupid and the solution is right in front of me, but please help.
Note: the .gcode file does still work as normal, it's just odd how the layer view doesn't render correctly.
    8 hours ago, GregValiant said:
    Make sure you have them all turned on except for "Only Show Top Layers".
    "Only Show Top Layers" will only be an option in "Compatibility mode", which OP is not using.
    In the 3rd screenshot, the horizontal slider at the bottom is at the beginning of the layer. If you move it from left to right (or press the "play" icon), you will see the top layer being filled in. Sometimes Cura gets confused whether it should be showing just the top layer in color, or all of them. Normally scrolling through the layers with the vertical slider will fix that.
    • 3 weeks later...
